  3. OpenHAB
  4. Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable)
60 Posts 19 Posters 24.2k Views 23 Watching
  • F fredswed
    @itbeyond As always your mileage will vary depending on experience and goals.
    Disclaimer: I only have a couple of MYS-sensors and a small OpenHAB installation for sensing and remote light control. OpenHAB is a complex system so it takes time to master. Fortunately it also has great support and I really like it for its flexiblity, power and structure.
    • MQTT or ethernet bridge? I've tried both but never got MQTT to work. Based on the questions in the MYS forums I believe it is easier to use the ethernet connection. I find it easier to troubleshoot. You can start with the ethernet bridge to ensure everything works. Then you can easily switch to the MQTT setup if there are advantages for you. But unless you have other applications that also listen to the MYS messages, I can't really see any obvious reasons to use MQTT. (Of course, it may give you a warm, fuzzy feeling of having an all-MQTT sensor network.)
    • Definitely go for config files. Autodiscovery is neat but there are many things you can't do in PaperUI or that are very difficult to do there. In config files you can also add comments to explain to your future self why you did something.
      You can try autodiscovery and PaperUI first if you like and then move to config files. Then you may want to check out the OpenHAB forums on how to manually clear the cache. Sometimes the OH cache is a bit too clever for itself.
    • As I understand it, OTA is not supported by any MQTT controller. It is also not supported by OpenHAB. If you use the ethernet bridge you can keep your current ways of working - sensing and control in OpenHAB and update OTA via MYSController. If I'm not mistaken you only have to configure the MYS gw to accept at least two connections.
    You seem to know your way around OH already, but I will add a few general comments for beginners, based on my own experience with OpenHAB (as a non-developer):
    • First step is to set up backup and restore. Then test that it really works the way you intended.
    • Use the production release of OpenHAB unless you really need the bleeding edge. It can be very time consuming to revert from a beta/snapshot release to the production release.
    • Spend some time setting up OpenHAB and software around it so you can easily edit the config files. I use Openhabian which automatically shares all interesting files using Samba. It is then trivial to connect from my desktop and edit with my favourite editor. (MS Code has great support for OpenHAB config files.)
    • Spend some time on how to properly backup and restore OpenHAB so you can experiment freely and still easily revert if it crashes.
    • The OH forum is your friend. It is even more true than for MYS.
      E.g. check out the advice on how to name (and not name) your config files, things and items.
      and the OH patterns that provides beatiful solutions for many "impossible" problems.
    • Did I mention backup and restore? At least archive your config directory regularely.
    /Fredrik
    I
    I
    itbeyond
    @fredswed thanks for your comments. I have gone with Ethernet gateway as it works well and at this stage I do not need MQTT - maybe if I play with node-red or something down the track but for the moment happy with Ethernet - it just works. I did have MQTT working but the MYSController connection is a possible problem.
    I have also gone to the config files directly and have worked out the bridge setup in the things file and have a few test items running.
    Yes backups - done that and have my system backing up to a local NAS box.
    Cheers David
    • MasMatM
      MasMatM
      MasMat
      wrote on last edited by MasMat
      #33
      I need a fresh set of eyes on my problem.
      Gateway is online, but things are not discovered. I have tried adding them manually (my syntax could be wrong), but it doesn't help.
      There are no errors in mysgw.log-file.
      Mosquitto mysensors-out:
      mysensors-out/1/14/1/0/23 35
      mysensors-out/1/15/1/0/0 49
      mysgw.things:
      Bridge mysensors:bridge-mqtt:mygateway1 [brokerName="mosquitto",
                                            topicPublish="mysensors-in",
                                            topicSubscribe="mysensors-out",
                                            startupCheckEnabled=true ]
        temperature BoilerTemp [nodeID=1, childId=15]
        motion PukuhLiike [nodeID=1, childId=3]
      default.items:
      Number BoilerTemp "Lämminvesivaraaja [%.1f °C]" <heating> {channel="mysensors:temperature:mygateway1:temperature_1_15:temp"}
      Contact PukuhLiike "Pukuhuone Liike" <motion> {channel="mysensors:motion:mygateway1:motion_1_3:tripped"}
      OpenHab2 frontail:
      2018-08-13 22:34:03.284 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid paho111686078117 and file store '/var/lib/openhab2/mqtt/127.0.0.1'
      2018-08-13 22:34:05.499 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
      2018-08-13 22:34:11.928 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Helsinki'.
      2018-08-13 22:34:11.999 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'fi'.
      2018-08-13 22:34:20.211 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.51:8080
      2018-08-13 22:34:20.317 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.51:8443
      2018-08-13 22:35:16.502 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
      2018-08-13 22:35:34.984 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
      2018-08-13 22:35:38.657 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mys.things'
      2018-08-13 22:35:39.245 [.ItemChannelLinkAddedEvent] - Link 'PukuhLiike-mysensors:motion:mygateway1:motion_1_3:tripped' has been added.
      2018-08-13 22:35:39.309 [.ItemChannelLinkAddedEvent] - Link 'BoilerTemp-mysensors:temperature:mygateway1:temperature_1_15:temp' has been added.
      2018-08-13 22:36:14.848 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
      2018-08-13 22:36:18.741 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
      2018-08-13 22:36:22.407 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
      2018-08-13 22:36:25.610 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from UNINITIALIZED to INITIALIZING
      2018-08-13 22:36:26.660 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
      2018-08-13 22:36:26.861 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
      2018-08-13 22:36:27.453 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from INITIALIZING to ONLINE
      2018-08-13 22:36:27.546 [INFO ] [rotocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
      2018-08-13 22:36:28.075 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
      2018-08-13 22:36:28.120 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
      In my addons I have the 2.4.0 Snapshot.
      org.eclipse.smarthome.mqttbroker.cfg:
      name=mosquitto
      host=127.0.0.1
      secure=false
      port=1883
      username=XXXX
      password=YYYYY
      retain=false
      clientId=openhabian
      EDIT: After a week of trying things. This worked: https://forum.mysensors.org/post/73600
      No autodiscovery, but this switches my sensors ONLINE (even ones that are not powered up :( ), but it's not updating the values.
