  3. Domoticz TEXT sensor triggering
45 Posts 10 Posters 13.5k Views 10 Watching
  • SushukkaS Sushukka
    And update here about V_TEXT and OpenHAB: Yes it works like it should. When I update the V_TEXT sensor in OpenHAB, it will send the update without any extra scripts or hacks to the MySensors node.
    However, after spending several days and nights setting up OpenHAB I have to say that it is far from being ready. MySensors seems not to be qualified yet in the list of "downloadable ready" bindings in PaperUI. Had several errors with MQTT nodes. It is customizable yes, but requires way too much time to set up and maintain. It seems to be more like an architectural masterpiece than easy-to-use home controller.
    You can define nearly everything in PaperUI or HABmin like me (a hell of mouse clicking and scrolling) or define everything in multiple configuration files. When you finally have all the nodes and sensors defined (bindings, things, items), you have to build your own gui to see them in usable format. You can either use HabPanel for dashboards or configuration files for sitemaps. Dashboards, which has the best outlook imo, seems to have a problem of working with different devices. I tried to avoid the manual sitemap building by installing Imperihome binding. Connection ok, but alas, you have to manually tag every damn item you have to show them in Imperihome. With all manual configurations you actually need to define quite much of information and they are nicely connected making bigger future changes complicated. Having now around 100 sensors, all this stuff really takes time. Moreover it seemed that the reliability at least with MySensors Ethernet Gateways (one main for NFR24L01 nodes and several ESP8266s) was not in par with Domoticz. Startup problems, rebooting, lost nodes etc...And this was the last drop --> changed back to Domoticz.
    Have to say that after a couple of years OpenHAB could maybe be the number one open source home automation controller, but it requires lots of more work for getting there. Now it's too much of engineering and configuration porn vs. the real benefits it gives. Also I'm little bit afraid that the they are getting lost to this super elegancy by trying to be everything and pleasing everybody. PaperUI, HABmin, HomeBuilder, HabPanel, Basic UI, Classic UI, some third party UIs, configuration files... The concept is nice, but as with any product, you need to focus somewhere or otherwise you are just semicore in all areas. Domoticz has its problems, but at least it is reliable and allows putting the most of the available tinkering time to the actual node building than tuning the controller.
    monteM
    monteM
    monte
    wrote on last edited by monte
    #27
    @sushukka why don't you use configs? It's not too hard to write them and you don't need to find options in incomplete gui. But I agree that their approach doesn't suit well for tinkering and building system step by step adding few devices every couple of days, or changing the layout. I guess it has more use for complete systems that doesn't require adding new things more than once in few months.
    I have to say that I like Domoticz' way of setting things up more, but the fact that it's almost not developing and amount of lag and unpolished corners here and there...It doesn't feel robust enough to suggest it to someone else than myself or people like ones on this forum.
    SushukkaS 1 Reply Last reply
    • monteM monte
      SushukkaS
      SushukkaS
      Sushukka
      wrote on last edited by Sushukka
      #28
      @monte True that. Thing is that people like to use the guis instead of configuration files. That's probably the reason why OpenHAB "fastly" evolves in that direction.
      For all the not-so-technical home automation builders I would myself suggest Domoticz as the choise for open source controller. OpenHAB maybe for the ones who buys ready-made stuff from Ikea, zWave etc and just want to control the stuff from one place. But still I'm pretty sure that many of those are not really interested or have required knowledge to start tinkering with OpenHAB. For MySensors users, as you said, it creates lots of additional work for little extra over Domoticz. Domo has this stupid V_TEXT sensor limitation and some people like that the default graphing stuff is limited. However, OpenHAB has nothing without setting up persistence services and their separate databases and definitions...and you can have the praised Influx-Grafana integration also for Domo. My personal opinion is that the normal Domo gui is still pretty useful plus you can have Imperihome, Dashticz type of connections or build your own with Rest API. With OpenHAB you don't have anything usable without manually building it first. I'm myself using Imperihome which basically gives little to complain about gui usability and visual aesthetics. With Domo you install MyDomoAtHome which has all the mappings done so that you can just start playing around with your Imperihome gui. With OpenHAB...
      https://github.com/openhab/openhab2-addons/tree/master/addons/io/org.openhab.io.imperihome
      The tagging part is not a small work to do...and this pretty much underlines the problem with OpenHAB. You can tune everything, but basically spend huge amount of time on doing that...or even getting things to work on basic level. The OpenHAB community seems to be active, but it has to, as there seems to be lots of problems too.
