  3. RFM69 new driver delay
67 Posts 10 Posters 17.7k Views 8 Watching
    github and if you attach the rfm69 verbose output both for gw and node
    pepsonP
    pepsonP
    pepson
    wrote on last edited by pepson
    @gohan
    But how I can download info from gateway and node?
    On github created issue but nothing replay from developers...
    • pepsonP pepson
      @gohan
      @pepson all core members are helping MySensors when they have free time. Quick replies can happen, but don't count on it. We have as many projects and as little time as you.
      pepsonP 1 Reply Last reply
        pepsonP
        pepsonP
        pepson
        @mfalkvidd
        OK thanks
          mickecarlsson
          wrote on last edited by mickecarlsson
          #23
          I run mysgw 2.30 on a RPi 3 Model B and all nodes on 2.20 with RFM69:
          cat /proc/cpuinfo
          Hardware	: BCM2835
          Revision	: a02082
          I did a git pull then configured:
          ./configure --my-transport=rfm69 --my-is-rfm69hw --my-rfm69-frequency=868
          make
          sudo make install
          Note that I don't use LED's or specify gateway. My Controller is Domoticz
          I then started the gateway with debug (note missing -d) (and the log is from today):
          pi@mysensors-gw:~ $ sudo /usr/local/bin/mysgw
          Jun 21 06:36:58 INFO  Starting gateway...
          Jun 21 06:36:58 INFO  Protocol version - 2.3.0
          Jun 21 06:36:58 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
          Jun 21 06:36:58 DEBUG TSF:LRT:OK
          Jun 21 06:36:58 DEBUG TSM:INIT
          Jun 21 06:36:58 DEBUG TSF:WUR:MS=0
          Jun 21 06:36:58 DEBUG TSM:INIT:TSP OK
          Jun 21 06:36:58 DEBUG TSM:INIT:GW MODE
          Jun 21 06:36:58 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
          Jun 21 06:36:58 DEBUG MCO:REG:NOT NEEDED
          Jun 21 06:36:58 DEBUG Listening for connections on 0.0.0.0:5003
          Jun 21 06:36:58 DEBUG MCO:BGN:STP
          Jun 21 06:36:58 DEBUG MCO:BGN:INIT OK,TSP=1
          Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;
          Jun 21 06:37:18 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;2;Get Version
          Jun 21 06:37:20 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
          Jun 21 06:37:30 DEBUG GWT:RFC:C=0,MSG=0;0;3;0;18;PING
          Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.3
          Jun 21 06:37:37 DEBUG TSF:MSG:READ,22-22-0,s=2,c=1,t=1,pt=7,l=5,sg=0:48.0
          After the debug check I pressed ctrl-c and started mysgw as a service
          System has been running without any hickup since then.
          If you check the commit 2175c993ef81b78527c85649f5bdc3585d2f41b2 you will notice that -d is removed and some other features has been added.
          git log 2175c993ef81b78527c85649f5bdc3585d2f41b2
          Author: Marcelo Aquino <marceloaqno@users.noreply.github.com>
          Date:   Fri Mar 23 07:00:34 2018 -0300
              Linux: Use config file for gateway settings (#1061)
              - The following settings can be use on the config file:
                - verbose=[debug,info,notice,warn,err] - Logging verbosity.
                - log_file[0|1] - Enable logging to a file.
                - log_filepath=(FILE) - Log file path.
                - log_pipe=[0|1] - Enable logging to a named pipe(aka fifo).
                  Use this option to view your gateway's log messages from the
                  log_pipe_file (defined below).
                  To do so, run the following command on another terminal:
                  - $ cat "log_pipe_file"
                - log_pipe_file=(FILE)
                - syslog=[0|1] - Enable logging to syslog.
                - eeprom_file=[/etc/mysensors.eeprom]
                - eeprom_size=[1024]
              - Change some mysgw parameters:
                - Added:
                  - -q, --quiet:  for quiet mode, disable log messages written to the
                  terminal.
