  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 219.0k Views 53 Watching
  • M MagnusF
    I am a newbie and have some thoughts about the battery level that I did not find in this forum.
    The 8MHz 3.3V Arduino Pro Mini can handle down to roughly 2.8V.
    If I have understood the calculations in the sketch correctly then the analog value of A0 is 1023 at 3.44V and 0 at 0V.
    This means that at 2.8V the value is about 830 = 83% and under this, the Arduino stops working. Is this right?
    If this is correct, I wonder if someone has changed the calculation in the sketch so that the battery percentage becomes 0 at 2.8V?
    This would mean that the battery percentage becomes a more real value on the battery level.
    rozpruwaczR
    rozpruwaczR
    rozpruwacz
    @magnusf It is important to know that the battery voltage is non linear in respect to how much juice left. Just search for "battery discharge curve" to see how much it depends on battery type, current and temperature. So calculating the percentage is actually meaningless unless You exactly know how much current your board sucks at what temperature and what type of battery You use.
    • I
      I
      Inso
      Instead of using "DC-DC Step Up Boost Module 5V" for a HBS, wouldn´t it make sense to just use 2 AA batteries for the nano and 2 additional batteries (i.e. four in a row) for the HBS?
        What's the hbs?
        • I
          I
          Inso
          Same as on the motion example - HC-SR501, 4.5V- 12V.
          • I
            I
            Inso
            Maybe only a third Battery, as the HBS only needs 4.5V..
            • I
              I
              Inso
              To answer my own question: yes, it seems to work. Searched around and read a while, found this:
              https://forum.mysensors.org/topic/6511/hc-sr501-3-3v-randomly-sends-tripped-when-radio-is-on/22
              Best addition imho ,no need for step up / down. :D
              • R
                R
                ricorico94
                I'm trying to build a Soil Moisture sensor with NiMh battery and solar panel as in another post. I use a stepup converter to 3.3V connected on the VCC of a pro-mini 3.3V. The sensor seems working when connected to FTDI USB device, ut once I remove the power from FTDI, no more communication. I measured the voltage on the output of the stepup which indicates 3.26V. Is it norml or a defective step-up ? And should I remove the regulator of the pro-mini as suggested above or not ? (in article above, it states the regulator is not necessary, but it doesn't say if pro-mini would still work if regulator remains there).
                Thanks for your support
                • R ricorico94
                  #176
                  @ricorico94 what does the debug output from the node and the gateway say?
                  What regulator are you using? Most regulators produce power that is too noisy to be usable by the nrf24 radio (you didn't state which radio you're using so I'm just guessing here, based on the most common problems). What capacitor(s) are you using after the regulator?
                  See https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for the most common problems and how to diagnose them.
                  Also see https://www.mysensors.org/build/battery for more information about battery powered sensors.
                  • R
                    R
                    ricorico94
                    As regulator I use a stepup like that one:
                    https://fr.aliexpress.com/item/DC-DC-0-8-3-3V-to-3-3V-Step-Up-Boost-Power-Module-For-Arduino/32819660926.html?spm=a2g0s.9042311.0.0.27426c37HEbdcz
                    I use a NRF24L01 as radio module following the connection guidelines from Mysensors. I did not add any capacitor to 3.3 and ground of the NRF24L01.
                    I connected the vO of the stepup to the VCC (the VCC between RX and GRD and not the RAW) of the arduino pro mini 3.3V as indicated in this post:https://forum.mysensors.org/topic/4045/solar-powered-soil-moisture-sensor
                    I use indeed a similar lamp with its small NiMh battery (1.2v) and its solar panel.
                    The NRF24L01 is connected on GRD (between RST and RAW) and on VCC (between A3 and RST). I hadn't put any capacitor.
                    I tried following your advice to add a 0.1uF ceramic capcitor between VCC (the one between RX and GRD) of pro mini and its ground, but apparently, I face same issue.