      But not bashing OpenHAB more: I want to like it, but it's just making liking it too hard for now. However, it has Eclipse foundation backing it up and has started evolving to the right direction out of the pure configuration file based setup/tuning. After year or two I believe it's much more user-friendly and more widely used. If not and Domo won't be developed anymore there is always the middleware/MQTT/NodeRed/cloud options to go...
      monteM 1 Reply Last reply
        monteM
        monteM
        monte
        @sushukka I'm using Domoticz myself at home, but have chosen OpenHAB as a platform for my friend's home automation project I'm working on. We are using some KNX modules and for now only openhab has native support for it (among platforms that are kept developing). Another big advantage of openhab is number of different bindings for different hardware and community that is willing to write the new ones. On the other hand developers of Domoticz either ignore your suggestions or tell you to implement them yourself. Can't see a bright future with such an attitude.
        • monteM monte
          SushukkaS
          SushukkaS
          Sushukka
          #30
          @monte I fully agree with this. I have tried to get some explanation to this V_TEXT problem through multiple channels and no one is really answering anything. Either the developers have dumped the whole project or are just nasty dwarfs in a cave. GitHub shows some activity but the project seems to lay very heavily on "gizmocuz" shoulders who probably has a nasty attitude but has also answered to this V_TEXT question 7/2017 not easily implemented -> Best to help with development...so it seems that they are lacking hands...but in other hand, if the attitude is bad there aren't probably many willing to come to help.
          So...same here, I'll continue using Domoticz, but actively seeking a better alternative for it and trying to build as little as possible Domoticz specific stuff.
            I have to say that domoticz is pushing out one or 2 updates for beta on a weekly basis, so something is moving. But yes, it seems there aren't many people actively developing it.
            • SushukkaS
              SushukkaS
              Sushukka
              Here is the latest update:
              https://github.com/domoticz/domoticz/issues/2380
              At least got some response...do it yourself.
              Darn sad: a good, reliable and widely-used product, but the developers are just pricks or don't give shit. With better attitude this could be so much more and most likely there would be lots of more contributors helping with them.
                Agreed, that is bad but on the other side consider it is a feature not used much actually.
                Nca78N GertSandersG 2 Replies Last reply
                  @gohan said in Domoticz TEXT sensor triggering:
                  Well I don't use it at the moment, but only because it's a PITA with Domoticz...
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @gohan I would love to have that feature so I can send updates to a LCD equipped sensor, without the "switch" hack.
                    Polling is really inefficient, one should be able to send V_TEXT just like V_STATUS.
                    alexsh1A 1 Reply Last reply
                      Don't get me wrong, I understand, I was just considering that it a feature not needed by many people and it is still on the feature request list
                      • alowhumA
                        alowhumA
                        alowhum
                        #37
                        I built a partial solution for this in the Aurora theme for Domoticz. With it you can just change the vText variable value in the interface.
                        • Install Aurora
                        • Go to Utility tab
                        • click on the text value. It will change into an edit field. Click outside of it when you're done.
                        The node still needs to poll Domoticz periodically to request the new value. But at least you can change the value easily this way.
                        • SushukkaS
                          SushukkaS
                          Sushukka
                          YEEEEEEESSSSHHH!!! This is now implemented in Domoticz!
                          You can change the V_TEXT sensor value from Domoticz via JSON, Scripts and Blocky and the update will be sent directly to the node without any hacks!!! This is big update; you can pass lots of information, parameters etc directly to the nodes without extra steps. And @alowhum you don't need that poll anymore in the sketch. :) LCD screen updates, speech-to-text commands...now we just need bigger payload size for MySensors... :D
                          • GertSandersG GertSanders
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @gertsanders said in Domoticz TEXT sensor triggering:
                            you ca do it now with the latest update
                            • alowhumA
                              alowhumA
                              alowhum
                              #40
                              What other things are bi-directional with Domoticz?
                              Fo example I'm looking to receive a setpoint value from Domoticz for a node that is an oven controller. Dresenting a s_hvac and then setting a new temperature in Domoticz, does that automatically get sent back to a node? Or is there a setpoint something?