                - Removed:
                  - -d, --debug: removed, log messages are now enabled by default.
                - Replaced:
                  - -b, --background: replaced by --daemon
              - isatty() is no longer used, log messages by default are printed to
                stderr unless the gateway is started with --quiet (#1022)
              - MY_LINUX_CONFIG_FILE: no longer holds the path to the eeprom file,
                but to the configuration file
          My nodes has these definitions (I don't use New Driver):
          #define   MY_SPLASH_SCREEN_DISABLED
          #define   MY_RADIO_RFM69
          #define   MY_IS_RFM69HW
          #define   MY_RFM69_FREQUENCY RFM69_868MHZ
          • M mickecarlsson
            cat /proc/cpuinfo
            Hardware	: BCM2835
            Revision	: a02082
            make
            sudo make install
                  - Added:
                    terminal.
                  - Removed:
                  - Replaced:
            pepsonP
            pepsonP
            pepson
            @mickecarlsson
            Hi
            But you run gateway on 2.3.0 and node on 2.2.0 without NEW DRIVER and it was working ?
            Even though the gateway has a different version and nodes have a different ?
            All people tell that gateway and nodes must have the same version ?
              There have been versions in the past that were not backward compatible, but usually it is not necessary to have same version on gw and nodes
                pepsonP
                pepsonP
                pepson
                @gohan
                Ok thanks
                • pepsonP pepson
                  @mickecarlsson
                  Hi
                  mickecarlsson
                  @pepson
                  Yes, I run gateway 2.30 and nodes on 2.20 without new driver. No probems.
                  • pepsonP
                    pepsonP
                    pepson
                    Today i installed Gateway on RPI3 with version 2.3.0 but node has 2.2.0 with NEW_DRIVER and still is problem with communication.
                    After come back to home i test it with change version on node to 2.2.0 without NEW_DRIVER.
                    I give you and info...
                    But tell me on what RPI you have run gateway version 2.3.0 ?
                    I have RPI3 version B.
                      mickecarlsson
                      @mickecarlsson said in RFM69 new driver delay:
                      > cat /proc/cpuinfo
                      > Hardware	: BCM2835
                      > Revision	: a02082
                      Type as above and check the last entries, my RPi is revision a02082
                      Se here for more info:
                      Raspberry Pi revision codes
                      • M mickecarlsson
                        > cat /proc/cpuinfo
                        > Hardware	: BCM2835
                        > Revision	: a02082
                        pepsonP
                        pepsonP
                        pepson
                        #30
                        @mickecarlsson
                        It is the same hardware and rev.
                        Ok i done test...
                        On Gateway on RPI3 i have installed MySensors 2.3.0
                        On node i installed version 2.2.0
                        One with NEW_DRIVER. Communication with gateway sometimes is ok but still with problem lost communication.
                        Second test installed on node 2.2.0 without NEW_DRIVER and it no working. No communicate with gateway.
                        Not working NODE. Any reaction to control relay.
                        For me only all working when i have MySensors 2.2.0 also on Gateway and also on node with NEW DRIVER option.
                        #define RFM69_868MH
                        #define MY_RFM69_NEW_DRIVER
                        other
                          mickecarlsson
                          What kind of antenna do you have on the RPi for the radio? And what kind of antenna do you have on the node?
                          • M mickecarlsson
                            pepsonP
                            pepsonP
                            pepson
                            @mickecarlsson
                            I have a wire length if I remember 82mm.
                              mickecarlsson
                              Just a hunch, add 4 mm to it so that it is 86 mm instead..
                              And the power supply for the RPi must be able to provide at leat 1.5 A at 5Volt. Dont go for a cheap powersupply, it wont cope with the power drain from the ROi.
                              • M mickecarlsson
                                pepsonP
                                pepsonP
                                pepson
                                @mickecarlsson
                                Hi
                                my bug lenght antenna is 86mm. Sorry.
                                Power for RPI is very good and original raspberry manufacturer provide about 2,5A
                                After my tests only on MySensors 2.2.0 on Gateway and on Nodes 2.2.0 with NEW_DRIVER all works ok.
