  2. Announcements
  3. πŸ’¬ Power Meter Pulse Sensor
183 Posts 40 Posters 93.6k Views 37 Watching
  • xydixX
    xydixX
    xydix
    wrote on last edited by xydix
    #133
    Yes. I guess.
    I don't have anything to compare with but i think it is accurate.
    I have a 1000blink/kwh
    Example:
    Node send state every 20 sec.
    pulsecount: 8 pulses every 20 sec.
    Instant power in W is about 1400W
    8 pulses x 3 = pulses /minute =24
    24 pulses x 60 min = pulses /hour = 1440.
    Edit.
    Now I get a new value every 20 sec, before I didn't get any value (W) from the node at all because it was too high. I only received pulse count and kWh earlier.
      Besides the cap, what exactly did you do?
      • xydixX
        xydixX
        xydix
        Nothing more.
        I use the same arduino, haven't uploaded anything new to it since i tried it last time.
        What I had to do was lower the sensitivity on the LM393 because at first the signal-LED glowed a bit but when i adjusted it to lower sensitivity and closed the door to get it totaly dark the led blinked exactly as the meeter.
        I have it on a bredboard and connected the cap between GND and to pin 3 so it is connected close to the arduino but i guess it shouldn't matter.
        Have you tried it?
          I can't believe it, IT WORKS!!!!! I added the cap directly under the pins of the LM939 board. Thanks man!
          • xydixX
            xydixX
            xydix
            I am glad to hear it works for you too.
              There is probably a sw way to correct this problem, I'll think about it
              • xydixX
                xydixX
                xydix
                #139
                It waswhat I thought too.
                As I said earlier, when I tested this my conclusion was, short blink, almost a flash will counted as a pulse (kWh) but it does something wrong with the calculation of instant power usage.
                A slower blink will correct this.
                My meeter gives a very short blink.
                  wrote on last edited by gohan
                  #140
                  Yes, could be that a simple debounce could do the trick but I'll have to look deeper into it. @Yveaux what do you think?
                    @xydix Could you try to increase the 10000L to 100000L interval in the OnPulse function and see if it works without the capacitor?
                    • U
                      U
                      user2684
                      I tried to build something similar and it is working nicely, thanks for sharing the idea! However, I've noticed the light sensor (alone) consumes 1mA constantly which is quite a lot when used for a battery powered project. Even if I report to the controller once per hour (summing up the power consumption along the way), still the light sensor needs to be always on, meaning I'd probably need to replace batteries after a month or so. Is there any workaround or alternative sensor which I can use or am I doing something completely wrong? Thanks
                      C 1 Reply Last reply
                      • U user2684
                        C
                        C
                        cstewy
                        @user2684 I had the same issue when I built this with a standalone atmega328p running on 2x AA's. I set it up with wake on interrupt from the It was constantly drawing 1.6mA to power the tsl257 to detect the flashes. My target was 1+ years on 2 x AA's. My solution to achieve this was to sleep for 125ms, wake up, send power to tsl257 to check light state (on/off), if it changed from previous reading then there was a pulse (well half pulse). By measuring every 125ms I can guarantee to capture fast pulses up to 14.4kW. (3600000/125)/2. It is 20kW max draw for residential in my country. Now:
                        Average mA Consumption Sleep 0.1
                        Average mA Consumption Wake 0.064516129
                        Average mA Consumption Transmit 0.002916667
                        Battery Life (2xAAs) = 1.7 years
                        U 1 Reply Last reply
                        • C cstewy
                          U
                          U
                          user2684
                          @cstewy many thanks and very interesting. You basically saying it consumes less by waking up every 125ms rather than being asleep but with the sensor eating up current continuously. Definitely worth trying thanks! Meanwhile I've reduced the number of radio transmission and the batteries lasted for a couple of months but still is not ideal. Thanks! I'll try and report back
                          • A
                            artipi
                            Hello, i'm stuck with this sensor, because no Interrupt is really working. I've cut down the code to this:
                             * Version 1.0 - Henrik Ekblad
                             * This sketch provides an example how to implement a LM393 PCB
                             * Use this sensor to measure kWh and Watt of your house meter
                             * You need to set the correct pulsefactor of your meter (blinks per kWh).
                             * The sensor starts by fetching current kWh value from gateway.
                             * Reports both kWh and Watt back to gateway.
                             * Unfortunately millis() won't increment when the Arduino is in
                             * sleepmode. So we cannot make this sensor sleep if we also want
                             * to calculate/report watt value.