                              gohanG K 2 Replies Last reply
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @alowhum
                                If I remember right, then domoticz sends the new temperature to the device, but only updates the gui when it receives a value from the node. So your node sketch have to reply the set command from your controller, with another set command, which sends the value back to your controller.
                                • alowhumA alowhum
                                  @alowhum those kind of values should be sent automatically to the node if they are changed in domoticz
                                  • alowhumA alowhum
                                    K
                                    K
                                    kimot
                                    @alowhum
                                    bool MySensorsBase::WriteToHardware(const char *pdata, const unsigned char length)
                                    	const tRBUF *pCmd = reinterpret_cast<const tRBUF *>(pdata);
                                    	unsigned char packettype = pCmd->ICMND.packettype;
                                    	unsigned char subtype = pCmd->ICMND.subtype;
                                    	if (packettype == pTypeLighting2)
                                    		//Light command
                                    		int node_id = pCmd->LIGHTING2.id4;
                                    		int child_sensor_id = pCmd->LIGHTING2.unitcode;
                                    		if (_tMySensorNode *pNode = FindNode(node_id))
                                    			_tMySensorChild *pChild = pNode->FindChild(child_sensor_id);
                                    			if (!pChild)
                                    				_log.Log(LOG_ERROR, "MySensors: Light command received for unknown node_id: %d, child_id: %d", node_id, child_sensor_id);
                                    				return false;
                                    			int light_command = pCmd->LIGHTING2.cmnd;
                                    			if ((pCmd->LIGHTING2.cmnd == light2_sSetLevel) && (pCmd->LIGHTING2.level == 0))
                                    				light_command = light2_sOff;
                                    			else if ((pCmd->LIGHTING2.cmnd == light2_sSetLevel) && (pCmd->LIGHTING2.level == 255))
                                    				light_command = light2_sOn;
                                    			if ((light_command == light2_sOn) || (light_command == light2_sOff))
                                    				std::string lState = (light_command == light2_sOn) ? "1" : "0";
                                    				if (pChild->presType == S_LOCK)
                                    					//Door lock/contact
                                    					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_LOCK_STATUS, lState, pChild->useAck, pChild->ackTimeout);
                                    				else if (pChild->presType == S_SCENE_CONTROLLER)
                                    					//Scene Controller
                                    					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, (light_command == light2_sOn) ? V_SCENE_ON : V_SCENE_OFF, lState, pChild->useAck, pChild->ackTimeout);
                                    					//normal
                                    					return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STATUS, lState, pChild->useAck, pChild->ackTimeout);
                                    			else if (light_command == light2_sSetLevel)
                                    				float fvalue = (100.0f / 14.0f)*float(pCmd->LIGHTING2.level);
                                    				if (fvalue > 100.0f)
                                    					fvalue = 100.0f; //99 is fully on
                                    				int svalue = round(fvalue);
                                    				std::stringstream sstr;
                                    				sstr << svalue;
                                    				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_PERCENTAGE, sstr.str(), pChild->useAck, pChild->ackTimeout);
                                    		else {
                                    			_log.Log(LOG_ERROR, "MySensors: Light command received for unknown node_id: %d", node_id);
                                    			return false;
                                    	else if (packettype == pTypeLimitlessLights)
                                    		//RGW/RGBW command
                                    		_tLimitlessLights *pLed = (_tLimitlessLights *)pdata;
                                    		//unsigned char ID1 = (unsigned char)((pLed->id & 0xFF000000) >> 24);
                                    		//unsigned char ID2 = (unsigned char)((pLed->id & 0x00FF0000) >> 16);
                                    		unsigned char ID3 = (unsigned char)((pLed->id & 0x0000FF00) >> 8);
                                    		unsigned char ID4 = (unsigned char)pLed->id & 0x000000FF;
                                    		int node_id = (ID3 << 8) | ID4;
                                    		int child_sensor_id = pLed->dunit;
                                    			if (!pChild)
                                    				return false;
                                    			bool bIsRGBW = (pNode->FindChildWithPresentationType(child_sensor_id, S_RGBW_LIGHT) != NULL);
                                    			if (pLed->command == Limitless_SetRGBColour)
                                    				int red, green, blue;
                                    				float cHue = (360.0f / 255.0f)*float(pLed->value);//hue given was in range of 0-255
                                    				int Brightness = 100;
                                    				int dMax = round((255.0f / 100.0f)*float(Brightness));
                                    				hue2rgb(cHue, red, green, blue, dMax);
                                    				sstr << std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << red
