Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable)
I need a fresh set of eyes on my problem.
Gateway is online, but things are not discovered. I have tried adding them manually (my syntax could be wrong), but it doesn't help.There are no errors in mysgw.log-file.
Mosquitto mysensors-out:mysensors-out/1/14/1/0/23 35 mysensors-out/1/15/1/0/0 49 mysensors-out/1/14/1/0/23 35 mysensors-out/1/15/1/0/0 49 mysensors-out/1/14/1/0/23 35 mysensors-out/1/15/1/0/0 49 mysensors-out/1/14/1/0/23 35 mysensors-out/1/15/1/0/0 49mysgw.things:
Bridge mysensors:bridge-mqtt:mygateway1 [brokerName="mosquitto", topicPublish="mysensors-in", topicSubscribe="mysensors-out", startupCheckEnabled=true ] { /** define things connected to that bridge here */ temperature BoilerTemp [nodeID=1, childId=15] motion PukuhLiike [nodeID=1, childId=3] }default.items:
Number BoilerTemp "Lämminvesivaraaja [%.1f °C]" <heating> {channel="mysensors:temperature:mygateway1:temperature_1_15:temp"} Contact PukuhLiike "Pukuhuone Liike" <motion> {channel="mysensors:motion:mygateway1:motion_1_3:tripped"}OpenHab2 frontail:
2018-08-13 22:34:03.284 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid paho111686078117 and file store '/var/lib/openhab2/mqtt/127.0.0.1' 2018-08-13 22:34:05.499 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder 2018-08-13 22:34:11.928 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Helsinki'. 2018-08-13 22:34:11.999 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'fi'. 2018-08-13 22:34:20.211 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.51:8080 2018-08-13 22:34:20.317 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.51:8443 2018-08-13 22:35:16.502 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items' 2018-08-13 22:35:34.984 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007 2018-08-13 22:35:38.657 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mys.things' 2018-08-13 22:35:39.245 [.ItemChannelLinkAddedEvent] - Link 'PukuhLiike-mysensors:motion:mygateway1:motion_1_3:tripped' has been added. 2018-08-13 22:35:39.309 [.ItemChannelLinkAddedEvent] - Link 'BoilerTemp-mysensors:temperature:mygateway1:temperature_1_15:temp' has been added. 2018-08-13 22:36:14.848 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app 2018-08-13 22:36:18.741 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui 2018-08-13 22:36:22.407 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel 2018-08-13 22:36:25.610 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from UNINITIALIZED to INITIALIZING 2018-08-13 22:36:26.660 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED) 2018-08-13 22:36:26.861 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED) 2018-08-13 22:36:27.453 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from INITIALIZING to ONLINE 2018-08-13 22:36:27.546 [INFO ] [rotocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge. 2018-08-13 22:36:28.075 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING) 2018-08-13 22:36:28.120 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)In my addons I have the 2.4.0 Snapshot.
org.eclipse.smarthome.mqttbroker.cfg:name=mosquitto host=127.0.0.1 secure=false port=1883 username=XXXX password=YYYYY retain=false clientId=openhabianEDIT: After a week of trying things. This worked: https://forum.mysensors.org/post/73600
No autodiscovery, but this switches my sensors ONLINE (even ones that are not powered up :( ), but it's not updating the values.@masmat said in Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable):
No autodiscovery, but this switches my sensors ONLINE (even ones that are not powered up ), but it's not updating the values.
Autodiscovery should work. :confused:
Does the temperature thing in OH2 get updates? Is it working?The sensors will show up ONLINE if the connection to the broker is established, because the sensors are just a topic. There is at the moment no implementation to check if the sensors/things are really available. This could be done, but it is not implemented yet.
@timo Before I did the re-install of everything autodiscovery was working, but now it isn't. Current sys: RpiZeroW, Openhabian 2.3.0-1release, mosquitto.
The temperature is not updating in OH2. But the mysensors-out topic does show the gateway sending the values out. OH2 is not listening for some reason...Re-install some (which?) parts or bindings? Openhab2 mqtt-binding?
Permissions? -
Needs to be changed to:
Number BoilerTemp "Lämminvesivaraaja [%.1f °C]" <heating> {channel="mysensors:temperature:mygateway1:BoilerTemp:temp"}But there is something additionally amiss, because discovery is not working.
Please enable debug in the OH2 console and post the output of the initialization.
Don't spend time reinstalling, this looks like a configuration issue. -
Don't spend time reinstalling, this looks like a configuration issue.@timo Firstly, I am very thankful for your help.
I changed that item and it started receiving values! I think there's something wrong with my light-level sensor's syntax too.In console I did: log:set DEBUG.
That prints out hundreds and hundreds of lines....should I narrow the search somehow? -
@masmat I'm glad the first sensor is updating now. Please post the the thing and item definition of the light sensor and I'll look at it.
