  3. RFM69 new driver delay
67 Posts 10 Posters 17.7k Views 8 Watching
    mickecarlsson
    @mickecarlsson said in RFM69 new driver delay:
    > cat /proc/cpuinfo
    > Hardware	: BCM2835
    > Revision	: a02082
    Type as above and check the last entries, my RPi is revision a02082
    Se here for more info:
    Raspberry Pi revision codes
    pepsonP 1 Reply Last reply
    • M mickecarlsson
      > cat /proc/cpuinfo
      > Hardware	: BCM2835
      > Revision	: a02082
      pepsonP
      pepsonP
      pepson
      wrote on last edited by pepson
      #30
      @mickecarlsson
      It is the same hardware and rev.
      Ok i done test...
      On Gateway on RPI3 i have installed MySensors 2.3.0
      On node i installed version 2.2.0
      One with NEW_DRIVER. Communication with gateway sometimes is ok but still with problem lost communication.
      Second test installed on node 2.2.0 without NEW_DRIVER and it no working. No communicate with gateway.
      Not working NODE. Any reaction to control relay.
      For me only all working when i have MySensors 2.2.0 also on Gateway and also on node with NEW DRIVER option.
      #define MY_RADIO_RFM69
      #define MY_IS_RFM69HW
      #define RFM69_868MH
      #define MY_RFM69_NEW_DRIVER
      other
      #define MY_RFM69_FREQUENCY RFM69_868MHZ
        mickecarlsson
        What kind of antenna do you have on the RPi for the radio? And what kind of antenna do you have on the node?
        • M mickecarlsson
          pepsonP
          pepsonP
          pepson
          @mickecarlsson
          I have a wire length if I remember 82mm.
            mickecarlsson
            Just a hunch, add 4 mm to it so that it is 86 mm instead..
            And the power supply for the RPi must be able to provide at leat 1.5 A at 5Volt. Dont go for a cheap powersupply, it wont cope with the power drain from the ROi.
            • M mickecarlsson
              pepsonP
              pepsonP
              pepson
              @mickecarlsson
              Hi
              my bug lenght antenna is 86mm. Sorry.
              Power for RPI is very good and original raspberry manufacturer provide about 2,5A
              After my tests only on MySensors 2.2.0 on Gateway and on Nodes 2.2.0 with NEW_DRIVER all works ok.
              In other like gateway 2.3.0 and node 2.2.0 or 2.3.0 with NEW_DRIVER or without NEW_DRIVER not working correct.
              • K
                K
                kimot
                • pepsonP pepson
                  @mickecarlsson
                  Hi
                  pepsonP
                  pepsonP
                  pepson
                  @kimot
                  I dont must use NEW_DRIVER, but when i write sketch to my node without option NEW_DRIVER, it no working. I tested some combination...mix. Gateway 2.3.0 or 2.2.0 with node 2.2.0 and 2.3.0 and Only with NEW_DRIVER works ok and only on 2.2.0 on node and gateway.
                  This is my sketch.
                  //#define MY_RFM69_FREQUENCY RFM69_868MHZ
                  #define RFM69_868MH
                  #define MY_REPEATER_FEATURE
                  //#define MY_RFM69_CSMA_LIMIT_DBM (-85)
                  // uncomment if we want to manually assign an ID
                  #define MY_NODE_ID 1
                  #define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
                  #define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
                  //#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
                  //#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
                  //#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
                  #define RELAY_UP_PIN 5
                  #define RELAY_DOWN_PIN 6
                  #define RELAY_ON 0
                  #define RELAY_OFF 1
                  //#define RELAY_DOWN 1
                  //#define RELAY_UP 0
                  #define DIRECTION_DOWN 0
                  #define DIRECTION_UP 1
                  #define SKETCH_NAME "Roleta w sypialni"
                  #define SKETCH_VER "2.2"
                  #define CHILD_ID_COVER 0   // sensor Id of the sensor child
                  #define STATE_UP 100 // 100 is open - up
                  #define STATE_DOWN 0 // 0 is closed - down
                  //#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
                  #define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
                  #define PRESENT_MESSAGE "Rolety dla Home Assistant"
                  const int LEVELS = 100; //the number of levels
                  float rollTime = 20.0; //the overall rolling time of the shutter
                  const bool IS_ACK = false; //is to acknowlage
                  static bool initial_state_sent = false;//for hass we need at list one state send at begining
                  // debouncing parameters
                  int value = 0;
                  int oldValueUp = 0;
                  int oldValueDown = 0;
                  int oldValueStop = 0;
                  //static unsigned long last_interrupt_time_up = 0;
                  //static unsigned long last_interrupt_time_down = 0;
                  //static unsigned long debounce_time = 200;
                  Bounce debouncerUp = Bounce();
                  Bounce debouncerDown = Bounce();
                  Bounce debouncerStop = Bounce();
                  // shutter position parameters
                  float timeOneLevel = rollTime / LEVELS;
                  int requestedShutterLevel = 0;
                  int currentShutterLevel = 0;
                  unsigned long lastLevelTime = 0;
                  bool isMoving = false;
                  int directionUpDown;
                  bool calibrateDown;
                  bool calibrateUp;
                  unsigned long calibrationStartTime;
                  float calibrationTime = 5.0;
                  bool calibratedDown;
                  bool calibratedUp;
                  enum CoverState {
                    STOP,
                    UP, // Window covering. Up.
