  2. Announcements
  3. 💬 Relay
💬 Relay
139 Posts 47 Posters 82.3k Views 45 Watching
    Agreed, set you sensors to higher ID numbers like 20 or 30 and you are good to go .
    • L
      L
      lekeb
      ok thanks a lot I will try this night
      • L
        L
        lekeb
        perfect it works great. I started my temperature sensor at CHILD ID 4 and let relays from 1 to 2. I had to add also "DS_First_Child_ID" in the sent message to gateway.
        thanks
        • pepsonP
          pepsonP
          pepson
          Hi
          Please put to this topic code your sketch....
          • L
            L
            lekeb
            Sur,
            my node controls two relays, one water pressure sensor and three DS18b20
             code pour controle cave a vin, temp et pression
            #define MY_REPEATER_FEATURE
            #define MY_NODE_ID 15
            #include <OneWire.h>
            #define BARO_CHILD 0 //Child ID for pressure sensor
            #define BAR_SENSOR_ANALOG_PIN 0 // pin for pressure sensor
            #define ONE_WIRE_BUS 5 // Pin where dallase sensor is connected
            #define RELAY_PIN 3 //pin for first relay
            #define NUMBER_OF_RELAYS 2
            int numSensors=0;
            bool receivedConfig = false;
            bool metric = true;
            float lastpression;
            uint8_t DS_First_Child_ID = 4; //First Child-ID to be used by Dallas Bus
            MyMessage msg(0,V_TEMP);
            void before()
                for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
                    pinMode(pin, OUTPUT);
              sensors.begin();
                sendSketchInfo("Buanderie node", "1.0");
                //present pressure sensor
                present(BARO_CHILD, S_BARO);
                    present(sensor, S_BINARY);
                 present(i + DS_First_Child_ID, S_TEMP);
              //read water pressure
            int lecture_adc = analogRead(BAR_SENSOR_ANALOG_PIN);
              float pression = ((lecture_adc*5/1024.0)-0.50)/1.7;
              if(pression != lastpression) {
                  send(pressureMsg.set(pression, 2));
              lastpression = pression;
              sleep(conversionTime);
                #if COMPARE_TEMP == 1
                  send(msg.setSensor(i + DS_First_Child_ID).set(temperature,1));
                if (message.type==V_STATUS) {
                    // Change relay state
                    digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                    // Store state in eeprom
            gohanG 1 Reply Last reply
            • L lekeb
              Sur,
              int numSensors=0;
              bool metric = true;
              float lastpression;
              void before()
                sensors.begin();
              @lekeb said in 💬 Relay:
              Why are you using the same child ID (since you set #define BARO_CHILD 0)?
              rejoe2R 1 Reply Last reply
                rejoe2R
                rejoe2R
                rejoe2
                @gohan Effectively, he will never report any temp reading under ChildID 0. Within presentation() and the send() commands, the "0" is replaced by "i + DS_First_Child_ID".
                But you are partly right, to avoid any misunderstandings wrt. that the statement could also be written as follows:
                MyMessage msg(DS_First_Child_ID,V_TEMP);
                • L
                  L
                  lekeb
                  correct, it makes sense. I will correct this error.
                  However Domoticz reads correctly the temperature and links correctly the CHILD ID's, so...
                  • Jonathan PucelJ
                    Jonathan PucelJ
                    Jonathan Pucel
                    Hello everybody !
                    I would like to creat a sensor with two relays and two buttons to command this relay direct from the sensor (with actualisation of their stat in domoticz)
                    Someone know the code to do this ? I'm a complete newbie on mysensor !
                    Thank's a lot !
                    • Jonathan PucelJ Jonathan Pucel
                      Hello everybody !
                      Thank's a lot !
                      rejoe2R
                      rejoe2R
                      rejoe2
                      @jonathan-pucel Have a look at the code in this post.
                      • Jonathan PucelJ
                        Jonathan PucelJ
                        Jonathan Pucel
                        Excellent ! It's perfect, thank's a lot rejoe2 !
