  3. RFM69 new driver delay
67 Posts 10 Posters 17.7k Views 8 Watching
  • K
    K
    kimot
    • pepsonP pepson
      @mickecarlsson
      Hi
      my bug lenght antenna is 86mm. Sorry.
      Power for RPI is very good and original raspberry manufacturer provide about 2,5A
      After my tests only on MySensors 2.2.0 on Gateway and on Nodes 2.2.0 with NEW_DRIVER all works ok.
      In other like gateway 2.3.0 and node 2.2.0 or 2.3.0 with NEW_DRIVER or without NEW_DRIVER not working correct.
      pepsonP
      pepsonP
      pepson
      @kimot
      I dont must use NEW_DRIVER, but when i write sketch to my node without option NEW_DRIVER, it no working. I tested some combination...mix. Gateway 2.3.0 or 2.2.0 with node 2.2.0 and 2.3.0 and Only with NEW_DRIVER works ok and only on 2.2.0 on node and gateway.
      This is my sketch.
      #define MY_RADIO_RFM69
      #define MY_IS_RFM69HW
      //#define MY_RFM69_FREQUENCY RFM69_868MHZ
      #define RFM69_868MH
      #define MY_RFM69_NEW_DRIVER
      #define MY_REPEATER_FEATURE
      //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
      // uncomment if we want to manually assign an ID
      #define MY_NODE_ID 1
      #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
      #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
      //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
      //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
      //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
      #define RELAY_UP_PIN 5
      #define RELAY_DOWN_PIN 6
      #define RELAY_ON 0
      #define RELAY_OFF 1
      //#define RELAY_DOWN 1
      //#define RELAY_UP 0
      #define DIRECTION_DOWN 0
      #define DIRECTION_UP 1
      #define SKETCH_NAME "Roleta w sypialni"
      #define SKETCH_VER "2.2"
      #define CHILD_ID_COVER 0   // sensor Id of the sensor child
      #define STATE_UP 100 // 100 is open - up
      #define STATE_DOWN 0 // 0 is closed - down
      //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
      #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
      #define PRESENT_MESSAGE "Rolety dla Home Assistant"
      const int LEVELS = 100; //the number of levels
      float rollTime = 20.0; //the overall rolling time of the shutter
      const bool IS_ACK = false; //is to acknowlage
      static bool initial_state_sent = false;//for hass we need at list one state send at begining
      // debouncing parameters
      int value = 0;
      int oldValueUp = 0;
      int oldValueDown = 0;
      int oldValueStop = 0;
      //static unsigned long last_interrupt_time_up = 0;
      //static unsigned long last_interrupt_time_down = 0;
      //static unsigned long debounce_time = 200;
      Bounce debouncerUp = Bounce();
      Bounce debouncerDown = Bounce();
      Bounce debouncerStop = Bounce();
      // shutter position parameters
      float timeOneLevel = rollTime / LEVELS;
      int requestedShutterLevel = 0;
      int currentShutterLevel = 0;
      unsigned long lastLevelTime = 0;
      bool isMoving = false;
      int directionUpDown;
      bool calibrateDown;
      bool calibrateUp;
      unsigned long calibrationStartTime;
      float calibrationTime = 5.0;
      bool calibratedDown;
      bool calibratedUp;
      enum CoverState {
        STOP,
        UP, // Window covering. Up.
        DOWN, // Window covering. Down.
      static int coverState = STOP;
      MyMessage msgUp(CHILD_ID_COVER, V_UP);
      MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
      MyMessage msgStop(CHILD_ID_COVER, V_STOP);
      MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
      //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
      void sendState() {
        // Send current state and status to gateway.
