  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.8m Views 44 Watching
  • N Offline
    N Offline
    Well, this is interesting: you can run micropython on your micro bit: https://www.amazon.com/dp/1260117588/ref=rdr_ext_tmb
    • O Offline
      O Offline
      Omemanti
      wrote on last edited by Omemanti
      #1705
      Not sure if it is allowed, else I remove this post, but the nrf52832's at ebyte are for sale (50% off)the coming 2 days.cdebyte AliExpress I sure grab myself some (max 2 at a time, but last time I ordered multiple times :)) only €2,62 a piece
      N 1 Reply Last reply
      • O Omemanti
        N Offline
        N Offline
        #1706
        @omemanti said in nRF5 action!:
        Your post is perfectly fine, and I would even encourage it. It makes good sense to share tips like that.
        The funny thing is that the 50% price is, IIRC, close to what the original price was when it was first introduced. Then the price slowly crept up from there.
        O 1 Reply Last reply
        • N NeverDie
          O Offline
          O Offline
          Omemanti
          #1707
          @neverdie well, July 2017 they were €4,15. So they went up around 1 euro in a year. FYI the last one I bought was about 5 months ago since then they went up from version 1,1 to 1,3.
          Also, the item number changed a bit (but the datasheet checks out).
          It went from E73-2G4M04S to E73-2G4M04S1B, and the introduced a nrf52810 E73-2G4M04S1A with the same footprint and pinout.
          N N 2 Replies Last reply
          • O Omemanti
            N Offline
            N Offline
            @omemanti Ah, yes, you're right. It was on March 7, 2018 that they were on sale for $2.55.
            Well, regardless, it's a good price. :)
            • O Omemanti
              N Offline
              N Offline
              @omemanti the A version is with NRF52810, be careful.
              • N NeverDie
                @alowhum IIRC, the crystal oscillator is only required by Bluetooth. For everything else, the internal resonator is sufficient.
                smilvert
                @neverdie Sorry, im a bit confused.
                If im are going to use the BT832 for a battery sensor do I need to connet a 32 khz crystal like you did on the 10+ years wireless PIR Sensor (on just one set of 3 AA's!) project? But you have also written:
                How much more current are used if the crystal is not connected?
                Can I use P00/P01 as a data pin instead of using the crystal?
                • N Offline
                  N Offline
                  You don't need the crystal. Not sure difference in current. Yes, to your last question.
                  • N Nca78
                    O Offline
                    O Offline
                    Omemanti
                    @nca78 yeah I noticed that, what is the downside of the NRF52810?
                    • O Omemanti
                      N Offline
                      N Offline
                      At least lower memory (ram and flash) and I don't know for the peripherals. Not sure if the core for nrf52832 will work flawlessly or not. Given the tiny price difference it's better to stick to nrf52832.
                      Low frequency crystal will make you save energy when you use Bluetooth, because it needs to wake up at precise time frames to send/receive data. Do in that case the internal oscillator is not precise enough and mcu has to wake up regularly to recalibrate it with high frequency clock.
                      For MySensors, it's not useful.
                      J 1 Reply Last reply
                      • N Nca78
                        J Offline
                        J Offline
                        Jokgi
                        @nca78 There is no downside to using the nRF52810. It depends on your needs. If you can live with 192K Flash and 24K RAM and a stack that supports peripheral only (at this time) then you are good. The device can use the internal 32Khz RC osc for BTLE and there is a slight current consumption hit as the receive window will be longer. (+/- 500ppm) . No different then on the nRF52832. as stated, a 32Khz crystal will give you a tighter clock and lower current consumption.
                        This is a scaled down version of the nRF52832 so there are some peripherals that have been taken out or reduced. PWM for example, only one. No NFC, 1x SPI Master or Slave, (instead of 3), No I2s...... The full datasheet and product briefs are available on Nordic's website so you can A-B the features.
                        • N NeverDie
                          @alowhum Thanks for your post. I just now looked on ebay, and there's an entire eco-system of little ad-ons for the micro bit! Lots of displays, buttons, sensors, power packs, etc.
                          I thought there would be a vast supply on ebay of cheap used BBC micro bits, but I didn't see any. Not sure, but maybe on the UK ebay they can be found. After all, I think a lot were given away for free initially by a magazine or something.
                          J Offline
                          J Offline
                          Jokgi
                          • N Offline
                            N Offline
                            An amusing video, which nonetheless suggests the power of tapping into existing bluetooth devices:
                            https://www.youtube.com/watch?v=bS1tPp2-l2w
                            • O Offline
                              O Offline
                              Omemanti
                              What are the options of getting OTA working? Is it supported? Or is it still work in progress? (If so, ia there an ETA?)
                              • O Omemanti
                                N Offline
                                N Offline
                                https://devzone.nordicsemi.com/f/nordic-q-a/38936/is-there-an-easier-to-use-ota-firmware-uploader
                                • N Offline
                                  N Offline
                                  #1719
                                  These are a bit cheaper than the Ebyte modules, and the breakout board is already built-in: https://www.aliexpress.com/item/NRF52832-Bluetooth-Module-BLE-4-2-Low-Power-Bluetooth-External-Antenna-IPEX-Support-Multi-Protocol/32904197412.html?spm=2114.search0104.3.102.772c16a3Fm2Lp8&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10130_10547_10546_10059_10884_10548_315_10545_10887_10696_100031_10084_531_10083_10103_10618_10307_449,searchweb201603_60,ppcSwitch_0&algo_expid=f8654a20-dd6e-4042-987f-5bd9eaf3c58d-15&algo_pvid=f8654a20-dd6e-4042-987f-5bd9eaf3c58d&transAbTest=ae803_4&priceBeautifyAB=0
                                  • N NeverDie
                                    J Offline
                                    J Offline
                                    Jokgi
                                    @neverdie And it has the 32Khz crystal on it too which will reduce power consumption. And It looks like the DC/DC converter is also included?
                                    • J Jokgi
                                      T Offline
                                      T Offline
                                      Toyman
                                      Guys, remind me pls: is CR2450 enough for the nrf52 Ebyte module acting as a Mysensors node?
                                      Is it capable to handle tx current spikes?
                                      Energizer datasheet states 9ma as max curent pulse. Is it sufficient?
                                      • N NeverDie
                                        T Offline
                                        T Offline
                                        Toyman
                                        @neverdie I've setup the bootloader for my BT project and I confirm its much easier than it looks.
                                        Can it be used for MySensors? For BT, I create a hex file in Keil and then upload it via nrftoolbox app.
                                        Can the same procedure be used with MySensors? OTA needs Softdevice and Softdevice is not compatible with MySensors
                                        • S Offline
                                          #1723
                                          @toyman said in nRF5 action!:
                                          yes but you need some power buffer for the spikes. So put 100uF low leakage ceramic capa close to batt holder, and you could also add one more close to your nrf5 module.
                                          You already have your answer I think ;)
