  2. Feature Requests
  3. Domoticz full integration
Scheduled Pinned Locked Moved Feature Requests
79 Posts 26 Posters 77.6k Views 11 Watching
  • AWIA
    AWIA
    AWI
    Good to see you are taking the jump... What you see in the first test is are generic error messages which can be generated in many place. There is a "catch-all" exception handler on the main loop, I suggest you take out the word "ValueError". After that the script will come to a halt and indicate where it went wrong.
    I am 'almost' in the next major update. I hope to upload today .
    Good luck!
      @AWI
      That would be awesome!
      AWIA
      AWIA
      AWI
      @hek I am almost done with the python -Domoticz "full integration" but strugling with a few message types. The code for Vera is a good source for information but it is hard to determine the role of the controller in the construction/routing of the network. For now I assumed only node numbering and keeping track of the sensors. Is the controller supposed to do something with the relay nodes? what is the function of the I_CHILDREN message?
        Just skip it. It's deprecated and will be removed.
        tekkaT 1 Reply Last reply
        • A andriej
          I've managed to get it to work.
          First issue - since always I've reported temperature and humidity altogether (from DHT sensors).
          Currently I can't specify one IDX for two values and I can't see in code where I could put two values to report in Domoticz at once.
          They use to be reported in one URL.
          AWIA
          AWIA
          AWI
          @andriej I will be posting a new version tomorrow which adds maximum functionality for Domoticz (from my view): combined sensors (trick), node numbering, inclusion and an external database in JSON. I will keep it running tonight to test the stability. ...
          • AWIA
            AWIA
            AWI
            Major update (but still very beta...,) supports:
            • dynamic sensor inclusion i.s.o. fixed nodes.
            • more sensor types and support for combined domoticz devices (e.g. Temp, Hum, Baro)
            • external JSON database
            The python script is built around a 'dictionary' based Database with the MySensor-Domoticz translation. The script is running stable with 20+ sensor/actuators and limited cpu load on raspberry pi (15%).
            Known issues:
            • You need to edit the JSON database yourself if you need combined Domoticz devices eg. (Temp/Hum/Baro). Not difficult
            • Need to create Switch types yourself in Domoticz , then assign these in the database
            • Usage/power not supported yet (need a "multiple value" trick..)
            You can find the attempt at: Domoticz-MySensors with a small instruction in the first few lines
            all suggestions welcome..
              @AWI, great work!
              You should probably post something over at Domoticz forum as well.
              • GizMoCuzG
                GizMoCuzG
                GizMoCuz
                wrote on last edited by GizMoCuz
                #50
                Domoticz:
                Starting with a native implementation, thanks to Ad for providing the RF interfaces.
                Maybe best (for domoticz) to continue on the forum,
                i need serial logs of all possible combinations and meaning
                node-id;child-sensor-id;message-type;ack;sub-type;payload
                we developers probably have to do some special tricks to get some nice sensors
                for instance, it would be nice if there where subtypes for:
                • Temp+Hum
                • Temp+Hum+Baro
                • Kwh+Watt
                • Wind+Gust+Direction
                I can not watch this forum, if you want to contribute, plz use the domoticz forum
                hekH 1 Reply Last reply
                • GizMoCuzG GizMoCuz
                  Domoticz:
                  • Temp+Hum
                  • Temp+Hum+Baro
                  • Kwh+Watt
                  @Rob-Peters
                  Hi, great to see you here! I'll send you my contact details if you have any specific questions.
                  @AWI seems to have implemented most of the logic necessary.
                  • A
                    andriej
                    In latest release of Domoticz I can see first implementations of MySensors!
                    Maybe it's worth a shot for someone to register on Domoticz forum and help their team out?
                    AWIA 1 Reply Last reply
                    • A andriej
                      AWIA
                      AWIA
                      AWI
                      @andriej Hi, GizMoCuz is working on it (2 reply's before) asked for serial log of all possible combinations. I am trying to help out, but some help and priority setting is more than welcome.
                      • epierreE
                        epierreE
                        epierre
                        I've answered to Rob sending some of my logs and a link to my interface, I guess seeing a link between values and JSON will help a bit ;-).
                        @hek we've not settled about gas values, no ?
                        z-wave - Vera -> Domoticz
                          @epierre
                          Sort of... But I will probably not change anything in 1.4.
                          • GizMoCuzG
                            GizMoCuzG
                            GizMoCuz
                            Posted a new beta of domoticz.
                            Lots have been changed
                            If anyone can supply me with serial log messages of:
                            S_LIGHT_LEVEL
                            S_WATT
                            S_KWH
                            That would be helpfull
                            With regards,
                            Rob
                              S_LIGHT_LEVEL
                              S_WATT
                              S_KWH
                              With regards,
                              Rob
                              @GizMoCuz
                              Sent you an email...
                                tekkaT
                                tekkaT
                                tekka
                                wrote on last edited by tekka
                                #58
                                @hek:
                                The I_CHILDREN+"C" message is useful during development/implementation/repositioning of nodes with repeater functionality (changing node location may alter routing).
                                From my experience, this function is helpful and should even be expanded to clearing the parent_node_id: i.e. I faced the situation where the parent node (not gw) was out of range and the node could not communicate back to the gateway. The only resolution is to clear the eeprom or sending the I_CHILDREN + "C" command
                                • jendrushJ
                                  jendrushJ
                                  jendrush
                                  I have a question. If someone is using pulse power meter with new version of Domoticz please tell me if Domoticz is able to send last know value of kwh to node?
                                  • A
                                    andriej
                                    Has anyone tested the Domoticz's support of MySensors?
                                    Maybe it should be mentioned on the webpage somehow.
                                    It's still one of the most nice-looking systems out there...
                                      I will create a page on the main site. Just waiting for some texts from Rob.
                                        markb
                                        wrote on last edited by markb
                                        #62
                                        @andriej I have managed to get a MySensor DHT11 sensor reporting consistently in Domoticz, via the Ethernet option. My next steps are to try a couple of other sensor types (eg distance, switches) and multiple sensors on one arduino node. After a first look at how the Serial and Ethernet options have been done in Domoticz, it looks to me like MQTT might also provide a third 'transport' option for integrating MySensors, with some development. I will be building my knowledge across MySensors and Domoticz over the coming week or two, so might be able to contribute to integration development in the future.
                                        • R
                                          R
                                          rtenklooster
                                          I've motion sensors, barometer, lux sensors 4 dallas sensors on 4 arduinos fully working on domoticz.
                                          It's al working fine, sensors don't always appear in the right tab, but that's no problem for now, new to mysensors, very happy with it!