                    (I did not solder the capcitor yet, I only connected through the pins I usually use for the FTDI)
                    26 TSM:INIT
                    28 TSF:WUR:MS=0
                    34 TSM:INIT:TSP OK
                    36 TSF:SID:OK,ID=4
                    38 TSM:FPAR
                    75 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    2084 !TSM:FPAR:NO REPLY
                    2086 TSM:FPAR
                    2123 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    4130 !TSM:FPAR:NO REPLY
                    4132 TSM:FPAR
                    4169 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    6176 !TSM:FPAR:NO REPLY
                    6178 TSM:FPAR
                    6215 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    8222 !TSM:FPAR:FAIL
                    8224 TSM:FAIL:CNT=1
                    8226 TSM:FAIL:DIS
                    8228 TSF:TDI:TSL
                    18229 TSM:FAIL:RE-INIT
                    18231 TSM:INIT
                    18237 TSM:INIT:TSP OK
                    18241 TSF:SID:OK,ID=4
                    18243 TSM:FPAR
                    18280 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    20289 !TSM:FPAR:NO REPLY
                    20291 TSM:FPAR
                    20328 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    22337 !TSM:FPAR:NO REPLY
                    22339 TSM:FPAR
                    22376 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    24385 !TSM:FPAR:NO REPLY
                    24387 TSM:FPAR
                    24424 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    26433 !TSM:FPAR:FAIL
                    26435 TSM:FAIL:CNT=2
                    26437 TSM:FAIL:DIS
                    26439 TSF:TDI:TSL
                    36442 TSM:FAIL:RE-INIT
                    36444 TSM:INIT
                    36450 TSM:INIT:TSP OK
                    36454 TSF:SID:OK,ID=4
                    36456 TSM:FPAR
                    36493 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    38502 !TSM:FPAR:NO REPLY
                    38504 TSM:FPAR
                    38541 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    40550 !TSM:FPAR:NO REPLY
                    40552 TSM:FPAR
                    40589 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    42598 !TSM:FPAR:NO REPLY
                    42600 TSM:FPAR
                    42637 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    44646 !TSM:FPAR:FAIL
                    44648 TSM:FAIL:CNT=3
                    44650 TSM:FAIL:DIS
                    44652 TSF:TDI:TSL
                    54657 TSM:FAIL:RE-INIT
                    54659 TSM:INIT
                    54665 TSM:INIT:TSP OK
                    54669 TSF:SID:OK,ID=4
                    54671 TSM:FPAR
                    54708 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    56717 !TSM:FPAR:NO REPLY
                    56719 TSM:FPAR
                    56756 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    57493 TSF:MSG:READ,0-0-4,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    57499 TSF:MSG:FPAR OK,ID=0,D=1
                    58765 TSM:FPAR:OK
                    58767 TSM:ID
                    58767 TSM:ID:OK
                    58769 TSM:UPL
                    58806 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    60815 TSM:UPL
                    60852 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
                    62861 TSM:UPL
                    62863 TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=OK:1
                    64872 TSM:UPL
                    64909 !TSF:MSG:SEND,4-4-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                    66918 !TSM:UPL:FAIL
                    66920 TSM:FPAR
                    66957 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                    68964 !TSM:FPAR:NO REPLY
                    68966 TSM:FPAR
                    69003 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    71012 !TSM:FPAR:NO REPLY
                    71014 TSM:FPAR
                    71051 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    73060 !TSM:FPAR:NO REPLY
                    73062 TSM:FPAR
                    73099 TSF:MSG:SEND,4-4-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    75108 !TSM:FPAR:FAIL
                    75110 TSM:FAIL:CNT=4
                    75112 TSM:FAIL:DIS
                    75114 TSF:TDI:TSL
                    Apparently, it sends correctly packets but can't receive any ACK or message from the gateway.
                    I got this log by connecting a FTDI adapter with only the RX/TX cables. If ever I connect also the GRD and 3.3V of the FTDI, then I get no error message at all (even without the capacitor) and Domoticz receives all updates (and also sends as I use Domoticz to send customized sleep duration to the sensor).
                    Should I try adding both the 0.1uF to VCC/GRD of arduino and also a 4.7uF to the 3.3/GRD of the NRF24 as suggested in the "Connect the Radio" page ?
                    Any idea ?
                    br,
                    Rico
                    • R ricorico94
                      26 TSM:INIT
                      28 TSF:WUR:MS=0
                      34 TSM:INIT:TSP OK
                      36 TSF:SID:OK,ID=4
                      38 TSM:FPAR
                      2086 TSM:FPAR
                      4132 TSM:FPAR
                      6178 TSM:FPAR
                      8222 !TSM:FPAR:FAIL
                      8224 TSM:FAIL:CNT=1
                      8226 TSM:FAIL:DIS
                      8228 TSF:TDI:TSL
                      18231 TSM:INIT
                      18243 TSM:FPAR
                      20291 TSM:FPAR
                      22339 TSM:FPAR
                      24387 TSM:FPAR
                      26437 TSM:FAIL:DIS
                      26439 TSF:TDI:TSL
                      36444 TSM:INIT
                      36456 TSM:FPAR
                      38504 TSM:FPAR
                      40552 TSM:FPAR
                      42600 TSM:FPAR
                      44650 TSM:FAIL:DIS
                      44652 TSF:TDI:TSL
                      54659 TSM:INIT
                      54671 TSM:FPAR
                      56719 TSM:FPAR
                      58765 TSM:FPAR:OK
                      58767 TSM:ID
                      58767 TSM:ID:OK
                      58769 TSM:UPL
                      60815 TSM:UPL
                      62861 TSM:UPL
                      64872 TSM:UPL
                      66918 !TSM:UPL:FAIL
                      66920 TSM:FPAR
                      68966 TSM:FPAR
                      71014 TSM:FPAR
                      73062 TSM:FPAR
                      75112 TSM:FAIL:DIS
                      75114 TSF:TDI:TSL
                      Any idea ?
                      br,
                      Rico
                      @ricorico94 yes add the recommended capacitor.
