  3. atmega328p-au counterfeit
19 Posts 5 Posters 5.7k Views 5 Watching
    Well... that's just a speculation.
      @gohan true, but the topic of this thread deals with counterfeit atmega328.
      I'm just thinking aloud if these could exist, that's it ;-)
        Where did you get them? Report the issue and ask for refund
        alexsh1A
        alexsh1A
        alexsh1
        @gohan Its eBay. The seller is from Shenzhen, china.
        Let's see if this would yield anything. I just feel frustrated as I lost so much time, which I could have spent elsewhere.
        gohanG 1 Reply Last reply
        • YveauxY Yveaux
          @alexsh1 Interesting, as I wasn't able to find any counterfeits reported that seem to work slightly.
          Sparkfun has some counterfeits reported that appear to only have a copper plane inside, but obviously they won't work at all.
          Could it be that your ATMegas are just handled badly (by the seller), or second hand, or...
          Anyway, I agree with @gohan to refund.
          Edit: This looks scary: https://www.avrfreaks.net/sites/default/files/forum_attachments/LGT8F88A V1_1.pdf
          and ftp://imall.iteadstudio.com/Microcontroller/IM131218002/Migrating_from_ATmega88_to_LGT8F88A_v1.0.pdf
          alexsh1A
          alexsh1A
          alexsh1
          @yveaux I am 99% sure this is a chip problem. I have tried a few from a same batch with the same results. For example, I upload a bootloader with l:0xe2 and h:0xde fuses but the chip is running at 1Mhz. How is that possible? I had to manually write l:0x62 and than l:0xe2 in order for it to run at 8 Mhz. And I am talking about several AVRs with the same pattern.
          Even the font on the AVRs is different from the ones supplied from arrow.com.
          Somehow, I was convinced I could make it work.
          • alexsh1A alexsh1
            @alexsh1 said in atmega328p-au counterfeit:
            That could be caused by the atmel microchip merger, but we'll probably never know...
            • alexsh1A alexsh1
              @alexsh1 My first nrf24 chips were fake not working clones, I spent so many hours trying to get them working but it was impossible as I later found out. Returned them and got other ones (clones too 😅)... I know the frustration
              • Nca78N
                It could be a lgt328, 328 clone by LGT (like the lgt88 quoted earlier). It's the chip used on the wemos XI. I bought one long ago and gave up as it has some differences for low power like the need to initialize all pins and even then the power consumption in sleep was in dozens of uA.
                • Nca78N Nca78
                  @nca78 Thanks for reporting! So what I feared is actually reality :skull_and_crossbones:
                    If they are correctly marked it would be fine.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Here I have an example of Chinese (AliExpress) sources atmega328p:
                      I have tried to solder a few of these, but none of them is working properly. I can upload the bootloader, but cannot upload any sketch.
                      alexsh1A 1 Reply Last reply
                      • alexsh1A alexsh1
                        alexsh1A
                        alexsh1A
                        alexsh1
                        Just to compare these are received today from digikey:
                        • alexsh1A alexsh1
                          @alexsh1 and do the ones from digikey work correctly?
                          • YveauxY Yveaux
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @yveaux Yes, the problem has gone as soon as the new chip was soldered and the firmware burned. A lot of valuable time wasted and a lesson learnt - no more Aliexpress for components. Only a reliable source - Digi-key, mouser, allow, Farnell etc.
                              I wonder if this spells death for PCBA, since those parts gets sourced from chinese distributors.
                              Seems as though reliable chinese distributors must exist, or the entire system there would break down. I just have no idea who they are.
