  3. Anyone help with 4 relays please?
34 Posts 6 Posters 8.5k Views 9 Watching
  • skywatchS skywatch
    If anyone is interested this now works perfectly with mycontroller, local buttons and remote buttons too.....
    Petr NosekP
    Petr NosekP
    Petr Nosek
    @skywatch Hi, I was trying to follow your findings as I have exactly the same issue, but unfortunately, although I basically used the same setup as you did, it still misbehaves. Sometimes is reacts immediately, 5 times in a row, and sometimes it simply does not work for 10 attempts. My 8 relay sketch is so simple that it can not be simpler. Also using the capacitor - still no effect. Other relay sketch - same code, same everything - works as expected :( Really no idea.
      Z
      Z
      ZachFlem
      wrote on last edited by ZachFlem
      @skywatch said in Anyone help with 4 relays please?:
      Any modification to the above code? This could be very handy for me!
      EDIT: does each button pin correspond to a relay? So in your example A0 relates to 4?
      Or can I use the rules in MC to dynamically assign buttons to operations?
      • skywatchS
        skywatchS
        skywatch
        @petr nosek
        You can only compare the one that works with the one that doesn't and see if you can figure out what is different and causing the problems.
        @ZachFlem
        Yes pins A0-A3 are button inputs for relay 1-4.
        Yes, works from mycontroller and buttons - I am re-learning all this again now as my controller sd card died and I lost a lot of settings - still it will be worth it.
        Petr NosekP 1 Reply Last reply
          @petr nosek
          @ZachFlem
          Petr NosekP
          Petr NosekP
          Petr Nosek
          @skywatch thanks for the answer. I did compare all and they all share teh same code. Pretty much. Some work for year or two without being touched and they are even further away from the gateway. I do think, that there is either HW problem with the arduino or the radio module. Before I touch it - which of those two determine what ID is the sensor? Is it the Radio module or arduino? I ask because when I change the one which delivers the ID, all the relays on the controller will be lost and I will have to rewrite all related dependencies etc.
          Regarding your further not on the lost configuration. I found somewhere a piece of code - a script, which does upload daily the current full database and configuration to dropbox - so in case I loose the raspberry Pi or SD card, I can restore it in a minute with the history. If you ned I can find it and send it.
            Node id is stored in Arduino eeprom
            • skywatchS
              skywatchS
              skywatch
              My currnet setup is running fine although there are occasional dropouts and that needs investigation.
              I added a heartbeat for the controller as the node often has no communications for hours at a time.
              I also tried to get 'ack' working with the node and gw/controller and this gave me some issues that I didn't have any time to really look into (World Cup etc....) ;)
              Hopefully I get some more time soon to look into this again.
              • Petr NosekP
                Petr NosekP
                Petr Nosek
                Hi skywatch,
                would you be so kind and share your ack and heart beat code snippets? I tried to use the code from examples, but it seems teh heartbeat never worked as expected. Regarding the ack - I am getting constantly a message: Error: MySensors: Repeating previous command (2/2) - seems to me to be related to ack as it simply does not get acknowledgement from the node and repeats the command again. But in 99% cases the command seems to be executed fine.
                skywatchS 1 Reply Last reply
                  Petr NosekP
                  Petr NosekP
                  Petr Nosek
                  @skywatch P.S. I have one more theory I need to prove. Based on another discussion where my sauna control display fails to display properly after several relay switch on and off which according to many users is caused by the use of common power source for arduino/LCD and the relays which create short but noticeable power peaks. So I will try to power my 8 node relay board from a independent power source from the power used for arduino... A little chance, but worth testing.
                  • Petr NosekP Petr Nosek
                    Hi skywatch,
                    skywatchS
                    skywatchS
                    skywatch
                    @petr-nosek
                    See below for the current code I run for my 4 relay test node.....
                    #define MY_RF24_PA_LEVEL   RF24_PA_HIGH
                    #define MY_NODE_ID 140
                    #define MY_RF24_CHANNEL (97)
                    #define MY_PARENT_NODE_ID 0
                    //#define MY_REPEATER_FEATURE
                    //#define MY_SIGNING_ATSHA204
                    #define RELAY_ON 1                      // switch around for relay HIGH/LOW state
                    #define RELAY_OFF 0
                    unsigned long HEARTBEAT_TIME = 60000*10; //every 10 mins.