                    DOWN, // Window covering. Down.
                  static int coverState = STOP;
                  MyMessage msgUp(CHILD_ID_COVER, V_UP);
                  MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
                  MyMessage msgStop(CHILD_ID_COVER, V_STOP);
                  MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
                  //MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
                  void sendState() {
                    // Send current state and status to gateway.
                  //  send(msgUp.set(coverState == UP));
                  //  send(msgDown.set(coverState == DOWN));
                  //  send(msgStop.set(coverState == STOP));
                    send(msgPercentage.set(currentShutterLevel));
                  void shuttersUp(void) {
                    #ifdef MY_DEBUG
                    Serial.println("Shutters going up");
                    if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
                      digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
                      wait(50);
                    digitalWrite(RELAY_UP_PIN, RELAY_ON);
                    directionUpDown = DIRECTION_UP;
                    isMoving = true;
                    coverState = UP;
                    sendState();
                  void shuttersDown(void) {
                    #ifdef MY_DEBUG
                    Serial.println("Shutters going down");
                    if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
                      digitalWrite(RELAY_UP_PIN, RELAY_OFF);
                      wait(50);
                    digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
                    directionUpDown = DIRECTION_DOWN;
                    isMoving = true;
                    coverState = DOWN;
                    sendState();
                  void shuttersHalt(void) {
                  #ifdef MY_DEBUG
                    Serial.println("Shutters halted");
                    isMoving = false;
                    requestedShutterLevel = currentShutterLevel;
                  #ifdef MY_DEBUG
                    Serial.println("saving state to: ");
                    Serial.println(String(currentShutterLevel));
                    saveState(CHILD_ID_COVER, currentShutterLevel);
                    coverState = STOP;
                    sendState();
                  void changeShuttersLevel(int level) {
                    int dir = (level > currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
                    if (isMoving && dir != directionUpDown) {
                      shuttersHalt();
                    requestedShutterLevel = level;
                  void initShutters() {
                  #ifdef MY_DEBUG
                    Serial.println("Init Cover");
                    shuttersUp();
                    wait((rollTime + timeOneLevel * LEVELS) * 1000);
                    currentShutterLevel = STATE_UP;
                  #ifdef MY_DEBUG
                    Serial.println("recieved incomming message");
                    Serial.println("Recieved message for sensor: ");
                    Serial.println(String(message.sensor));
                    Serial.println("Recieved message with type: ");
                    Serial.println(String(message.type));
                    if (message.sensor == CHILD_ID_COVER) {
                      switch (message.type) {
                        case V_UP:
                          //Serial.println(", New status: V_UP");
                          changeShuttersLevel(STATE_UP);
                          //state = UP;
                          //sendState();
                        case V_DOWN:
                          //Serial.println(", New status: V_DOWN");
                          changeShuttersLevel(STATE_DOWN);
                          //state = DOWN;
                          //sendState();
                        case V_STOP:
                          //Serial.println(", New status: V_STOP");
                          shuttersHalt();
                          //state = IDLE;
                          //sendState();
                        case V_PERCENTAGE:
                          //Serial.println(", New status: V_PERCENTAGE");
                          //          if (!initial_state_sent) {
                          //            #ifdef MY_DEBUG
                          //            Serial.println("Receiving initial value from controller");
                          //            #endif
                          //            initial_state_sent = true;
                          int per = message.getInt();
                          if (per > STATE_UP) {
                            per = STATE_UP;
                          changeShuttersLevel(per);
                          //InitShutters(message.getInt());//send value < 0 or > 100 to calibrate
                          //sendState();
                  else if (message.sensor ==  CHILD_ID_SET) {
                      if (message.type == V_VAR1) {
                        #ifdef MY_DEBUG
                        Serial.println(", New status: V_VAR1, with payload: ");
                        String strRollTime = message.getString();
                        rollTime = strRollTime.toFloat();
                        #ifdef MY_DEBUG
                        Serial.println("rolltime value: ");
                        Serial.println(String(rollTime));
                        saveState(CHILD_ID_SET, rollTime);
                  #ifdef MY_DEBUG
                    Serial.println("exiting incoming message");
                    return;
                  void before() {