      • MasMatM MasMat
        mysgw.things:
        default.items:
        OpenHab2 frontail:
        name=mosquitto
        host=127.0.0.1
        secure=false
        port=1883
        username=XXXX
        password=YYYYY
        retain=false
        clientId=openhabian
        TimO
        @masmat said in Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable):
        No autodiscovery, but this switches my sensors ONLINE (even ones that are not powered up ), but it's not updating the values.
        Autodiscovery should work. :confused:
        Does the temperature thing in OH2 get updates? Is it working?
        The sensors will show up ONLINE if the connection to the broker is established, because the sensors are just a topic. There is at the moment no implementation to check if the sensors/things are really available. This could be done, but it is not implemented yet.
        MasMatM 1 Reply Last reply
        • T TimO
          MasMatM
          MasMatM
          MasMat
          #35
          @timo Before I did the re-install of everything autodiscovery was working, but now it isn't. Current sys: RpiZeroW, Openhabian 2.3.0-1release, mosquitto.
          The temperature is not updating in OH2. But the mysensors-out topic does show the gateway sending the values out. OH2 is not listening for some reason...
          Re-install some (which?) parts or bindings? Openhab2 mqtt-binding?
          Permissions?
          • T
            TimO
            Needs to be changed to:
            Number BoilerTemp "Lämminvesivaraaja [%.1f °C]" <heating> {channel="mysensors:temperature:mygateway1:BoilerTemp:temp"}
            But there is something additionally amiss, because discovery is not working.
            Please enable debug in the OH2 console and post the output of the initialization.
            Don't spend time reinstalling, this looks like a configuration issue.
            • T TimO
              MasMatM
              MasMatM
              MasMat
              @timo Firstly, I am very thankful for your help.
              I changed that item and it started receiving values! I think there's something wrong with my light-level sensor's syntax too.
              In console I did: log:set DEBUG.
              That prints out hundreds and hundreds of lines....should I narrow the search somehow?
              • MasMatM MasMat
                TimO
                @masmat I'm glad the first sensor is updating now. Please post the the thing and item definition of the light sensor and I'll look at it.
                I only need the debug output from the binding so please use:
                log:set DEBUG org.openhab.binding.mysensors
                • T TimO
                  MasMatM
                  MasMatM
                  MasMat
                  @timo OK, here's the output:
                  2018-08-15 23:55:44.092 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid paho79389486520739 and file store '/var/lib/openhab2/mqtt/127.0.0.1'
                  2018-08-15 23:55:47.333 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
                  2018-08-15 23:55:53.357 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Helsinki'.
                  2018-08-15 23:55:53.406 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '60.172424790463936,25.020736667463083'.
                  2018-08-15 23:55:53.427 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'fi'.
                  2018-08-15 23:56:01.971 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.51:8080
                  2018-08-15 23:56:02.082 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.51:8443
                  2018-08-15 23:57:01.390 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
                  2018-08-15 23:57:21.507 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                  2018-08-15 23:57:24.448 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
                  2018-08-15 23:57:26.351 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mys.things'
                  ==> /var/log/openhab2/events.log <==
                  2018-08-15 23:57:27.306 [.ItemChannelLinkAddedEvent] - Link 'PukuhLiike-mysensors:motion:mygateway1:PukuhLiike:tripped' has been added.
                  2018-08-15 23:57:27.346 [.ItemChannelLinkAddedEvent] - Link 'PukuhValoisuus-mysensors:light-level:mygateway1:PukuhValoisuus:light-level' has been added.
                  2018-08-15 23:57:27.424 [.ItemChannelLinkAddedEvent] - Link 'TalliSivuoviLukko-mysensors:lock:mygateway1:TalliSivuoviLukko:lock-status' has been added.
                  2018-08-15 23:57:27.487 [.ItemChannelLinkAddedEvent] - Link 'BoilerTemp-mysensors:temperature:mygateway1:BoilerTemp:temp' has been added.
                  2018-08-15 23:57:27.655 [.ItemChannelLinkAddedEvent] - Link 'TalliSivuovi-mysensors:door:mygateway1:TalliSivuovi:tripped' has been added.
                  ==> /var/log/openhab2/openhab.log <==
                  2018-08-15 23:57:44.601 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
                  2018-08-15 23:57:46.005 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=296, service.bundleid=197, service.scope=bundle, component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=176} - org.openhab.binding.mysensors
                  2018-08-15 23:57:47.811 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
                  2018-08-15 23:57:53.081 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                  2018-08-15 23:57:56.733 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                  2018-08-15 23:57:59.038 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                  2018-08-15 23:58:02.474 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
                  2018-08-15 23:58:02.518 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from UNINITIALIZED to INITIALIZING
                  2018-08-15 23:58:02.740 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
                  2018-08-15 23:58:02.777 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1]
                  2018-08-15 23:58:03.074 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
                  2018-08-15 23:58:03.246 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Connected to MQTT broker!