      //  send(msgUp.set(coverState == UP));
      //  send(msgDown.set(coverState == DOWN));
      //  send(msgStop.set(coverState == STOP));
        send(msgPercentage.set(currentShutterLevel));
      void shuttersUp(void) {
        #ifdef MY_DEBUG
        Serial.println("Shutters going up");
        if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
          digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
          wait(50);
        digitalWrite(RELAY_UP_PIN, RELAY_ON);
        directionUpDown = DIRECTION_UP;
        isMoving = true;
        coverState = UP;
        sendState();
      void shuttersDown(void) {
        #ifdef MY_DEBUG
        Serial.println("Shutters going down");
        if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
          digitalWrite(RELAY_UP_PIN, RELAY_OFF);
          wait(50);
        digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
        directionUpDown = DIRECTION_DOWN;
        isMoving = true;
        coverState = DOWN;
        sendState();
      void shuttersHalt(void) {
      #ifdef MY_DEBUG
        Serial.println("Shutters halted");
        isMoving = false;
        requestedShutterLevel = currentShutterLevel;
      #ifdef MY_DEBUG
        Serial.println("saving state to: ");
        Serial.println(String(currentShutterLevel));
        saveState(CHILD_ID_COVER, currentShutterLevel);
        coverState = STOP;
        sendState();
      void changeShuttersLevel(int level) {
        int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
        if (isMoving && dir != directionUpDown) {
          shuttersHalt();
        requestedShutterLevel = level;
      void initShutters() {
      #ifdef MY_DEBUG
        Serial.println("Init Cover");
        shuttersUp();
        wait((rollTime + timeOneLevel * LEVELS) * 1000);
        currentShutterLevel = STATE_UP;
      #ifdef MY_DEBUG
        Serial.println("recieved incomming message");
        Serial.println("Recieved message for sensor: ");
        Serial.println(String(message.sensor));
        Serial.println("Recieved message with type: ");
        Serial.println(String(message.type));
        if (message.sensor == CHILD_ID_COVER) {
          switch (message.type) {
            case V_UP:
              //Serial.println(", New status: V_UP");
              changeShuttersLevel(STATE_UP);
              //state = UP;
              //sendState();
            case V_DOWN:
              //Serial.println(", New status: V_DOWN");
              changeShuttersLevel(STATE_DOWN);
              //state = DOWN;
              //sendState();
            case V_STOP:
              //Serial.println(", New status: V_STOP");
              shuttersHalt();
              //state = IDLE;
              //sendState();
            case V_PERCENTAGE:
              //Serial.println(", New status: V_PERCENTAGE");
              //          if (!initial_state_sent) {
              //            #ifdef MY_DEBUG
              //            Serial.println("Receiving initial value from controller");
              //            #endif
              //            initial_state_sent = true;
              int per = message.getInt();
              if (per > STATE_UP) {
                per = STATE_UP;
              changeShuttersLevel(per);
              //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
              //sendState();
      else if (message.sensor ==  CHILD_ID_SET) {
          if (message.type == V_VAR1) {
            #ifdef MY_DEBUG
            Serial.println(", New status: V_VAR1, with payload: ");
            String strRollTime = message.getString();
            rollTime = strRollTime.toFloat();
            #ifdef MY_DEBUG
            Serial.println("rolltime value: ");
            Serial.println(String(rollTime));
            saveState(CHILD_ID_SET, rollTime);
      #ifdef MY_DEBUG
        Serial.println("exiting incoming message");
        return;
      void before() {
        // Setup the button
        pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
        // Activate internal pull-up
      //  digitalWrite(BUTTON_UP_PIN, HIGH);
        //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
        pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
      //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
        //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
      //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
      //  digitalWrite(BUTTON_STOP_PIN, HIGH);
        debouncerUp.attach(BUTTON_UP_PIN);
        debouncerUp.interval(5);
        debouncerDown.attach(BUTTON_DOWN_PIN);
        debouncerDown.interval(5);
      //  debouncerStop.attach(BUTTON_STOP_PIN);
      //  debouncerStop.interval(5);
        pinMode(RELAY_UP_PIN, OUTPUT);
        pinMode(RELAY_DOWN_PIN, OUTPUT);
        sendSketchInfo(SKETCH_NAME, SKETCH_VER);
        present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
        // present(CHILD_ID_SET, S_CUSTOM);
      void setup(void) {
        //set up roll time if the saved value is not 255
        #ifdef MY_DEBUG
        Serial.println("getting rolltime from eeprom: ");
        float tmpRollTime = loadState(CHILD_ID_SET);
        if (tmpRollTime != 0xff) {
          rollTime = tmpRollTime;
        #ifdef MY_DEBUG
        int state = loadState(CHILD_ID_COVER);
        #ifdef MY_DEBUG
        Serial.println("getting state from eeprom: ");
        Serial.println(String(state));
      //  if (state == 0xff) {
      //    initShutters();
      //  } else {
          currentShutterLevel = state;
          requestedShutterLevel = state;
      void loop(void) {
      #ifdef MY_DEBUG
          Serial.println("Sending initial value");
          sendState();
         // send(msgCode.set('20.0'));
          //    #ifdef MY_DEBUG
          //    Serial.println("Requesting initial value from controller");
          //    #endif
          //    request(CHILD_ID_COVER, V_PERCENTAGE);
          //    wait(2000, C_SET, V_PERCENTAGE);
        debouncerUp.update();
        value = debouncerUp.read();
        if (value == 0 && value != oldValueUp) {
          if(isMoving){
            shuttersHalt();
          else{
          calibrateUp = false;
          calibratedUp = false;
          //state = UP;
          //sendState();
        oldValueUp = value;
        debouncerDown.update();
        value = debouncerDown.read();
        if (value == 0 && value != oldValueDown) {
          if(isMoving){
            shuttersHalt();
          else{
          calibrateDown = false;
          calibratedDown = false;
          //state = DOWN;
          //sendState();
        oldValueDown = value;
      /*  debouncerStop.update();
        value = debouncerStop.read();
        if (value == 0 && value != oldValueStop) {
          shuttersHalt();
          //state = IDLE;
          //sendState();
        oldValueStop = value;
        if(currentShutterLevel != 100)
        if(currentShutterLevel != 0)
        if (isMoving)
          unsigned long _now = millis();
          if (_now - lastLevelTime >= timeOneLevel * 1000) {
            if (directionUpDown == DIRECTION_UP) {
              currentShutterLevel += 1;
              currentShutterLevel -= 1;
            currentShutterLevel = constrain(currentShutterLevel, 0, 100);
            #ifdef MY_DEBUG
            Serial.println(String(requestedShutterLevel));
            lastLevelTime = millis();
          if (currentShutterLevel == requestedShutterLevel)
            if(currentShutterLevel == 0 && !calibratedDown)
              if(calibrateDown == false)
                calibrateDown = true;
                calibrationStartTime = _now;
                if(calibratedDown == false)
                  if (_now - calibrationStartTime >= calibrationTime * 1000)
                   calibratedDown = true;
            else if (currentShutterLevel == 100 && !calibratedUp)
              if(calibrateUp == false)
                calibrateUp = true;
                if(calibratedUp == false)
                   calibratedUp = true;
              shuttersHalt();
          if (requestedShutterLevel != currentShutterLevel)
            if (requestedShutterLevel > currentShutterLevel) {
              shuttersUp();
            else {
              shuttersDown();
      pepsonP 1 Reply Last reply
      • pepsonP pepson
        @kimot
        This is my sketch.
