  3. CDEBYTE's new NRF24 modules are great! (and cheap)
36 Posts 8 Posters 12.6k Views 7 Watching
  • skywatchS
    skywatchS
    skywatch
    @alowhum You may be correct on this as they have changed the photos and description in the last month or so - it now says components "Imported from Japan, USA & Germany" and then 'original nordic imported' - So that is clearer than it was before.
    • sundberg84S
      sundberg84S
      And for those who likes ebay: https://www.ebay.com/itm/Ebyte-E01-ML01D-100m-nRF24L01-2-4GHz-SPI-wireless-transmitter-receiver-module/191974998709?hash=item2cb29a02b5:g:gzcAAOSwKflZN7Al
      skywatchS 1 Reply Last reply
      • sundberg84S sundberg84
        skywatchS
        skywatchS
        skywatch
        @sundberg84 That's nearly twice the price of ali!
        FWIW I checked my orders, earlier this year they were $2.24each. They had the ML01D screen printed on them.
        Now they are $1.42 each, they are a different colour red and have no screen printing on the back.
        • skywatchS skywatch
          @skywatch using a smd capacitor like that is a clever and clean solution to placing the capacitor close to the chip. Thanks for sharing! I'll do that in the future instead of messing with the big electrolycic cans.
          skywatchS sundberg84S 2 Replies Last reply
            skywatchS
            skywatchS
            skywatch
            @mfalkvidd Thank you! - If I had known I would have used one with better soldering for the photo It was just to show that the newer cheaper ones were not identical to the original ones they sold a few months ago.
            I use either 1206 or 0805 ceramic multilayer capacitors, 47uF, 6.3V. All nrf's get this treatment before use. A jewellers eyepiece is good for checking the joints and I solder them by hand but it needs a pair of tweezers or fine pliers.
              sundberg84S
              sundberg84S
              @mfalkvidd would be interesting which perform best, smd cheramic or electrolytic cap... now when you are thinking about a new oscilloscope ;)
              • nitroburnN
                nitroburnN
                nitroburn
                There are two stores that manufacturer the same modules. Often the prices will differ between the two so you're best off comparing which one is less expensive. CDSNET
                https://www.aliexpress.com/store/product/omg-a-few-cents/2798183_32807273986.html
                store link: https://www.aliexpress.com/store/2798183
                Same board, 2c less right now. It is too bad they no longer do their insane, I have no idea why they were so low, price sales anymore. Happened the same time as an EBates 10% back Not that I need any more of their products. I have way too many modules from them already (100s), but 75% off was hard to pass up. items quantities were limited but they seem to reset the sale so often I just placed a ton of orders whenever it let me. Many NRF52832 modules were acquired this way.
                but if your already shopping AliExpress, I hope you're using eBates on top of that.
                USA eBates (note, I use this from Canada if greater cashback before or after exchange. ie, both are 3% right now, but USD>CAD): http://bit.ly/eBatesDotCom
                Canada eBates: http://bit.ly/eBatesDotCa
                There are often 10% back offered.
                • alowhumA
                  alowhumA
                  alowhum
                  Too bad they're not so cheap anymore..
                  • alowhumA alowhum
                    skywatchS
                    skywatchS
                    skywatch
                    @alowhum You are right! - That is some inflation they have in China! ;)
                    I got a load in August for $1.42 each. Now $3.50 - $3.89. What the .....?
                      at that price it is worth to switch to rfm69
                      • alowhumA alowhum
                        I bought and tested one of these new small modules:
                        https://www.aliexpress.com/item/E01-ML01D-small-size-SPI-nRF24L01P-2-4Ghz-1mW-PCB-antenna-IOT-uhf-wireless-transceiver-transmitter/32803704874.html
                        • Smaller
                        • Thinner
                        • Works at full power
                        • Claim to use real imported NRF chips
                        • $1,25
                        I've also ordered a shielded version that I'm still waiting for.
                        Perhaps the website can reflect some of the newer options?
                        • These small parts (but perhaps the shielded alternative will be even better)
                        • Shielded NRF24 PA high power version. Very nice too. No need to wrap aluminium foil around them :-)
                        ร
                        ร
                        รอเรือ
                        @alowhum said in CDEBYTE's new NRF24 modules are great! (and cheap):
                        Today, I've tried the unshielded one and the few that I've tried seem to work.
                        However, I haven't been able to make the shielded one work on a IO Shield for Arduino Nano. I've used antennas from older traditional NRF24L01+PA+LNA Antenna version. No way. I will try different decoupling-Capacitors tomorrow.
                        I feel I'm stuck in the NRF24-hell...
                        • ร รอเรือ
                          @รอเร-อ said in CDEBYTE's new NRF24 modules are great! (and cheap):
                          What's the issue? Is the module not responding to arduino commands or are transmissions /receptions failing?
                          ร 2 Replies Last reply
                          • YveauxY Yveaux
                            ร
                            ร
                            รอเรือ
                            @yveaux I'll investigate further today and report here afterwards. Thanks.
                            • YveauxY Yveaux
                              ร
                              ร
                              รอเรือ
                              wrote on last edited by รอเรือ
                              #21
                              @yveaux
                              I have spent 2 days trying to solve my various NRF24 related problems at my home.
                              What I'd like to achieve is to make my serial gateway using a NRF24-transciever with an external antenna to extends it's range.
                              CDEBYTE's new NRF24-transciever (the unshielded one) works in my serial gateway (built with a Nano IO Shield) and fed with USB power only. I can attach a separate power source if I want to but it seems to work well without it.