                  2018-08-15 23:58:03.294 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=324, service.bundleid=197, service.scope=singleton} - org.openhab.binding.mysensors
                  2018-08-15 23:58:03.308 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
                  2018-08-15 23:58:03.330 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
                  2018-08-15 23:58:03.493 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
                  2018-08-15 23:58:03.617 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
                  2018-08-15 23:58:03.743 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mysensors-out/+/+/+/+/+
                  2018-08-15 23:58:03.840 [hingStatusInfoChangedEvent] - 'mysensors:light-level:mygateway1:PukuhValoisuus' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
                  2018-08-15 23:58:03.908 [hingStatusInfoChangedEvent] - 'mysensors:door:mygateway1:TalliSivuovi' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
                  2018-08-15 23:58:03.997 [hingStatusInfoChangedEvent] - 'mysensors:lock:mygateway1:TalliSivuoviLukko' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
                  2018-08-15 23:58:04.055 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
                  2018-08-15 23:58:04.076 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mysensors-in, Message: 0;0;3;0;2;
                  2018-08-15 23:58:04.241 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/0/255/3/0/2, Message: 2.3.0
                  2018-08-15 23:58:04.276 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 0/255/3/0/2
                  2018-08-15 23:58:04.311 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 0;255;3;0;2;2.3.0
                  2018-08-15 23:58:04.373 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.3.0
                  2018-08-15 23:58:04.390 [DEBUG] [rsAbstractConnection$MySensorsReader] - Good,Gateway is up and running! (Ver:2.3.0)
                  2018-08-15 23:58:04.849 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from INITIALIZING to ONLINE
                  2018-08-15 23:58:04.940 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [1]
                  2018-08-15 23:58:04.975 [INFO ] [rotocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
                  2018-08-15 23:58:05.191 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=5, childId=5, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  2018-08-15 23:58:05.211 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                  2018-08-15 23:58:05.224 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=15, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  2018-08-15 23:58:05.347 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=3, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  2018-08-15 23:58:05.404 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=14, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  2018-08-15 23:58:05.494 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=5, childId=6, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false}
                  2018-08-15 23:58:05.521 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=5, childNumber=1, chidldList={5=MySensorsChild [childId=5, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LOCK_STATUS=MySensorsVariableVLockStatus [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]}]
                  2018-08-15 23:58:05.610 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {5=MySensorsChild [childId=5, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LOCK_STATUS=MySensorsVariableVLockStatus [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]} with: {6=MySensorsChild [childId=6, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_TRIPPED=MySensorsVariableVTripped [value=null], V_ARMED=MySensorsVariableVArmed [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]}
                  2018-08-15 23:58:05.607 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 5-5 not registered yet, registering...
                  2018-08-15 23:58:05.704 [hingStatusInfoChangedEvent] - 'mysensors:lock:mygateway1:TalliSivuoviLukko' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                  2018-08-15 23:58:05.737 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {} with: {14=MySensorsChild [childId=14, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_LEVEL=MySensorsVariableVLevel [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LIGHT_LEVEL=MySensorsVariableVLightLevel [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]}
                  2018-08-15 23:58:05.800 [hingStatusInfoChangedEvent] - 'mysensors:light-level:mygateway1:PukuhValoisuus' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                  2018-08-15 23:58:05.769 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 5-6 not registered yet, registering...
                  2018-08-15 23:58:05.783 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {14=MySensorsChild [childId=14, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_LEVEL=MySensorsVariableVLevel [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LIGHT_LEVEL=MySensorsVariableVLightLevel [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]} with: {15=MySensorsChild [childId=15, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null], V_TEMP=MySensorsVariableVTemp [value=null], V_ID=MySensorsVariableVId [value=null]}]}
                  2018-08-15 23:58:05.795 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 1-14 not registered yet, registering...
                  2018-08-15 23:58:05.858 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {14=MySensorsChild [childId=14, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_LEVEL=MySensorsVariableVLevel [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LIGHT_LEVEL=MySensorsVariableVLightLevel [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}], 15=MySensorsChild [childId=15, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null], V_TEMP=MySensorsVariableVTemp [value=null], V_ID=MySensorsVariableVId [value=null]}]} with: {3=MySensorsChild [childId=3, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_TRIPPED=MySensorsVariableVTripped [value=null], V_ARMED=MySensorsVariableVArmed [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]}
                  2018-08-15 23:58:05.866 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 1-15 not registered yet, registering...
                  2018-08-15 23:58:05.908 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                  2018-08-15 23:58:05.902 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 1-3 not registered yet, registering...
                  2018-08-15 23:58:05.982 [hingStatusInfoChangedEvent] - 'mysensors:door:mygateway1:TalliSivuovi' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
                  2018-08-15 23:58:06.050 [hingStatusInfoChangedEvent] - 'mysensors:lock:mygateway1:TalliSivuoviLukko' changed from INITIALIZING to ONLINE
                  2018-08-15 23:58:06.109 [hingStatusInfoChangedEvent] - 'mysensors:light-level:mygateway1:PukuhValoisuus' changed from INITIALIZING to ONLINE