I only need the debug output from the binding so please use:log:set DEBUG org.openhab.binding.mysensors@timo OK, here's the output:
2018-08-15 23:55:44.092 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid paho79389486520739 and file store '/var/lib/openhab2/mqtt/127.0.0.1' 2018-08-15 23:55:47.333 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder 2018-08-15 23:55:53.357 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Helsinki'. 2018-08-15 23:55:53.406 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '60.172424790463936,25.020736667463083'. 2018-08-15 23:55:53.427 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'fi'. 2018-08-15 23:56:01.971 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.51:8080 2018-08-15 23:56:02.082 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.51:8443 2018-08-15 23:57:01.390 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items' 2018-08-15 23:57:21.507 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007 2018-08-15 23:57:24.448 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap' 2018-08-15 23:57:26.351 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mys.things' ==> /var/log/openhab2/events.log <== 2018-08-15 23:57:27.306 [.ItemChannelLinkAddedEvent] - Link 'PukuhLiike-mysensors:motion:mygateway1:PukuhLiike:tripped' has been added. 2018-08-15 23:57:27.346 [.ItemChannelLinkAddedEvent] - Link 'PukuhValoisuus-mysensors:light-level:mygateway1:PukuhValoisuus:light-level' has been added. 2018-08-15 23:57:27.424 [.ItemChannelLinkAddedEvent] - Link 'TalliSivuoviLukko-mysensors:lock:mygateway1:TalliSivuoviLukko:lock-status' has been added. 2018-08-15 23:57:27.487 [.ItemChannelLinkAddedEvent] - Link 'BoilerTemp-mysensors:temperature:mygateway1:BoilerTemp:temp' has been added. 2018-08-15 23:57:27.655 [.ItemChannelLinkAddedEvent] - Link 'TalliSivuovi-mysensors:door:mygateway1:TalliSivuovi:tripped' has been added. ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:57:44.601 [DEBUG] [org.openhab.binding.mysensors ] - BundleEvent STARTING - org.openhab.binding.mysensors 2018-08-15 23:57:46.005 [DEBUG] [org.openhab.binding.mysensors ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=296, service.bundleid=197, service.scope=bundle, component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=176} - org.openhab.binding.mysensors 2018-08-15 23:57:47.811 [DEBUG] [org.openhab.binding.mysensors ] - BundleEvent STARTED - org.openhab.binding.mysensors 2018-08-15 23:57:53.081 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app 2018-08-15 23:57:56.733 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui 2018-08-15 23:57:59.038 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel 2018-08-15 23:58:02.474 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:02.518 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from UNINITIALIZED to INITIALIZING ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:02.740 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist. 2018-08-15 23:58:02.777 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [1] 2018-08-15 23:58:03.074 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog 2018-08-15 23:58:03.246 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Connected to MQTT broker! 2018-08-15 23:58:03.294 [DEBUG] [org.openhab.binding.mysensors ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=324, service.bundleid=197, service.scope=singleton} - org.openhab.binding.mysensors 2018-08-15 23:58:03.308 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan 2018-08-15 23:58:03.330 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE! ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:03.493 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED) 2018-08-15 23:58:03.617 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED) ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:03.743 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Adding consumer for topic: mysensors-out/+/+/+/+/+ ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:03.840 [hingStatusInfoChangedEvent] - 'mysensors:light-level:mygateway1:PukuhValoisuus' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED) 2018-08-15 23:58:03.908 [hingStatusInfoChangedEvent] - 'mysensors:door:mygateway1:TalliSivuovi' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED) 2018-08-15 23:58:03.997 [hingStatusInfoChangedEvent] - 'mysensors:lock:mygateway1:TalliSivuoviLukko' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED) ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:04.055 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2; 2018-08-15 23:58:04.076 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Sending MQTT Message: Topic: mysensors-in, Message: 0;0;3;0;2; 2018-08-15 23:58:04.241 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/0/255/3/0/2, Message: 2.3.0 2018-08-15 23:58:04.276 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 0/255/3/0/2 2018-08-15 23:58:04.311 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 0;255;3;0;2;2.3.0 2018-08-15 23:58:04.373 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;2;2.3.0 2018-08-15 23:58:04.390 [DEBUG] [rsAbstractConnection$MySensorsReader] - Good,Gateway is up and running! (Ver:2.3.0) ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:04.849 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from INITIALIZING to ONLINE ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:04.940 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [1] 2018-08-15 23:58:04.975 [INFO ] [rotocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge. 2018-08-15 23:58:05.191 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=5, childId=5, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false} ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:05.211 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:05.224 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=15, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false} 2018-08-15 23:58:05.347 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=3, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false} 2018-08-15 23:58:05.404 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=1, childId=14, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false} 2018-08-15 23:58:05.494 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration{nodeId=5, childId=6, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false, usePureWhiteLightInRGBW=false} 2018-08-15 23:58:05.521 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Adding device MySensorsNode [nodeId=5, childNumber=1, chidldList={5=MySensorsChild [childId=5, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LOCK_STATUS=MySensorsVariableVLockStatus [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]}] 2018-08-15 23:58:05.610 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {5=MySensorsChild [childId=5, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LOCK_STATUS=MySensorsVariableVLockStatus [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]} with: {6=MySensorsChild [childId=6, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_TRIPPED=MySensorsVariableVTripped [value=null], V_ARMED=MySensorsVariableVArmed [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]} 2018-08-15 23:58:05.607 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 5-5 not registered yet, registering... ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:05.704 [hingStatusInfoChangedEvent] - 'mysensors:lock:mygateway1:TalliSivuoviLukko' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:05.737 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {} with: {14=MySensorsChild [childId=14, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_LEVEL=MySensorsVariableVLevel [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LIGHT_LEVEL=MySensorsVariableVLightLevel [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]} ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:05.800 [hingStatusInfoChangedEvent] - 'mysensors:light-level:mygateway1:PukuhValoisuus' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:05.769 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 5-6 not registered yet, registering... 2018-08-15 23:58:05.783 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {14=MySensorsChild [childId=14, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_LEVEL=MySensorsVariableVLevel [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LIGHT_LEVEL=MySensorsVariableVLightLevel [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]} with: {15=MySensorsChild [childId=15, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null], V_TEMP=MySensorsVariableVTemp [value=null], V_ID=MySensorsVariableVId [value=null]}]} 2018-08-15 23:58:05.795 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 1-14 not registered yet, registering... 2018-08-15 23:58:05.858 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {14=MySensorsChild [childId=14, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_LEVEL=MySensorsVariableVLevel [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_LIGHT_LEVEL=MySensorsVariableVLightLevel [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}], 15=MySensorsChild [childId=15, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null], V_TEMP=MySensorsVariableVTemp [value=null], V_ID=MySensorsVariableVId [value=null]}]} with: {3=MySensorsChild [childId=3, nodeValue={V_VAR1=MySensorsVariableVVar1 [value=null], V_TRIPPED=MySensorsVariableVTripped [value=null], V_ARMED=MySensorsVariableVArmed [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null]}]} 2018-08-15 23:58:05.866 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 1-15 not registered yet, registering... ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:05.908 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:05.902 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 1-3 not registered yet, registering... ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:05.982 [hingStatusInfoChangedEvent] - 'mysensors:door:mygateway1:TalliSivuovi' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING 2018-08-15 23:58:06.050 [hingStatusInfoChangedEvent] - 'mysensors:lock:mygateway1:TalliSivuoviLukko' changed from INITIALIZING to ONLINE 2018-08-15 23:58:06.109 [hingStatusInfoChangedEvent] - 'mysensors:light-level:mygateway1:PukuhValoisuus' changed from INITIALIZING to ONLINE 2018-08-15 23:58:06.160 [hingStatusInfoChangedEvent] - 'mysensors:door:mygateway1:TalliSivuovi' changed from INITIALIZING to ONLINE 2018-08-15 23:58:06.202 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from INITIALIZING to ONLINE 2018-08-15 23:58:06.253 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from INITIALIZING to ONLINE ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:10.493 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/14/1/0/23, Message: 0 2018-08-15 23:58:10.511 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/14/1/0/23 2018-08-15 23:58:10.526 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;14;1;0;23;0 2018-08-15 23:58:10.542 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;14;1;0;23;0 2018-08-15 23:58:10.574 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway 2018-08-15 23:58:10.586 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/15/1/0/0, Message: 53 2018-08-15 23:58:10.606 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/15/1/0/0 2018-08-15 23:58:10.591 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 14 found in node 1 2018-08-15 23:58:10.619 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;15;1;0;0;53 2018-08-15 23:58:10.661 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: light-level(V_LIGHT_LEVEL) value to: 0 ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:11.034 [vent.ItemStateChangedEvent] - PukuhValoisuus changed from NULL to 0 ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:11.617 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/14 to 2018-08-15T23:58:10.000+0300 2018-08-15 23:58:11.629 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;15;1;0;0;53 2018-08-15 23:58:11.642 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway 2018-08-15 23:58:11.657 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 15 found in node 1 2018-08-15 23:58:11.671 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: temp(V_TEMP) value to: 53 ==> /var/log/openhab2/events.log <== 2018-08-15 23:58:11.758 [vent.ItemStateChangedEvent] - BoilerTemp changed from NULL to 53 ==> /var/log/openhab2/openhab.log <== 2018-08-15 23:58:11.770 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/15 to 2018-08-15T23:58:11.000+0300 2018-08-15 23:58:47.461 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/14/1/0/23, Message: 0 2018-08-15 23:58:47.482 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/14/1/0/23 2018-08-15 23:58:47.495 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;14;1;0;23;0 2018-08-15 23:58:47.513 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;14;1;0;23;0 2018-08-15 23:58:47.533 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway 2018-08-15 23:58:47.565 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - MQTT message received. Topic: mysensors-out/1/15/1/0/0, Message: 53 2018-08-15 23:58:47.556 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 14 found in node 1 2018-08-15 23:58:47.579 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: light-level(V_LIGHT_LEVEL) value to: 0 2018-08-15 23:58:47.597 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Message topic part: 1/15/1/0/0 2018-08-15 23:58:47.612 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Converted MQTT message to MySensors Serial format. Sending on to bridge: 1;15;1;0;0;53 2018-08-15 23:58:47.719 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/14 to 2018-08-15T23:58:47.000+0300 2018-08-15 23:58:47.731 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;15;1;0;0;53 2018-08-15 23:58:47.750 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Node 1 found in gateway 2018-08-15 23:58:47.765 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Child 15 found in node 1 2018-08-15 23:58:47.778 [DEBUG] [ensors.handler.MySensorsThingHandler] - Updating channel: temp(V_TEMP) value to: 53 2018-08-15 23:58:47.839 [DEBUG] [ensors.handler.MySensorsThingHandler] - Setting last update for node/child 1/15 to 2018-08-15T23:58:47.000+0300And my item & thing (in separate files of course):
Number PukuhValoisuus "Pukuhuone valoisuus [%.1f %]" <719914_monitor> {channel="mysensors:light-level:mygateway1:PukuhValoisuus:light-level"} light-level PukuhValoisuus [nodeId=1, childId=14] -
I have a strange issue now when I am trying to bring my irrigation controller over from Vera to openHab. I setup the Ethernet Gateway and have several nodes working ok. I then configured the binding to have the irrigation controller as follows:
