  3. RFM69 new driver delay
67 Posts 10 Posters 17.7k Views 8 Watching
    If I got it right it is related to RPI3, on RPI2 it should work
    pepsonP
    pepsonP
    pepson
    @gohan
    From where you have this information?
    Is any chance to fix this problem?
      I was talking to @tekka some time ago about the issues I had on 2.3 alpha, I don't know what he did after that.
      pepsonP 1 Reply Last reply
        pepsonP
        pepsonP
        pepson
        @gohan
        And where we can send issue with this?
          github and if you attach the rfm69 verbose output both for gw and node
            pepsonP
            pepsonP
            pepson
            wrote on last edited by pepson
            @gohan
            But how I can download info from gateway and node?
            On github created issue but nothing replay from developers...
            • pepsonP pepson
              @gohan
              @pepson all core members are helping MySensors when they have free time. Quick replies can happen, but don't count on it. We have as many projects and as little time as you.
                pepsonP
                pepsonP
                pepson
                @mfalkvidd
                OK thanks
                  mickecarlsson
                  wrote on last edited by mickecarlsson
                  #23
                  I run mysgw 2.30 on a RPi 3 Model B and all nodes on 2.20 with RFM69:
                  cat /proc/cpuinfo
                  Hardware	: BCM2835
                  Revision	: a02082
                  I did a git pull then configured:
                  ./configure --my-transport=rfm69 --my-is-rfm69hw --my-rfm69-frequency=868
                  make
                  sudo make install
                  Note that I don't use LED's or specify gateway. My Controller is Domoticz
                  I then started the gateway with debug (note missing -d) (and the log is from today):
                  pi@mysensors-gw:~ $ sudo /usr/local/bin/mysgw
                  Jun 21 06:36:58 INFO  Starting gateway...
                  Jun 21 06:36:58 INFO  Protocol version - 2.3.0
                  Jun 21 06:36:58 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
                  Jun 21 06:36:58 DEBUG TSF:LRT:OK
                  Jun 21 06:36:58 DEBUG TSM:INIT
                  Jun 21 06:36:58 DEBUG TSF:WUR:MS=0
                  Jun 21 06:36:58 DEBUG TSM:INIT:TSP OK
                  Jun 21 06:36:58 DEBUG TSM:INIT:GW MODE
                  Jun 21 06:36:58 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                  Jun 21 06:36:58 DEBUG MCO:REG:NOT NEEDED
                  Jun 21 06:36:58 DEBUG Listening for connections on 0.0.0.0:5003
                  Jun 21 06:36:58 DEBUG MCO:BGN:STP
                  Jun 21 06:36:58 DEBUG MCO:BGN:INIT OK,TSP=1
                  Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;
                  Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;Get Version
                  Jun 21 06:37:20 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  Jun 21 06:37:30 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
                  Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.3
                  Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=2,c=1,t=1,pt=7,l=5,sg=0:48.0
                  After the debug check I pressed ctrl-c and started mysgw as a service
                  System has been running without any hickup since then.
                  If you check the commit 2175c993ef81b78527c85649f5bdc3585d2f41b2 you will notice that -d is removed and some other features has been added.
                  git log 2175c993ef81b78527c85649f5bdc3585d2f41b2
                  Author: Marcelo Aquino <marceloaqno@users.noreply.github.com>
                  Date:   Fri Mar 23 07:00:34 2018 -0300
                      Linux: Use config file for gateway settings (#1061)
                      - The following settings can be use on the config file:
                        - verbose=[debug,info,notice,warn,err] - Logging verbosity.
                        - log_file[0|1] - Enable logging to a file.
                        - log_filepath=(FILE) - Log file path.
                        - log_pipe=[0|1] - Enable logging to a named pipe(aka fifo).
                          Use this option to view your gateway's log messages from the
                          log_pipe_file (defined below).
                          To do so, run the following command on another terminal:
                          - $ cat "log_pipe_file"
                        - log_pipe_file=(FILE)
                        - syslog=[0|1] - Enable logging to syslog.
                        - eeprom_file=[/etc/mysensors.eeprom]
                        - eeprom_size=[1024]
                      - Change some mysgw parameters:
                        - Added:
                          - -q, --quiet:  for quiet mode, disable log messages written to the
                          terminal.
                        - Removed:
                          - -d, --debug: removed, log messages are now enabled by default.