        #define RFM69_868MH
        #define RELAY_ON 0
        #define RELAY_OFF 1
        int value = 0;
        int oldValueUp = 0;
        bool calibrateDown;
        bool calibrateUp;
        bool calibratedUp;
        enum CoverState {
          STOP,
        void sendState() {
          #ifdef MY_DEBUG
            wait(50);
          isMoving = true;
          coverState = UP;
          sendState();
          #ifdef MY_DEBUG
            wait(50);
          isMoving = true;
          coverState = DOWN;
          sendState();
        #ifdef MY_DEBUG
          isMoving = false;
        #ifdef MY_DEBUG
          coverState = STOP;
          sendState();
            shuttersHalt();
        #ifdef MY_DEBUG
          shuttersUp();
        #ifdef MY_DEBUG
              case V_UP:
                //state = UP;
                //sendState();
              case V_DOWN:
                //state = DOWN;
                //sendState();
              case V_STOP:
                shuttersHalt();
                //state = IDLE;
                //sendState();
              case V_PERCENTAGE:
                //            #ifdef MY_DEBUG
                //            #endif
                  per = STATE_UP;
                //sendState();
              #ifdef MY_DEBUG
              #ifdef MY_DEBUG
        #ifdef MY_DEBUG
          return;
        void before() {
          // Setup the button
        void setup(void) {
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
          #ifdef MY_DEBUG
        //    initShutters();
        //  } else {
        void loop(void) {
        #ifdef MY_DEBUG
            sendState();
            //    #ifdef MY_DEBUG
            //    #endif
            if(isMoving){
              shuttersHalt();
            else{
            //state = UP;
            //sendState();
          oldValueUp = value;
            if(isMoving){
              shuttersHalt();
            else{
            //state = DOWN;
            //sendState();
            shuttersHalt();
            //state = IDLE;
            //sendState();
          if (isMoving)
              #ifdef MY_DEBUG
                  calibrateUp = true;
                shuttersHalt();
                shuttersUp();
              else {
                shuttersDown();
        pepsonP
        pepsonP
        pepson
        And is any chance to run gateway on RPI3 but on old default driver not with NEW DRIVER ?
        Anybody has any solution for my problem with communication on version 2.3.0 ?
          mickecarlsson
          wrote on last edited by mickecarlsson
          #38
          I just checked all my nodes:
          1. Garage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO, powered all times.
          2. Storage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO powered all times.
          3. Greenhouse - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
          4. Patio - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
          5. Bedroom - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
          6. Kitchen area - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
          My nodes are within 40 meters from the gateway.
          I will no reprogram the node 4 and 5 to use the new driver to see if that makes any difference.
          Node 1 and 2 are the nodes farthest away from the gateway, there is one brick wall and three wood walls between the node and the gateway.
          • M mickecarlsson
            pepsonP
            pepsonP
            pepson
            wrote on last edited by pepson
            #39
            @mickecarlsson
            Please also for all points give info what version MySensors use and if you can upload your sketches for all point.
            And Gateway has on RPI3 with version 2.3.0 ? By Serial or ethernet ? And tell me with what controller you use it ? I use with Home Assistant.
            And BTW tell me how long Arduino Mini Pro work for you on battery and what battery you use ... and show your project... Did you remove LED from Arduino to save power battery ?
            In Sketch you measure % power from battery ? And send to controller ? What controller you use ?
              #40
              @pepson @mickecarlsson
              in theory, if I remember well, length of antenna should be:
              • 86mm for 868mhz
              • 82mm for 915Mhz
                Better check which frequency you can use where you live.
              Also this is in ideal world, it depends on:
              • antenna material
              • gnd plane size
              • etc
              So when you want to tune your network, you could use a good, 868mhz for example, antenna on gateway (from a reliable supplier, as there are also a lot of unmatched antenna around).
              Then you can try to tune emprically, by checking rssi vs length. Add length or cut, and check. If you need more or less length is dependant on above factors.
              As already said, we don't recommand mixing new driver with older.. As packet has not the same format.
              No eta for fixing rfm69 if issues, too busy for the moment, but we'll try asap.
              • scalzS scalz
                • 86mm for 868mhz
                • 82mm for 915Mhz
                • antenna material
                • gnd plane size
                • etc
                pepsonP
                pepsonP
                pepson
                @scalz said in RFM69 new driver delay:
                Yes i have for my radio anntena 86mm.
                On nodes and gateway i am sure that i use freq 868MHz.
                Look on my command to build gateway and on my sketches node.
                On version 2.2.0 i use gateway (as people write by my command i use NEW DRIVER) and also on node also use NEW DRIVER and in this solution all works perfect with no problem.
                When i update gateway and node to 2.3.0 also with NEW DRIVER i have a problem that controll node and connection is no stabilish. In my Home Assistant sometimes i can controll relay but sometimes no reaction on click by Home Assistant. When use on node old driver (but on gateway NEW DRIVER) it is no working. Only on version 2.2.0 on gatewy and node all works perfect.