                                In other like gateway 2.3.0 and node 2.2.0 or 2.3.0 with NEW_DRIVER or without NEW_DRIVER not working correct.
                                • K
                                  K
                                  kimot
                                  • pepsonP pepson
                                    @mickecarlsson
                                    Hi
                                    pepsonP
                                    pepsonP
                                    pepson
                                    @kimot
                                    I dont must use NEW_DRIVER, but when i write sketch to my node without option NEW_DRIVER, it no working. I tested some combination...mix. Gateway 2.3.0 or 2.2.0 with node 2.2.0 and 2.3.0 and Only with NEW_DRIVER works ok and only on 2.2.0 on node and gateway.
                                    This is my sketch.
                                    //#define MY_RFM69_FREQUENCY RFM69_868MHZ
                                    #define RFM69_868MH
                                    #define MY_REPEATER_FEATURE
                                    //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
                                    // uncomment if we want to manually assign an ID
                                    #define MY_NODE_ID 1
                                    #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
                                    #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
                                    //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
                                    //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
                                    //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
                                    #define RELAY_UP_PIN 5
                                    #define RELAY_DOWN_PIN 6
                                    #define RELAY_ON 0
                                    #define RELAY_OFF 1
                                    //#define RELAY_DOWN 1
                                    //#define RELAY_UP 0
                                    #define DIRECTION_DOWN 0
                                    #define DIRECTION_UP 1
                                    #define SKETCH_NAME "Roleta w sypialni"
                                    #define SKETCH_VER "2.2"
                                    #define CHILD_ID_COVER 0   // sensor Id of the sensor child
                                    #define STATE_UP 100 // 100 is open - up
                                    #define STATE_DOWN 0 // 0 is closed - down
                                    //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
                                    #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
                                    #define PRESENT_MESSAGE "Rolety dla Home Assistant"
                                    const int LEVELS = 100; //the number of levels
                                    float rollTime = 20.0; //the overall rolling time of the shutter
                                    const bool IS_ACK = false; //is to acknowlage
                                    static bool initial_state_sent = false;//for hass we need at list one state send at begining
                                    // debouncing parameters
                                    int value = 0;
                                    int oldValueUp = 0;
                                    int oldValueDown = 0;
                                    int oldValueStop = 0;
                                    //static unsigned long last_interrupt_time_up = 0;
                                    //static unsigned long last_interrupt_time_down = 0;
                                    //static unsigned long debounce_time = 200;
                                    Bounce debouncerUp = Bounce();
                                    Bounce debouncerDown = Bounce();
                                    Bounce debouncerStop = Bounce();
                                    // shutter position parameters
                                    float timeOneLevel = rollTime / LEVELS;
                                    int requestedShutterLevel = 0;
                                    int currentShutterLevel = 0;
                                    unsigned long lastLevelTime = 0;
                                    bool isMoving = false;
                                    int directionUpDown;
                                    bool calibrateDown;
                                    bool calibrateUp;
                                    unsigned long calibrationStartTime;
                                    float calibrationTime = 5.0;
                                    bool calibratedDown;
                                    bool calibratedUp;
                                    enum CoverState {
                                      STOP,
                                      UP, // Window covering. Up.
                                      DOWN, // Window covering. Down.
                                    static int coverState = STOP;
                                    MyMessage msgUp(CHILD_ID_COVER, V_UP);
                                    MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
                                    MyMessage msgStop(CHILD_ID_COVER, V_STOP);
                                    MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
                                    //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
                                    void sendState() {
                                      // Send current state and status to gateway.