                  2018-08-15 23:58:06.160 [hingStatusInfoChangedEvent] - 'mysensors:door:mygateway1:TalliSivuovi' changed from INITIALIZING to ONLINE
                  2018-08-15 23:58:06.202 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from INITIALIZING to ONLINE
                  2018-08-15 23:58:06.253 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from INITIALIZING to ONLINE
                  2018-08-15 23:58:10.493 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/14/1/0/23, Message: 0
                  2018-08-15 23:58:10.511 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/14/1/0/23
                  2018-08-15 23:58:10.526 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;14;1;0;23;0
                  2018-08-15 23:58:10.542 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;14;1;0;23;0
                  2018-08-15 23:58:10.574 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-08-15 23:58:10.586 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/15/1/0/0, Message: 53
                  2018-08-15 23:58:10.606 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/15/1/0/0
                  2018-08-15 23:58:10.591 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 14 found in node 1
                  2018-08-15 23:58:10.619 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;15;1;0;0;53
                  2018-08-15 23:58:10.661 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: light-level(V_LIGHT_LEVEL) value to: 0
                  2018-08-15 23:58:11.034 [vent.ItemStateChangedEvent] - PukuhValoisuus changed from NULL to 0
                  2018-08-15 23:58:11.617 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/14 to 2018-08-15T23:58:10.000+0300
                  2018-08-15 23:58:11.629 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;15;1;0;0;53
                  2018-08-15 23:58:11.642 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-08-15 23:58:11.657 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 15 found in node 1
                  2018-08-15 23:58:11.671 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: temp(V_TEMP) value to: 53
                  2018-08-15 23:58:11.758 [vent.ItemStateChangedEvent] - BoilerTemp changed from NULL to 53
                  2018-08-15 23:58:11.770 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/15 to 2018-08-15T23:58:11.000+0300
                  2018-08-15 23:58:47.461 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/14/1/0/23, Message: 0
                  2018-08-15 23:58:47.482 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/14/1/0/23
                  2018-08-15 23:58:47.495 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;14;1;0;23;0
                  2018-08-15 23:58:47.513 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;14;1;0;23;0
                  2018-08-15 23:58:47.533 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-08-15 23:58:47.565 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/15/1/0/0, Message: 53
                  2018-08-15 23:58:47.556 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 14 found in node 1
                  2018-08-15 23:58:47.579 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: light-level(V_LIGHT_LEVEL) value to: 0
                  2018-08-15 23:58:47.597 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/15/1/0/0
                  2018-08-15 23:58:47.612 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;15;1;0;0;53
                  2018-08-15 23:58:47.719 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/14 to 2018-08-15T23:58:47.000+0300
                  2018-08-15 23:58:47.731 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;15;1;0;0;53
                  2018-08-15 23:58:47.750 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway
                  2018-08-15 23:58:47.765 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 15 found in node 1
                  2018-08-15 23:58:47.778 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: temp(V_TEMP) value to: 53
                  2018-08-15 23:58:47.839 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/15 to 2018-08-15T23:58:47.000+0300
                  And my item & thing (in separate files of course):
                  Number PukuhValoisuus   "Pukuhuone valoisuus [%.1f %]"  <719914_monitor> {channel="mysensors:light-level:mygateway1:PukuhValoisuus:light-level"}
                  light-level PukuhValoisuus [nodeId=1, childId=14]
                  • I
                    I
                    itbeyond
                    wrote on last edited by itbeyond
                    #40
                    I have a strange issue now when I am trying to bring my irrigation controller over from Vera to openHab. I setup the Ethernet Gateway and have several nodes working ok. I then configured the binding to have the irrigation controller as follows:
                    Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.100.63", tcpPort=5003, sendDelay=150,  startupCheckEnabled=true,  networkSanCheckEnabled=true, networkSanCheckInterval=1, networkSanCheckConnectionFailAttempts=1 ] {
                      light     Water_All_Zones "Water - All Zones" @ "Backyard"    [ nodeId=2, childId=0 ]
                      light     Water_Zone1     "Water - Veg Garden" @ "Backyard"   [ nodeId=2, childId=1 ]
                      light     Water_Zone2     "Water - Rear Garden" @ "Backyard"  [ nodeId=2, childId=2 ]
                      light     Water_Zone3     "Water - Side Garden" @ "Backyard"  [ nodeId=2, childId=3 ]
                      light     Water_Zone4     "Water - Verge Grass" @ "Backyard"  [ nodeId=2, childId=4 ]
                      light     Water_Zone5     "Water - Front Grass" @ "Backyard"  [ nodeId=2, childId=5 ]
                      light     Water_Zone6     "Water - Front Garden" @ "Backyard" [ nodeId=2, childId=6 ]
                      cover     Courtyard_Door_Blind  "Door Blind" @ "Courtyard" [ nodeId=4, childId=1 ]
                      cover     Office_Front_Blinds   "Front Blinds" @ "Office" [ nodeId=4, childId=2 ]
                      cover     Office_Side_Blinds    "Side Blinds" @ "Office" [ nodeId=4, childId=3 ]
                      cover     Courtyard_LHS_Blinds   "LHS Blinds" @ "Courtyard" [ nodeId=4, childId=4 ]
                      cover     Courtyard_RHS_Blinds   "RHS Blinds" @ "Courtyard" [ nodeId=4, childId=5 ]
                      power     Power_Phase1  "Energy Phase 1" @ "Garage"  [ nodeId=5, childId=0 ]
                      power     Power_Phase2  "Energy Phase 2" @ "Garage"  [ nodeId=5, childId=1 ]
                      power     Power_Phase3  "Energy Phase 3" @ "Garage"  [ nodeId=5, childId=2 ]
                      power     Power_Main    "Energy Main" @ "Garage"  [ nodeId=5, childId=8 ]
                      light     Entry_FrontGarden_Lights    "Power Socket Relay" @ "Entry"  [ nodeId=7, childId=1 ]
                      light     Office_Door   "Door Controller" @ "Office"  [ nodeId=13, childId=1 ]
                      light     Desktop_Debug_Light   "Power Socket Relay" @ "Office"  [ nodeId=27, childId=1 ]
                    So far so good, I then setup the items as follows:
                    Switch  Water_All_Zones     "Water All Zones" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ]  {channel="mysensors:light:gateway:Water_All_Zones:status"}
