  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
      delay(500);
      // Battery monitoring reading
      delay(500);
      // Calculate the battery in %
      float Vbat = sensorValue * VBAT_PER_BITS;
      send(msgVBat.set(Vbat, 3));
      int batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN))*100.);
      if (batLoop > 2) {
        if (batteryPcnt > 100) {
          batteryPcnt = 100;
        batLoop = 0;
        batLoop++;
    This is the function I use, I just define the VMAX and VMIN in the beginning of sketch. The function calculates an average of 3 measurements before sending the value
    tonnerre33T
    tonnerre33T
    tonnerre33
    @gohan said in 💬 Battery Powered Sensors:
    Hello, i didn't know why you add 4 measures (batarray) and you divide by 3 the sum .
    • tonnerre33T tonnerre33
      @tonnerre33 good catch! maybe it's an optimistic value :)
        I actually didn't look much at battery percentage, but I prefer looking at the voltage that gives me a better idea of how the battery is doing since I can log the values on a graph
        • M MagnusF
          I am a newbie and have some thoughts about the battery level that I did not find in this forum.
          The 8MHz 3.3V Arduino Pro Mini can handle down to roughly 2.8V.
          If I have understood the calculations in the sketch correctly then the analog value of A0 is 1023 at 3.44V and 0 at 0V.
          This means that at 2.8V the value is about 830 = 83% and under this, the Arduino stops working. Is this right?
          If this is correct, I wonder if someone has changed the calculation in the sketch so that the battery percentage becomes 0 at 2.8V?
          This would mean that the battery percentage becomes a more real value on the battery level.
          rozpruwaczR
          rozpruwaczR
          rozpruwacz
          @magnusf It is important to know that the battery voltage is non linear in respect to how much juice left. Just search for "battery discharge curve" to see how much it depends on battery type, current and temperature. So calculating the percentage is actually meaningless unless You exactly know how much current your board sucks at what temperature and what type of battery You use.
          • I
            I
            Inso
            Instead of using "DC-DC Step Up Boost Module 5V" for a HBS, wouldn´t it make sense to just use 2 AA batteries for the nano and 2 additional batteries (i.e. four in a row) for the HBS?
              What's the hbs?
              • I
                I
                Inso
                Same as on the motion example - HC-SR501, 4.5V- 12V.
                • I
                  I
                  Inso
                  Maybe only a third Battery, as the HBS only needs 4.5V..
                  • I
                    I
                    Inso
                    To answer my own question: yes, it seems to work. Searched around and read a while, found this:
                    https://forum.mysensors.org/topic/6511/hc-sr501-3-3v-randomly-sends-tripped-when-radio-is-on/22
                    Best addition imho ,no need for step up / down. :D
                    • R
                      R
                      ricorico94
                      I'm trying to build a Soil Moisture sensor with NiMh battery and solar panel as in another post. I use a stepup converter to 3.3V connected on the VCC of a pro-mini 3.3V. The sensor seems working when connected to FTDI USB device, ut once I remove the power from FTDI, no more communication. I measured the voltage on the output of the stepup which indicates 3.26V. Is it norml or a defective step-up ? And should I remove the regulator of the pro-mini as suggested above or not ? (in article above, it states the regulator is not necessary, but it doesn't say if pro-mini would still work if regulator remains there).
                      Thanks for your support
                      • R ricorico94
                        #176
                        @ricorico94 what does the debug output from the node and the gateway say?
                        What regulator are you using? Most regulators produce power that is too noisy to be usable by the nrf24 radio (you didn't state which radio you're using so I'm just guessing here, based on the most common problems). What capacitor(s) are you using after the regulator?
                        See https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to diagnose them.
                        Also see https://www.mysensors.org/build/battery for more information about battery powered sensors.
                        • R
                          R
                          ricorico94
                          As regulator I use a stepup like that one:
                          https://fr.aliexpress.com/item/DC-DC-0-8-3-3V-to-3-3V-Step-Up-Boost-Power-Module-For-Arduino/32819660926.html?spm=a2g0s.9042311.0.0.27426c37HEbdcz
                          I use a NRF24L01 as radio module following the connection guidelines from Mysensors. I did not add any capacitor to 3.3 and ground of the NRF24L01.
                          I connected the vO of the stepup to the VCC (the VCC between RX and GRD and not the RAW) of the arduino pro mini 3.3V as indicated in this post:https://forum.mysensors.org/topic/4045/solar-powered-soil-moisture-sensor
                          I use indeed a similar lamp with its small NiMh battery (1.2v) and its solar panel.
                          The NRF24L01 is connected on GRD (between RST and RAW) and on VCC (between A3 and RST). I hadn't put any capacitor.
                          I tried following your advice to add a 0.1uF ceramic capcitor between VCC (the one between RX and GRD) of pro mini and its ground, but apparently, I face same issue.