                      Also check the gateway log at the same time you check the node log. That will let you know if the gateway isn't hearing the node, or if the node isn't hearing the gateway.
                      • R
                        R
                        ricorico94
                        Thanks for the advice, I'll try that.
                        For the log on the gateway side : I use a gateway on the raspberry pi itself (as per https://www.mysensors.org/build/raspberry ) of my Domoticz installation. Is there an easy way (like via telnet) to get the logs other than by creating the new line in the config file ? Maybe the 3rd option proposed with "mysgw.pipe" ? (in such case, do I need to reboot whole raspberry after modifying the config file?)
                        • R ricorico94
                          @ricorico94 follow the instructions at https://www.mysensors.org/build/raspberry#troubleshooting
                          • R
                            R
                            ricorico94
                            wrote on last edited by ricorico94
                            #181
                            Thanks to another arduino forum, I found what was wrong.. probably indeed a stability of power due to step-up converter. In that forum, they were explaining that receiving is more sensitive to power noise than sending data and that in such case, it's good to add a 100uF capacitor on 3.3V and GRD of radio module. I tried 100uF and it worked.. I then tried with 47uF and it's still working. (I had tried with 0.47uF and it was not working at all)
                            In the "Connect Radio" guidelines, of Mysensors, it is stated that a capacitor of 0,47-47uF is improving reliability but that "the exact size usually doesn't matter" which was misleading in my case.
                            Could I suggest to rephrase that sentence into "the exact size usually doesn't matter, but you can try 47uF if 0.47uF still doesn't work, especially if sending data works well and not receiving data." ?
                            Edit for Erratum: please read 4.7-47uF instead of 0,47uF-47uF. Tests I had made were with 4.7uF as well, not 0.47uF
                            br,
                            Ricorico94
                            • R ricorico94
                              br,
                              Ricorico94
                              @ricorico94 great input, thanks! I have updated the page, except that I changed 0.47uF to 4.7uF in your text since the recommendation is 4.7 - 47)
                              • R
                                R
                                ricorico94
                                oups, indeed. I'll edit my post as well to avoid confusion as well. Thank you for your support, I appreciated a lot.
                                By the way, I could never find how to get the logs in my gateway installed on raspPI. But that's another post. ;-)
                                  Maschler
                                  wrote on last edited by Maschler
                                  #184
                                  Hello together,
                                  I'm just trying to get the voltage measurement to work. But there is something wrong. I built everything as shown above and uploaded the program to the Arduino pro mini. The only thing I changed is the sensing Pin A0 -> A3
                                  In debug mode I see the following (the supply voltage is constant 3.3V):
                                  Battery Voltage: 3.12 V
                                  Battery percent: 92 %
                                  Battery Voltage: 2.40 V
                                  Battery percent: 71 %
                                  Battery Voltage: 2.32 V
                                  Battery percent: 69 %
                                  Battery Voltage: 2.31 V
                                  Battery percent: 68 %
                                  Battery Voltage: 2.29 V
                                  Battery Voltage: 2.30 V
                                  Battery Voltage: 2.33 V
                                  What could be the reason? That doesn't make sense to me.
                                  • M Maschler
                                    Hello together,
                                    zboblamontZ
                                    zboblamontZ
                                    zboblamont
                                    @maschler You may be picking up noise which will give an unsteady voltage during the ADC sample.
                                    A 0.1uF electrolytic cap between the analogue pin and ground in parallel with the resistor should stabilise it sufficiently.
                                    I use this arrangement with much higher resistances which are known to increase noise, the capacitor maintains a steady voltage sufficient for the ADC sample period.
                                    One thing worth checking with a multimeter is what the actual voltage is on supply and on the pin. The 1.1v bandgap is sometimes not exactly 1.1v, particularly on clones. Once you know the two values you can modify the ratio and you should get reliable and accurate readings.
                                      The 1.1v reference could be + or - 10%, but a small ceramic cap on near the analog pin should help to stabilize the reading. Also taking 3 measures and then sending the average is a good way of minimizing errors
                                      • alowhumA
                                        alowhumA
                                        alowhum
                                        I'm looking for a USB rechargeable battery that can deal with very low power drain, so that I can power an Arduino Nano. Most power packs will not work with very small currents - they turn themselves off. So ideally it should not be too clever..
                                        Does anybody have a favourite?
                                          https://www.aliexpress.com/item/ESP32-ESP32S-For-Wemos-For-Raspberry-Pi-18650-Battery-Charge-Shield-Board-V3-Micro-USB-Port/32843629344.html