                Is any chance to build gateway on RPI3 with old driver to RFM69HW ? Because as people write in default building on gateway on RPI3 use NEW DRIVER and we can not change it.... It is true ?
                  #42
                  @pepson
                  My comments about tuning antenna were general, it can be useful for optimizing your network.
                  I already read what you said previously ;) It should be normal that new&old driver not working together (unless a recent change..).
                  We'll take a look at which changes are incorrect. I'm using experimental local mysensors version, so I'm a bit off topic regarding official release and no time for debugging, for the moment, as like I said we'll try to check that asap.
                  Regarding RPI, I'm not using it as gw (I prefer a lower power gw that i can place where i want) so I'm not sure. Take it with a pinch of salt but if i remember, old rfm69 driver spi functions etc are not adapted to linux (whereas new driver is)
                  If 2.3 is blocking, do you need a particular fix in 2.3 ? Else you could stick to 2.2
                    mickecarlsson
                    #43
                    OK,
                    Here goes what I have:
                    Arduino Pro Mini, chinese clones. Regulator and led removed. Soldered on EasyPCB rev 9.
                    Radio is RFM69 868 MHz with helicoil antenna on the nodes, 86 mm antenna on the Gateway
                    Bootloader is from https://github.com/MCUdude/MiniCore
                    The bootloader settings are:
                    Board: ATmega328
                    Bootloader: Yes
                    Variant: 328P / 328PA
                    BOD: 1.8v
                    Clock: 1MHz internal
                    Compiler LTO: Disabled (default)
                    On the EasyPCB I have only soldered the radio, the antenna and the Arduino. No booster, no capacitors, no resistors.
                    I have put a link on the REG and run the node on two AA batteries.
                    The nodes only have one sensor, the BME280.
                    The controller I use is Domoticz, latest version (I think).
                    I have now reprogrammed some of the nodes to 2.30 and I use NEW_DRIVER.
                    Gateway - 2.3.0
                    Patio - 2.3.0
                    Test-node - 2.3.0
                    Kitchen - 2.3.0
                    Bedroom - 2.3.0
                    UV and LUX - 2.3.0
                    No problems at all.
                    However, I do not use the receive() function on my nodes.
                    And I see that you use the REPEATER setting, if your node can reach the gateway the disable repeater.
                    • M mickecarlsson
                      OK,
                      Board: ATmega328
                      Bootloader: Yes
                      BOD: 1.8v
                      Gateway - 2.3.0
                      Patio - 2.3.0
                      Test-node - 2.3.0
                      Kitchen - 2.3.0
                      Bedroom - 2.3.0
                      UV and LUX - 2.3.0
                      No problems at all.
                      pepsonP
                      pepsonP
                      pepson
                      #44
                      @mickecarlsson
                      Tell me for what you change bootloader ? And i also have clone chine arduino pro mini... I also must change bootloader on this Arduino Pro Mini CLONE CHINA ? Because i dont change bootloader after buy...
                      And if you can show also your antenna...and where you buy this antenna ? I try found on Aliexpres but not found.
                      But i can not use REPEATER function to to increase the range from the gate - something like the MESH network ?
                      And is any chance to you test my SKETCH with relay on your arduino ?
                        mickecarlsson
                        You don't ned to change bootloader, I do because I run on battery and it fits my need.
                        I can't test your sketch as I don't have the necessary hardware to test it.
                        How far apart are your nodes?
                        My antenna is from AliExpress
                        • M mickecarlsson
                          pepsonP
                          pepsonP
                          pepson
                          #46
                          @mickecarlsson
                          Now my node is very near my Gateway about 6meters. Because now i project my automation in my new home.
                          But if you only have Arduino Pro Mini with Radio RFM69HW you can test my sketch. I think that you dont need 2xrelay to test it... Please...
                          But for what is function REPEATER ? To increase range from Gateway to very far node ? Then the node with the repeater function extends the range?
                          When come back to home i try build node without option REPEATER and try run this...
                          Also can you give on priv info how upload this bootloader ? I can only write by ArduinoIDE or i must do other actions ?