                             * http://www.mysensors.org/build/pulse_power
                            // Enable debug prints
                            //#define MY_RADIO_NRF24
                            //#define MY_RADIO_NRF5_ESB
                            //#define MY_RADIO_RFM95
                            //#include <MySensors.h>
                            #define DIGITAL_INPUT_SENSOR 2  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                            #define PULSE_FACTOR 500       // Number of blinks per of your meter
                            #define SLEEP_MODE false        // Watt value can only be reported when sleep mode is false.
                            #define MAX_WATT 1000000          // Max watt value to report. This filters outliers.
                            #define CHILD_ID 10             // Id of the sensor child
                            uint32_t SEND_FREQUENCY =
                                15000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                            double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                            bool pcReceived = true;
                            volatile uint32_t pulseCount = 0;
                            volatile uint32_t lastBlink = 0;
                            volatile uint32_t watt = 0;
                            uint32_t oldPulseCount = 0;
                            uint32_t oldWatt = 0;
                            double oldkWh;
                            uint32_t lastSend;
                            //MyMessage wattMsg(CHILD_ID,V_WATT);
                            //MyMessage kWhMsg(CHILD_ID,V_KWH);
                            //MyMessage pcMsg(CHILD_ID,V_VAR1);
                              Serial.begin(9600);
                              Serial.println("Start setup");
                              //request(CHILD_ID, V_VAR1);
                              pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                              attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                              lastSend=millis();
                              Serial.println("Start setup: last sent: ");
                              pinMode(LED_BUILTIN, OUTPUT);
                              digitalWrite(LED_BUILTIN, LOW);
                              //sendSketchInfo("Energy Meter", "1.3");
                              //present(CHILD_ID, S_POWER);
                            void onPulse()
                              Serial.println("onPulse:");
                              digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
                              delay(1000);                       // wait for a second
                              digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
                              delay(1000);
                              pulseCount++;
                              Serial.println("pulseCount:");
                            The Problem ist, that only on Start the interrupt ist working once, but no LED blinks.
                            Can someone help?
                            • A artipi
                              double oldkWh;
                              uint32_t lastSend;
                                Serial.begin(9600);
                                lastSend=millis();
                              void onPulse()
                                delay(1000);
                                pulseCount++;
                              Can someone help?
                              #146
                              @artipi using Serial.print and delay from within an interrupt service routine will mess things up. Interrupt service routines must be executed quickly.
                              From https://www.arduino.cc/reference/en/language/functions/external-interrupts/attachinterrupt/:
                              Since delay() requires interrupts to work, it will not work if called inside an ISR.
                              You need to do the blinking inside loop().
                              • A
                                artipi
                                Ah, this explains many things. Thank you, now its working:)!
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  @artipi can you share your code?
                                  • A
                                    artipi
                                    @alowhum: Its the original code. Nothing changed. I've only made some tests with my version...
                                    • P
                                      P
                                      patrikr76
                                      wrote on last edited by patrikr76
                                      #150
                                      Hey guys
                                      So i am trying to use this sketch with the sleep mode set to true 'cause i need to run it on battery.
                                      It works fine running with usb power on it and sleep mode on false.
                                      But with sleep mode true i am getting nothing in myscontroller after the initial startup.
                                      All i changed is the sleep mode from false to true.
                                      Running it on a clone nano with some chinese "flame detector" sensor.
                                      Been trying to figure out if it has something to do with how it reports when in sleep mode but it should still report whatever the send frequency is set to right?
                                      I was using a tv remote to fake impulses, with seems to work on usb power, but not on battery.
                                      Any suggestions?
                                      Best regards
                                      Patrik
                                      • P patrikr76
                                        Hey guys
                                        Any suggestions?
                                        Best regards
                                        Patrik
                                        #151
                                        @patrikr76 just to make sure we are on the same page, could you clarify which sketch you are using? This thread has discussed lots of sketches and it would be a pity if we’re looking at different code :)
                                        In any case, the debug log from the node will give the best information on what is happening.
                                        It could also be useful to only change one thing. Right now you change sleep mode and switch to battery, right? How does the node behave with sleep mode on, but still running on usb power? How does the node behave with sleep mode off, but running on battery?
                                        • P
                                          P
                                          patrikr76
                                          #152
                                          @mfalkvidd , you are absolutely right. Let me clarify.
                                          I am using the example code that is under build and power meter pulse sensor, updated may 1st, 2018.
                                          Running it with "sleep mode = false" it works fine with both usb and battery power, just drains the battery quite fast.
