  2. Announcements
1.1k Posts 173 Posters 1.3m Views 131 Watching
  • alowhumA Offline
    alowhumA Offline
    alowhum
    @Anticimex: I understand, but:
    • Currently even the outline of the steps eludes me. Seeing the steps for usecase #14 or #385 would already help me understand the scope, and to see what ballpark of difficulty it's in. It's easier to mod a guide when there is something to go on.
    • Secondly, there must be a common use case? The defaults that MySensors uses already suggests a lot of these: a Raspberry Pi with the default settings of the software (ethernet), with the nRF24 radio.
    A 1 Reply Last reply
    • alowhumA alowhum
      A Offline
      A Offline
      Anticimex
      @alowhum ok, well first of all, I don't have a rPi setup to test on, secondly I don't have time to look into that (this) environment.
      But, this is a open source project so anyone is free to contribute with both code and documentation (which in our case lives in the same repositories) so if there are guides missing enyone is welcome to contribute with experiences and guides to help others out.
      It is just important to understand that the guides need to be maintained in order to remain valid.
      I don't mind guides at all. But it makes little sense for me to write guides for an environment which I am not familiar with nor can test on.
      • alowhumA Offline
        alowhumA Offline
        alowhum
        @Anticimex: Sure, that's totally understandable. There are other people on the forum :-) Can anyone help me and @pepson out?
        And it is exactly my goal to create a more elaborate guide after someone points out the basic steps.
        • J Offline
          J Offline
          John Oliva
          I have designed a 3D printable enclosure for this and the design/STL files are available here: https://www.thingiverse.com/thing:3072244
          • hekH Offline
            hekH Offline
            @John-Oliva, nice! Added it to the MySensors collection:
            https://www.thingiverse.com/mysensors/collections/mysensors
            • ? A Former User
              Hello, it seems I found the problem: Complete newbie thing: :beginner:
              I just gave the right to the folder, and now it's working.
              Thanks for taking time to help beginners !
              cadetC Offline
              cadetC Offline
              cadet
              @korleone HI
              I have same error
              Can you write that rigth do you ser to folder ?
              Andrey
              cadetC 1 Reply Last reply
              • cadetC cadet
                @korleone HI
                I have same error
                Andrey
                cadetC Offline
                cadetC Offline
                cadet
                @cadet I just remove /usr/local/bin/mysgw and compile again
                And I have one question - why is it happened?
                MysGW work fine about 3 months.
                  what problem did you have?
                    cadetC Offline
                    cadetC Offline
                    cadet
                    @gohan mysgw: ERROR accept: Bad file descriptor - today morning
                      I get that when another instance of the process is already running
                        cadetC Offline
                        cadetC Offline
                        cadet
                        @gohan I was try to find it with ps -ef, but nothing found. Reload RPI.
                        @korleone was write about this
                        "Hello, it seems I found the problem: Complete newbie thing: 🔰
                        I just gave the right to the folder, and now it's working."
                        But what right hi gave ?
                          sudo ./bin/mysgw -h could work, it only depends in which folder you are running the command from
                          • M Offline
                            M Offline
                            mvader
                            FYI looks like on the 2.3.1 beta the transport has been changed to rf24 instead of nrf24
                            • M Offline
                              M Offline
                              magjef29
                              Is the rasberry pi serving as a gateway and a server in this project? Or do you have to have a separate pi to host something like openhab and another pi for your gateway?
                              • M magjef29
                                #965
                                Hi @magjef29, welcome to the MySensors forum!
                                You can run your controller(s) on the same Raspberry Pi.
                                Depending on what tou mean by ”server”, the gateway can be a server, but the gateway is not a controller.
                                If you haven’t already, see the getting started guide for information about the different parts.
                                • А Offline
                                  А Offline
                                  Артем ТИхонович
                                  Hi! Does anybody test Cubieboard as Gateway? I have a cubieboard runing archlinux with spi enabled in kernel. How i define pins for nrf24 gateway connection? Or i need to make big changes in code to star work with different bord than Rpi?
                                  Best regards
                                  • А Offline
                                    А Offline
                                    Артем ТИхонович
                                    This is my old dream to connect directly nrf to Cubieboard GPIOs. Few years ago i try to do this without success using this lib - https://github.com/bearpawmaxim/librf24-sunxi
                                    • А Артем ТИхонович
                                      #968
                                      Hi @артем-тихонович, welcome to the MySensors forum!
                                      For the NRF24, the same defines as for normal sketches are used. Documentation: https://www.mysensors.org/apidocs/group__RF24SettingGrpPub.html
                                      The defines can be added to the Raspberry Pi gateway by following the instructions on https://www.mysensors.org/build/raspberry#advanced
                                      I have not heard about anyone using the Cubieboard but hopefully someone else has. The information provided on https://www.mysensors.org/build/orange might be useful if the Cubieboard is similar to the Orange Pie.
                                      oh, and in case you haven't already, see the ./configure --help text about the most common NRF24 defines; you might not need the advanced build options.
                                      • А Offline
                                        А Offline
                                        Артем ТИхонович
                                        Thank you, @mfalkvidd. Ihave a little troubles with correct defining gpios from Cubie. In fex file the gpios defines is:
                                        [gpio_para]
                                        gpio_used = 1
                                        gpio_num = 2
                                        gpio_pin_1 = port:PH07<0><default><default><default>
                                        gpio_pin_2 = port:PH15<6><default><default><default>
                                        in sys/gpio:
                                        [root@Archey boot]# ls -ls /sys/class/gpio/
                                        total 0
                                        0 --w------- 1 root root 4096 Nov 21 11:58 export
                                        0 lrwxrwxrwx 1 root root 0 Nov 18 17:01 gpio1_ph7 -> ../../devices/platform/gpio-sunxi/gpio/gpio1_ph7
                                        0 lrwxrwxrwx 1 root root 0 Nov 21 11:54 gpio2_ph15 -> ../../devices/platform/gpio-sunxi/gpio/gpio2_ph15
                                        0 lrwxrwxrwx 1 root root 0 Nov 18 10:45 gpiochip1 -> ../../devices/platform/gpio-sunxi/gpio/gpiochip1
                                        0 --w------- 1 root root 4096 Nov 18 16:52 unexport
                                        When i define in configure: --my-rf24-ce-pin=1 --my-rf24-cs-pin=2 build is ok, but test failed with error:
                                        Nov 21 11:58:15 ERROR Could not open /sys/class/gpio/gpio1/direction[root@Archey MySensors]#
                                        when i define --my-transport=nrf24 --my-rf24-ce-pin=gpio1_ph7 the build failed wirh error:
                                        ./drivers/RF24/RF24.cpp: In function 'void RF24_ce(bool)':
                                        <command-line>:0:16: error: 'gpio1_ph7' was not declared in this scope
                                        ./drivers/RF24/RF24.cpp:52:17: note: in expansion of macro 'MY_RF24_CE_PIN'
                                        hwDigitalWrite(MY_RF24_CE_PIN, level);
                                        How can i resolve this problem? Please help.
                                        • А Offline
                                          А Offline
                                          Артем ТИхонович
                                          I just see for another app using nrf24 on cubieboard
                                          and funcrtion to use nrf24 have GPIO defining is RF24 radio(SUNXI_GPB(10), SUNXI_GPB(11), "/dev/spidev0.0");
                                          GPIO set using this style: SUNXI_GPB(10), this type of gpio defined in #include "gpio_sun4i.h" file. Maybe this specific defining in ARCHLINUX ARM distro.