                    Switch  Water_Veg_Garden    "Water - Veg Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ]  {channel="mysensors:light:gateway:Water_Zone1:status"}
                    Switch  Water_Rear_Garden   "Water - Rear Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ]  {channel="mysensors:light:gateway:Water_Zone2:status"}
                    Switch  Water_Side_Garden   "Water - Side Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ]  {channel="mysensors:light:gateway:Water_Zone3:status"}
                    Switch  Water_Verge_Grass   "Water - Verge Grass" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ]  {channel="mysensors:light:gateway:Water_Zone4:status"}
                    Switch  Water_Front_Grass   "Water - Front Grass" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ]  {channel="mysensors:light:gateway:Water_Zone5:status"}
                    Switch  Water_Front_Garden  "Water - Front Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_Zone6:status"}
                    Number  Water_Zone1_AllTime "Water - Zone 1 - All Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone1:var1"}
                    Number  Water_Zone2_AllTime "Water - Zone 2 - All Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone2:var1"}
                    Number  Water_Zone3_AllTime "Water - Zone 3 - All Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone3:var1"}
                    Number  Water_Zone4_AllTime "Water - Zone 4 - All Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone4:var1"}
                    Number  Water_Zone5_AllTime "Water - Zone 5 - All Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone5:var1"}
                    Number  Water_Zone6_AllTime "Water - Zone 6 - All Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone6:var1"}
                    Number  Water_Zone1_Time    "Water - Zone1 - Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone1:var2"}
                    Number  Water_Zone2_Time    "Water - Zone2 - Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone2:var2"}
                    Number  Water_Zone3_Time    "Water - Zone3 - Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone3:var2"}
                    Number  Water_Zone4_Time    "Water - Zone4 - Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone4:var2"}
                    Number  Water_Zone5_Time    "Water - Zone5 - Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone5:var2"}
                    Number  Water_Zone6_Time    "Water - Zone6 - Time [%d]" <selfruntime>  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone6:var2"}
                    String  Water_Zone1_Name    "Water - Zone1 - Name [%s]"  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone1:var3"}
                    String  Water_Zone2_Name    "Water - Zone2 - Name [%s]"  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone2:var3"}
                    String  Water_Zone3_Name    "Water - Zone3 - Name [%s]"  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone3:var3"}
                    String  Water_Zone4_Name    "Water - Zone4 - Name [%s]"  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone4:var3"}
                    String  Water_Zone5_Name    "Water - Zone5 - Name [%s]"  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone5:var3"}
                    String  Water_Zone6_Name    "Water - Zone6 - Name [%s]"  (gDevices,gRoom_Backyard)   {channel="mysensors:light:gateway:Water_Zone6:var3"}
                    As the Irrigation project uses 3 vars to manage time and names I setup a System Started rule as follows:
                    rule "System started"
                    when
                        System started
                    then
                        createTimer(now.plusSeconds(180)) [ |
                            logInfo("Watering", "System started")
                            if (Water_Zone1_AllTime.state == NULL) Water_Zone1_AllTime.sendCommand(5 as Number)
                            if (Water_Zone2_AllTime.state == NULL) Water_Zone2_AllTime.sendCommand(8 as Number)
                            if (Water_Zone3_AllTime.state == NULL) Water_Zone3_AllTime.sendCommand(8 as Number)
                            if (Water_Zone4_AllTime.state == NULL) Water_Zone4_AllTime.sendCommand(12 as Number)
                            if (Water_Zone5_AllTime.state == NULL) Water_Zone5_AllTime.sendCommand(12 as Number)
                            if (Water_Zone6_AllTime.state == NULL) Water_Zone6_AllTime.sendCommand(10 as Number)
                            if (Water_Zone1_Time.state == NULL) Water_Zone1_Time.sendCommand(5 as Number)
                            if (Water_Zone2_Time.state == NULL) Water_Zone2_Time.sendCommand(8 as Number)
                            if (Water_Zone3_Time.state == NULL) Water_Zone3_Time.sendCommand(8 as Number)
                            if (Water_Zone4_Time.state == NULL) Water_Zone4_Time.sendCommand(12 as Number)
                            if (Water_Zone5_Time.state == NULL) Water_Zone5_Time.sendCommand(12 as Number)
                            if (Water_Zone6_Time.state == NULL) Water_Zone6_Time.sendCommand(10 as Number)
                            if (Water_Zone1_Name.state == NULL) Water_Zone1_Name.sendCommand("Veg Garden")
                            if (Water_Zone2_Name.state == NULL) Water_Zone2_Name.sendCommand("Rear Garden")
                            if (Water_Zone3_Name.state == NULL) Water_Zone3_Name.sendCommand("Side Garden")
                            if (Water_Zone4_Name.state == NULL) Water_Zone4_Name.sendCommand("Verge Grass")
                            if (Water_Zone5_Name.state == NULL) Water_Zone5_Name.sendCommand("Front Grass")
                            if (Water_Zone6_Name.state == NULL) Water_Zone6_Name.sendCommand("Front Garden")
                    end
                    This all loaded up nicely (for interest I tried postUpdate as well as sendCommand) shows the right stuff in PaperUI - Control can see all the numbers and string however I have had several issues with the setup.
                    Firstly when my controller requests the time from the gateway it receives UTC and is showing the wrong time on the LCD display. I have checked that my controller is configured for the right timezone and is showing the right time but everytime I reset the Irrigation controller and it requests the time it is getting UTC. (I did work once and got the right time but not sure how this occurred) I rebooted the openhabianpi unit and it is still delivering UTC, but the fact it did it right once means I cannot just adjust the timezone in the node as it may get it right somehow and then be adjusted wrong! I would have thought the gateway should deliver the correct system time.
                    Secondly I cannot get the Irrigation Controller to read the var3 String value - when this is requested from from the Irrigation controller it only gets a 0 (numeric). This seems to indicate that the var's can only handle a Number - is this true and how does one get around this if this is the case? I tried changing the value in PaperUI and it changes but nothing gets sent to the node but changing the numeric values in var1 & 2 update to the node - all updates are shown in the logtail.
