  2. Announcements
  • joaoabsJ joaoabs
    I found that the configuration file is /etc/mysensors.conf but " The first time you start the gateway the configuration file will be created if it does not already exist.", so that's why I wasn't finding it.
    Anyway, the file states that:
    "Note: The gateway must have been built with signing support to use the options below."
    What flags should I include to have signing support?
    OK, found it: just run ./configure -h and there is a list of options. Leaving it here just for future reference
    @joaoabs said in 💬 Building a Raspberry Pi Gateway:
    it is already written in the article
    • joaoabsJ joaoabs
      AnticimexA
      AnticimexA
      Anticimex
      @joaoabs
      Release: https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html
      Beta/development: https://www.mysensors.org/apidocs-beta/group__RaspberryPiGateway.html
      • joaoabsJ
        joaoabsJ
        joaoabs
        Thanks for the replies.
        I've changed the PI from a PI1 to a PI3 and was able to make it working with signing. Its running smoothly, I guess the GW is chosen :).
        I'll now focus on the nodes, specially the SenseBender micros that are 2xAA battery powered and are consuming ~3% bat per day, but that will be for another post...
        Joaoabs
        • D
          Damian
          Hi, is there any way to check the current gateway operating parameters? My purpose is to check the radio channel and power level set before compilation but I would be glad if I could check other configurable parameters. I looked at Makefile.inc and found some flags set, but not the information I was looking for (does it mean that the default values are set)? Debug logs neither provide these informations.
            What radio are you using?
            D 1 Reply Last reply
              Damian
              @gohan nrf24, one deployment pa+lna version with external antenna and the other standard with build-in "zig-zag" antenna.
                I always set gw to max power if the radio is shielded
                • joaoabsJ
                  joaoabsJ
                  joaoabs
                  wrote on last edited by joaoabs
                  #914
                  Is it normal to have frequently these errors in the RPI GW?
                  May 11 00:43:54 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                  May 11 00:43:56 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                  May 11 00:43:58 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                  May 11 00:44:00 nettemp mysgw: RF24: Recovered from a bad interrupt trigger.
                    Damian
                    @gohan Well, that is not an answer to my question apparently :) I suppose that max power lever is the default setting according to the configure script's help.
                      also look for a channel outside the WiFi range
                      • K
                        K
                        kberck3
                        Openhab2 on pi3b+ using nrf24 radios and mqtt. I can follow the wiring diagram, but the commands are a bit confusing and seem to jump around randomly. Do I put all the --my-blah-blah together after the ./configure to build a file? Should I do development version? Do the nfr improvements go together with everything else?
                        gohanG 1 Reply Last reply
                        • K kberck3
                          @kberck3 said in 💬 Building a Raspberry Pi Gateway:
                          From the article "Note: All options must be added to the same line, after ./configure"
                          Leave the development version for now, the stable works fine.
                            #919
                            @gohan to be fair, I added that note this morning so kberck3 might not have seen it :-)
                            • K
                              K
                              kberck3
                              Appreciate the reply mfalkvidd and gohan! Service is running, will report back if I run into other issues.
                              • Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                Hi Guys,
                                Is anyone here using the Pi with OTA updates? I'm finding them painfully slow (1-2 stream messages every few seconds). It's taking 1 hour per OTA update compared with 2-3 minutes when using the Arduino gateway!
                                  I did some tests on pi3 and I found slow ota too. Tekka has an open issue on github about this.
                                    mirodin
                                    Hey guys,
                                    I tried to setup my Raspberry running Node-RED and serial gateway but I got stuck halfway. I followed the serial gateway compilation above and got it up and running, however using the serial nodes an Node-RED I could not manage to get them to connect tho the gateway.
                                    First I tried to connect to /dev/ttyMySensorsGateway which did not work due to permissions (owned by root). When checking out /dev/ttyMySensorsGateway I found it links to /dev/pts/1
                                    which belongs to root and the tty group. But I could not connect to this as the tty group only has write privileges. I think I miss some crucial point connecting those two together so I hope somebody can save the day by pointing me in the right direction.
                                    Thanks in advance,
                                    mirodin
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @mirodin
                                      So you run a separate arduino board as a mysensors gateway, connected with serial (USB) to your raspberry pi? Or do you mean that you are using the rpi directly with radio, and then run the rpi variant of the mysensors gateway code?
                                      • tbowmoT tbowmo
                                        @mirodin
                                        mirodin
                                        wrote on last edited by mirodin
                                        #925
                                        @tbowmo I run the gateway on my Pi directly with the radio is connected to the Pi's GPIOs. Compilation and gateway do just fine I, if only I could convince my Pi to let Node-RED talk to the device :D
                                        EDIT:
                                        This is my output:
                                        dietpi@buddy:~ $ ll /dev/ttMySensorsGateway
                                        lrwxrwxrwx 1 root root 10 Jun 18 14:38 /dev/ttMySensorsGateway -> /dev/pts/2
                                        dietpi@buddy:~ $ ll /dev/pts/
                                        total 0
                                        crw--w---- 1 dietpi tty  136, 0 Jun 18 14:38 0
                                        crw--w---- 1 dietpi tty  136, 1 Jun 18 14:38 1
                                        crw--w---- 1 root   tty  136, 2 Jun 18 14:38 2
                                        crw--w---- 1 dietpi tty  136, 3 Jun 18 14:38 3
                                        c--------- 1 root   root   5, 2 Nov  3  2016 ptmx
                                          wasn't it the problem of the missing permission on the dialup group?