                                          Setting it to "sleep mode = true" it doesn't work either on usb or battery power.
                                          Here's how the serial monitor looks for the startup phase with sleep mode as true.
                                          23:21:24.219 ->  __  __       ____
                                          23:21:24.219 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
                                          23:21:24.219 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
                                          23:21:24.219 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
                                          23:21:24.219 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
                                          23:21:24.219 ->         |___/                      2.3.0
                                          23:21:24.219 ->
                                          23:21:24.219 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
                                          23:21:24.254 -> 25 TSM:INIT
                                          23:21:24.254 -> 26 TSF:WUR:MS=0
                                          23:21:24.254 -> 33 TSM:INIT:TSP OK
                                          23:21:24.254 -> 35 TSF:SID:OK,ID=2
                                          23:21:24.254 -> 37 TSM:FPAR
                                          73 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          201 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          23:21:24.428 -> 205 TSF:MSG:FPAR OK,ID=0,D=1
                                          2080 TSM:FPAR:OK
                                          23:21:26.306 -> 2081 TSM:ID
                                          23:21:26.306 -> 2082 TSM:ID:OK
                                          23:21:26.306 -> 2084 TSM:UPL
                                          23:21:26.306 -> 2087 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          23:21:26.306 -> 2095 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          23:21:26.306 -> 2100 TSF:MSG:PONG RECV,HP=1
                                          23:21:26.306 -> 2103 TSM:UPL:OK
                                          23:21:26.306 -> 2104 TSM:READY:ID=2,PAR=0,DIS=1
                                          23:21:26.306 -> 2109 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                          23:21:26.341 -> 2118 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          23:21:26.341 -> 2125 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
                                          23:21:26.341 -> 2134 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          2203 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          23:21:26.410 -> 2210 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
                                          23:21:26.445 -> 2220 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
                                          23:21:26.445 -> 2228 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
                                          23:21:26.445 -> 2234 MCO:REG:REQ
                                          23:21:26.445 -> 2237 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                          2252 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          23:21:26.480 -> 2257 MCO:PIM:NODE REG=1
                                          23:21:26.480 -> 2259 MCO:BGN:STP
                                          23:21:26.480 -> 2263 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                          23:21:26.480 -> 2269 MCO:BGN:INIT OK,TSP=1
                                          23:21:26.480 -> 2272 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:21:26.480 -> 2277 TSF:TDI:TSL
                                          As far as i can see it seems fine and also shows up in myscontroller.
                                          And here is an example how it looks after 20 seconds sleep.
                                          2414 MCO:SLP:WUP=-1
                                          23:26:36.346 -> 2416 TSF:TRI:TSB
                                          23:26:36.346 -> 2418 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:26:36.346 -> 2423 TSF:TDI:TSL
                                          I don't see any connection attempts with my gateway, or shouldn't there by any if the sensor is not triggered?
                                          Here i can show how it looks when tricking the sensor with the ir on the mouse.
                                          2456 MCO:SLP:WUP=-1
                                          23:27:48.785 -> 2458 TSF:TRI:TSB
                                          23:27:48.785 -> 2460 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:27:48.785 -> 2465 TSF:TDI:TSL
                                          2467 MCO:SLP:WUP=-1
                                          23:27:48.924 -> 2468 TSF:TRI:TSB
                                          23:27:48.959 -> 2470 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:27:48.959 -> 2476 TSF:TDI:TSL
                                          2478 MCO:SLP:WUP=-1
                                          23:27:49.098 -> 2480 TSF:TRI:TSB
                                          23:27:49.098 -> 2481 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:27:49.098 -> 2486 TSF:TDI:TSL
                                          2488 MCO:SLP:WUP=-1
                                          23:27:49.235 -> 2490 TSF:TRI:TSB
                                          23:27:49.235 -> 2492 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:27:49.270 -> 2497 TSF:TDI:TSL
                                          2498 MCO:SLP:WUP=-1
                                          23:27:49.408 -> 2500 TSF:TRI:TSB
                                          23:27:49.408 -> 2502 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:27:49.408 -> 2507 TSF:TDI:TSL
                                          2509 MCO:SLP:WUP=-1
                                          23:27:49.546 -> 2510 TSF:TRI:TSB
                                          23:27:49.546 -> 2512 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                          23:27:49.546 -> 2518 TSF:TDI:TSL
                                          Interrupt is triggered and it wakes up, but nothing is sent to the gateway.
                                          Have i missed something?
                                          With your input, this post could be even better πŸ’—
