  3. 💬 Livolo 3 buttons US/AU switch adapter
contest2017livolowall switchusaumysensorsswitch
75 Posts 12 Posters 30.8k Views 11 Watching
  • Nca78N
    Hello, I have finally finished a new version of this board, I will double check tomorrow and order PCB before end of week.
    Changes :
    • radio moved between 2 buttons, it should fix the touch sensing problem on the third button
    • touch pads improved using restrict layers to keep constant distance between touch electrode and ground planes, it should give much more margin to set sensitivity of each pad with the Cs capacitors of the TTP223
    • added a ws2812B for middle button instead of the "extra leds". I'm not 100% sure that it will work...
    • rearranged all components on the PCB, so they are properly aligned instead of the mess it was before
    • Nca78N
      I assembled a new board and quickly tested on a switch. There's a software bug that prevents the relays to switch and I'm out of SMD leds, so it was a bit difficult to test efficiently, but I could check on domoticz if buttons were activated, good news is it works for the 3 buttons so I can keep this design.
      I put the SK6812 on central button and it can run but unfortunately it's too thick so light is not visible when glass cover is on :( Meaning I'll have to make a new version with SK6812mini which is thinner (less than 1mm against 1.6), or use a RGB side led which is not a convenient solution as atmega is missing pins and PWM capabilities. So I guess I'll try the mini version first to try to keep the component count as low as possible.
      Tomorrow I'll steak some leds from another project and make more tests for touch to make sure the problem on third button is solved.
      (meanwhile the old version PCB is great for one button switches, I installed one 2 months ago and it's been running perfectly, 100% instant response by touch or via controller).
      • H
        H
        htko89
        I'm very interested in this project. I suppose it isn't too hard for me to swap the microcontrollers to something like an ESP or Photon? I just want WIFI capability :) I never bought anything on openhardware / mysensors before, does this come with all parts soldered (plug and play), or will I have to assemble?
        Sorry for all the questions!! Thanks
        Nca78N 1 Reply Last reply
        • H htko89
          @htko89 hello !
          No one openhardware you only have the PCBs, it's possible to link to an eBay shop to sell fully assembled PCBs buy I'm not planning to do it.
          You can't replace with a wifi board/chip as you can't draw enough power from thr "main" board.
          Your choices are:
          • use MySensors and control using WiFi through the smart home controller
          • replace main board with a transformer that will provide enough power. But you will need live+neutral
          • buy a sonoff wall switch, it's cheap but you will also need live and neutral wires
          And don't buy on openhardware now it's not a finished project and I will changed it some more...
            marcusakamg7
            Hey, I was just wondering if you finished this project?
            • M marcusakamg7
              @marcusakamg7 said in 💬 Livolo 3 buttons US/AU switch adapter:
              Hello, I made two, one with one button, one with three. The one with three buttons stopped running after a power outage because of radio failure, I'm not sure what happened but I had some problems with radios on other boards so maybe a batch with faulty components. But it could be related to the board using too much current and heating up too much, or overvoltage when power came back. Switch with one button is still running perfectly but it's used much less.
              I have bought new radios and will provably assemble new boards soon, but it's not my priority project at the moment.
                marcusakamg7
                is it possible to get the file for the one button switch, i would like to order the pcb and try it out.
                • M marcusakamg7
                  @marcusakamg7 it is the same PCB, as explained in the first line of the description I just put the touch sensor and led for the middle button.
                  Design is pretty old here, it will work for one button but touch sensitivity will be bad for the third button, so be aware that if you order this PCB you won't be able to make a fully functional 3 buttons version.
                  I didn't see much demand for this project so I put it a bit aside, but if you really want it I can move it up the priority list and make + test the lastest version of PCB this month.
                    marcusakamg7
                    I tried to order on OSH Park and it says your brd file is owned by another user and have not been shared.
                    • M marcusakamg7
                      @marcusakamg7 that's strange, I never ordered this board on OSHPark, I will check later.
                      12.5k