Bridge mysensors:bridge-eth:gateway [ ipAddress="192.168.100.63", tcpPort=5003, sendDelay=150, startupCheckEnabled=true, networkSanCheckEnabled=true, networkSanCheckInterval=1, networkSanCheckConnectionFailAttempts=1 ] { light Water_All_Zones "Water - All Zones" @ "Backyard" [ nodeId=2, childId=0 ] light Water_Zone1 "Water - Veg Garden" @ "Backyard" [ nodeId=2, childId=1 ] light Water_Zone2 "Water - Rear Garden" @ "Backyard" [ nodeId=2, childId=2 ] light Water_Zone3 "Water - Side Garden" @ "Backyard" [ nodeId=2, childId=3 ] light Water_Zone4 "Water - Verge Grass" @ "Backyard" [ nodeId=2, childId=4 ] light Water_Zone5 "Water - Front Grass" @ "Backyard" [ nodeId=2, childId=5 ] light Water_Zone6 "Water - Front Garden" @ "Backyard" [ nodeId=2, childId=6 ] cover Courtyard_Door_Blind "Door Blind" @ "Courtyard" [ nodeId=4, childId=1 ] cover Office_Front_Blinds "Front Blinds" @ "Office" [ nodeId=4, childId=2 ] cover Office_Side_Blinds "Side Blinds" @ "Office" [ nodeId=4, childId=3 ] cover Courtyard_LHS_Blinds "LHS Blinds" @ "Courtyard" [ nodeId=4, childId=4 ] cover Courtyard_RHS_Blinds "RHS Blinds" @ "Courtyard" [ nodeId=4, childId=5 ] power Power_Phase1 "Energy Phase 1" @ "Garage" [ nodeId=5, childId=0 ] power Power_Phase2 "Energy Phase 2" @ "Garage" [ nodeId=5, childId=1 ] power Power_Phase3 "Energy Phase 3" @ "Garage" [ nodeId=5, childId=2 ] power Power_Main "Energy Main" @ "Garage" [ nodeId=5, childId=8 ] light Entry_FrontGarden_Lights "Power Socket Relay" @ "Entry" [ nodeId=7, childId=1 ] light Office_Door "Door Controller" @ "Office" [ nodeId=13, childId=1 ] light Desktop_Debug_Light "Power Socket Relay" @ "Office" [ nodeId=27, childId=1 ] }So far so good, I then setup the items as follows:
Switch Water_All_Zones "Water All Zones" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_All_Zones:status"} Switch Water_Veg_Garden "Water - Veg Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_Zone1:status"} Switch Water_Rear_Garden "Water - Rear Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_Zone2:status"} Switch Water_Side_Garden "Water - Side Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_Zone3:status"} Switch Water_Verge_Grass "Water - Verge Grass" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_Zone4:status"} Switch Water_Front_Grass "Water - Front Grass" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_Zone5:status"} Switch Water_Front_Garden "Water - Front Garden" <selfwater> (gDevices,gRoom_Backyard) [ "iss:type:DevSwitch", "iss:room:Backyard" ] {channel="mysensors:light:gateway:Water_Zone6:status"} Number Water_Zone1_AllTime "Water - Zone 1 - All Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone1:var1"} Number Water_Zone2_AllTime "Water - Zone 2 - All Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone2:var1"} Number Water_Zone3_AllTime "Water - Zone 3 - All Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone3:var1"} Number Water_Zone4_AllTime "Water - Zone 4 - All Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone4:var1"} Number Water_Zone5_AllTime "Water - Zone 5 - All Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone5:var1"} Number Water_Zone6_AllTime "Water - Zone 6 - All Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone6:var1"} Number Water_Zone1_Time "Water - Zone1 - Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone1:var2"} Number Water_Zone2_Time "Water - Zone2 - Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone2:var2"} Number Water_Zone3_Time "Water - Zone3 - Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone3:var2"} Number Water_Zone4_Time "Water - Zone4 - Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone4:var2"} Number Water_Zone5_Time "Water - Zone5 - Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone5:var2"} Number Water_Zone6_Time "Water - Zone6 - Time [%d]" <selfruntime> (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone6:var2"} String Water_Zone1_Name "Water - Zone1 - Name [%s]" (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone1:var3"} String Water_Zone2_Name "Water - Zone2 - Name [%s]" (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone2:var3"} String Water_Zone3_Name "Water - Zone3 - Name [%s]" (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone3:var3"} String Water_Zone4_Name "Water - Zone4 - Name [%s]" (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone4:var3"} String Water_Zone5_Name "Water - Zone5 - Name [%s]" (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone5:var3"} String Water_Zone6_Name "Water - Zone6 - Name [%s]" (gDevices,gRoom_Backyard) {channel="mysensors:light:gateway:Water_Zone6:var3"}As the Irrigation project uses 3 vars to manage time and names I setup a System Started rule as follows:
rule "System started" when System started then createTimer(now.plusSeconds(180)) [ | logInfo("Watering", "System started") if (Water_Zone1_AllTime.state == NULL) Water_Zone1_AllTime.sendCommand(5 as Number) if (Water_Zone2_AllTime.state == NULL) Water_Zone2_AllTime.sendCommand(8 as Number) if (Water_Zone3_AllTime.state == NULL) Water_Zone3_AllTime.sendCommand(8 as Number) if (Water_Zone4_AllTime.state == NULL) Water_Zone4_AllTime.sendCommand(12 as Number) if (Water_Zone5_AllTime.state == NULL) Water_Zone5_AllTime.sendCommand(12 as Number) if (Water_Zone6_AllTime.state == NULL) Water_Zone6_AllTime.sendCommand(10 as Number) if (Water_Zone1_Time.state == NULL) Water_Zone1_Time.sendCommand(5 as Number) if (Water_Zone2_Time.state == NULL) Water_Zone2_Time.sendCommand(8 as Number) if (Water_Zone3_Time.state == NULL) Water_Zone3_Time.sendCommand(8 as Number) if (Water_Zone4_Time.state == NULL) Water_Zone4_Time.sendCommand(12 as Number) if (Water_Zone5_Time.state == NULL) Water_Zone5_Time.sendCommand(12 as Number) if (Water_Zone6_Time.state == NULL) Water_Zone6_Time.sendCommand(10 as Number) if (Water_Zone1_Name.state == NULL) Water_Zone1_Name.sendCommand("Veg Garden") if (Water_Zone2_Name.state == NULL) Water_Zone2_Name.sendCommand("Rear Garden") if (Water_Zone3_Name.state == NULL) Water_Zone3_Name.sendCommand("Side Garden") if (Water_Zone4_Name.state == NULL) Water_Zone4_Name.sendCommand("Verge Grass") if (Water_Zone5_Name.state == NULL) Water_Zone5_Name.sendCommand("Front Grass") if (Water_Zone6_Name.state == NULL) Water_Zone6_Name.sendCommand("Front Garden") ] endThis all loaded up nicely (for interest I tried postUpdate as well as sendCommand) shows the right stuff in PaperUI - Control can see all the numbers and string however I have had several issues with the setup.
Firstly when my controller requests the time from the gateway it receives UTC and is showing the wrong time on the LCD display. I have checked that my controller is configured for the right timezone and is showing the right time but everytime I reset the Irrigation controller and it requests the time it is getting UTC. (I did work once and got the right time but not sure how this occurred) I rebooted the openhabianpi unit and it is still delivering UTC, but the fact it did it right once means I cannot just adjust the timezone in the node as it may get it right somehow and then be adjusted wrong! I would have thought the gateway should deliver the correct system time.
Secondly I cannot get the Irrigation Controller to read the var3 String value - when this is requested from from the Irrigation controller it only gets a 0 (numeric). This seems to indicate that the var's can only handle a Number - is this true and how does one get around this if this is the case? I tried changing the value in PaperUI and it changes but nothing gets sent to the node but changing the numeric values in var1 & 2 update to the node - all updates are shown in the logtail.
