  3. 💬 EFEKTA Temperature & Humidity mini sensor
temperatureatmega328batteryhumidityatmega 328p-mu
42 Posts 10 Posters 10.8k Views 9 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/589/EFEKTA-Temperature-and-Humidity-mini-sensor
    berkseoB 1 Reply Last reply
      Hi.
      looks cute board. But for better message delivery reliability and range, you could improve antenna placement (for better rf radiation there should not be any routes, metal etc under antenna) + more gnd plane, else you'll get shorter range than you should expect.
        berkseoB
        berkseoB
        berkseo
        @openhardware-io
        Maybe, but no problem noticed, this device is powered by battery, not by pulse power supply. There's no PWM, no induction. Work perfectly. There are no lines behind the transmitting antenna
          @berkseo
          my comments were not about pulse power, but about rf radiation, gnd counterpoise size regarding monopole (on batt, less gnd = less range & possible freq detuning), meandered antenna prone to detuning.. (and on pic looks like you have a route behind it).
          In some usecase (more range needed, or when board is enclosed etc), these details, combined, could create retransmission for example and more power used etc.
          Well, I bet you could get better range if you tested different design vs range. But, no matter, great if it's working well enough for you. That's most important point ;)
          Keep the good work!
          • scalzS scalz
            @berkseo
            Keep the good work!
            berkseoB
            berkseoB
            berkseo
            @scalz
            Partially agree. Ideally, the ground distance from the antenna should be > 30mm. This condition is not feasible :). In my case, as far as possible... Generally a big issue to the most printed antenna. How well these printed antennas are calculated on all these radio modules :)). But this already the twists and turns... However, thanks for the advice, not in my rules to give up reasonable, kind and free advice :)
            • berkseoB
              berkseoB
              berkseo
              very soon I will start selling, now there is a completion of the design of the housing for the sensor.
              • berkseoB
                berkseoB
                berkseo
                @instrumentsmeco
                perhaps it will be more interesting extended version ... coming soon ;)
                E-paper Temp&Hum sensor | First prototype test | MySensors
                • berkseoB
                  berkseoB
                  berkseo
                  Added test sketch
                  • berkseoB
                    berkseoB
                    berkseo
                    The second revision of the pcb. Added mounting holes for mounting to the device body. Added cutouts for the buttons. Added temperature barrier for temperature and humidity sensor. The lines are moved as far away from the antenna as possible. The empty areas on the Board are filled and connected to the ground.
                    • berkseoB
                      berkseoB
                      berkseo
                      Who makes orders. Please specify in the order what battery holders to put. cr2450 or cr2477
                      • MiKaM
                        MiKaM
                        MiKa
                        exist some enclosures for your sensors?
                        MiKa
                        • MiKaM MiKa
                          MiKa
                          berkseoB
                          berkseoB
                          berkseo
                          @mika said in 💬 EFEKTA Temperature & Humidity mini sensor:
                          MiKa
                          Hi, this is a problem, for now, I do it, but I practically have no time for it. But I will definitely make them myself. Maybe I will do them on industrial equipment, if some people like my devices, now they are testing them :)
                          J 1 Reply Last reply
                          • berkseoB berkseo
                            MiKa
                            J
                            J
                            jeti
                            @berkseo do you have a 3d Model of the Sensor? I could support with designing a housing if you want!
                            • T
                              terxw
                              What is the serial upload speed?
                              • T terxw
                                berkseoB
                                berkseoB
                                berkseo
                                @terxw ...as usual, 115200 (max). And why such question???
                                • J jeti
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  @jeti Sorry, I did not answer. No, I do not have a 3D model. I can send you a device using components. It would be great if there were cases for devices from third-party developers.
                                  • magpernM
                                    magpernM
                                    magpern
                                    Could you upload the schematics or some guide of what component goes where?
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      Started the development of the case...
                                      Remember to support the project with your likes !!! :)
                                      • berkseoB berkseo
                                        berkseoB
                                        berkseoB
                                        berkseo
                                        @berkseo
                                        Update, the hull prototype is ready. Developed at SOLIDWORKS. It was printed on a 3D printer type SLA. Trial printing on opaque resins has been started. This case cannot be reproduced on the printer type FDM.
                                        • berkseoB berkseo
                                          @berkseo
                                          berkseoB
                                          berkseoB
                                          berkseo
                                          @berkseo