                                    					<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << green
                                    					<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << blue;
                                    				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, (bIsRGBW == true) ? V_RGBW : V_RGB, sstr.str(), pChild->useAck, pChild->ackTimeout);
                                    			else if (pLed->command == Limitless_SetColorToWhite)
                                    				int wWhite = round((255.0f / 100.0f)*float(Brightness));
                                    				if (!bIsRGBW)
                                    					sstr << std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << wWhite
                                    						<< std::setw(2) << std::uppercase << std::hex << std::setfill('0') << std::hex << wWhite;
                                    					sstr << "#000000"
                                    			else if (pLed->command == Limitless_SetBrightnessLevel)
                                    				float fvalue = pLed->value;
                                    				if (svalue > 100)
                                    					svalue = 100;
                                    				sstr << svalue;
                                    			else if ((pLed->command == Limitless_LedOff) || (pLed->command == Limitless_LedOn))
                                    				std::string lState = (pLed->command == Limitless_LedOn) ? "1" : "0";
                                    			return false;
                                    	else if (packettype == pTypeBlinds)
                                    		//Blinds/Window command
                                    		int node_id = pCmd->BLINDS1.id3;
                                    		int child_sensor_id = pCmd->BLINDS1.unitcode;
                                    			if (!pChild)
                                    				return false;
                                    			if (pCmd->BLINDS1.cmnd == blinds_sOpen)
                                    				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_UP, "", pChild->useAck, pChild->ackTimeout);
                                    			else if (pCmd->BLINDS1.cmnd == blinds_sClose)
                                    				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_DOWN, "", pChild->useAck, pChild->ackTimeout);
                                    			else if (pCmd->BLINDS1.cmnd == blinds_sStop)
                                    				return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, V_STOP, "", pChild->useAck, pChild->ackTimeout);
                                    		else {
                                    			_log.Log(LOG_ERROR, "MySensors: Blinds/Window command received for unknown node_id: %d", node_id);
                                    			return false;
                                    	else if ((packettype == pTypeThermostat) && (subtype == sTypeThermSetpoint))
                                    		//Set Point
                                    		const _tThermostat *pMeter = reinterpret_cast<const _tThermostat *>(pCmd);
                                    		int node_id = pMeter->id2;
                                    		int child_sensor_id = pMeter->id3;
                                    		_eSetType vtype_id = (_eSetType)pMeter->id4;
                                    			if (!pChild)
                                    				return false;
                                    			char szTmp[10];
                                    			sprintf(szTmp, "%.1f", pMeter->temp);
                                    			return SendNodeSetCommand(node_id, child_sensor_id, MT_Set, vtype_id, szTmp, pChild->useAck, pChild->ackTimeout);
                                    		else {
                                    			return false;
                                    	else if (packettype == pTypeGeneralSwitch)
                                    		//Used to store IR codes
                                    		const _tGeneralSwitch *pSwitch= reinterpret_cast<const _tGeneralSwitch *>(pCmd);
                                    		int node_id = pSwitch->unitcode;
                                    		unsigned int ir_code = pSwitch->id;
                                    			_tMySensorChild* pChild = pNode->FindChildByValueType(V_IR_RECEIVE);
                                    			if (pChild)
                                    				sstr << ir_code;
                                    				return SendNodeSetCommand(node_id, pChild->childID, MT_Set, V_IR_SEND, sstr.str(), pChild->useAck, pChild->ackTimeout);
                                    		else {
                                    			return false;
                                    		_log.Log(LOG_ERROR, "MySensors: Unknown action received");
                                    		return false;
                                    	return true;
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      @kimot : Thanks! If I'm reading that domoticz code correctly:
                                      • All kinds of switches, including percentage and V_IR_RECEIVE
                                      • "sTypeThermSetpoint"
                                      • Hmm, I don't see the V_text update in that code
                                      @tbowmo : I had discovered that by experimenting, good to see it confirmed by you too.
                                      K 1 Reply Last reply
                                      • alowhumA alowhum
                                        K
                                        K
                                        kimot
                                        @alowhum
                                        There are some changes in V_TEXT type in latest builds.
                                        Read this:
                                        https://forum.mysensors.org/topic/9340/domoticz-v_text-sensor-now-bidirectional