For the record here is the Serial boot log from the node:
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.2.0 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0 25 TSM:INIT 26 TSF:WUR:MS=0 33 TSM:INIT:TSP OK 35 TSM:INIT:STATID=2 37 TSF:SID:OK,ID=2 39 TSM:FPAR 75 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 81 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0 87 TSF:MSG:FPAR OK,ID=0,D=1 2082 TSM:FPAR:OK 2083 TSM:ID 2084 TSM:ID:OK 2086 TSM:UPL 2089 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2100 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2105 TSF:MSG:PONG RECV,HP=1 2107 TSM:UPL:OK 2109 TSM:READY:ID=2,PAR=0,DIS=1 2113 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 2120 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 2127 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0 2137 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 2156 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M 2163 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:Irrigation Ctrl (2) 2173 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:4.0 2182 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2189 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2196 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2204 TSF:MSG:SEND,2-2-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2211 TSF:MSG:SEND,2-2-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2219 TSF:MSG:SEND,2-2-0-0,s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2227 TSF:MSG:SEND,2-2-0-0,s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2232 MCO:REG:REQ 2236 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2 2242 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1 2247 MCO:PIM:NODE REG=1 2249 MCO:BGN:STP Initialising... Turning All Valves Off... Checking EEPROM for stored date: Retreiving last run time from EEPROM... Sensor Presentation Complete Ready... 2907 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK: Requesting time from Gateway: 2932 TSF:MSG:READ,0-0-2,s=255,c=3,t=1,pt=0,l=10,sg=0:1534904507 Time value received and updated... Clock updated.... Sensor's time currently set to: 02:21am ***** Should be 10:21am GMT +8 ******* 8/22/2018 Wednesday Calling for Valve 1 Data... 3946 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 3966 TSF:MSG:READ,0-0-2,s=1,c=1,t=24,pt=0,l=1,sg=0:5 Recieved variable1 valve:1 = 5 New Zone Times Recieved... Zone 1 individual time: 0 group time: 5 name: Zone 1 Zone 2 individual time: 0 group time: 0 name: Zone 2 Zone 3 individual time: 0 group time: 0 name: Zone 3 Zone 4 individual time: 0 group time: 0 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 4005 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4065 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4116 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:5 Recieved variable2 valve:1 = 5 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: Zone 1 Zone 2 individual time: 0 group time: 0 name: Zone 2 Zone 3 individual time: 0 group time: 0 name: Zone 3 Zone 4 individual time: 0 group time: 0 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 4152 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4212 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4267 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:5 Recieved variable2 valve:1 = 5 Calling for Valve 2 Data... 4303 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 4363 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 4417 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 1 = 0 4425 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4484 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4543 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4567 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 1 = 0 4602 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4662 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4717 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:8 Recieved variable1 valve:2 = 8 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 0 group time: 8 name: Zone 2 Zone 3 individual time: 0 group time: 0 name: Zone 3 Zone 4 individual time: 0 group time: 0 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 Calling for Valve 3 Data... 4781 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 4839 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 4868 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:8 Recieved variable1 valve:2 = 8 4898 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4957 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5016 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5022 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:8 Recieved variable2 valve:2 = 8 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: Zone 2 Zone 3 individual time: 0 group time: 0 name: Zone 3 Zone 4 individual time: 0 group time: 0 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 5075 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5135 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5168 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:8 Recieved variable2 valve:2 = 8 Calling for Valve 4 Data... 5222 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5281 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5318 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:8 Recieved variable2 valve:2 = 8 5340 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5399 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5458 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5474 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 2 = 0 5518 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5577 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5619 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 2 = 0 Calling for Valve 5 Data... 5663 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5722 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5770 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:8 Recieved variable1 valve:3 = 8 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 0 group time: 8 name: Zone 3 Zone 4 individual time: 0 group time: 0 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 5805 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5865 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5931 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5952 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:8 Recieved variable1 valve:3 = 8 5996 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6055 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6071 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:8 Recieved variable2 valve:3 = 8 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 8 group time: 8 name: Zone 3 Zone 4 individual time: 0 group time: 0 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 Calling for Valve 6 Data... 6142 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 6202 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 6220 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:8 Recieved variable2 valve:3 = 8 6261 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6320 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6371 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:8 Recieved variable2 valve:3 = 8 6379 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6438 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6498 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6521 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 3 = 0 6556 MCO:BGN:INIT OK,TSP=1 6723 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 3 = 0 6927 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=2,sg=0:12 Recieved variable1 valve:4 = 12 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 8 group time: 8 name: 0 Zone 4 individual time: 0 group time: 12 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 7129 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=2,sg=0:12 Recieved variable1 valve:4 = 12 7148 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=2,sg=0:12 Recieved variable2 valve:4 = 12 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 8 group time: 8 name: 0 Zone 4 individual time: 12 group time: 12 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 7331 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=2,sg=0:12 Recieved variable2 valve:4 = 12 7534 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=2,sg=0:12 Recieved variable2 valve:4 = 12 7736 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 4 = 0 7754 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 4 = 0 7939 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=2,sg=0:12 Recieved variable1 valve:5 = 12 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 8 group time: 8 name: 0 Zone 4 individual time: 12 group time: 12 name: 0 Zone 5 individual time: 0 group time: 12 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 8141 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=2,sg=0:12 Recieved variable1 valve:5 = 12 8344 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=2,sg=0:12 Recieved variable2 valve:5 = 12 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 8 group time: 8 name: 0 Zone 4 individual time: 12 group time: 12 name: 0 Zone 5 individual time: 12 group time: 12 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 8375 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=2,sg=0:12 Recieved variable2 valve:5 = 12 8546 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=2,sg=0:12 Recieved variable2 valve:5 = 12 8748 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 5 = 0 8950 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 5 = 0 8970 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=2,sg=0:10 Recieved variable1 valve:6 = 10 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 8 group time: 8 name: 0 Zone 4 individual time: 12 group time: 12 name: 0 Zone 5 individual time: 12 group time: 12 name: 0 Zone 6 individual time: 0 group time: 10 name: Zone 6 9153 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=2,sg=0:10 Recieved variable1 valve:6 = 10 9356 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=2,sg=0:10 Recieved variable2 valve:6 = 10 New Zone Times Recieved... Zone 1 individual time: 5 group time: 5 name: 0 Zone 2 individual time: 8 group time: 8 name: 0 Zone 3 individual time: 8 group time: 8 name: 0 Zone 4 individual time: 12 group time: 12 name: 0 Zone 5 individual time: 12 group time: 12 name: 0 Zone 6 individual time: 10 group time: 10 name: Zone 6 9559 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=2,sg=0:10 Recieved variable2 valve:6 = 10 9577 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 6 = 0 9760 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 6 = 0 9963 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 6 = 0EDIT - After the next openHab restart when the variables all got restored from Persistance they all show up right but now the node when reboot will not pick up the data see this node reboot log (Note Zone 1 group time 5 came through as I had forced a sendCommand on that single item - all other values restored from persistance - seems the same issue if they come from postUpdate also)