                              However, CDEBYTE's new shielded NRF24-transciever (Shielded nRF24L01 PA+LNA) refuses to work. I get only NACKs in the log even if I attach a separate power source. I've also tried just connecting my Nano board directly to the radio with cables (without the IO shield) just like in the Build a serial gateway demo. (I've tried all kind of power settings) I also tried to power the radio with a battery. Those NACKs are resilient indeed. Of course I've tried all kind of decouple capacitors and several combinations of electrolytic and ceramic ones... No way.
                              BUT, there is always a but isn't there? ... I have managed to get the CDEBYTE Shielded nRF24L01 PA+LNA to work stable on a battery powered node, a Pro Mini ATmega 328 (1.8V 1 MHz). I can't tell why that works while not working with the Nano.
                              My current working solution is using the "old" unshielded nRF24L01 PA+LNA mounted on the Nano IO Shield fed with usb power only. #define MY_RF24_PA_LEVEL RF24_PA_MAX While this seems to work (at least for the moment) I can not just switch to using the shielded radio.
                              So if someone succeeds using the CDEBYTE Shielded nRF24L01 PA+LNA connected to a Nano board I'm interested to hear how you made it work.
                              The thing is that everything that I have tried gives so random results that it's driving me crazy. Whatever seems to work one minute stops to work the next minute.
                              skywatchS YveauxY 2 Replies Last reply
                              • ร รอเรือ
                                @yveaux
                                skywatchS
                                skywatchS
                                skywatch
                                #22
                                @รอเร-อ I have been using the cdebyte shielded pa/lna for months now with a 5V pro mini and all is good with the radio module. I have a 47uF ceramic smd capacitor soldered across the nrf24 power pins on the reverse side of the board. I am running it with POWER=HIGH since it is the higher powered version I don't need to set it to MAX.
                                What current rating is the power source you are using? Maybe the voltage is dropping when it is sending data as there is not enough current available? Just a thought.
                                Also, try moving the position of the nrf slightly. Just a few cm can make quite a big difference. Finding a 'sweet spot' is often the solution, that's why on many modules I put the nrf in a separate tiny box so it can be positioned in a good place for best signal.
                                I can confirm that from my experience this is that this is a very frustrating and time consuming path!
                                ร 1 Reply Last reply
                                • ร รอเรือ
                                  @yveaux
                                  #23
                                  I recently received the same Nano IO shields and discovered the IO lines to the nRF are fed through a voltage divider; levels are halved w.r.t. direct connection.
                                  According to Nordic's datasheet this should be ok (minimum HIGH level input voltage is 0.7 * VDD, so 0.7 * 3.3V = 2.31V) as long as your Arduino is fed with 5V this should just work, but it is tricky IMHO.
                                  You could measure the VCC of the Nano to see if it is below 5V, or try powering the board through the power jack and see if things improve.
                                  So your shielded module is proven OK; that helps :+1:
                                  Did you also try the shielded module with #define MY_RF24_PA_LEVEL RF24_PA_MIN ?
                                  Power issues (e.g. a bad/fake AMS1117 regulator on the Nano IO shield not being able to supply enough current for RF24_PA_MAX) usually manifest at high power levels.
                                  Currently I'm out of Nanos, but as soon as the new batch comes in I can replicate your setup.
                                  Yes, toubleshooting can be very frustrating... Try to test components in isolation first, but you already seem to do that.
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    @yveaux said in CDEBYTE's new NRF24 modules are great! (and cheap):
                                    Since moving to these boards all my connection troubles have stopped. I'm very happy with them.
                                      ร
                                      ร
                                      รอเรือ
                                      @skywatch said in CDEBYTE's new NRF24 modules are great! (and cheap):
                                      I intend to run them on power level RF24_PA_MAX. I have tried other power levels in my efforts without any success.
                                      That's interesting. I'm powering it with USB only but i have tried to connect an additional power source as well but it made no difference, I will do some more tests and measure the voltage levels.
                                      From what I recall, I have tried RF24_PA_LOW. I will test RF24_PA_MIN too.
                                      I'd be happy to send you one from my batch. Please send me a PM if you'd like that.
                                      Sounds very promising :grinning:
                                      • YveauxY Yveaux
                                        #26
                                        My Nano came in and I did a quick test with one of my IO shield boards and a regular, unamplified clone nRF24.
                                        This is a scope plot of the SCK (clock) signal:
                                        It does work, but apparently only barely: The blue line is SCK coming from the Nano (at 4.77V) and the red one is the SCK as seen by the nRF (2.26V max, where nRF24 expects at least 2.31V according to the datasheet)
                                        An amplified EByte E01-ML01DP5 and amplified, unshielded clone indeed do not work.
                                        I see a few solutions to this ploblem (lowering the nRF24 VCC or changing the resistors on the voltage dividers) which I'll give a try and report back.
                                        • YveauxY Yveaux
                                          #27
                                          Lowering the nRF24 VCC is not feasible as it will also impact the signals going to the ATMega below minimum levels.
                                          I replaced 4 10k SMD resistors R5, R6, R7 & R8 by 4k7 types:
                                          @รอเร-อ This patch makes both regular and amplified nRF24 modules work correctly! The IO levels to the nRF are raised to 3.3V at 5V Arduino supply.
                                          Btw. I ordered 2 of these IO shields (red version, by 'Robotale' according to silkscreen) and the quality is horrible...
                                          It's nearly impossible to push the Nano in the socket, it was full of (near) solder shorts, the silscreen is barely readable and one of the boards contained a short to GND on the RX line, making it impossible to program (geen circle):