                    For the record here is the Serial boot log from the node:
                     __  __       ____
                            |___/                      2.2.0
                    25 TSM:INIT
                    26 TSF:WUR:MS=0
                    33 TSM:INIT:TSP OK
                    35 TSM:INIT:STATID=2
                    37 TSF:SID:OK,ID=2
                    39 TSM:FPAR
                    75 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    81 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    87 TSF:MSG:FPAR OK,ID=0,D=1
                    2082 TSM:FPAR:OK
                    2083 TSM:ID
                    2084 TSM:ID:OK
                    2086 TSM:UPL
                    2089 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2100 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2105 TSF:MSG:PONG RECV,HP=1
                    2107 TSM:UPL:OK
                    2109 TSM:READY:ID=2,PAR=0,DIS=1
                    2113 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2120 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2127 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
                    2137 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2156 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    2163 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:Irrigation Ctrl (2)
                    2173 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:4.0
                    2182 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2189 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2196 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2204 TSF:MSG:SEND,2-2-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2211 TSF:MSG:SEND,2-2-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2219 TSF:MSG:SEND,2-2-0-0,s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2227 TSF:MSG:SEND,2-2-0-0,s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2232 MCO:REG:REQ
                    2236 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    2242 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2247 MCO:PIM:NODE REG=1
                    2249 MCO:BGN:STP
                    Initialising...
                    Turning All Valves Off...
                    Checking EEPROM for stored date:
                    Retreiving last run time from EEPROM...
                    Sensor Presentation Complete
                    Ready...
                    2907 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    Requesting time from Gateway:
                    2932 TSF:MSG:READ,0-0-2,s=255,c=3,t=1,pt=0,l=10,sg=0:1534904507
                    Time value received and updated...
                    Clock updated....
                    Sensor's time currently set to: 02:21am ***** Should be 10:21am GMT +8 *******
                    8/22/2018
                    Wednesday
                    Calling for Valve 1 Data...
                    3946 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    3966 TSF:MSG:READ,0-0-2,s=1,c=1,t=24,pt=0,l=1,sg=0:5
                    Recieved variable1 valve:1 = 5
                    New Zone Times Recieved...
                    Zone 1 individual time: 0 group time: 5 name: Zone 1
                    Zone 2 individual time: 0 group time: 0 name: Zone 2
                    Zone 3 individual time: 0 group time: 0 name: Zone 3
                    Zone 4 individual time: 0 group time: 0 name: Zone 4
                    Zone 5 individual time: 0 group time: 0 name: Zone 5
                    Zone 6 individual time: 0 group time: 0 name: Zone 6
                    4005 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4065 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4116 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:5
                    Recieved variable2 valve:1 = 5
                    Zone 1 individual time: 5 group time: 5 name: Zone 1
                    4152 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4212 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4267 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:5
                    Calling for Valve 2 Data...
                    4303 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    4363 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    4417 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0
                    Recieved variable3 valve: 1 = 0
                    4425 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4484 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4543 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4567 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0
                    4602 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4662 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4717 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:8
                    Recieved variable1 valve:2 = 8
                    Zone 1 individual time: 5 group time: 5 name: 0
                    Zone 2 individual time: 0 group time: 8 name: Zone 2
                    Calling for Valve 3 Data...
                    4781 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    4839 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    4868 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:8
                    4898 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4957 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5016 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5022 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:8
                    Recieved variable2 valve:2 = 8
                    Zone 2 individual time: 8 group time: 8 name: Zone 2
                    5075 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5135 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5168 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:8
                    Calling for Valve 4 Data...
                    5222 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5281 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5318 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:8
                    5340 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5399 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5458 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5474 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0
                    Recieved variable3 valve: 2 = 0
                    5518 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5577 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5619 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0
                    Calling for Valve 5 Data...
                    5663 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5722 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5770 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:8
                    Recieved variable1 valve:3 = 8
                    Zone 2 individual time: 8 group time: 8 name: 0
                    Zone 3 individual time: 0 group time: 8 name: Zone 3
                    5805 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5865 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5931 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5952 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:8
                    5996 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6055 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6071 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:8
                    Recieved variable2 valve:3 = 8
                    Zone 3 individual time: 8 group time: 8 name: Zone 3
                    Calling for Valve 6 Data...
                    6142 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    6202 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    6220 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:8
                    6261 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6320 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6371 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:8
                    6379 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6438 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6498 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6521 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0
                    Recieved variable3 valve: 3 = 0
                    6556 MCO:BGN:INIT OK,TSP=1
                    6723 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0
                    6927 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=2,sg=0:12
                    Recieved variable1 valve:4 = 12
                    Zone 3 individual time: 8 group time: 8 name: 0
                    Zone 4 individual time: 0 group time: 12 name: Zone 4
                    7129 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=2,sg=0:12
                    7148 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=2,sg=0:12
                    Recieved variable2 valve:4 = 12
                    Zone 4 individual time: 12 group time: 12 name: Zone 4
                    7331 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=2,sg=0:12
                    7534 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=2,sg=0:12
                    7736 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0
                    Recieved variable3 valve: 4 = 0
                    7754 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0
                    7939 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=2,sg=0:12
                    Recieved variable1 valve:5 = 12
                    Zone 4 individual time: 12 group time: 12 name: 0
                    Zone 5 individual time: 0 group time: 12 name: Zone 5
                    8141 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=2,sg=0:12
                    8344 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=2,sg=0:12
                    Recieved variable2 valve:5 = 12
                    Zone 5 individual time: 12 group time: 12 name: Zone 5
                    8375 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=2,sg=0:12
                    8546 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=2,sg=0:12
                    8748 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0
                    Recieved variable3 valve: 5 = 0
                    8950 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0
                    8970 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=2,sg=0:10
                    Recieved variable1 valve:6 = 10
                    Zone 5 individual time: 12 group time: 12 name: 0
                    Zone 6 individual time: 0 group time: 10 name: Zone 6
                    9153 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=2,sg=0:10
                    9356 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=2,sg=0:10
                    Recieved variable2 valve:6 = 10
                    Zone 6 individual time: 10 group time: 10 name: Zone 6
                    9559 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=2,sg=0:10
                    9577 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0
                    Recieved variable3 valve: 6 = 0
                    9760 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0
                    9963 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0
                    EDIT - After the next openHab restart when the variables all got restored from Persistance they all show up right but now the node when reboot will not pick up the data see this node reboot log (Note Zone 1 group time 5 came through as I had forced a sendCommand on that single item - all other values restored from persistance - seems the same issue if they come from postUpdate also)
                     __  __       ____
                            |___/                      2.2.0
                    25 TSM:INIT
                    26 TSF:WUR:MS=0
                    33 TSM:INIT:TSP OK
                    37 TSF:SID:OK,ID=2
                    39 TSM:FPAR
                    388 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    393 TSF:MSG:FPAR OK,ID=0,D=1
                    2082 TSM:FPAR:OK
                    2083 TSM:ID
                    2084 TSM:ID:OK
                    2086 TSM:UPL
                    2107 TSM:UPL:OK
                    2128 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
                    2162 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    2170 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:Irrigation Ctrl (2)
                    2180 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:4.0
                    2188 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2195 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2203 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2210 TSF:MSG:SEND,2-2-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2217 TSF:MSG:SEND,2-2-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2226 TSF:MSG:SEND,2-2-0-0,s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2233 TSF:MSG:SEND,2-2-0-0,s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    2239 MCO:REG:REQ
                    2242 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    2249 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    2254 MCO:PIM:NODE REG=1
                    2256 MCO:BGN:STP
                    Initialising...