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.2.0 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0 25 TSM:INIT 26 TSF:WUR:MS=0 33 TSM:INIT:TSP OK 35 TSM:INIT:STATID=2 37 TSF:SID:OK,ID=2 39 TSM:FPAR 75 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 388 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0 393 TSF:MSG:FPAR OK,ID=0,D=1 2082 TSM:FPAR:OK 2083 TSM:ID 2084 TSM:ID:OK 2086 TSM:UPL 2089 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2100 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2105 TSF:MSG:PONG RECV,HP=1 2107 TSM:UPL:OK 2109 TSM:READY:ID=2,PAR=0,DIS=1 2113 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 2120 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 2128 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0 2137 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 2162 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M 2170 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:Irrigation Ctrl (2) 2180 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:4.0 2188 TSF:MSG:SEND,2-2-0-0,s=0,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2195 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2203 TSF:MSG:SEND,2-2-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2210 TSF:MSG:SEND,2-2-0-0,s=3,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2217 TSF:MSG:SEND,2-2-0-0,s=4,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2226 TSF:MSG:SEND,2-2-0-0,s=5,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2233 TSF:MSG:SEND,2-2-0-0,s=6,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK: 2239 MCO:REG:REQ 2242 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2 2249 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1 2254 MCO:PIM:NODE REG=1 2256 MCO:BGN:STP Initialising... Turning All Valves Off... Checking EEPROM for stored date: Retreiving last run time from EEPROM... Sensor Presentation Complete Ready... 2914 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=1,pt=0,l=0,sg=0,ft=0,st=OK: Requesting time from Gateway: 2939 TSF:MSG:READ,0-0-2,s=255,c=3,t=1,pt=0,l=10,sg=0:1534915205 Time value received and updated... Clock updated.... Sensor's time currently set to: 05:20am 8/22/2018 Wednesday Calling for Valve 1 Data... 3952 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 3976 TSF:MSG:READ,0-0-2,s=1,c=1,t=24,pt=0,l=1,sg=0:5 Recieved variable1 valve:1 = 5 New Zone Times Recieved... Zone 1 individual time: 0 group time: 5 name: Zone 1 Zone 2 individual time: 0 group time: 0 name: Zone 2 Zone 3 individual time: 0 group time: 0 name: Zone 3 Zone 4 individual time: 0 group time: 0 name: Zone 4 Zone 5 individual time: 0 group time: 0 name: Zone 5 Zone 6 individual time: 0 group time: 0 name: Zone 6 4012 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4072 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4126 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:1 = 0 4134 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4194 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4253 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4276 TSF:MSG:READ,0-0-2,s=1,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:1 = 0 Calling for Valve 2 Data... 4340 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 4399 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 4426 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 1 = 0 4458 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4517 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4611 !TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=NACK: 4670 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=1,st=OK: 4729 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 4736 TSF:MSG:READ,0-0-2,s=1,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 1 = 0 4789 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4848 TSF:MSG:SEND,2-2-0-0,s=2,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 4878 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:2 = 0 Calling for Valve 3 Data... 4935 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 4995 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5027 TSF:MSG:READ,0-0-2,s=2,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:2 = 0 5054 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5113 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5173 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5179 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:2 = 0 5232 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5292 TSF:MSG:SEND,2-2-0-0,s=3,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5328 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:2 = 0 Calling for Valve 4 Data... 5379 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5438 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5479 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:2 = 0 5497 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5557 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5616 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 5632 TSF:MSG:READ,0-0-2,s=2,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:2 = 0 5676 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5735 TSF:MSG:SEND,2-2-0-0,s=4,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 5780 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 2 = 0 Calling for Valve 5 Data... 5822 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5881 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 5929 TSF:MSG:READ,0-0-2,s=2,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 2 = 0 5941 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6000 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6060 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6080 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:3 = 0 6119 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6178 TSF:MSG:SEND,2-2-0-0,s=5,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6231 TSF:MSG:READ,0-0-2,s=3,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:3 = 0 Calling for Valve 6 Data... 6267 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 6326 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK: 6381 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:3 = 0 6389 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6448 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6507 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=25,pt=0,l=0,sg=0,ft=0,st=OK: 6531 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:3 = 0 6566 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6626 TSF:MSG:SEND,2-2-0-0,s=6,c=2,t=26,pt=0,l=0,sg=0,ft=0,st=OK: 6681 TSF:MSG:READ,0-0-2,s=3,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:3 = 0 6689 MCO:BGN:INIT OK,TSP=1 6884 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 3 = 0 7087 TSF:MSG:READ,0-0-2,s=3,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 3 = 0 7288 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:4 = 0 7308 TSF:MSG:READ,0-0-2,s=4,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:4 = 0 7491 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:4 = 0 7694 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:4 = 0 7897 TSF:MSG:READ,0-0-2,s=4,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:4 = 0 7915 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 4 = 0 8099 TSF:MSG:READ,0-0-2,s=4,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 4 = 0 8301 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:5 = 0 8504 TSF:MSG:READ,0-0-2,s=5,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:5 = 0 8522 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:5 = 0 8706 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:5 = 0 8908 TSF:MSG:READ,0-0-2,s=5,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:5 = 0 9111 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 5 = 0 9129 TSF:MSG:READ,0-0-2,s=5,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 5 = 0 9313 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:6 = 0 9516 TSF:MSG:READ,0-0-2,s=6,c=1,t=24,pt=0,l=1,sg=0:0 Recieved variable1 valve:6 = 0 9718 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:6 = 0 9737 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:6 = 0 9921 TSF:MSG:READ,0-0-2,s=6,c=1,t=25,pt=0,l=1,sg=0:0 Recieved variable2 valve:6 = 0 10123 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 6 = 0 10326 TSF:MSG:READ,0-0-2,s=6,c=1,t=26,pt=0,l=1,sg=0:0 Recieved variable3 valve: 6 = 0Sorry also just realised I am posting in an MQTT thread - I had an MQTT Gateway and now changed to Ethernet.
