  2. Announcements
  • S sineverba
    Background: I use signing software on some nodes + whitelisting on a node (of course only PI serial is on the whitelist).
    With current --development branch (I think 2.3.0alpha) I cannot anymore set my previous personalized flags on gateway RPI3.
    In detail, with current master (2.2.0) I can do:
    sudo mysgw --set-soft-hmac-key=F618D4848992B
    sudo mysgw --set-soft-serial-key=26[...]9
    sudo mysgw --set-aes-key=EC7[...]CEB4
    WIth development I did see only the --get[...] flags and cannot set anymore. Can you confirm?
    How can I set my previous values for signing?
    AnticimexA
    AnticimexA
    Anticimex
    #903
    @sineverba I believe this change alters how rPi port handles signing related personalisation: https://github.com/mysensors/MySensors/commit/3c0b2727a56907277d4d04c985fd72b14e4a483c
    And, as usual, the documentation is a good place to start ;) https://www.mysensors.org/apidocs-beta/group__MySigninggrpPub.html#MySigninggrphowuse
    • joaoabsJ
      joaoabsJ
      joaoabs
      wrote on last edited by joaoabs
      #904
      I'm currently compiling the code for connecting the NRF24l01+ directly to the Raspberry PI. Since I'm running the controller (on this case OpenHab) on the same Raspberry PI, would it be recommended the Ethernet or the serial flavor of it?
      In the case of ethernet, can I place the own machine IP (127.0.0.1)? This way, if I need to change the IP address of the PI it wouldn't affect the communication between the controller and the MySensors code, right?
      --my-gateway=ethernet --my-controller-url-address=127.0.0.1
      And by the way, for the signing configuration, it is mentioned in the documentation "Update the gateway config file with the generated keys/valeus", what file is that (name, path)?
      I should be able to re-use the keys I have defined before, right? So I just go to step 2 (no need to generate new keys).
      I'm refering to this link.
        --my-controller-url-address=127.0.0.1 is not needed for ethernet
        • joaoabsJ
          joaoabsJ
          joaoabs
          #906
          I found that the configuration file is /etc/mysensors.conf but " The first time you start the gateway the configuration file will be created if it does not already exist.", so that's why I wasn't finding it.
          Anyway, the file states that:
          "Note: The gateway must have been built with signing support to use the options below."
          What flags should I include to have signing support?
          OK, found it: just run ./configure -h and there is a list of options. Leaving it here just for future reference
          gohanG AnticimexA 2 Replies Last reply
          • joaoabsJ joaoabs
            @joaoabs said in 💬 Building a Raspberry Pi Gateway:
            it is already written in the article
            • joaoabsJ joaoabs
              AnticimexA
              AnticimexA
              Anticimex
              @joaoabs
              Release: https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html
              Beta/development: https://www.mysensors.org/apidocs-beta/group__RaspberryPiGateway.html
              • joaoabsJ
                joaoabsJ
                joaoabs
                Thanks for the replies.
                I've changed the PI from a PI1 to a PI3 and was able to make it working with signing. Its running smoothly, I guess the GW is chosen :).
                I'll now focus on the nodes, specially the SenseBender micros that are 2xAA battery powered and are consuming ~3% bat per day, but that will be for another post...
                Joaoabs
                • D
                  Damian
                  Hi, is there any way to check the current gateway operating parameters? My purpose is to check the radio channel and power level set before compilation but I would be glad if I could check other configurable parameters. I looked at Makefile.inc and found some flags set, but not the information I was looking for (does it mean that the default values are set)? Debug logs neither provide these informations.
                    What radio are you using?
                    D 1 Reply Last reply
                      Damian
                      @gohan nrf24, one deployment pa+lna version with external antenna and the other standard with build-in "zig-zag" antenna.
                        I always set gw to max power if the radio is shielded
                        • joaoabsJ
                          joaoabsJ
                          joaoabs
                          #914
                          Is it normal to have frequently these errors in the RPI GW?
                          May 11 00:43:54 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                          May 11 00:43:56 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                          May 11 00:43:58 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                          May 11 00:44:00 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                            Damian
                            @gohan Well, that is not an answer to my question apparently :) I suppose that max power lever is the default setting according to the configure script's help.
                              also look for a channel outside the WiFi range
                              • K
                                K
                                kberck3
                                Openhab2 on pi3b+ using nrf24 radios and mqtt. I can follow the wiring diagram, but the commands are a bit confusing and seem to jump around randomly. Do I put all the --my-blah-blah together after the ./configure to build a file? Should I do development version? Do the nfr improvements go together with everything else?
                                gohanG 1 Reply Last reply
                                • K kberck3
                                  @kberck3 said in 💬 Building a Raspberry Pi Gateway:
                                  From the article "Note: All options must be added to the same line, after ./configure"
                                  Leave the development version for now, the stable works fine.
                                    #919
                                    @gohan to be fair, I added that note this morning so kberck3 might not have seen it :-)
                                    • K
                                      K
                                      kberck3
                                      Appreciate the reply mfalkvidd and gohan! Service is running, will report back if I run into other issues.
                                      • Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        Hi Guys,
                                        Is anyone here using the Pi with OTA updates? I'm finding them painfully slow (1-2 stream messages every few seconds). It's taking 1 hour per OTA update compared with 2-3 minutes when using the Arduino gateway!
                                          I did some tests on pi3 and I found slow ota too. Tekka has an open issue on github about this.