                                    //  send(msgUp.set(coverState == UP));
                                    //  send(msgDown.set(coverState == DOWN));
                                    //  send(msgStop.set(coverState == STOP));
                                      send(msgPercentage.set(currentShutterLevel));
                                    void shuttersUp(void) {
                                      #ifdef MY_DEBUG
                                      Serial.println("Shutters going up");
                                      if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
                                        digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
                                        wait(50);
                                      digitalWrite(RELAY_UP_PIN, RELAY_ON);
                                      directionUpDown = DIRECTION_UP;
                                      isMoving = true;
                                      coverState = UP;
                                      sendState();
                                    void shuttersDown(void) {
                                      #ifdef MY_DEBUG
                                      Serial.println("Shutters going down");
                                      if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
                                        digitalWrite(RELAY_UP_PIN, RELAY_OFF);
                                        wait(50);
                                      digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
                                      directionUpDown = DIRECTION_DOWN;
                                      isMoving = true;
                                      coverState = DOWN;
                                      sendState();
                                    void shuttersHalt(void) {
                                    #ifdef MY_DEBUG
                                      Serial.println("Shutters halted");
                                      isMoving = false;
                                      requestedShutterLevel = currentShutterLevel;
                                    #ifdef MY_DEBUG
                                      Serial.println("saving state to: ");
                                      Serial.println(String(currentShutterLevel));
                                      saveState(CHILD_ID_COVER, currentShutterLevel);
                                      coverState = STOP;
                                      sendState();
                                    void changeShuttersLevel(int level) {
                                      int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
                                      if (isMoving && dir != directionUpDown) {
                                        shuttersHalt();
                                      requestedShutterLevel = level;
                                    void initShutters() {
                                    #ifdef MY_DEBUG
                                      Serial.println("Init Cover");
                                      shuttersUp();
                                      wait((rollTime + timeOneLevel * LEVELS) * 1000);
                                      currentShutterLevel = STATE_UP;
                                    #ifdef MY_DEBUG
                                      Serial.println("recieved incomming message");
                                      Serial.println("Recieved message for sensor: ");
                                      Serial.println(String(message.sensor));
                                      Serial.println("Recieved message with type: ");
                                      Serial.println(String(message.type));
                                      if (message.sensor == CHILD_ID_COVER) {
                                        switch (message.type) {
                                          case V_UP:
                                            //Serial.println(", New status: V_UP");
                                            changeShuttersLevel(STATE_UP);
                                            //state = UP;
                                            //sendState();
                                          case V_DOWN:
                                            //Serial.println(", New status: V_DOWN");
                                            changeShuttersLevel(STATE_DOWN);
                                            //state = DOWN;
                                            //sendState();
                                          case V_STOP:
                                            //Serial.println(", New status: V_STOP");
                                            shuttersHalt();
                                            //state = IDLE;
                                            //sendState();
                                          case V_PERCENTAGE:
                                            //Serial.println(", New status: V_PERCENTAGE");
                                            //          if (!initial_state_sent) {
                                            //            #ifdef MY_DEBUG
                                            //            Serial.println("Receiving initial value from controller");
                                            //            #endif
                                            //            initial_state_sent = true;
                                            int per = message.getInt();
                                            if (per > STATE_UP) {
                                              per = STATE_UP;
                                            changeShuttersLevel(per);
                                            //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
                                            //sendState();
                                    else if (message.sensor ==  CHILD_ID_SET) {
                                        if (message.type == V_VAR1) {
                                          #ifdef MY_DEBUG
                                          Serial.println(", New status: V_VAR1, with payload: ");
                                          String strRollTime = message.getString();
                                          rollTime = strRollTime.toFloat();
                                          #ifdef MY_DEBUG
                                          Serial.println("rolltime value: ");
                                          Serial.println(String(rollTime));
                                          saveState(CHILD_ID_SET, rollTime);
                                    #ifdef MY_DEBUG
                                      Serial.println("exiting incoming message");
                                      return;
                                    void before() {
                                      // Setup the button
                                      pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
                                      // Activate internal pull-up
                                    //  digitalWrite(BUTTON_UP_PIN, HIGH);
                                      //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