                    Ready...
                    2914 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
                    2939 TSF:MSG:READ,0-0-2,s=255,c=3,t=1,pt=0,l=10,sg=0:1534915205
                    Clock updated....
                    Sensor's time currently set to: 05:20am
                    8/22/2018
                    Wednesday
                    3952 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    3976 TSF:MSG:READ,0-0-2,s=1,c=1,t=24,pt=0,l=1,sg=0:5
                    4012 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4072 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4126 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:0
                    Recieved variable2 valve:1 = 0
                    4134 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4194 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4253 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4276 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:0
                    4340 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    4399 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    4426 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0
                    4458 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4517 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4611 !TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=NACK:
                    4670 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=1,st=OK:
                    4729 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    4736 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0
                    4789 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4848 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    4878 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:0
                    Recieved variable1 valve:2 = 0
                    4935 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    4995 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5027 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:0
                    5054 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5113 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5173 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5179 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0
                    Recieved variable2 valve:2 = 0
                    5232 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5292 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5328 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0
                    5379 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5438 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5479 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0
                    5497 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5557 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5616 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    5632 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0
                    5676 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5735 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    5780 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0
                    5822 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5881 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    5929 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0
                    5941 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6000 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6060 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6080 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:0
                    Recieved variable1 valve:3 = 0
                    6119 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6178 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6231 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:0
                    6267 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    6326 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                    6381 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:0
                    Recieved variable2 valve:3 = 0
                    6389 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6448 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6507 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK:
                    6531 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:0
                    6566 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6626 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK:
                    6681 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:0
                    6689 MCO:BGN:INIT OK,TSP=1
                    6884 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0
                    7087 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0
                    7288 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=1,sg=0:0
                    Recieved variable1 valve:4 = 0
                    7308 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=1,sg=0:0
                    7491 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=1,sg=0:0
                    Recieved variable2 valve:4 = 0
                    7694 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=1,sg=0:0
                    7897 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=1,sg=0:0
                    7915 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0
                    8099 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0
                    8301 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=1,sg=0:0
                    Recieved variable1 valve:5 = 0
                    8504 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=1,sg=0:0
                    8522 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=1,sg=0:0
                    Recieved variable2 valve:5 = 0
                    8706 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=1,sg=0:0
                    8908 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=1,sg=0:0
                    9111 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0
                    9129 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0
                    9313 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=1,sg=0:0
                    Recieved variable1 valve:6 = 0
                    9516 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=1,sg=0:0
                    9718 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=1,sg=0:0
                    Recieved variable2 valve:6 = 0
                    9737 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=1,sg=0:0
                    9921 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=1,sg=0:0
                    10123 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0
                    10326 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0
                    Sorry also just realised I am posting in an MQTT thread - I had an MQTT Gateway and now changed to Ethernet.
                    • C
                      C
                      CrisVarela
                      Hi all, and thanks for the previous posts.
                      I was having the same issue where the Bridge would stay as INITIALIZING. My set up is a little different as I use Openhan on docker with the following volumes mounting in /opt/openhab:
                      -v /etc/localtime:/etc/localtime:ro \
                      -v /etc/timezone:/etc/timezone:ro \
                      -v /opt/openhab/conf:/openhab/conf \
                      -v /opt/openhab/userdata:/openhab/userdata \
                      -v /opt/openhab/addons:/openhab/addons \
                      -v /opt/openhab/.java:/openhab/.java \
                      I'm using OH2.3 with the Docker Image: openhab/openhab:2.3.0-amd64-debian and the location of the org.eclipse.smarthome.mqttbroker.cfg file is in /opt/openhab/userdata/config/org/eclipse/smarthome.
                      After making all the changes above I couldn't get the Brdige to work, until finally I downloaded the MySensors addon 2.4.0 from http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.4.0-SNAPSHOT.jar as suggested by @MasMat and placed it in /opt/openhab/addons.
                      Immediately the status of the bridge changed to ONLINE.
                      Hope this helps sombedy.
                      C
                      • MasMatM MasMat
                        @timo I did. I can't figure out where it's finding that .0 it adds to the 1883 port I have in the cfg-file
                        Marcin Korpacki
                        @masmat
                        Were You able to find out what is wrong regarding MQTT port 1883.0
                        Suddenly I have the same error...no idea why. It was working just yesterday.
                        • Puneit ThukralP
                          Puneit ThukralP
                          Puneit Thukral
                            martim
                            I am very new to openHAB but I am really getting crazy with it. I did exactly what was on top of the screen. But I get an error the MYSensors MQTT Gateway was initializing.. and never came out. So I continue too read and I switch to the binding v 2.4.0. But wathever I do I get an error:
                            mysensors:bridge-mqtt:gateway' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback
                            I am not sure where to look and what to change. This is in my demo.things file.