                            mickecarlsson
                            You only need repeater fi you have a node far away that can’t reach the gateway, then you add repeater on a node nearer the gateway.
                            See here: MySensors Network
                            And if the node has repeater defined it must allways have power and no Sleep.
                            Sorry, I can’t test the sketch.
                            pepsonP 3 Replies Last reply
                            • M mickecarlsson
                              pepsonP
                              pepsonP
                              pepson
                              #48
                              @mickecarlsson
                              Can you share me your all sketches ? Thanks
                              And tell me how you have connected Gateway to RPI3? By ethernet or by serial ? Because i see in your building Gateway that you dont use parameter ETHERNET on port 5003
                              And anybody has any contact to developer @tekka007 ?
                              This is info what show in debug on version 2.3.0 gateway and also node on version 2.3.0
                              pi@hassbian:~/MySensors $ sudo /usr/local/bin/mysgw
                              Jun 22 17:22:49 INFO  Starting gateway...
                              Jun 22 17:22:49 INFO  Protocol version - 2.3.0
                              Jun 22 17:22:49 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
                              Jun 22 17:22:49 DEBUG TSF:LRT:OK
                              Jun 22 17:22:49 DEBUG TSM:INIT
                              Jun 22 17:22:49 DEBUG TSF:WUR:MS=0
                              Jun 22 17:22:49 DEBUG TSM:INIT:TSP OK
                              Jun 22 17:22:49 DEBUG TSM:INIT:GW MODE
                              Jun 22 17:22:49 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                              Jun 22 17:22:49 DEBUG MCO:REG:NOT NEEDED
                              Jun 22 17:22:49 DEBUG Listening for connections on 0.0.0.0:5003
                              Jun 22 17:22:49 DEBUG MCO:BGN:STP
                              Jun 22 17:22:49 DEBUG MCO:BGN:INIT OK,TSP=1
                              Jun 22 17:22:54 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                              Jun 22 17:22:54 DEBUG TSF:MSG:BC
                              Jun 22 17:22:54 DEBUG TSF:MSG:FPAR REQ,ID=2
                              Jun 22 17:22:54 DEBUG TSF:CKU:OK,FCTRL
                              Jun 22 17:22:54 DEBUG TSF:MSG:GWL OK
                              Jun 22 17:22:54 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=O                 K:0
                              Jun 22 17:22:56 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              Jun 22 17:22:56 DEBUG TSF:MSG:PINGED,ID=2,HP=1
                              Jun 22 17:22:57 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=                 OK:1
                              Jun 22 17:22:57 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                              Jun 22 17:22:58 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=                 OK:0100
                              Jun 22 17:22:59 DEBUG TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                              Jun 22 17:23:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=25,sg=0:1xRelay &                  Button-Sypialni
                              Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=5,sg=0:2.2.0
                              Jun 22 17:23:04 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                              Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                              Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                              Jun 22 17:23:06 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                              Jun 22 17:23:07 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                              Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                              Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                              Jun 22 17:23:09 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                              • M mickecarlsson
                                pepsonP
                                pepsonP
                                pepson
                                @mickecarlsson I done next test.
                                Updated my Gateway on RPI3 to 2.3.0
                                Then also update my nodes to 2.3.0
                                One node which i use is to control Switch Relay. It works ok also with Repeater function and also without Repeater function.
                                Second node is to control cover by relay. It no working correct also with Reapeater and also without Repeater function. Status is not update in the same time. Sometimes no respod reaction on click button.
                                Below i see SWITCH releay SKETCH and also to Cover.
                                Please help me.
                                Also i need help to convert this sketch for Switch 1xRelay to Switch 2x Releay. ANybody can help me. ?
