  3. What's the "best" UPS for a Raspberry Pi 3B?
51 Posts 12 Posters 43.9k Views 12 Watching
  • NeverDieN Offline
    NeverDieN Offline
    Now that I'm using Octopi, I need to care about such things. At the very least, I don't want the SD card to get corrupted.
      I use a turned off UPS with a voltage regulator connected directly on the 12V battery. The battery maintainer will keep battery charged. Probably not the most energy efficient solution, but it works and it gives you hours of runtime.
      • NeverDieN Offline
        NeverDieN Offline
        There's a lot to choose from:
        https://www.aliexpress.com/item/18650-Pi-Partner-for-Raspberry-Pi/32824221009.html?spm=2114.10010108.1000015.2.7a6878b31vZgqA&s=p
        https://www.aliexpress.com/item/UPS-power-extension-board-with-RTC-measurement-5V-output-serial-port-function-5V-3A-USB-data/32849706946.html?spm=2114.10010108.1000014.8.58672b9c3X3XTo&traffic_analysisId=recommend_3035_null_null_null&scm=1007.13338.98644.000000000000000&pvid=81b8fe3b-0458-4b06-9f5c-9bd5d88c8ffb&tpp=1
        https://www.aliexpress.com/item/UGEEK-UPS-HAT-with-Battery-for-Raspberry-Pi-3-Model-B-2B-B-Raspberry-Pi-Battery/32786176030.html?spm=2114.search0104.3.37.28041b49kgJHo2&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_5711320_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10698_10545_10696_10084_5722520_10083_10618_10307_5711220_10059_5722620_5722920_308_5722720_5722820_100031_10103_10624_10623_10622_10621_10620,searchweb201603_32,ppcSwitch_5&algo_expid=f1da8c36-0437-4996-b1c8-266691914f00-5&algo_pvid=f1da8c36-0437-4996-b1c8-266691914f00&transAbTest=ae803_1&priceBeautifyAB=0
        and that barely scratches the surface. That's why I thought I'd ask what people are actually using, and whether they like it or not.
        Nca78N 1 Reply Last reply
          I used that because I have a bunch of used UPS
          • NeverDieN Offline
            NeverDieN Offline
            Your approach does have the virtue of no lithium fire hazard.
            • NeverDieN Offline
              NeverDieN Offline
              At the moment I'm using one of these, which also contains some surge protection:
              https://www.amazon.com/gp/product/B00KH07WRC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
              I guess all the raspberry Pi UPS's just assume you're plugged into a surge protector of some kind. So, it's worth considering the entire package.
              • NeverDieN Offline
                NeverDieN Offline
                OK, I just settled on this: https://smile.amazon.com/gp/product/B00NTQYUA8/ref=od_aui_detailpages00?ie=UTF8&psc=1
                $25, surge protection, no lithium, and maybe (?) I'll be able to power the Pi directly from one of the UPS usb power ports.
                It seems ridiculous that the Pi still doesnt have a shutdown button. Presently I have to ssl to it and do a "sudo poweroff" before unplugging it. Not exactly convenient!
                  Actually you can use a shut down script when you short a pin, you only need a voltage detector that triggers it when voltage goes below a certain value. Andreas Spiess made a video showing how to do it with a cheap battery indicator and 2 supercaps in series
                  • NeverDieN Offline
                    NeverDieN Offline
                    It turns out that these little Borkin buttons are the easiest way to power down your Pi:
                    https://www.aliexpress.com/item/3-5mm-Smart-Mikey-Mi-Key-Quick-Click-Button-Smart-Key-Dustproof-Plug-Earphone-Jack-For/32861089928.html?spm=a2g0s.8153825.cb0001.6.O3XqCd&scm=1007.13409.84631.0&pvid=11dce56f-ab9b-4d70-9349-4ff0bc6f4c93&tpp=1
                      but those also require a little wire mod and they are not very "automatic" :D
                        NeverDieN Offline
                        NeverDieN Offline
                        @gohan Yes on the wire mod, but what do you mean by automatic?
                          I mean that they are manual switch and will not shutdown raspberry when battery is low
                            NeverDieN Offline
                            NeverDieN Offline
                            @gohan Good point. Also, ideally it would have some kind of indicator to show when it has successfully finished powering down.
                              Nca78N Offline
                              Nca78N Offline
                              @neverdie I have bought the last one in your list (ugeek hat) but not set up on my pi 3 yet.
                              You can get battery information through i2c and prepare for shutdown when battery is low as explained here
                              http://www.raspberrypiwiki.com/index.php/Raspi_UPS_HAT_Board
                                The super cheap way is to get this https://www.aliexpress.com/item/10W-3-7V-4-2V-Charger-5V-6V-9V-12V-Discharger-Board-DC-DC-Converter-Boost/32816412117.html
                                • alexsh1A Offline
                                  alexsh1A Offline
                                  alexsh1
                                  Guys, this is the best UPS for RPi3
                                  http://www.pimodulescart.com/shop/item.aspx?itemid=50
                                  It is compatible with many batteries including 18650 and different chemistries.
                                  Unfortunately, firmware development is a bit slow, but hardware part is just brilliant
                                    that costs more than the RPI itself :D
                                    alexsh1A 1 Reply Last reply
                                      Nca78N Offline
                                      Nca78N Offline
                                      @gohan said in What's the "best" UPS for a Raspberry Pi 3B?:
                                      Super cheap because it's just a cheap charging ic and a cheap step up, and there's no battery protection. If you rely on battery protection of an eBay/AliExpress lipo it will be a DW01 with undervoltage protection at 2.4V, fast way to kill your battery.
                                        it is written that it requires battery protection if your battery doesn't have it and they sell that too
                                        • jamzmJ Offline
                                          jamzmJ Offline
                                          jamzm
                                          wrote on last edited by jamzm
                                          Has anyone gotten their PiModules UPS PIco to work right or for very long? And is it even compatible with a Pi 3B?
                                          11.8k
                                          113.2k
