  3. Has anyone else seen a varistor/MOV failure in a power supply?
12 Posts 5 Posters 4.4k Views 5 Watching
  • sundberg84S
    sundberg84S
    @tomg what I've read some people seem to dislike varistors just because the can fail causing a short. If you don't have a fuse before you will have a fire. Have a look on Wikipedia under hazards.
    Offcourse with a fuse this seems to be a good tool to avoid surge damage with a MOV but I guess selecting it's values are crusial.
    I'm don't have knowledge enough and it's been pointed out to me that selecting the varistor values and specs are very important. Unfortunately I haven't got that far in my readings yet...
    Edit: myself are also using the HLK with MOV. Even one outside (under roof) and it's been working great for a while... so offcourse there might be a chance it was just an unlucky event.
    skywatchS 1 Reply Last reply
    • sundberg84S sundberg84
      skywatchS
      skywatchS
      skywatch
      @TomG
      If I were you I would simply take out all the aliexpress mov's and replace them with good quality ones from a reputable supplier of electronic equipment (RS in UK or Farnell/Element14 or Mouser in US etc.) That way you can be sure you have the components from a known source with full spec.
      Maybe the ones from ali were seconds or rejects sold as the real thing. You never know. I once encountered a seller who was getting his 'stock' from the wheelie bins at the back of a factory......
      • T
        TomG
        Replacing them with better parts is definitely a good idea. Unfortunately, I'm limited in what I can buy locally. I have to order them from another continent if my local electronics store doesn't have them. I may just cut them off the PCB and replace them at a future date.
        • Nca78N
          Hello, I had a similar case with a varistor from AliExpress too, after some time and for an unknown reason it shorted, but without any visual indication of a problem. It was on the dual ssr board that didn't have a fuse before the varistor so it triggered the circuit breaker... Board worked fine for a few weeks without varistor after that, but I didn't feel confident to continue using it for a long time.
          • T
            TomG
            I found some varistors at the best electronic component store in the area. They had a wide variety of voltages. One was 120v (part number CNR-07D121K). We have 110v AC (measured) here. On the outside of the plastic bag with five parts was a store printed label that included "120v1ma +- 10%". If that 10% applies to the max voltage, then that may explain the failure of my varistor. 120v * .9 = 108v. Perhaps it was working just fine, but it was at the low end of the tolerance range. The next voltage up on the supplier's shelf was 150v. The more I learn about these things, the less I think I know. A datasheet I found was 24 pages long!
            • T TomG
              skywatchS
              skywatchS
              skywatch
              @tomg
              That is good news.
              As you now know the rating on them is where they start to conduct. Here in UK we have 240V mains voltage. I wouldn't use a 250V mov. Generally a 380v or 470V would be my choice. There are some good youtube videos that explain varistors rather well.
              Good luck. ;)
              • skywatchS skywatch
                @tomg
                That is good news.
                Good luck. ;)
                sundberg84S
                sundberg84S
                @skywatch i was looking for a good video about varistors - mostly about finding the right one for my AC rating. Do you happen to know one? All i found was "this is how a mov functions"-videos.
                  skywatchS
                  skywatchS
                  skywatch
                  @sundberg84 Try this one......
                  https://www.youtube.com/watch?v=r2o0Y8wI2Z0
                  But mainly once you know how they work and what they do, you really only need to look up the data sheet(s) to see which one is suitable for your application.
                  My rule has been to use 1.5x - 2.0x the usual operating voltage. Remember this is protection from big surges and spikes, not to limit noise and glitches on the power line. For that you need capacitors and a common mode inductor.
                    sundberg84S
                    sundberg84S
                    @skywatch - great, I will have a look.
                    The question im asking myself now is if AC voltage is the only parameter you need to know when selecting a MOV. I had a comment here suggesting there was more to it.
                    Edit: Something like this? https://www.electronicdesign.com/power/select-right-varistors-overvoltage-circuit-protection
                      skywatchS
                      skywatchS
                      skywatch
                      @sundberg84 You first have to decide what you are protecting against, then define the parameters you are likely (or even unlikely) to face. You always should have a fuse with a mov. Like all electronic parts there is a whole depth of knowledge and physics waiting for you! ;)
                      If you have a specific concern then an electronics forum like this one would be a good place to ask. That way you get a lot of opinions and can make a better judgement.
                      I have rarely needed to use them as I don't build psu's much these days, so I copied what I saw in commercial designs.
                      • JohnRobJ
                        JohnRobJ
                        JohnRob
                        My recollection of MOV specifications is the are often rated for AC operation I.e. In the US we might use a 130Vac MOV. While others are rated for DC operation. For most folks it is probably wise to follow those ratings. If you are really into MOV.s then you look to the curves.
                        I do not mean to imply that AC rated MOVs a different from DC rated MOVs, they are both physically the same parts, its just how the catalog presents the specifications.