                                   Relay with button sketch
                                #define RFM69_868MH
                                #define MY_NODE_ID 2                       // Node id defaults to AUTO (tries to fetch id from controller)
                                #define RELAY_ON 0
                                #define RELAY_OFF 1
                                Bounce debouncer = Bounce();
                                int oldValue = 0;
                                bool uplinkAvailable = true;
                                bool state = false;
                                bool requestState;
                                bool firstStart = true;
                                unsigned long oldTime = 0;
                                unsigned long newTime = 0;
                                void setup(){
                                  debouncer.interval(5);
                                  send(msg.set(RELAY_OFF), false);           // notify controller to show off state
                                  sendSketchInfo("1xRelay & Button-Sypialnia", "2.2.0");
                                  present(CHILD_ID, S_BINARY);
                                void loop(){
                                      uplinkCheckTime = millis();
                                     else{
                                      Serial.println(requestState);
                                  debouncer.update();
                                    requestTime();
                                      oldTime = newTime;
                                  oldValue = value;
                                        send(msg.set(state));
                                void uplinkCheck() {
                                    requestTime();
                                      oldTime = newTime;
                                  if (firstStart){
                                    oldTime = time;
                                    newTime = time;
                                  else{
                                  newTime = time;
                                  Serial.println(time);
                                • pepsonP pepson
                                  Please help me.
                                  #define RFM69_868MH
                                  #define RELAY_ON 0
                                  #define RELAY_OFF 1
                                  int oldValue = 0;
                                  bool state = false;
                                  bool requestState;
                                  void setup(){
                                  void loop(){
                                       else{
                                    debouncer.update();
                                      requestTime();
                                        oldTime = newTime;
                                    oldValue = value;
                                      requestTime();
                                        oldTime = newTime;
                                    if (firstStart){
                                      oldTime = time;
                                      newTime = time;
                                    else{
                                    newTime = time;
                                  pepsonP
                                  pepsonP
                                  pepson
                                  #define RFM69_868MH
                                  #define RELAY_ON 0
                                  #define RELAY_OFF 1
                                  #define SKETCH_VER "2.3"
                                  int value = 0;
                                  int oldValueUp = 0;
                                  bool calibrateDown;
                                  bool calibrateUp;
                                  bool calibratedUp;
                                  enum CoverState {
                                    STOP,
                                  void sendState() {
                                    #ifdef MY_DEBUG
                                      wait(50);
                                    isMoving = true;
                                    coverState = UP;
                                    sendState();
                                    #ifdef MY_DEBUG
                                      wait(50);
                                    isMoving = true;
                                    coverState = DOWN;
                                    sendState();
                                  #ifdef MY_DEBUG
                                    isMoving = false;
                                  #ifdef MY_DEBUG
                                    coverState = STOP;
                                    sendState();
                                      shuttersHalt();
                                  #ifdef MY_DEBUG
                                    shuttersUp();
                                  #ifdef MY_DEBUG
                                        case V_UP:
                                          //state = UP;
                                          //sendState();
                                        case V_DOWN:
                                          //state = DOWN;
                                          //sendState();
                                        case V_STOP:
                                          shuttersHalt();
                                          //state = IDLE;
                                          //sendState();
                                        case V_PERCENTAGE:
                                          //            #ifdef MY_DEBUG
                                          //            #endif
                                            per = STATE_UP;
                                          //sendState();
                                        #ifdef MY_DEBUG
                                        #ifdef MY_DEBUG
                                  #ifdef MY_DEBUG
                                    return;
                                  void before() {
                                    // Setup the button
                                  void setup(void) {
                                    #ifdef MY_DEBUG
                                    #ifdef MY_DEBUG
                                    #ifdef MY_DEBUG
                                  //    initShutters();
                                  //  } else {
                                  void loop(void) {
                                  #ifdef MY_DEBUG
                                      sendState();
                                      //    #ifdef MY_DEBUG
                                      //    #endif
                                      if(isMoving){
                                        shuttersHalt();
                                      else{
                                      //state = UP;
                                      //sendState();
                                    oldValueUp = value;
                                      if(isMoving){
                                        shuttersHalt();
                                      else{
                                      //state = DOWN;
                                      //sendState();
                                      shuttersHalt();
                                      //state = IDLE;