                          (I did not solder the capcitor yet, I only connected through the pins I usually use for the FTDI)
                          26 TSM:INIT
                          28 TSF:WUR:MS=0
                          34 TSM:INIT:TSP OK
                          36 TSF:SID:OK,ID=4
                          38 TSM:FPAR
                          75 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2084 !TSM:FPAR:NO REPLY
                          2086 TSM:FPAR
                          2123 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4130 !TSM:FPAR:NO REPLY
                          4132 TSM:FPAR
                          4169 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6176 !TSM:FPAR:NO REPLY
                          6178 TSM:FPAR
                          6215 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          8222 !TSM:FPAR:FAIL
                          8224 TSM:FAIL:CNT=1
                          8226 TSM:FAIL:DIS
                          8228 TSF:TDI:TSL
                          18229 TSM:FAIL:RE-INIT
                          18231 TSM:INIT
                          18237 TSM:INIT:TSP OK
                          18241 TSF:SID:OK,ID=4
                          18243 TSM:FPAR
                          18280 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          20289 !TSM:FPAR:NO REPLY
                          20291 TSM:FPAR
                          20328 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          22337 !TSM:FPAR:NO REPLY
                          22339 TSM:FPAR
                          22376 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          24385 !TSM:FPAR:NO REPLY
                          24387 TSM:FPAR
                          24424 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          26433 !TSM:FPAR:FAIL
                          26435 TSM:FAIL:CNT=2
                          26437 TSM:FAIL:DIS
                          26439 TSF:TDI:TSL
                          36442 TSM:FAIL:RE-INIT
                          36444 TSM:INIT
                          36450 TSM:INIT:TSP OK
                          36454 TSF:SID:OK,ID=4
                          36456 TSM:FPAR
                          36493 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          38502 !TSM:FPAR:NO REPLY
                          38504 TSM:FPAR
                          38541 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          40550 !TSM:FPAR:NO REPLY
                          40552 TSM:FPAR
                          40589 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          42598 !TSM:FPAR:NO REPLY
                          42600 TSM:FPAR
                          42637 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          44646 !TSM:FPAR:FAIL
                          44648 TSM:FAIL:CNT=3
                          44650 TSM:FAIL:DIS
                          44652 TSF:TDI:TSL
                          54657 TSM:FAIL:RE-INIT
                          54659 TSM:INIT
                          54665 TSM:INIT:TSP OK
                          54669 TSF:SID:OK,ID=4
                          54671 TSM:FPAR
                          54708 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          56717 !TSM:FPAR:NO REPLY
                          56719 TSM:FPAR
                          56756 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          57493 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          57499 TSF:MSG:FPAR OK,ID=0,D=1
                          58765 TSM:FPAR:OK
                          58767 TSM:ID
                          58767 TSM:ID:OK
                          58769 TSM:UPL
                          58806 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          60815 TSM:UPL
                          60852 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                          62861 TSM:UPL
                          62863 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=OK:1
                          64872 TSM:UPL
                          64909 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          66918 !TSM:UPL:FAIL
                          66920 TSM:FPAR
                          66957 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                          68964 !TSM:FPAR:NO REPLY
                          68966 TSM:FPAR
                          69003 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          71012 !TSM:FPAR:NO REPLY
                          71014 TSM:FPAR
                          71051 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          73060 !TSM:FPAR:NO REPLY
                          73062 TSM:FPAR
                          73099 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          75108 !TSM:FPAR:FAIL
                          75110 TSM:FAIL:CNT=4
                          75112 TSM:FAIL:DIS
                          75114 TSF:TDI:TSL
                          Apparently, it sends correctly packets but can't receive any ACK or message from the gateway.
                          I got this log by connecting a FTDI adapter with only the RX/TX cables. If ever I connect also the GRD and 3.3V of the FTDI, then I get no error message at all (even without the capacitor) and Domoticz receives all updates (and also sends as I use Domoticz to send customized sleep duration to the sensor).
                          Should I try adding both the 0.1uF to VCC/GRD of arduino and also a 4.7uF to the 3.3/GRD of the NRF24 as suggested in the "Connect the Radio" page ?
                          Any idea ?
