  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 513.6k Views 73 Watching
  • J
    J
    jribera
    This looks very interesting. Seems like it will make remote debugging easy, ie can run this on a PC at home and RDP into it.
    • C
      C
      chris021
      Also Following. Very keen to try this!
      • RJ_MakeR
        RJ_MakeR
        RJ_Make
        Will this program act like a controller (take the place of Vera?) and handle automation logic?
        RJ_Make
        • tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          hi all,
          here is the first alpha version of the MYSController (I changed the name).
          http://goo.gl/9DCWNo
          There are still lots of things that need to be done and some bugs :), but feel free to give it a try. I included the modified bootloader (flash according to the settings in the fuses.txt file) and two example .hexs for testing/uploading. From my experience, the OTA works better/faster using the serial gateway.
          Cheers,
          tekka
          • C
            C
            chris021
            Got it working first try! Can see data coming back from my Temp and Hum sensors!
            Looks like a great tool.
            Thank you!
            • daulagariD
              daulagariD
              daulagari
              @tekka
              :+1:
              Saw it was a Windows executable but did give it a try on Linux:
              wine MYSController.exe
              And the GUI comes up nicely!
              I can not select the serial port yet, so could not test it further, likely have to do some mapping in wine.
                wrote on last edited by hek
                Yepp.. GUI comes up on mac using wine as well. Will try tomorrow when I have an Arduino nearby.
                • T
                  Tibus
                  is it possible tu use the ota bootloader on 8Mhz?
                  • tekkaT
                    tekkaT
                    tekka
                    For OTA should be ok, for AVRDUDE not tested
                    • T
                      Tibus
                      OK, Thank's!
                      The GUI doesn't work on mac with wine. The program is running good but do not recognize the usb device (even with a symbolic link to wine,...). Is it possible to get the program on mac?
                      tekkaT 1 Reply Last reply
                      • T Tibus
                        OK, Thank's!
                        tekkaT
                        tekkaT
                        tekka
                        @Tibus
                        I will look into that. Meanwhile, can you try to link the serial gateway to localhost (e.g. ser2net or socat) and connect via tcp?
                        • T
                          Tibus
                          ok, I'll try that. Really looking forward to play with it ;D
                          • daulagariD
                            daulagariD
                            daulagari
                            Took some time to find out but after:
                            • Adding a mapping from the Linux serial port to the Wine dosdevice configuration:
                              ln -s /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_* ~/.wine/dosdevices/COM3
                            • Adding to ~/.wine/system.reg:
                                [Hardware\\Devicemap\\Serialcomm] 1231984861
                                "Serial0"="COM1"
                                "Serial1"="COM2"
                                "Serial2"="COM3"
                            I could start MYSController.exe and select COM3 and get:
                            But after pressing OK things look to work however:
                            @tekka : Thanks!
                            • daulagariD daulagari
                                  "Serial0"="COM1"
                                  "Serial1"="COM2"
                                  "Serial2"="COM3"
                              @tekka : Thanks!
                              tekkaT
                              tekkaT
                              tekka
                              @daulagari thanks for the workaround. Success with OTA?
                              • daulagariD
                                daulagariD
                                daulagari
                                Doing OTA did work once but trying a second time did not work out yet.
                                I found that it is important the user that runs "wine MYSController.exe" must have access to the port ~/.wine/dosdevices/COMx links to:
                                $ ls -als /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_*
                                0 lrwxrwxrwx 1 root root 13 25 jan 09:38 /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A9SZN99X-if00-port0 -> ../../ttyUSB0
                                Is not good ("root root"), I changed the link to to:
                                $ ls -asl /dev/ttyUSB0
                                0 crw-rw---- 1 root dialout 188, 0 25 jan 11:34 /dev/ttyUSB0
                                In the debug log I see the 0;0;3;0;14;Gateway startup complete. message but no messages from the sensor.
                                Looks like the "File not open." window I am getting and:
                                fixme:comm:set_queue_size insize 4096 outsize 0 unimplemented stub
                                I am seeing on the command line has something to do with it.
                                NB: Seems like the GUI is programmed using TK. How about compiling it for Linux?
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @daulagari
                                  interesting, do you get the "File not open" message with AutoFW disabled? Also, what happens if you reboot the gateway several times (reset button), does the "Gateway startup complete" message re-appear? I recall that I had problems with OTA with the debug-mode enabled in config.h, the gateway kept freezing when sending OTA messages.
                                  The controller is written in lazarus/fpc - porting to mac or *nix should be straight forward, I'll have a look.
                                  • daulagariD
                                    daulagariD
                                    daulagari
                                    I have AutoFW disabled.
                                    The funny thing is that things do not work at all if I do not get the "File not open" error.
                                    No, rebooting the gateway does not make the "Gateway startup complete" message re-appear.
                                    Did watch the serial port using interceptty and see data is passed so it seems like Wine is not passing it.
                                    • daulagariD
                                      daulagariD
                                      daulagari
                                      Did do some more experimenting using a sort of Ethernet gateway (actual the relayed Serial gateway data) and see that MYSController.exe can connect but once it prints the first data it gives the "File not open." error and no further data is printed.
                                      So it does not look like a serial port issue but something else.
                                      Did not know Lazarus but it looks pretty good!
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #32
                                        @daulagari
                                        ok, I could reproduce the error which seems to appear in connection with scrambled data from the gateway (during the gateway startup). If you press the dis- and connect-button a few times once the error appears, all pending messages will be processed and the controller should resume.
                                        • tekkaT
                                          tekkaT
                                          tekka
                                          New version available with bug fixes 0.1.2.256:
                                          • "File not open" error fixed
                                          • Display errors fixed
                                          • Mac users: use wine to run program, no remapping of serial ports necessary - use e.g. /dev/ttyUSB0 in config window
                                          To update hit the update button or download here.
                                          AWIA S 2 Replies Last reply