Hi all, and thanks for the previous posts.
I was having the same issue where the Bridge would stay as INITIALIZING. My set up is a little different as I use Openhan on docker with the following volumes mounting in /opt/openhab:
-v /etc/localtime:/etc/localtime:ro \ -v /etc/timezone:/etc/timezone:ro \ -v /opt/openhab/conf:/openhab/conf \ -v /opt/openhab/userdata:/openhab/userdata \ -v /opt/openhab/addons:/openhab/addons \ -v /opt/openhab/.java:/openhab/.java \I'm using OH2.3 with the Docker Image: openhab/openhab:2.3.0-amd64-debian and the location of the org.eclipse.smarthome.mqttbroker.cfg file is in /opt/openhab/userdata/config/org/eclipse/smarthome.
After making all the changes above I couldn't get the Brdige to work, until finally I downloaded the MySensors addon 2.4.0 from http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.4.0-SNAPSHOT.jar as suggested by @MasMat and placed it in /opt/openhab/addons.
Immediately the status of the bridge changed to ONLINE.
Hope this helps sombedy.
C
@timo I did. I can't figure out where it's finding that .0 it adds to the 1883 port I have in the cfg-file
Were You able to find out what is wrong regarding MQTT port 1883.0
Suddenly I have the same error...no idea why. It was working just yesterday. -
I am very new to openHAB but I am really getting crazy with it. I did exactly what was on top of the screen. But I get an error the MYSensors MQTT Gateway was initializing.. and never came out. So I continue too read and I switch to the binding v 2.4.0. But wathever I do I get an error:
mysensors:bridge-mqtt:gateway' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org/eclipse/smarthome/io/transport/mqtt/MqttActionCallbackI am not sure where to look and what to change. This is in my demo.things file.
Bridge mysensors:bridge-mqtt:gateway [ brokerName="mosquitto", topicPublish="mygateway1-in", topicSubscribe="mygatewa$ temperature temp01 [ nodeId=5, childId=0 ] }org.eclipse.smarthome.mqttbroker.cfg:
name=mosquitto host=192.168.10.4 <- This points to the MySensors gateway PI (different then the openHAB) secure=false port=1883 retain=falseAny idears what I can try?
@martim I'm running OpenHAB with a few MYS sensors (and other subsystems) and I really like the system system. It is complex with a steep learning curve but incredibly flexible and powerful.
As for your problems with MYS/MQTT I have no solution but to use the direct connection over ethernet instead. I have tried switching to MQTT twice and failed miserably both times.
The MYS addon requires the new MQTT binding which easily collides with the old one. (The new MQTT binding is almost ready for release so it may have been fixed, if you are lucky.)
I don't know if the cause of this problem is with the OpenHAB MQTT bindings or with the MYS binding but it was not trivial to fix with the instructions available. As I could not really see any upside of using MQTT except to have an "all MQTT System" I went back to the ethernet connection which works fine.
I would recommend connecting it as ethernet connection first and get it working that way. Then you can switch to MQTT if you want to. The biggets hurdles are installation of supportive packages (mqtt and serial transports) and getting MQTT to work in parallel with MQTT binding version 1. If you post your logs (WARN level for the Mys binding) I can try help you decode it.
I spend again a few hours. I really want to get it to work with MQTT as I have my complete system based on it. But Apparently, the binding does not work and also the log does not say much. Only those errors:
2018-12-17 11:38:03.559 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'mysensors:bridge-mqtt:gateway': org/eclipse/sma ansport/mqtt/MqttActionCallback java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback at java.lang.ClassLoader.defineClass1(Native Method) ~[?:?] at java.lang.ClassLoader.defineClass(ClassLoader.java:763) ~[?:?] at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:276) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:655) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) ~[?:?] at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?] at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?] at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?] at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection.<init>(MySensorsMqttConnection.java:44) ~[?:?] at org.openhab.binding.mysensors.internal.gateway.MySensorsGateway.setup(MySensorsGateway.java:99) ~[?:?] at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:81) ~[?:?] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?] at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh230] at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230] at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?] at java.lang.Thread.run(Thread.java:748) [?:?] Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.io.transport.mqtt.MqttActionCallback cannot be found by org.openhab.binding.mysensors_2.4.0.201812040738 -
2018-12-17 11:38:03.559 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while initializing handler of thing 'mysensors:bridge-mqtt:gateway': org/eclipse/sma ansport/mqtt/MqttActionCallback java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback at java.lang.ClassLoader.defineClass1(Native Method) ~[?:?] at java.lang.ClassLoader.defineClass(ClassLoader.java:763) ~[?:?] at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:276) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:655) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) ~[?:?] at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) ~[?:?] at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?] at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?] at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?] at org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection.<init>(MySensorsMqttConnection.java:44) ~[?:?] at org.openhab.binding.mysensors.internal.gateway.MySensorsGateway.setup(MySensorsGateway.java:99) ~[?:?] at org.openhab.binding.mysensors.handler.MySensorsBridgeHandler.initialize(MySensorsBridgeHandler.java:81) ~[?:?] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?] at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh230] at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh230] at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?] at java.lang.Thread.run(Thread.java:748) [?:?] Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.io.transport.mqtt.MqttActionCallback cannot be found by org.openhab.binding.mysensors_2.4.0.201812040738@martim Don't use the binding! Use plain MQTT.I'd love to have a simple working binding but it isn't there yet. Use plain mqtt elements and it'll work great.The new mqtt binding works. I don't like the mechanism needed to configure the broker, and then each thing, but works, and it is in fact more integrated with openhab than ever.