                          mysz0n
                          • V
                            V
                            Vorace
                            Hi
                            Using Home assistant, and Optimistic set to false in the mysensors config, the switch in homeassistant would turn the relay on, but in the view in homeassistant the flip switch jumped off straight after switching on. It was solved by adding the following line to the sketch, ensuring that hassio knows that the actuator actually have received the command. Not sure if this is a good way of doing it, but it seems to work for me.
                            send(msg.set(state)); // Send new state and request ack back
                            in:
                            if (message.isAck()) {
                            state = message.getBool();
                            saveState(CHILD_ID, state);
                            • A
                              arraWX
                              wrote on last edited by arraWX
                              #118
                              Hi!
                              I would like to control some 230VAC equipment (for now roller shutters), based on inputs from my mysensors sensors (temperature and light). For controller I use domoticz.
                              I would like a safe, robust and preferably authorized/lawful solution (I'm in EU/Denmark).
                              I came across the following solutions:
                              https://aeotec.com/z-wave-plug-in-switch
                              https://sonoff.itead.cc/en/products/sonoff/sonoff-basic
                              https://dlidirect.com/products/iot-power-relay
                              I think the first one and maybe the second one will be authorized/lawful...? However, I have experience only with mysensors and neither z wave nor sonoff...
                              Anyone has some experience/thoughts/suggestions to share?
                                There are also roller shutters nodes running via zwave if you are looking at a retail solution
                                A 1 Reply Last reply
                                  arraWX
                                  #120
                                  Thank you @gohan! Retail solution is not the keyword here. What I am searching for is an authorized/lawful (safe) solution.
                                  I decided to do my own node (mysensors) with a cheap relay module for the arduino. Once I achieve the desired functionality I will change to some more robust hardware. Following your suggestion this could be a z wave roller shutter (e.g. fibaro or qubino).
                                  bjacobseB 1 Reply Last reply
                                  • A arraWX
                                    bjacobseB
                                    bjacobseB
                                    bjacobse
                                    @arrawx said in 💬 Relay:
                                    Sorry to comment negative, but your wording doesn't make sense. either you will go for a DIY solution, cheap and illegal (but not necessary a bad solution), or you will purchase a retail solution.
                                    Retail solution must have the required certificates to allow you to sell. Those are not cheap to get, which also provide the reason for a retail solution to
                                    be usually fairly expensive
                                    https://arbejdstilsynet.dk/da/regler/bekendtgorelser/i/sam-indretning-af-tekniske-hjaelpemidler-612
                                    And also you need Notified Body
                                    https://en.wikipedia.org/wiki/Notified_Body
                                    And I know that Cetekom can create certificate for Country Approvals
                                    https://www.cetecom.com/en/certification/country-appoval/
                                      slt1
                                      There is a problem with the example code for RelayActuator.ino It is not checking for ACK messages. See the other example called SecureActuator.ino that does this. Without checking for ACK messages my relay gets an ON signal and turns on then immediately thereafter gets an ACK signal for V_STATUS command which is assumed in this example to be a control and the value is "0" so it turns off the relay.
                                      • S slt1
                                        @slt1 I'm not sure I'm following. RelayActuator.ino does not send any messages, so it should never receive any ack messages. Compare with RelayWithButtonActuator.ino which does send messages, and therefore also checks for ack.
                                        Could you elaborate on the problem?
                                        S 1 Reply Last reply
                                          slt1
                                          wrote on last edited by slt1
                                          #124
                                          @mfalkvidd
                                          For some reason I am now unable to reproduce the issue on the standard RelayActuator.ino example. It was definitely sending ACK requests when I was testing a few days ago. I have subsequently updated MySensors library and also MyController to their latest Snapshot - so perhaps the issue comes up under one of those scenarios.
                                          The issue around this though is that the example does not report the current status of the relay in the loop. My own sketch was doing so. I guess many people take an example and modify it like I do. Therefore copying the example and adding in the code to send the current relay status periodically means the receive function will not work properly due to the Ack messages received,
                                          I would then suggest adding a note to the receive function of the relay example sketch to say that "if your node sends messages then you need to check for Ack and discard those messages" - or something along those lines. This will help !
                                          mfalkviddM 2 Replies Last reply