                    // Setup the button
                    pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
                    // Activate internal pull-up
                  //  digitalWrite(BUTTON_UP_PIN, HIGH);
                    //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
                    pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
                  //  digitalWrite(BUTTON_DOWN_PIN, HIGH);
                    //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
                  //  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
                  //  digitalWrite(BUTTON_STOP_PIN, HIGH);
                    debouncerUp.attach(BUTTON_UP_PIN);
                    debouncerUp.interval(5);
                    debouncerDown.attach(BUTTON_DOWN_PIN);
                    debouncerDown.interval(5);
                  //  debouncerStop.attach(BUTTON_STOP_PIN);
                  //  debouncerStop.interval(5);
                    pinMode(RELAY_UP_PIN, OUTPUT);
                    pinMode(RELAY_DOWN_PIN, OUTPUT);
                    sendSketchInfo(SKETCH_NAME, SKETCH_VER);
                    present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
                    // present(CHILD_ID_SET, S_CUSTOM);
                  void setup(void) {
                    //set up roll time if the saved value is not 255
                    #ifdef MY_DEBUG
                    Serial.println("getting rolltime from eeprom: ");
                    float tmpRollTime = loadState(CHILD_ID_SET);
                    if (tmpRollTime != 0xff) {
                      rollTime = tmpRollTime;
                    #ifdef MY_DEBUG
                    int state = loadState(CHILD_ID_COVER);
                    #ifdef MY_DEBUG
                    Serial.println("getting state from eeprom: ");
                    Serial.println(String(state));
                  //  if (state == 0xff) {
                  //    initShutters();
                  //  } else {
                      currentShutterLevel = state;
                      requestedShutterLevel = state;
                  void loop(void) {
                  #ifdef MY_DEBUG
                      Serial.println("Sending initial value");
                      sendState();
                     // send(msgCode.set('20.0'));
                      //    #ifdef MY_DEBUG
                      //    Serial.println("Requesting initial value from controller");
                      //    #endif
                      //    request(CHILD_ID_COVER, V_PERCENTAGE);
                      //    wait(2000, C_SET, V_PERCENTAGE);
                    debouncerUp.update();
                    value = debouncerUp.read();
                    if (value == 0 && value != oldValueUp) {
                      if(isMoving){
                        shuttersHalt();
                      else{
                      calibrateUp = false;
                      calibratedUp = false;
                      //state = UP;
                      //sendState();
                    oldValueUp = value;
                    debouncerDown.update();
                    value = debouncerDown.read();
                    if (value == 0 && value != oldValueDown) {
                      if(isMoving){
                        shuttersHalt();
                      else{
                      calibrateDown = false;
                      calibratedDown = false;
                      //state = DOWN;
                      //sendState();
                    oldValueDown = value;
                  /*  debouncerStop.update();
                    value = debouncerStop.read();
                    if (value == 0 && value != oldValueStop) {
                      shuttersHalt();
                      //state = IDLE;
                      //sendState();
                    oldValueStop = value;
                    if(currentShutterLevel != 100)
                    if(currentShutterLevel != 0)
                    if (isMoving)
                      unsigned long _now = millis();
                      if (_now - lastLevelTime >= timeOneLevel * 1000) {
                        if (directionUpDown == DIRECTION_UP) {
                          currentShutterLevel += 1;
                          currentShutterLevel -= 1;
                        currentShutterLevel = constrain(currentShutterLevel, 0, 100);
                        #ifdef MY_DEBUG
                        Serial.println(String(requestedShutterLevel));
                        lastLevelTime = millis();
                      if (currentShutterLevel == requestedShutterLevel)
                        if(currentShutterLevel == 0 && !calibratedDown)
                          if(calibrateDown == false)
                            calibrateDown = true;
                            calibrationStartTime = _now;
                            if(calibratedDown == false)
                              if (_now - calibrationStartTime >= calibrationTime * 1000)
                               calibratedDown = true;
                        else if (currentShutterLevel == 100 && !calibratedUp)
                          if(calibrateUp == false)
                            calibrateUp = true;
                            if(calibratedUp == false)
                               calibratedUp = true;
                          shuttersHalt();
                      if (requestedShutterLevel != currentShutterLevel)
                        if (requestedShutterLevel > currentShutterLevel) {
                          shuttersUp();
                        else {
                          shuttersDown();
                  • pepsonP pepson
                    @kimot
                    This is my sketch.