                    unsigned long last_heartbeat_time = 0;
                    #define noRelays 4                     //2-4
                    const int relayPin[] = {4,5,6,7};          //  switch around pins to your desire
                    const int buttonPin[] = {A0,A1,A2,A3};      //  switch around pins to your desire
                    class Relay             // relay class, store all relevant data (equivalent to struct)
                    public:
                      int buttonPin;                   // physical pin number of button
                      int relayPin;             // physical pin number of relay
                      byte oldValue;                    // last Values for key (debounce)
                      boolean relayState;               // relay status (also stored in EEPROM)
                    Relay Relays[noRelays];
                    Bounce debouncer[noRelays];
                    MyMessage msg[noRelays];
                    void setup(){
                        wait(250);
                        for (int i = 0; i < noRelays; i++){
                        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                        msg[i].type = V_STATUS;
                        debouncer[i].interval(5);
                        digitalWrite(Relays[i].relayPin, RELAY_OFF);
                        wait(250);
                        Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                        digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
                        send(msg[i].set(Relays[i].relayState? true : false),true);                  // make controller aware of last status
                        wait(250);
                    void presentation()  {
                          sendSketchInfo("MYS-4-Relay", "0.2");
                          wait(250);
                          present(0, S_BINARY,"Relay 1");
                          wait(150);
                          present(1, S_BINARY,"Relay 2");
                          wait(150);
                          present(2, S_BINARY,"Relay 3");
                          wait(150);
                          present(3, S_BINARY,"Relay 4");
                        // Send heartbeat
                        if ((millis() - last_heartbeat_time) > HEARTBEAT_TIME) {
                        sendHeartbeat();
                        last_heartbeat_time = millis();
                      #ifdef MY_DEBUG
                        Serial.println("Sent heartbeat");
                        for (byte i = 0; i < noRelays; i++){
                        debouncer[i].update();
                        byte value = debouncer[i].read();
                        if (value != Relays[i].oldValue && value==0){
                        digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
                        saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                        Relays[i].oldValue = value;
                        wait(50);
                    // process incoming message
                    void receive(const MyMessage &message){
                       if (message.type == V_STATUS){
                       if (message.sensor < noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                       digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
                       saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                    This includes my latest attempt at heartbeat and ack. Heartbeat works fine, but ack is still a problem with mycontroller.
                    I can't risk using it until ack and signing are implemented and fully reliable as it will be controlling mains devices and that needs to be done securely.
                    As for your sauna problem don't forget to connect the grounds between power supplies. You could try adding a 0.1uF capacitor across the 5v supply along with a nice big 220uF 6.3V or higher electrolytic. That might help with spikes or momentary sags in the voltage caused by current rush.
                      If you want complete isolation between relays and arduino you don't need to share common ground if your relays have optocouplers.
                      • skywatchS
                        skywatchS
                        skywatch
                        @gohan, Good point! :)
                        • Petr NosekP
                          Petr NosekP
                          Petr Nosek
                          Good day everyone,
                          in case someone faces the same issues I did:
                          • controlling multiple relays from one arduino and sharing the same power (powering relay board from Arduino
                            or
                          • controlling relay which switches high loads circuit causing connected LCD to show garbage and again powering the relay from Arduino...
                          ...the solution proposed above is the only one which helps - provide separated power supply for the relay boards. Once this is done with an extra little bucket power source for 5V (3W) all the issues with relays not working, domoticz not switching relays, LCD going crazy - all solved. I should have done this long before.
                          Thanks everyone!
                          P.S. For those, who still do not follow, the relay boards for Arduino contain extra jumper connecting VCC and JD-VCC (plus sometimes extra GND pin). So remove the jumper and connect the standalone, not common sharing 5V power source to this extra JD-VCC and GND (or GND near the IN1 pin) and disconnect the GND from Arduino and then you have a full optosiolation and then there are no interferences and other garbage breaking the Arduino functionality by switching relays coils. (also explained here: https://forum.arduino.cc/index.php?topic=470134.0)
                          • parachutesjP
                            parachutesjP
                            parachutesj
                            If this really solves the problem...would have saved me a lot of headaches. Got rid of all my relay nodes in the meantime.
                            • parachutesjP parachutesj
                              Petr NosekP
                              Petr NosekP
                              Petr Nosek
                              @parachutesj I do say it does. I have about 50 nodes in my house, 15 relays or so, temperature sensors and some others. All the relays i power now with standalone little china made 5V, 3W adapters and as I sit now in my house I do switch on and off lights, turn on gate, control pumps in greenhouse, all works on the first tap. I am finally happy with my mysensors equipped domoticz, first after 2 years. It took my so long to just give it a try.
                              parachutesjP 1 Reply Last reply
                                parachutesjP
                                parachutesjP
                                parachutesj
                                @petr-nosek my problem was maily unrealiability. They worked for minutes or weeks and then stopped (or anything in between).
                                All other nodes work flawless.
                                Maybe give it a try at next project
                                  have you been using watchdogs on your sketches?
                                    Petr NosekP
                                    Petr NosekP
                                    Petr Nosek
                                    @gohan I have tried all kinds of things. I believe that the fact that I used watchdogs which checked the MySensors nodes every 8 seconds (or less) helped me to recover from relay failures so the nodes appeared to be functional, but only randomly. In real life it looked good when I started them. did several turn on and off and it worked. In 2-3 minutes I did try again, it worked for 2 out of 4 attempts and then it stopped responding. In another 20-30 seconds I did try again and then again it appeared to work - I believe it was thanks to the watchdogs recovering the frozen node after the relay peak caused them to stop working. But only a theory, I have no deeper knowledge to prove this.
                                      if node restarts you should see it in the logs of the gateway or the controller
                                        Petr NosekP
                                        Petr NosekP
                                        Petr Nosek
                                        @gohan Hmm, then I dare to say I have never seen such entry. I could see in the past (before I added second power supply for relay boards) many information about repeating last command and lately issues with sending gmail notifications (caused by securing gmail account) but I do not recall seeing an information about node restart and by that I mean even manual restarts I did by unplugging the node. But I guess you refer to watchdog driven from the controller - Domoticz Gateway. I was perhaps answering on another "watchdog" - a internal Arduino node code which monitors the Arduino internally and checks whether it is running and if not, then it restarts itself. I cant imagine a remote restart of a node which is not responding to commands, how could it react on a remote restart? I suppose it can work just in case the arduino works, only the node itself is somehow not reporting data or so, right?
                                          I was referring to the internal Arduino watchdog
                                          12.5k
