  3. Sudden extreme battery drain [SOLVED]
32 Posts 6 Posters 7.5k Views 6 Watching
    Strixx
    So now I have been investigating some more. I tried to upload my own sketch again, but that made no difference. The constant power consumption was still there. So I then took the example code from the homepage and did some small adjustments and tried again.
    It still consume power even when sleep. But now my meter only shows a constant 26-28 mA.
    Here is the code that I use now:
    #define MY_DEBUG  // Enable debug prints to serial monitor
    #define MY_SPLASH_SCREEN_DISABLED  // Save memory
    #define MY_SECURITY_SIMPLE_PASSWD "secret"  //Simpel soft signing with password
    #define MY_SIGNING_SOFT_RANDOMSEED_PIN A3  // Unconnected analog pin for random seed
    #define MY_RF24_CHANNEL 110  // Set the frequency to channel 110 (2,510MHz), to prevent interference with all available WiFi channels (ch 14 -> 2,495MHz)
    #include <OneWire.h>
    #define MAX_ATTACHED_DS18B20 1
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
      sendSketchInfo("pool", "2.2");
         present(i, S_TEMP);
      sleep(conversionTime);
    	  Serial.print("Temperature sent: ");
      Serial.println("Sleep");
      sleep(SLEEP_TIME);
      Serial.println("Back from sleep");
    And this is the serial output:
    0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
    4 MCO:BGN:BFR
    65 TSM:INIT
    65 TSF:WUR:MS=0
    73 TSM:INIT:TSP OK
    75 TSF:SID:OK,ID=2
    77 TSM:FPAR
    114 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    413 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    417 TSF:MSG:FPAR OK,ID=0,D=1
    2121 TSM:FPAR:OK
    2121 TSM:ID
    2123 TSM:ID:OK
    2125 TSM:UPL
    2129 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2136 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2142 TSF:MSG:PONG RECV,HP=1
    2146 TSM:UPL:OK
    2148 TSM:READY:ID=2,PAR=0,DIS=1
    2152 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2160 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2168 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    2179 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    3131 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    3139 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:pool
    3149 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.2
    3158 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    3164 MCO:REG:REQ
    3168 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    3176 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    3182 MCO:PIM:NODE REG=1
    3184 MCO:BGN:STP
    3186 MCO:BGN:INIT OK,TSP=1
    3192 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
    3196 TSF:TDI:TSL
    3201 MCO:SLP:WUP=-1
    3203 TSF:TRI:TSB
    3233 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.2
    Temperature sent: 25.20
    Sleep
    3241 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    3250 TSF:TDI:TSL
    3252 MCO:SLP:WUP=-1
    3254 TSF:TRI:TSB
    Back from sleep
    3260 MCO:SLP:MS=750,SMS=0,I1=255,M1=255,I2=255,M2=255
    3264 TSF:TDI:TSL
    3268 MCO:SLP:WUP=-1
    3270 TSF:TRI:TSB
    3336 !TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=NACK:25.2
    Sleep
    3346 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    3352 TSF:TDI:TSL
    3356 MCO:SLP:WUP=-1
    3358 TSF:TRI:TSB
    Back from sleep
      wrote on last edited by gohan
      did you try to run a clear_eeprom sketch from the mysensors examples? Or burn an optiboot bootloader?
      S 1 Reply Last reply
        Strixx
        @gohan Nope. But I tried that now, and then the sketch above again. Still the same.
        • S Strixx
          sundberg84S
          sundberg84S
          @strixx if you removed sensors like suggested above and you still have a high mA you should try to change the pro-mini. It could be a failing capacitor leaking.
          Your logs look fine.
          • sundberg84S sundberg84
            Strixx
            @sundberg84 Yes. I think I will have to do that.
            I changed the test code above a little bit and added a delay for 5 seconds before sleep. And now I got better readings from my meter. It is about 48 mA when not sleeping and 28 mA when sleeping. So it does go to sleep but it is leaking somewhere.
            To bad I don't have time this week for changing the arduino. I will have to get back next week about the progress.
              Strixx
              So. Forgot to get back.
              But it was the Arduino it self that had gone bad. I switched the Arduino to a new, and everything was back to normal.
              bjacobseB 1 Reply Last reply
                I had reports about switching to a different bootloader (like minicore) solved similar issues, as the stock bootloader sometimes doesn't like the sleep state
                • S Strixx
                  bjacobseB
                  bjacobseB
                  bjacobse
                  @strixx
                  so did you change the IC ATmega328P or was it the whole Arduino board?
                  if it's the whole Arduino board, then Sundbergs suggestion that a cap is faulty quite likely the error
                  quote Sundber84: "
                  sundberg84 Hardware Contributor 2 months ago
                  @strixx if you removed sensors like suggested above and you still have a high mA you should try to change the pro-mini. It could be a failing capacitor leaking."
                  • bjacobseB bjacobse
                    @strixx
                    quote Sundber84: "
                    Strixx
                    @bjacobse
                    Changed the whole board. I have it laying here in my workshop, but haven't got the time yet to investigate more.
                    It's shore sounds like @sundberg84 was right about a leaking capacitor.
                      Strixx
                      @gohan Well. I could try that. But it sounds strange to me that it will all the sudden change behavior. It was running fine without battery drain for a couple of weeks, and then all the sudden started draining the batteries.
                        I had a pro mini running fine for months in my outdoor solar sensor but I had to replace it as it was no longer working, with led flashing all the time. Later I managed to recover it by replashing bootloader and sketch again.
                          Strixx
                          @gohan Ok. Then I will try your suggestion. I will first have to learn how to replace the bootloader.. :-)
                          • S Strixx
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @strixx
                            Yes please try to update the bootloader first- I think it's quite interesting for the rest of us what is the actual rootcause
                            I don't use the stock bootlader in any Arduino codes, but instead an optiboot from GertSanders (as optiboot have enabled the WTD/watchdog)
                            https://forum.mysensors.org/topic/3261/various-bootloader-files-based-on-optiboot-6-2
                              @strixx
                              Strixx
                              @bjacobse So it's time for a new raid with this project. I have been trying to read up on how to change bootloader. And if I understand it correct I need a programmer. And I only have a FTDI for uploading my code to my arduinos.
                              But somewhere I found that I can use a Arduino Uno instead.
                              So is this correct? If I buy a Uno will I be able to change to the new bootloader?
                              • S Strixx
                                @strixx you can use almost any Arduino. Instructions are available at https://www.arduino.cc/en/Tutorial/ArduinoISP
                                  Strixx
                                  @mfalkvidd Thanks! Don't think I found that page before. Found a lot of pages about this subject but not this page. But if I understand it correct I still need to buy a new Arduino. I only have a big supply of Pro Minis. No other models.
                                  • S Strixx
                                    @strixx a Pro Mini should work. It has the same mcu (atmega328) as the Uno, and pins 10-13 are available.
                                      Strixx
                                      So I have been reading up alot. And yesterday I finally managed to upload a new bootloader to this ProMini. It was the optiboot that @bjacobse linked to. All worked fine without any errors.
                                      But I must have been doing something wrong, because I am not able to upload any sketch to the Arduino after that. I only get not in sync errors.
                                      Unfortunately I don't have time to continue on this until late next week...
                                      • S Strixx
                                        @strixx make sure you flash the correct bootloader for the crystal frequency of your pro mini (3.3V 8Mhz vs 5V 16MHz) and select the correct pro mini target in the Arduino IDE. Any errors will cause baudrate deviation in the serial bootloader communication, causing sync errors.