                    #define RFM69_868MH
                    #define RELAY_ON 0
                    #define RELAY_OFF 1
                    int value = 0;
                    int oldValueUp = 0;
                    bool calibrateDown;
                    bool calibrateUp;
                    bool calibratedUp;
                    enum CoverState {
                      STOP,
                    void sendState() {
                      #ifdef MY_DEBUG
                        wait(50);
                      isMoving = true;
                      coverState = UP;
                      sendState();
                      #ifdef MY_DEBUG
                        wait(50);
                      isMoving = true;
                      coverState = DOWN;
                      sendState();
                    #ifdef MY_DEBUG
                      isMoving = false;
                    #ifdef MY_DEBUG
                      coverState = STOP;
                      sendState();
                        shuttersHalt();
                    #ifdef MY_DEBUG
                      shuttersUp();
                    #ifdef MY_DEBUG
                          case V_UP:
                            //state = UP;
                            //sendState();
                          case V_DOWN:
                            //state = DOWN;
                            //sendState();
                          case V_STOP:
                            shuttersHalt();
                            //state = IDLE;
                            //sendState();
                          case V_PERCENTAGE:
                            //            #ifdef MY_DEBUG
                            //            #endif
                              per = STATE_UP;
                            //sendState();
                          #ifdef MY_DEBUG
                          #ifdef MY_DEBUG
                    #ifdef MY_DEBUG
                      return;
                    void before() {
                      // Setup the button
                    void setup(void) {
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                      #ifdef MY_DEBUG
                    //    initShutters();
                    //  } else {
                    void loop(void) {
                    #ifdef MY_DEBUG
                        sendState();
                        //    #ifdef MY_DEBUG
                        //    #endif
                        if(isMoving){
                          shuttersHalt();
                        else{
                        //state = UP;
                        //sendState();
                      oldValueUp = value;
                        if(isMoving){
                          shuttersHalt();
                        else{
                        //state = DOWN;
                        //sendState();
                        shuttersHalt();
                        //state = IDLE;
                        //sendState();
                      if (isMoving)
                          #ifdef MY_DEBUG
                              calibrateUp = true;
                            shuttersHalt();
                            shuttersUp();
                          else {
                            shuttersDown();
                    pepsonP
                    pepsonP
                    pepson
                    And is any chance to run gateway on RPI3 but on old default driver not with NEW DRIVER ?
                    Anybody has any solution for my problem with communication on version 2.3.0 ?
                      mickecarlsson
                      wrote on last edited by mickecarlsson
                      #38
                      I just checked all my nodes:
                      1. Garage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO, powered all times.
                      2. Storage - measures temperature/humidity and power usage - uses NEW_DRIVER, Arduino UNO powered all times.
                      3. Greenhouse - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                      4. Patio - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                      5. Bedroom - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                      6. Kitchen area - measures temperature/humidity - uses "old" driver, Arduino Pro Mini, battery powered.
                      My nodes are within 40 meters from the gateway.
                      I will no reprogram the node 4 and 5 to use the new driver to see if that makes any difference.
                      Node 1 and 2 are the nodes farthest away from the gateway, there is one brick wall and three wood walls between the node and the gateway.
                      • M mickecarlsson
                        pepsonP
                        pepsonP
                        pepson
                        #39
                        @mickecarlsson
                        Please also for all points give info what version MySensors use and if you can upload your sketches for all point.
                        And Gateway has on RPI3 with version 2.3.0 ? By Serial or ethernet ? And tell me with what controller you use it ? I use with Home Assistant.
                        And BTW tell me how long Arduino Mini Pro work for you on battery and what battery you use ... and show your project... Did you remove LED from Arduino to save power battery ?
                        In Sketch you measure % power from battery ? And send to controller ? What controller you use ?
                          #40
                          @pepson @mickecarlsson
                          in theory, if I remember well, length of antenna should be:
                          • 86mm for 868mhz
                          • 82mm for 915Mhz
                            Better check which frequency you can use where you live.