                        - Replaced:
                          - -b, --background: replaced by --daemon
                      - isatty() is no longer used, log messages by default are printed to
                        stderr unless the gateway is started with --quiet (#1022)
                      - MY_LINUX_CONFIG_FILE: no longer holds the path to the eeprom file,
                        but to the configuration file
                  My nodes has these definitions (I don't use New Driver):
                  #define   MY_SPLASH_SCREEN_DISABLED
                  #define   MY_RADIO_RFM69
                  #define   MY_IS_RFM69HW
                  #define   MY_RFM69_FREQUENCY RFM69_868MHZ
                  • M mickecarlsson
                    cat /proc/cpuinfo
                    Hardware	: BCM2835
                    Revision	: a02082
                    make
                    sudo make install
                          - Added:
                            terminal.
                          - Removed:
                          - Replaced:
                    pepsonP
                    pepsonP
                    pepson
                    @mickecarlsson
                    Hi
                    But you run gateway on 2.3.0 and node on 2.2.0 without NEW DRIVER and it was working ?
                    Even though the gateway has a different version and nodes have a different ?
                    All people tell that gateway and nodes must have the same version ?
                      There have been versions in the past that were not backward compatible, but usually it is not necessary to have same version on gw and nodes
                        pepsonP
                        pepsonP
                        pepson
                        @gohan
                        Ok thanks
                        • pepsonP pepson
                          @mickecarlsson
                          Hi
                          mickecarlsson
                          @pepson
                          Yes, I run gateway 2.30 and nodes on 2.20 without new driver. No probems.
                          • pepsonP
                            pepsonP
                            pepson
                            Today i installed Gateway on RPI3 with version 2.3.0 but node has 2.2.0 with NEW_DRIVER and still is problem with communication.
                            After come back to home i test it with change version on node to 2.2.0 without NEW_DRIVER.
                            I give you and info...
                            But tell me on what RPI you have run gateway version 2.3.0 ?
                            I have RPI3 version B.
                              mickecarlsson
                              @mickecarlsson said in RFM69 new driver delay:
                              > cat /proc/cpuinfo
                              > Hardware	: BCM2835
                              > Revision	: a02082
                              Type as above and check the last entries, my RPi is revision a02082
                              Se here for more info:
                              Raspberry Pi revision codes
                              • M mickecarlsson
                                > cat /proc/cpuinfo
                                > Hardware	: BCM2835
                                > Revision	: a02082
                                pepsonP
                                pepsonP
                                pepson
                                #30
                                @mickecarlsson
                                It is the same hardware and rev.
                                Ok i done test...
                                On Gateway on RPI3 i have installed MySensors 2.3.0
                                On node i installed version 2.2.0
                                One with NEW_DRIVER. Communication with gateway sometimes is ok but still with problem lost communication.
                                Second test installed on node 2.2.0 without NEW_DRIVER and it no working. No communicate with gateway.
                                Not working NODE. Any reaction to control relay.
                                For me only all working when i have MySensors 2.2.0 also on Gateway and also on node with NEW DRIVER option.
                                #define RFM69_868MH
                                #define MY_RFM69_NEW_DRIVER
                                other
                                  mickecarlsson
                                  What kind of antenna do you have on the RPi for the radio? And what kind of antenna do you have on the node?
                                  • M mickecarlsson
                                    pepsonP
                                    pepsonP
                                    pepson
                                    @mickecarlsson
                                    I have a wire length if I remember 82mm.
                                      mickecarlsson
                                      Just a hunch, add 4 mm to it so that it is 86 mm instead..
                                      And the power supply for the RPi must be able to provide at leat 1.5 A at 5Volt. Dont go for a cheap powersupply, it wont cope with the power drain from the ROi.
                                      • M mickecarlsson
                                        pepsonP
                                        pepsonP
                                        pepson
                                        @mickecarlsson
                                        Hi
                                        my bug lenght antenna is 86mm. Sorry.
                                        Power for RPI is very good and original raspberry manufacturer provide about 2,5A
                                        After my tests only on MySensors 2.2.0 on Gateway and on Nodes 2.2.0 with NEW_DRIVER all works ok.
                                        In other like gateway 2.3.0 and node 2.2.0 or 2.3.0 with NEW_DRIVER or without NEW_DRIVER not working correct.
                                        • K
                                          K
                                          kimot