                                      pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
                                    //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
                                      //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
                                    //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
                                    //  digitalWrite(BUTTON_STOP_PIN, HIGH);
                                      debouncerUp.attach(BUTTON_UP_PIN);
                                      debouncerUp.interval(5);
                                      debouncerDown.attach(BUTTON_DOWN_PIN);
                                      debouncerDown.interval(5);
                                    //  debouncerStop.attach(BUTTON_STOP_PIN);
                                    //  debouncerStop.interval(5);
                                      pinMode(RELAY_UP_PIN, OUTPUT);
                                      pinMode(RELAY_DOWN_PIN, OUTPUT);
                                      sendSketchInfo(SKETCH_NAME, SKETCH_VER);
                                      present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
                                      // present(CHILD_ID_SET, S_CUSTOM);
                                    void setup(void) {
                                      //set up roll time if the saved value is not 255
                                      #ifdef MY_DEBUG
                                      Serial.println("getting rolltime from eeprom: ");
                                      float tmpRollTime = loadState(CHILD_ID_SET);
                                      if (tmpRollTime != 0xff) {
                                        rollTime = tmpRollTime;
                                      #ifdef MY_DEBUG
                                      int state = loadState(CHILD_ID_COVER);
                                      #ifdef MY_DEBUG
                                      Serial.println("getting state from eeprom: ");
                                      Serial.println(String(state));
                                    //  if (state == 0xff) {
                                    //    initShutters();
                                    //  } else {
                                        currentShutterLevel = state;
                                        requestedShutterLevel = state;
                                    void loop(void) {
                                    #ifdef MY_DEBUG
                                        Serial.println("Sending initial value");
                                        sendState();
                                       // send(msgCode.set('20.0'));
                                        //    #ifdef MY_DEBUG
                                        //    Serial.println("Requesting initial value from controller");
                                        //    #endif
                                        //    request(CHILD_ID_COVER, V_PERCENTAGE);
                                        //    wait(2000, C_SET, V_PERCENTAGE);
                                      debouncerUp.update();
                                      value = debouncerUp.read();
                                      if (value == 0 && value != oldValueUp) {
                                        if(isMoving){
                                          shuttersHalt();
                                        else{
                                        calibrateUp = false;
                                        calibratedUp = false;
                                        //state = UP;
                                        //sendState();
                                      oldValueUp = value;
                                      debouncerDown.update();
                                      value = debouncerDown.read();
                                      if (value == 0 && value != oldValueDown) {
                                        if(isMoving){
                                          shuttersHalt();
                                        else{
                                        calibrateDown = false;
                                        calibratedDown = false;
                                        //state = DOWN;
                                        //sendState();
                                      oldValueDown = value;
                                    /*  debouncerStop.update();
                                      value = debouncerStop.read();
                                      if (value == 0 && value != oldValueStop) {
                                        shuttersHalt();
                                        //state = IDLE;
                                        //sendState();
                                      oldValueStop = value;
                                      if(currentShutterLevel != 100)
                                      if(currentShutterLevel != 0)
                                      if (isMoving)
                                        unsigned long _now = millis();
                                        if (_now - lastLevelTime >= timeOneLevel * 1000) {
                                          if (directionUpDown == DIRECTION_UP) {
                                            currentShutterLevel += 1;
                                            currentShutterLevel -= 1;
                                          currentShutterLevel = constrain(currentShutterLevel, 0, 100);
                                          #ifdef MY_DEBUG
                                          Serial.println(String(requestedShutterLevel));
                                          lastLevelTime = millis();
                                        if (currentShutterLevel == requestedShutterLevel)
                                          if(currentShutterLevel == 0 && !calibratedDown)
                                            if(calibrateDown == false)
                                              calibrateDown = true;
                                              calibrationStartTime = _now;
                                              if(calibratedDown == false)
                                                if (_now - calibrationStartTime >= calibrationTime * 1000)
                                                 calibratedDown = true;
                                          else if (currentShutterLevel == 100 && !calibratedUp)
                                            if(calibrateUp == false)
                                              calibrateUp = true;
                                              if(calibratedUp == false)
                                                 calibratedUp = true;
                                            shuttersHalt();
                                        if (requestedShutterLevel != currentShutterLevel)
                                          if (requestedShutterLevel > currentShutterLevel) {
                                            shuttersUp();
                                          else {
                                            shuttersDown();
                                    • pepsonP pepson
                                      @kimot
                                      This is my sketch.