                          Also this is in ideal world, it depends on:
                          • antenna material
                          • gnd plane size
                          • etc
                          So when you want to tune your network, you could use a good, 868mhz for example, antenna on gateway (from a reliable supplier, as there are also a lot of unmatched antenna around).
                          Then you can try to tune emprically, by checking rssi vs length. Add length or cut, and check. If you need more or less length is dependant on above factors.
                          As already said, we don't recommand mixing new driver with older.. As packet has not the same format.
                          No eta for fixing rfm69 if issues, too busy for the moment, but we'll try asap.
                          • scalzS scalz
                            • 86mm for 868mhz
                            • 82mm for 915Mhz
                            • antenna material
                            • gnd plane size
                            • etc
                            pepsonP
                            pepsonP
                            pepson
                            @scalz said in RFM69 new driver delay:
                            Yes i have for my radio anntena 86mm.
                            On nodes and gateway i am sure that i use freq 868MHz.
                            Look on my command to build gateway and on my sketches node.
                            On version 2.2.0 i use gateway (as people write by my command i use NEW DRIVER) and also on node also use NEW DRIVER and in this solution all works perfect with no problem.
                            When i update gateway and node to 2.3.0 also with NEW DRIVER i have a problem that controll node and connection is no stabilish. In my Home Assistant sometimes i can controll relay but sometimes no reaction on click by Home Assistant. When use on node old driver (but on gateway NEW DRIVER) it is no working. Only on version 2.2.0 on gatewy and node all works perfect.
                            Is any chance to build gateway on RPI3 with old driver to RFM69HW ? Because as people write in default building on gateway on RPI3 use NEW DRIVER and we can not change it.... It is true ?
                              #42
                              @pepson
                              My comments about tuning antenna were general, it can be useful for optimizing your network.
                              I already read what you said previously ;) It should be normal that new&old driver not working together (unless a recent change..).
                              We'll take a look at which changes are incorrect. I'm using experimental local mysensors version, so I'm a bit off topic regarding official release and no time for debugging, for the moment, as like I said we'll try to check that asap.
                              Regarding RPI, I'm not using it as gw (I prefer a lower power gw that i can place where i want) so I'm not sure. Take it with a pinch of salt but if i remember, old rfm69 driver spi functions etc are not adapted to linux (whereas new driver is)
                              If 2.3 is blocking, do you need a particular fix in 2.3 ? Else you could stick to 2.2
                                mickecarlsson
                                #43
                                OK,
                                Here goes what I have:
                                Arduino Pro Mini, chinese clones. Regulator and led removed. Soldered on EasyPCB rev 9.
                                Radio is RFM69 868 MHz with helicoil antenna on the nodes, 86 mm antenna on the Gateway
                                Bootloader is from https://github.com/MCUdude/MiniCore
                                The bootloader settings are:
                                Board: ATmega328
                                Bootloader: Yes
                                Variant: 328P / 328PA
                                BOD: 1.8v
                                Clock: 1MHz internal
                                Compiler LTO: Disabled (default)
                                On the EasyPCB I have only soldered the radio, the antenna and the Arduino. No booster, no capacitors, no resistors.
                                I have put a link on the REG and run the node on two AA batteries.
                                The nodes only have one sensor, the BME280.
                                The controller I use is Domoticz, latest version (I think).
                                I have now reprogrammed some of the nodes to 2.30 and I use NEW_DRIVER.
                                Gateway - 2.3.0
                                Patio - 2.3.0
                                Test-node - 2.3.0
                                Kitchen - 2.3.0
                                Bedroom - 2.3.0
                                UV and LUX - 2.3.0
                                No problems at all.
                                However, I do not use the receive() function on my nodes.
                                And I see that you use the REPEATER setting, if your node can reach the gateway the disable repeater.
                                • M mickecarlsson
                                  OK,
                                  Board: ATmega328
                                  Bootloader: Yes
                                  BOD: 1.8v
                                  Gateway - 2.3.0
                                  Patio - 2.3.0
                                  Test-node - 2.3.0
                                  Kitchen - 2.3.0
                                  Bedroom - 2.3.0
                                  UV and LUX - 2.3.0
                                  No problems at all.
                                  pepsonP
                                  pepsonP
                                  pepson
                                  #44
                                  @mickecarlsson
                                  Tell me for what you change bootloader ? And i also have clone chine arduino pro mini... I also must change bootloader on this Arduino Pro Mini CLONE CHINA ? Because i dont change bootloader after buy...
                                  And if you can show also your antenna...and where you buy this antenna ? I try found on Aliexpres but not found.
