  3. Minimal design thoughts
299 Posts 34 Posters 276.4k Views 17 Watching
  • D
    Dirk_H
    @tbowmo I don't see a Load Capacitor on the crystal. Especially if you need a precise clock you should use some. Have a look at https://www.adafruit.com/blog/2012/01/24/choosing-the-right-crystal-and-caps-for-your-design/ for example about Load Capacitors.
    tbowmoT 1 Reply Last reply
    • D Dirk_H
      tbowmoT
      tbowmoT
      tbowmo
      I know that normally the crystal require load capacitors, but for the low freq. oscilator (32Khz) its not necessary (as far as I have read), that's why I omitted them from the design. I'll try and dig out the datasheets when I'm at home and double check things.
      • T Tibus
        @tbowmo said:
        ATSHA204
        This module is verry interesting but how it work? What you have to do in code to make it work, crypting messages,...?
        tbowmoT
        tbowmoT
        tbowmo
        @Tibus said:
        @tbowmo said:
        ATSHA204
        There are other threads about the ATSHA204 around in the forum. It's basically just a method for signing messages between units, not encryption. I haven't made any code for it myself, just thinking about implementing it for future plans (and for others to pick up on)
        RJ_MakeR 1 Reply Last reply
        • tbowmoT tbowmo
          @Tibus said:
          @tbowmo said:
          ATSHA204
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @tbowmo said:
          @Tibus said:
          @tbowmo said:
          ATSHA204
          Ah but from what I've read it can indeed encrypt the data stream. Did I completely get it wrong?
          RJ_Make
          • RJ_MakeR RJ_Make
            @tbowmo said:
            @Tibus said:
            @tbowmo said:
            ATSHA204
            tbowmoT
            tbowmoT
            tbowmo
            @ServiceXp said:
            @tbowmo said:
            @Tibus said:
            @tbowmo said:
            ATSHA204
            It's a crypto authentication device, datasheet is at
            http://www.atmel.com/devices/ATSHA204A.aspx
            For sensor data it should be enough, it help to prevent replay attacks, so an intruder can't switch of the lights for example, because the attacker don't have the presharred keys available
            • daulagariD
              daulagariD
              daulagari
              wrote on last edited by daulagari
              #118
              As discussed in the security thread I think authentication alone can be useful but encryption is providing both security and a reasonable form of authentication so why not go for an encryption IC instead of the ATSHA204A.
              Atmel has a nice IC doing AES:
              http://www.atmel.com/devices/ATAES132.aspx
              A bit larger (8 pins SOIC), but reasonable cheap € 0,782 (@10)
              It is also part of CryptoCape, so there should be some software support for it.
              • tbowmoT
                tbowmoT
                tbowmo
                @daulagari
                That chip is still only for authentication, only it's with aes-128 message auth instead of sha 256
                Also another thing i noted, is that the supported supply range is from 2.5 to 5v, whereas the atsha204 could operate down to 2.0v.
                • daulagariD
                  daulagariD
                  daulagari
                  If I have a look at the datasheet I see:
                  Opcode Name        Description
                  0x06   Encrypt     Encrypts 16 or 32 bytes of plaintext data provided by the Host.
                  0x07   Decrypt     Decrypts 16 or 32 bytes of data provided by the Host after verifying the integrity MAC.
                  So it does encrypt/decrypt.
                  The CryptoCape board has both ATSHA204A and ATAES132 where the ATAES132 can "Encrypt up to a 32 byte packet at a time with AES-128-CCM"
                  Not sure if it is handy to have the integrity MAC combined as that does require 16 additional bytes, but that is the same story for SHA-256.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    Hmm I was tricked by the "crypto-authentication" note on atmel site, so thought it only did auth.
                    Still, lowest vcc is 2.5v. If they could make a device that could operate down to 1.8v instead instead, it would be more interesting.
                    • tbowmoT tbowmo
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @tbowmo Yeah the 2.5v would be a problem, unless we can build an extremely efficient boost...
                      RJ_Make
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @ServiceXp
                        Yes, but I am trying to avoid booster circuits at all costs in this design. Also the main function is to collect temperature and humidity values from around the house. So for my part encryption is not a must have for this device.
                        btw I'm almost there with rerouting rev 2 to make room for the atsha204 (in sot23 housing)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          Just reading through the datasheet of ATAES132, and realise that I already have support for it on the board. It uses a standard I2C / SPI eeprom footprint, and that is already on the board. So if anyone would like to use it, they only need to replace the flash.
                          Anyway, I have finished re-routing things.. and the ATSHA204 is now incorporated in the design, so challenge/response authentication could be implemented.
                          Just need to do the last couple of reviews, before I press the order button for a new set of pcb's
                          AnticimexA 1 Reply Last reply
                          • RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            Is it not possible to just encrypt the entire packet with an AES library on both ends?
                            RJ_Make
                            • tbowmoT tbowmo
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @tbowmo Does your design support both I2C and single-write ATSHA204?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #127
                                @Anticimex
                                It's single wire atsha204, it's connected to A3. I couldn't fit in the 8 pin variants of the atsha204, so that ruled out the full I2C bus version. It even took me a couple of hours of re-routing to make enough room for the sot23 housing of the ATSHA204.
                                Anyway, schematic / pcb layouts are as follows
                                AnticimexA RJ_MakeR 2 Replies Last reply
                                • tbowmoT tbowmo
                                  @Anticimex
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @tbowmo Excellent.
                                  • tbowmoT tbowmo
                                    @Anticimex
                                    RJ_MakeR
                                    RJ_MakeR
                                    RJ_Make
                                    @tbowmo Once again,... Well Done!
                                    RJ_Make
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      And for the fun of it.. Just made a github repository of the design
                                      https://github.com/tbowmo/MySensorMicro
                                      Just in case anyone would like to have a closer look in eagle.
                                      • RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        I wonder what kind of "hit" on battery life authentication/encryption will have?
                                        RJ_Make
                                        • AnticimexA
                                          AnticimexA
                                          Anticimex
                                          I do not think it is a big issue. Authentication is normally only needed on nodes that have actuators. And this implies that they always have to listen for incoming data and are therefore inherently non-battery friendly The ATSHA has a very low power consumption, so the added cost for message signing procedures is probably negligible compared to the cost of running the radio continuously.