                                      //sendState();
                                    if (isMoving)
                                        #ifdef MY_DEBUG
                                            calibrateUp = true;
                                          shuttersHalt();
                                          shuttersUp();
                                        else {
                                          shuttersDown();
                                  • pepsonP pepson
                                    #define RFM69_868MH
                                    #define RELAY_ON 0
                                    #define RELAY_OFF 1
                                    int value = 0;
                                    int oldValueUp = 0;
                                    bool calibrateDown;
                                    bool calibrateUp;
                                    bool calibratedUp;
                                    enum CoverState {
                                      STOP,
                                    void sendState() {
                                      #ifdef MY_DEBUG
                                        wait(50);
                                      isMoving = true;
                                      coverState = UP;
                                      sendState();
                                      #ifdef MY_DEBUG
                                        wait(50);
                                      isMoving = true;
                                      coverState = DOWN;
                                      sendState();
                                    #ifdef MY_DEBUG
                                      isMoving = false;
                                    #ifdef MY_DEBUG
                                      coverState = STOP;
                                      sendState();
                                        shuttersHalt();
                                    #ifdef MY_DEBUG
                                      shuttersUp();
                                    #ifdef MY_DEBUG
                                          case V_UP:
                                            //state = UP;
                                            //sendState();
                                          case V_DOWN:
                                            //state = DOWN;
                                            //sendState();
                                          case V_STOP:
                                            shuttersHalt();
                                            //state = IDLE;
                                            //sendState();
                                          case V_PERCENTAGE:
                                            //            #ifdef MY_DEBUG
                                            //            #endif
                                              per = STATE_UP;
                                            //sendState();
                                          #ifdef MY_DEBUG
                                          #ifdef MY_DEBUG
                                    #ifdef MY_DEBUG
                                      return;
                                    void before() {
                                      // Setup the button
                                    void setup(void) {
                                      #ifdef MY_DEBUG
                                      #ifdef MY_DEBUG
                                      #ifdef MY_DEBUG
                                    //    initShutters();
                                    //  } else {
                                    void loop(void) {
                                    #ifdef MY_DEBUG
                                        sendState();
                                        //    #ifdef MY_DEBUG
                                        //    #endif
                                        if(isMoving){
                                          shuttersHalt();
                                        else{
                                        //state = UP;
                                        //sendState();
                                      oldValueUp = value;
                                        if(isMoving){
                                          shuttersHalt();
                                        else{
                                        //state = DOWN;
                                        //sendState();
                                        shuttersHalt();
                                        //state = IDLE;
                                        //sendState();
                                      if (isMoving)
                                          #ifdef MY_DEBUG
                                              calibrateUp = true;
                                            shuttersHalt();
                                            shuttersUp();
                                          else {
                                            shuttersDown();
                                    pepsonP
                                    pepsonP
                                    pepson
                                    Finally
                                    In my opinion on MySensors 2.2.0 all my sketches (switch relay and cover ) works better. With no problem. NO PROBLEM.
                                    Cover works perfect and switch works perfect without any timeout and delay. ANd all node works without REPEATER.
                                    My opinion is that in version 2.3.0 something not working correct with radio RFM69HW.
                                    Maybe for sensors which send data from time to time is ok , but for cover which transfer data when cover is roll, it is problem... and gateway can not recived all data when node send position cover. Maybe developer read this thread and can do any changes to correct it.
                                    scalzS S 2 Replies Last reply
                                    • M mickecarlsson
                                      pepsonP
                                      pepsonP
                                      pepson
                                      @mickecarlsson
                                      ANd tell me how you connect Gateway to your Domoticz Controller ? What path to usb or serial you setup in Domoticz ?
                                      • pepsonP pepson
                                        Finally
                                        #53
                                        @pepson said in RFM69 new driver delay:
                                        Like I said, we will take a look as soon as we get time. For the moment, busy (at least on my side). And we're a few, using rfm69.
                                        So if 2.2 fixes your issue, it can be a good idea.
                                        • scalzS scalz
                                          pepsonP
                                          pepsonP
                                          pepson
                                          @scalz
                                          Ok thanks. WAiting for info... and good info for me will be that problem with RFM69HW on version 2.3.0 will be resolve and i can update to this version. Now i must come back to version 2.2.0