                                  But i can not use REPEATER function to to increase the range from the gate - something like the MESH network ?
                                  And is any chance to you test my SKETCH with relay on your arduino ?
                                    mickecarlsson
                                    You don't ned to change bootloader, I do because I run on battery and it fits my need.
                                    I can't test your sketch as I don't have the necessary hardware to test it.
                                    How far apart are your nodes?
                                    My antenna is from AliExpress
                                    • M mickecarlsson
                                      pepsonP
                                      pepsonP
                                      pepson
                                      #46
                                      @mickecarlsson
                                      Now my node is very near my Gateway about 6meters. Because now i project my automation in my new home.
                                      But if you only have Arduino Pro Mini with Radio RFM69HW you can test my sketch. I think that you dont need 2xrelay to test it... Please...
                                      But for what is function REPEATER ? To increase range from Gateway to very far node ? Then the node with the repeater function extends the range?
                                      When come back to home i try build node without option REPEATER and try run this...
                                      Also can you give on priv info how upload this bootloader ? I can only write by ArduinoIDE or i must do other actions ?
                                        mickecarlsson
                                        You only need repeater fi you have a node far away that can’t reach the gateway, then you add repeater on a node nearer the gateway.
                                        See here: MySensors Network
                                        And if the node has repeater defined it must allways have power and no Sleep.
                                        Sorry, I can’t test the sketch.
                                        pepsonP 3 Replies Last reply
                                        • M mickecarlsson
                                          pepsonP
                                          pepsonP
                                          pepson
                                          #48
                                          @mickecarlsson
                                          Can you share me your all sketches ? Thanks
                                          And tell me how you have connected Gateway to RPI3? By ethernet or by serial ? Because i see in your building Gateway that you dont use parameter ETHERNET on port 5003
                                          And anybody has any contact to developer @tekka007 ?
                                          This is info what show in debug on version 2.3.0 gateway and also node on version 2.3.0
                                          pi@hassbian:~/MySensors $ sudo /usr/local/bin/mysgw
                                          Jun 22 17:22:49 INFO  Starting gateway...
                                          Jun 22 17:22:49 INFO  Protocol version - 2.3.0
                                          Jun 22 17:22:49 DEBUG MCO:BGN:INIT GW,CP=RPNGL---,VER=2.3.0
                                          Jun 22 17:22:49 DEBUG TSF:LRT:OK
                                          Jun 22 17:22:49 DEBUG TSM:INIT
                                          Jun 22 17:22:49 DEBUG TSF:WUR:MS=0
                                          Jun 22 17:22:49 DEBUG TSM:INIT:TSP OK
                                          Jun 22 17:22:49 DEBUG TSM:INIT:GW MODE
                                          Jun 22 17:22:49 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                          Jun 22 17:22:49 DEBUG MCO:REG:NOT NEEDED
                                          Jun 22 17:22:49 DEBUG Listening for connections on 0.0.0.0:5003
                                          Jun 22 17:22:49 DEBUG MCO:BGN:STP
                                          Jun 22 17:22:49 DEBUG MCO:BGN:INIT OK,TSP=1
                                          Jun 22 17:22:54 DEBUG TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          Jun 22 17:22:54 DEBUG TSF:MSG:BC
                                          Jun 22 17:22:54 DEBUG TSF:MSG:FPAR REQ,ID=2
                                          Jun 22 17:22:54 DEBUG TSF:CKU:OK,FCTRL
                                          Jun 22 17:22:54 DEBUG TSF:MSG:GWL OK
                                          Jun 22 17:22:54 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=O                 K:0
                                          Jun 22 17:22:56 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          Jun 22 17:22:56 DEBUG TSF:MSG:PINGED,ID=2,HP=1
                                          Jun 22 17:22:57 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=                 OK:1
                                          Jun 22 17:22:57 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          Jun 22 17:22:58 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=                 OK:0100
                                          Jun 22 17:22:59 DEBUG TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.0
                                          Jun 22 17:23:00 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=25,sg=0:1xRelay &                  Button-Sypialni
                                          Jun 22 17:23:03 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=5,sg=0:2.2.0
                                          Jun 22 17:23:04 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                                          Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=1,c=0,t=3,pt=0,l=0,sg=0:
                                          Jun 22 17:23:05 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                          Jun 22 17:23:06 DEBUG TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          Jun 22 17:23:07 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                                          Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                                          Jun 22 17:23:08 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                                          Jun 22 17:23:09 DEBUG TSF:MSG:READ,2-2-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
