  3. What's the "best" UPS for a Raspberry Pi 3B?
51 Posts 12 Posters 49.7k Views 12 Watching
  • tony1tfT tony1tf
    Carrying on with the "Super Cheap" theme, I have successfully used two Poundshop Lithium ion batteries. They have a 5V USB input and output which can only be used one side at a time. However, connect the two batteries in parallel (+ve to +ve, and - ve to - ve), and you get 2 charger/discharge circuits, so you can power the micro USB side from a USB 5V supply, and the other USB 5V o/p to the Pi. The cheaper ones (1pound) will supply 800mA, but they also have higher power ones for a bit more, especially as they are sometimes on offer.
    Tony
    @tony1tf Do you mean this kind of charger?
    https://www.aliexpress.com/item/ESP32-ESP32S-For-Wemos-For-Raspberry-Pi-18650-Battery-Charge-Shield-Board-V3-Micro-USB-Port/32843629344.html?spm=2114.search0104.3.8.197d1137ao0RVa&ws_ab_test=searchweb0_0,searchweb201602_5_10152_10065_10151_5711320_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10698_10545_10696_10084_5722520_10083_10618_10307_5711220_10059_5722620_5722920_308_5722720_5722820_100031_10103_10624_10623_10622_10621_10620,searchweb201603_36,ppcSwitch_5&algo_expid=63f9de1f-1174-45ff-a9fd-4ebff214ea1b-1&algo_pvid=63f9de1f-1174-45ff-a9fd-4ebff214ea1b&transAbTest=ae803_1&priceBeautifyAB=0
      2A at 5V... if it works it looks a nice and compact solution
        #26
        @gohan I notice that the silkscreen on the back of the PCB says "5v 4A output" and "3v 1A output", which would seem to contradict the seller's description of the lower amounts you quoted. On the other hand, maybe one is burst mode and the other is continuous?
          anyway 2A is more than enough for a Raspberry
          alexsh1A 1 Reply Last reply
          • Nca78N Nca78
            @neverdie I have bought the last one in your list (ugeek hat) but not set up on my pi 3 yet.
            You can get battery information through i2c and prepare for shutdown when battery is low as explained here
            http://www.raspberrypiwiki.com/index.php/Raspi_UPS_HAT_Board
            rozpruwaczR
            rozpruwaczR
            rozpruwacz
            wrote on last edited by rozpruwacz
            #28
            @nca78 does this Raspi UPS HAT is able to turn rpi on when power comes back ?
            • B
              B
              benbidouille
              Designed for Rpi2 & 3, Best UPS I have found is definitively UPS PIco HV3.0B HAT Stack with Battery 450 available under below link.
              http://www.pimodulescart.com/shop/item.aspx?itemid=30
              It accepts most technologies of batteries and capacities, but with supplied version is good enough to manage supply of RPI3 and HDD running domoticz at least for 1h and if not sufficient will proceed with clean shutdown and automatic restart on main supply is back.
              Nice industrial design, including user configurable Leds and button, relay and temperature monitoring with FAN control.
              I bought one 2 month ago, and I'm very happy with it.
              I have not any incentive nor interest in this product, just to highlight was quickly delivered to me, technical manual is well documented ( not chinese like) and firmware is professionally maintained with a dedicated forum also available.
                Price is not bad compared to others, but still costs more than a pi3 😅
                  #31
                  @gohan said in What's the "best" UPS for a Raspberry Pi 3B?:
                  The pi is mass produced. His UPS is probably produced in small batches. i.e. it's more of a specialty item, which somewhat explains the price.
                    OK, I just settled on this: https://smile.amazon.com/gp/product/B00NTQYUA8/ref=od_aui_detailpages00?ie=UTF8&psc=1
                    $25, surge protection, no lithium, and maybe (?) I'll be able to power the Pi directly from one of the UPS usb power ports.
                    It seems ridiculous that the Pi still doesnt have a shutdown button. Presently I have to ssl to it and do a "sudo poweroff" before unplugging it. Not exactly convenient!
                    @neverdie said in What's the "best" UPS for a Raspberry Pi 3B?:
                    I have this installed now. It turns out that the built-in USB power port is enough to power the Raspi3b running Octoprint. :)
                      does the usb port work also when UPS is powered off?
                        #34
                        @gohan If I unplug it from the wall (thereby simulating a power failure), it continues to send uninterrupted power over it's built-in USB power port, if that's what you mean. i.e. power failures don't crash the Octopi.
                        Or did you mean what happens if I switch-off the UPS and then unplug it? i.e. is there a different (longer lasting) circuit powering it's USB power port?
                        • jamzmJ jamzm
                          Has anyone gotten their PiModules UPS PIco to work right or for very long? And is it even compatible with a Pi 3B?
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @jamzm I have
                            that costs more than the RPI itself :D
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @gohan You can hardly find a UPS HAT priced less than Euro 25. And the cheapest version of PiModules works well for me. I am not a fan of external UPS for RPi
                              alexsh1A
                              alexsh1A
                              alexsh1
                              No, I do not think it is enough. They recommend 2.5A PSU for the latest RPI. I have 3A power supply for RPi3B. 2A was not enough, but I must say I have a few bits and bobs attached to my RPi like camera or Z-wave USB module
                              gohanG 1 Reply Last reply
                                alexsh1A
                                alexsh1A
                                alexsh1
                                Yes, you are spot on. It is hard to beat the RPi price. I think Pi Zero W priced at GBP 9 here in the UK - this is less expensive than some AVR platforms and yet much more powerful.
                                All UPS HATs I looked at here priced around Euro 25+. This is designed for DIY users and hence produced in much smaller quantities. Additionally, things like firmware has to be written and maintained up to date. And that is a big cost as this is not an open source.
                                • alexsh1A alexsh1
                                  @alexsh1 said in What's the "best" UPS for a Raspberry Pi 3B?:
                                  I did extensive measurements of the current drawn from the RPI3 and you can actually run on 1A, the extra power depends on the devices you connect to it (if you count the 4USB ports it is potentially 4x0.5A = 2A, you add the 0.7A from the RPI3 itself and you end up in the 2.5/3A range)
                                  sundberg84S alexsh1A 2 Replies Last reply
                                    sundberg84S
                                    sundberg84S
                                    @gohan cpu- load ?
                                      0.7A at full CPU load, while in idle it is about 0.2/0.25A
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @gohan I did the same thing too. Only for my set-up. I am not interesting powering a bare RPi. 2.5A is not enough in my case - I am using 3A PSU. I suppose this is due to 20x4 screen I am running from the RPi together with other peripherals.
                                        • alexsh1A alexsh1
                                          @alexsh1 Which power supply are you using to supply the 3A?