                                      #define RFM69_868MH
                                      #define RELAY_ON 0
                                      #define RELAY_OFF 1
                                      int value = 0;
                                      int oldValueUp = 0;
                                      bool calibrateDown;
                                      bool calibrateUp;
                                      bool calibratedUp;
                                      enum CoverState {
                                        STOP,
                                      void sendState() {
                                        #ifdef MY_DEBUG
                                          wait(50);
                                        isMoving = true;
                                        coverState = UP;
                                        sendState();
                                        #ifdef MY_DEBUG
                                          wait(50);
                                        isMoving = true;
                                        coverState = DOWN;
                                        sendState();
                                      #ifdef MY_DEBUG
                                        isMoving = false;
                                      #ifdef MY_DEBUG
                                        coverState = STOP;
                                        sendState();
                                          shuttersHalt();
                                      #ifdef MY_DEBUG
                                        shuttersUp();
                                      #ifdef MY_DEBUG
                                            case V_UP:
                                              //state = UP;
                                              //sendState();
                                            case V_DOWN:
                                              //state = DOWN;
                                              //sendState();
                                            case V_STOP:
                                              shuttersHalt();
                                              //state = IDLE;
                                              //sendState();
                                            case V_PERCENTAGE:
                                              //            #ifdef MY_DEBUG
                                              //            #endif
                                                per = STATE_UP;
                                              //sendState();
                                            #ifdef MY_DEBUG
                                            #ifdef MY_DEBUG
                                      #ifdef MY_DEBUG
                                        return;
                                      void before() {
                                        // Setup the button
                                      void setup(void) {
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                      //    initShutters();
                                      //  } else {
                                      void loop(void) {
                                      #ifdef MY_DEBUG
                                          sendState();
                                          //    #ifdef MY_DEBUG
                                          //    #endif
                                          if(isMoving){
                                            shuttersHalt();
                                          else{
                                          //state = UP;
                                          //sendState();
                                        oldValueUp = value;
                                          if(isMoving){
                                            shuttersHalt();
                                          else{
                                          //state = DOWN;
                                          //sendState();
                                          shuttersHalt();
                                          //state = IDLE;
                                          //sendState();
                                        if (isMoving)
                                            #ifdef MY_DEBUG
                                                calibrateUp = true;
                                              shuttersHalt();
                                              shuttersUp();
                                            else {
                                              shuttersDown();
                                      pepsonP
                                      pepsonP
                                      pepson
                                      And is any chance to run gateway on RPI3 but on old default driver not with NEW DRIVER ?
                                      Anybody has any solution for my problem with communication on version 2.3.0 ?
                                        mickecarlsson
                                        #38
                                        I just checked all my nodes:
                                        1. Garage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO, powered all times.
                                        2. Storage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO powered all times.
                                        3. Greenhouse - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                        4. Patio - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                        5. Bedroom - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                        6. Kitchen area - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                                        My nodes are within 40 meters from the gateway.
                                        I will no reprogram the node 4 and 5 to use the new driver to see if that makes any difference.
                                        Node 1 and 2 are the nodes farthest away from the gateway, there is one brick wall and three wood walls between the node and the gateway.
                                        • M mickecarlsson
                                          pepsonP
                                          pepsonP
                                          pepson
                                          #39
                                          @mickecarlsson
                                          Please also for all points give info what version MySensors use and if you can upload your sketches for all point.
                                          And Gateway has on RPI3 with version 2.3.0 ? By Serial or ethernet ? And tell me with what controller you use it ? I use with Home Assistant.
                                          And BTW tell me how long Arduino Mini Pro work for you on battery and what battery you use ... and show your project... Did you remove LED from Arduino to save power battery ?
                                          In Sketch you measure % power from battery ? And send to controller ? What controller you use ?