If you have any questions do not hesitate to contact me.
java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/transport/mqtt/MqttActionCallbackThe new MQTT binding requires parts of the new automation engine. This is missing from your system for some reason. Should be automatically installed when MQTT or the MySensors binding are installed.
This statement is not correct. The OH 2.4 release officially supports the new binding and if any errors are reported, they are getting fixed. The new binding allows Paper UI and textual configuration so there is no reason to start with mqtt1 nowadays.
Cheers,
David -
Cheers,
David@davidgraeff Yes David, you are correct. The new binding works. I'm in fact using it and with the corresponding changes on the items files its ok.
I would love some kind of auto discovery though. In order to create each thing you have to manually enter the topic (which on mysensors is very complex)
Anyways, I will try to edit previous message which is in fact wrong.
@jogant Finally had time to double check this:
Paper UI:Broker Name mosquitto Subscription Topic mygateway1-out Publish Topic mygateway1-in Send Delay 100 Startup check enabled Metric answer enabled Network sanity check enabled Interval to launch network sanity check 3 Attempts before disconnecting the bridge 3 Heartbeat disabled Attempts before disconnecting nodes 10EDIT: I noticed I have different topics in MQTT, corrected AND I did:
cd /usr/share/openhab2/addons/ wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.4.0-SNAPSHOT.jar <== THIS probably fixed it! chown for the same file rm org.openhab.binding.mysensors-2.3.0-SNAPSHOT.jarNow my MQTT Gw is ONLINE, in Paper UI I just selected the bridge for every individual Thing and now it works.
Hope this helps people strugling with this.@masmat Yes!!!! Thank you man. I found 2.4.0 thanks to your message and now it's working!
Love
Hi all, I am a Newbie an trying to get OH2.4 to work with MySensors nodes.
I have a MYS Mqtt ethernet GW up&running (seems to work, can talk to other sensors)
Now I can't get MQTT thing/broker/binding to work in OH2.4. I first tries the manual above, then I read that Musquitto is not needed any more....right??
I have to use MQTT 2.4 Ting binding and MQTT broker right? -> I have installed this and have MQTT broker running on localhost (online) (no channels addes in MQTT broker)
I have added in Things: MysensorsMQTT gateway: broker name: "MQTT Broker" and 'startup check' and 'sanity check' ON
Then I checked from the CLI the file "org.eclipse.smarthome.mqtt.cfg" ->there was still the musquitto entries I made... Also in mqtt-eventbus.cfg was still broker=musquitto. What do I do with this??
In OH log I get errors:****2019-02-10 21:52:35.274 [me.event.ThingUpdatedEvent] - Thing 'mysensors:bridge-mqtt:9954d183' has been updated. 2019-02-10 21:52:35.682 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:9954d183' changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org/openhab/binding/mysensors/internal/protocol/mqtt/MySensorsMqttConnection$MySensorsMqttPublishCallback to INITIALIZING 2019-02-10 21:52:35.685 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:9954d183' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org/openhab/binding/mysensors/internal/protocol/mqtt/MySensorsMqttConnection$MySensorsMqttPublishCallback**** ---*Next problem:
I installed the MySensors Ethernet gateway thing in OH, configged it with IP of Arduino running the Mys GW. -> This Thing will NOT come 'online'. I can Ping the GW board, all looks OK in GW log:0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1 4 TSM:INIT 5 TSF:WUR:MS=0 11 TSM:INIT:TSP OK 13 TSM:INIT:GW MODE 15 TSM:READY:ID=0,PAR=0,DIS=0 17 MCO:REG:NOT NEEDED 580 GWT:TPC:IP=192.168.178.87 1583 MCO:BGN:STP 1585 MCO:BGN:INIT OK,TSP=1 1588 GWT:TPC:IP=192.168.178.87 2590 GWT:RMQ:MQTT RECONNECT 2798 GWT:RMQ:MQTT CONNECTED 2801 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT 2807 TSM:READY:NWD REQ 2844 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK: 0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1 4 TSM:INIT 5 TSF:WUR:MS=0 11 TSM:INIT:TSP OK 13 TSM:INIT:GW MODE 15 TSM:READY:ID=0,PAR=0,DIS=0 17 MCO:REG:NOT NEEDED 580 GWT:TPC:IP=192.168.178.87 1583 MCO:BGN:STP 1585 MCO:BGN:INIT OK,TSP=1 1588 GWT:TPC:IP=192.168.178.87 2590 GWT:RMQ:MQTT RECONNECT 2798 GWT:RMQ:MQTT CONNECTED 2800 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT 2807 TSM:READY:NWD REQ 2844 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK: 3810 TSF:MSG:READ,254-254-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0 3815 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/21,MSG SENT 636790 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99 636795 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/0,MSG SENT 637304 TSF:MSG:READ,254-254-0,s=255,c=3,t=1,pt=0,l=0,sg=0: 637309 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/1,MSG SENT 637815 TSF:MSG:READ,254-254-0,s=1,c=1,t=16,pt=2,l=2,sg=0:0 637820 GWT:TPS:TOPIC=mygateway1-out/254/1/1/0/16,MSG SENT 637827 TSF:MSG:READ,254-254-0,s=1,c=1,t=15,pt=1,l=1,sg=0:1 637832 GWT:TPS:TOPIC=mygateway1-out/254/1/1/0/15,MSG SENT 637838 TSF:MSG:READ,254-254-0,s=7,c=1,t=0,pt=4,l=4,sg=0:44 637844 GWT:TPS:TOPIC=mygateway1-out/254/7/1/0/0,MSG SENT 637850 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99 637855 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/0,MSG SENT 900006 TSF:SAN:OKHow do I proceed? Ive tried to find more posts on getting MySensors to work under OH24 but I think it is sooo simple that nobody has any problems to post....right?!
Hope you guys can get this Newbie back on track.... thx a lot!