                          br,
                          Rico
                          • R ricorico94
                            26 TSM:INIT
                            28 TSF:WUR:MS=0
                            34 TSM:INIT:TSP OK
                            36 TSF:SID:OK,ID=4
                            38 TSM:FPAR
                            2086 TSM:FPAR
                            4132 TSM:FPAR
                            6178 TSM:FPAR
                            8222 !TSM:FPAR:FAIL
                            8224 TSM:FAIL:CNT=1
                            8226 TSM:FAIL:DIS
                            8228 TSF:TDI:TSL
                            18231 TSM:INIT
                            18243 TSM:FPAR
                            20291 TSM:FPAR
                            22339 TSM:FPAR
                            24387 TSM:FPAR
                            26437 TSM:FAIL:DIS
                            26439 TSF:TDI:TSL
                            36444 TSM:INIT
                            36456 TSM:FPAR
                            38504 TSM:FPAR
                            40552 TSM:FPAR
                            42600 TSM:FPAR
                            44650 TSM:FAIL:DIS
                            44652 TSF:TDI:TSL
                            54659 TSM:INIT
                            54671 TSM:FPAR
                            56719 TSM:FPAR
                            58765 TSM:FPAR:OK
                            58767 TSM:ID
                            58767 TSM:ID:OK
                            58769 TSM:UPL
                            60815 TSM:UPL
                            62861 TSM:UPL
                            64872 TSM:UPL
                            66918 !TSM:UPL:FAIL
                            66920 TSM:FPAR
                            68966 TSM:FPAR
                            71014 TSM:FPAR
                            73062 TSM:FPAR
                            75112 TSM:FAIL:DIS
                            75114 TSF:TDI:TSL
                            Any idea ?
                            br,
                            Rico
                            @ricorico94 yes add the recommended capacitor.
                            Also check the gateway log at the same time you check the node log. That will let you know if the gateway isn't hearing the node, or if the node isn't hearing the gateway.
                            • R
                              R
                              ricorico94
                              Thanks for the advice, I'll try that.
                              For the log on the gateway side : I use a gateway on the raspberry pi itself (as per https://www.mysensors.org/build/raspberry ) of my Domoticz installation. Is there an easy way (like via telnet) to get the logs other than by creating the new line in the config file ? Maybe the 3rd option proposed with "mysgw.pipe" ? (in such case, do I need to reboot whole raspberry after modifying the config file?)
                              • R ricorico94
                                @ricorico94 follow the instructions at https://www.mysensors.org/build/raspberry#troubleshooting
                                • R
                                  R
                                  ricorico94
                                  wrote on last edited by ricorico94
                                  #181
                                  Thanks to another arduino forum, I found what was wrong.. probably indeed a stability of power due to step-up converter. In that forum, they were explaining that receiving is more sensitive to power noise than sending data and that in such case, it's good to add a 100uF capacitor on 3.3V and GRD of radio module. I tried 100uF and it worked.. I then tried with 47uF and it's still working. (I had tried with 0.47uF and it was not working at all)
                                  In the "Connect Radio" guidelines, of Mysensors, it is stated that a capacitor of 0,47-47uF is improving reliability but that "the exact size usually doesn't matter" which was misleading in my case.
                                  Could I suggest to rephrase that sentence into "the exact size usually doesn't matter, but you can try 47uF if 0.47uF still doesn't work, especially if sending data works well and not receiving data." ?
                                  Edit for Erratum: please read 4.7-47uF instead of 0,47uF-47uF. Tests I had made were with 4.7uF as well, not 0.47uF
                                  br,
                                  Ricorico94
                                  • R ricorico94
                                    br,
                                    Ricorico94
                                    @ricorico94 great input, thanks! I have updated the page, except that I changed 0.47uF to 4.7uF in your text since the recommendation is 4.7 - 47)
                                    • R
                                      R
                                      ricorico94
                                      oups, indeed. I'll edit my post as well to avoid confusion as well. Thank you for your support, I appreciated a lot.
                                      By the way, I could never find how to get the logs in my gateway installed on raspPI. But that's another post. ;-)
                                        Maschler
                                        wrote on last edited by Maschler
                                        #184
                                        Hello together,
                                        I'm just trying to get the voltage measurement to work. But there is something wrong. I built everything as shown above and uploaded the program to the Arduino pro mini. The only thing I changed is the sensing Pin A0 -> A3
                                        In debug mode I see the following (the supply voltage is constant 3.3V):
                                        Battery Voltage: 3.12 V
                                        Battery percent: 92 %
                                        Battery Voltage: 2.40 V
                                        Battery percent: 71 %
                                        Battery Voltage: 2.32 V
                                        Battery percent: 69 %
                                        Battery Voltage: 2.31 V
                                        Battery percent: 68 %
                                        Battery Voltage: 2.29 V
                                        Battery Voltage: 2.30 V
                                        Battery Voltage: 2.33 V
                                        What could be the reason? That doesn't make sense to me.
                                        • M Maschler
                                          Hello together,
                                          zboblamontZ
                                          zboblamontZ
                                          zboblamont
                                          @maschler You may be picking up noise which will give an unsteady voltage during the ADC sample.
                                          A 0.1uF electrolytic cap between the analogue pin and ground in parallel with the resistor should stabilise it sufficiently.
                                          I use this arrangement with much higher resistances which are known to increase noise, the capacitor maintains a steady voltage sufficient for the ADC sample period.
                                          One thing worth checking with a multimeter is what the actual voltage is on supply and on the pin. The 1.1v bandgap is sometimes not exactly 1.1v, particularly on clones. Once you know the two values you can modify the ratio and you should get reliable and accurate readings.