                            Bridge mysensors:bridge-mqtt:gateway [ brokerName="mosquitto", topicPublish="mygateway1-in", topicSubscribe="mygatewa$
                                    temperature             temp01  [ nodeId=5, childId=0 ]
                            name=mosquitto
                            host=192.168.10.4 <- This points to the MySensors gateway PI (different then the openHAB)
                            secure=false
                            port=1883
                            retain=false
                            Any idears what I can try?
                            F 1 Reply Last reply
                            • M martim
                              name=mosquitto
                              secure=false
                              port=1883
                              retain=false
                              F
                              F
                              fredswed
                              @martim I'm running OpenHAB with a few MYS sensors (and other subsystems) and I really like the system system. It is complex with a steep learning curve but incredibly flexible and powerful.
                              As for your problems with MYS/MQTT I have no solution but to use the direct connection over ethernet instead. I have tried switching to MQTT twice and failed miserably both times.
                              The MYS addon requires the new MQTT binding which easily collides with the old one. (The new MQTT binding is almost ready for release so it may have been fixed, if you are lucky.)
                              I don't know if the cause of this problem is with the OpenHAB MQTT bindings or with the MYS binding but it was not trivial to fix with the instructions available. As I could not really see any upside of using MQTT except to have an "all MQTT System" I went back to the ethernet connection which works fine.
                              I would recommend connecting it as ethernet connection first and get it working that way. Then you can switch to MQTT if you want to. The biggets hurdles are installation of supportive packages (mqtt and serial transports) and getting MQTT to work in parallel with MQTT binding version 1. If you post your logs (WARN level for the Mys binding) I can try help you decode it.
                              • F fredswed
                                martim
                                wrote on last edited by martim
                                #46
                                @fredswed Hi, I really like MQTT so that is my prefered method. But I can try first on ethernet and then step back. I will try in the weekend since I am now a week away :( I used the latest version of the binding and also for MQTT.
                                  martim
                                  I spend again a few hours. I really want to get it to work with MQTT as I have my complete system based on it. But Apparently, the binding does not work and also the log does not say much. Only those errors:
                                  2018-12-17 11:38:03.559 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'mysensors:bridge-mqtt:gateway': org/eclipse/sma
                                  java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback
                                          at java.lang.ClassLoader.defineClass1(Native Method) ~[?:?]
                                          at java.lang.ClassLoader.defineClass(ClassLoader.java:763) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:276) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:655) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
                                          at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
                                          at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
                                          at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection.<init>(MySensorsMqttConnection.java:44) ~[?:?]
                                          at org.openhab.binding.mysensors.internal.gateway.MySensorsGateway.setup(MySensorsGateway.java:99) ~[?:?]
                                          at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:81) ~[?:?]
                                          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
                                          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
                                          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
                                          at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?]
                                          at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh230]
                                          at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230]
                                          at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?]
                                          at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?]
                                          at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?]
                                          at java.lang.Thread.run(Thread.java:748) [?:?]
                                  Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.io.transport.mqtt.MqttActionCallback cannot be found by org.openhab.binding.mysensors_2.4.0.201812040738
                                  G 1 Reply Last reply
                                  • M martim
                                    G
                                    G
                                    Guillermo Schimmel
                                    wrote on last edited by Guillermo Schimmel
                                    #48
                                    @martim Don't use the binding! Use plain MQTT.
                                    I'd love to have a simple working binding but it isn't there yet. Use plain mqtt elements and it'll work great.
                                    The new mqtt binding works. I don't like the mechanism needed to configure the broker, and then each thing, but works, and it is in fact more integrated with openhab than ever.
                                    If you have any questions do not hesitate to contact me.
                                      A Former User
                                      The new MQTT binding requires parts of the new automation engine. This is missing from your system for some reason. Should be automatically installed when MQTT or the MySensors binding are installed.
                                      This statement is not correct. The OH 2.4 release officially supports the new binding and if any errors are reported, they are getting fixed. The new binding allows Paper UI and textual configuration so there is no reason to start with mqtt1 nowadays.
                                      Cheers,
                                      David
                                      • ? A Former User
                                        Cheers,
                                        David
                                        G
                                        G
                                        Guillermo Schimmel
                                        @davidgraeff Yes David, you are correct. The new binding works. I'm in fact using it and with the corresponding changes on the items files its ok.
                                        I would love some kind of auto discovery though. In order to create each thing you have to manually enter the topic (which on mysensors is very complex)
                                        Anyways, I will try to edit previous message which is in fact wrong.
                                        • MasMatM MasMat
                                          @jogant Finally had time to double check this:
                                          Paper UI:
                                          Broker Name
                                          mosquitto
                                          Subscription Topic
                                          mygateway1-out
                                          Publish Topic
                                          mygateway1-in
                                          Send Delay 100
                                          Startup check enabled
                                          Metric answer enabled
                                          Network sanity check enabled
                                          Interval to launch network sanity check 3
                                          Attempts before disconnecting the bridge 3
                                          Heartbeat disabled
                                          Attempts before disconnecting nodes 10
                                          EDIT: I noticed I have different topics in MQTT, corrected AND I did:
                                          cd /usr/share/openhab2/addons/
                                          wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.4.0-SNAPSHOT.jar   <== THIS probably  fixed it!
                                          chown for the same file
                                          rm org.openhab.binding.mysensors-2.3.0-SNAPSHOT.jar
                                          Now my MQTT Gw is ONLINE, in Paper UI I just selected the bridge for every individual Thing and now it works.
                                          Hope this helps people strugling with this.
                                          G
                                          G
                                          Guillermo Schimmel
                                          @masmat Yes!!!! Thank you man. I found 2.4.0 thanks to your message and now it's working!
                                          Love
