  3. 💬 HLK-PM01 breakout board
hlk-pm01
38 Posts 17 Posters 12.6k Views 15 Watching
  • sundberg84S
    sundberg84S
    AAaaand... DONE :) I just had to do dinner but @Anticimex you were quick ;)
    • A
      arp5z5
      Can I ask what the ratings are of the two capacitors used in your circuit? A 1000 uF and a 100 uF?
      • A arp5z5
        sundberg84S
        sundberg84S
        @arp5z5 it is added just to be able to smooth any DC power as needed. I would probably just go with a 0.1 and 10uF but it might be that you don't need any. If you are running a normal MySenwors node with only a temp the HLK module provides enough caps.
        • A
          arp5z5
          @sundberg84 Good to know! Thank you for the quick response!
          • A
            apeeters
            Would you mind uploading the design files that include the capacitors? The photos contain them, but the Gerber files don't :(
            • sundberg84S
              sundberg84S
              Hi! Really? Im sure I have uploaded them.
              Well, I will upload them again!
              Edit: All files removed and updated. New revision created.
              A 1 Reply Last reply
              • sundberg84S sundberg84
                apeeters
                @sundberg84 said in 💬 HLK-PM01 breakout board:
                Thanks for the excellent work!
                • alexsh1A
                  alexsh1A
                  alexsh1
                  This is a 5V version. Did you consider doing a 3.3V version? I have pretty much all my sensors /GW using 3.3V power source
                  • alexsh1A alexsh1
                    sundberg84S
                    sundberg84S
                    @alexsh1 the 3.3v uses the same pinout so you should be able to just change the hlk module ?
                    http://www.hlktech.net/product_detail.php?ProId=59
                    alexsh1A 1 Reply Last reply
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @sundberg84 thank you for pointing at this. I did not realise there is a 3.3v version :((
                      I have a few 5V ones which are useless without a voltage dropout
                      • pihomeP
                        pihomeP
                        pihome
                        Thank you for sharing, what Varistor part number you are using?
                        PiHome - Smart Heating Control
                        • pihomeP pihome
                          sundberg84S
                          sundberg84S
                          @pihome im using the recommendations from this thread: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
                          Make sure you buy the right depending on what AC voltage you have 120/240 or other.
                          I think these are the ones i bought last time.
                          • beicB
                            beicB
                            beic
                            Dear @sundberg84 can you please read and write here the Varistors exact model/part number from your assembled board, please?
                            • beicB beic
                              sundberg84S
                              sundberg84S
                              @beic hi. Please see the thread above yours
                              beicB 1 Reply Last reply
                                beicB
                                beicB
                                beic
                                wrote on last edited by beic
                                There is no value mentioned there, and how did you calculated the tp peak of the sine for varistor against mains?
                                You just trow some varistor value in there without calculating anything for RMS and Vpp?!
                                • sundberg84S
                                  sundberg84S
                                  @beic - sorry, I missed your reply :(
                                  I didnt calculate - it depends on your AC, depending on your locations so everyone using this PCB has to get their own MOV.
                                  I have followed the collected recommendations from this thread: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
                                  Im happy to learn more about varistors (haven't got that far in AOE yet :) ) so please inform us if you know more that would be usefull here. You can use the thread above.
                                  The varistor was recommended here: http://lygte-info.dk/review/Power Mains to 5V 0.6A Hi-Link HLK-PM01 UK.html
                                  • R
                                    R
                                    ru64
                                    Hi @sundberg84, did you create custom components for this design? Can you add your library files to the download, please?
                                    • R ru64
                                      sundberg84S
                                      sundberg84S
                                      @ru64 - i tried uploading them but openhardware didnt allow it.
                                      @hek - is it possible to allow these?
                                      .dcm
                                      .lib
                                      .kicad_mod
                                        Yes, should be possible to allow those file extensions. I'll take a look at it tonight.
                                          @sundberg84
                                          Could you give it another try try uploading the files. They should work now.
