  3. Ethernet W5100 gateway IP problem
9 Posts 4 Posters 3.1k Views 4 Watching
  • W
    W
    WMMHOME
    Hi, New to MySensors and I'm trying to figure out how to fix an IP addressing issue.
    ( apologies if this represents a double post, I attempted prior to validating my registration)
    I'm using the latest IDE, Mysensors and etherenet gateway packages from here.
    I put in my static IP address of 192,168,1,3 but can't ping it so I checked the logs and the address comes back as 0.0.0.0 or 127.127.127.127 or any other random set depending on what random nbr I use for the last digit. I tried a to go the DHCP route and it failed. Any ping attempts fail as well,
    I have provided the 5100 with it's own 3.3v power, get good link and flashing tr/rx leds.
    I'm using a NANO and have tried every build version down to about 10 where the old boot loader is not supported.
    Strange thing is VERA seems to detect it but doesn't actually work ( start does noting) but if I disconnect the board, the ip address I entered disappears from the device.
    Any ideas ?
    Wayne
    • W WMMHOME
      Any ideas ?
      Wayne
      Hi @wmmhome, welcome to the MySensors forum!
      Could you post the debug log of the gateway and your entire sketch? The debug log will help see what is going wrong and a new set of eyes on the sketch might reveal some subtle difference.
      W 1 Reply Last reply
      • parachutesjP
        parachutesjP
        parachutesj
        power issue was my 1st thought. I had that before when it wasn't good enough.
        I just experienced also an issue with a gateway, I had to specify the MAC address (change to whatever you like)
        #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xAD
        BR
        SJ
          W
          W
          WMMHOME
          @mfalkvidd
          Here is a dump of the log when using 192,168,1,3 I've used 1,250 and various in between and get random.
          0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.3.0
          11:32:45.228 -> 3 TSM:INIT
          11:32:45.228 -> 4 TSF:WUR:MS=0
          11:32:45.228 -> 11 TSM:INIT:TSP OK
          11:32:45.228 -> 12 TSM:INIT:GW MODE
          11:32:45.228 -> 14 TSM:READY:ID=0,PAR=0,DIS=0
          11:32:45.228 -> 17 MCO:REG:NOT NEEDED
          580 GWT:TIN:IP=120.0.0.0
          1583 MCO:BGN:STP
          11:32:46.834 -> 1585 MCO:BGN:INIT OK,TSP=1
          51289 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          11:33:36.507 -> 51294 TSF:MSG:BC
          11:33:36.507 -> 51296 TSF:MSG:FPAR REQ,ID=255
          11:33:36.507 -> 51299 TSF:PNG:SEND,TO=0
          11:33:36.547 -> 51301 TSF:CKU:OK
          11:33:36.547 -> 51302 TSF:MSG:GWL OK
          51444 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          53292 TSF:MSG:READ,255-255-0,s=148,c=3,t=3,pt=0,l=0,sg=0:
          57296 TSF:MSG:READ,255-255-0,s=56,c=3,t=3,pt=0,l=0,sg=0:
          59298 TSF:MSG:READ,255-255-0,s=10,c=3,t=3,pt=0,l=0,sg=0:
          here is the sketch ( I have used static, no static commented and uncommented the my-ip-gateway and my-ip-static)
           * Version 1.0 - Henrik EKblad
           * LED purposes:
           * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
           * - ERR (red) - fast blink on error during transmission error or receive crc error
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          #define MY_GATEWAY_W5100
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          // Enable UDP communication
          //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
          #define MY_IP_ADDRESS 192,168,1,3
          //#define MY_IP_GATEWAY_ADDRESS 192,168,1,1
          #define MY_PORT 5003
          // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
          #include <Ethernet.h>
          K 1 Reply Last reply
          • mfalkviddM
            Strange. Does the debug print always show 120.0.0.0 when you are using 192,168,1,3 or does the IP change for every reset or sketch upload?
            My guess would be some sort of memory corruption.
            Which version of the Ethernet library are you using? (The version will be printed at the end of sketch upload if the preference "Show verbose output during compilation/upload" is checked). The latest version seems to be 2.0.0.
            W 2 Replies Last reply
            • W WMMHOME
              @mfalkvidd
              1583 MCO:BGN:STP
               * LED purposes:
              #define MY_SOFTSPI
              K
              K
              Karl-Heinz K
              wrote on last edited by Karl-Heinz K
              @wmmhome
              could it be that your problem is related to the SPI issue which was discussed in this thread:
              W5100 Ethernet gateway with RFM69 Radio fails at init
              The suggested patches helped me a lot.
              In addition: When I built my W5100 gateway I could not use the Arduino Nano, I had to switch to an Arduino Mega. The nano had not enough memory available for my project using an RFM69 AND the W5100 ethernet shield. The nano started to work, but after some 10 - 15 min the stack ran out of memory and the nano crashed. But it was not so obvious in the beginning when I started to debug the project at that time. Maybe you ran into a similar problem.
              Sincerely
              Karl-Heinz
                W
                W
                WMMHOME
                @mfalkvidd
                The ethernet library I'm using is 2.0.0
                The IP stays at 120.0.0.0 as long as I am using 192,168,1,3 through multiple complies and restarts. It changes to other numbers as I change the entered IP.
                Karl-Heinz - thanks , I'll look through that and hopefully I'll begin to really understand it all.
                Wayne
                  W
                  W
                  WMMHOME
                  @mfalkvidd
                  Good afternoon. I did some more research and found this sketch that works, in that I can get a pingable connection. I now am confident that the boards and wiring are correct. Problem now is I'm not smart enough yet to figure out how to incorporate the calls to initiate it. When I tried to put the code into SETUP, the compiler throws an error stating IPAddress is wrong. It appears that I'm not getting a reset in the stock gateway code?
                  const int W5100_RESET_PIN = 8;
                  #define MY_IP_ADDRESS 10,0,0,250
                  // Enter a MAC address for your controller below.
                  // Newer Ethernet shields have a MAC address printed on a sticker on the shield
                  byte mac[] = {
                  0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02
                  Serial.println();
                  Serial.println(F("node starting..."));
                  pinMode(W5100_RESET_PIN, OUTPUT);
                  digitalWrite(W5100_RESET_PIN, LOW);
                  delay(100);
                  digitalWrite(W5100_RESET_PIN, HIGH);
                  // give the Ethernet shield a second to initialize:
                  delay(3000);
                  #ifdef USE_DHCP
                  Serial.println(F("DHCP..."));
                  while (Ethernet.begin(mac) == 0) {
                  Serial.println(F("DHCP failed."));
                  delay(10000);
                  Serial.print(F("static IP..."));
                  Ethernet.begin(mac, IPAddress(MY_IP_ADDRESS));
                  Serial.print(F("local IP:"));
                  Serial.println(Ethernet.localIP());
                  Serial.println(F("node started."));
                  // put your main code here, to run repeatedly:
                  • K
                    K
                    Karl-Heinz K
                    Dear Wayne,
                    I copy my documentation for the Arduino Mega which I put in the header of my sketch (which means I did not think through all details again for this post, just wanted to help quickly) at the end of this post. It will help if you use an Arduino Mega. It might also help if you use an Arduino Nano.
                    During my experiments I also made the following note to myself (did not validate all details though):
                    " // final conclusion:
                    // the Arduino Nano was not stable. Probably because it was low on SRAM.
                    // However, for the Arduino Nano test I did not use the SPI patched RFM69 Library -> could improve stability
                    // and I did not try to use an ethernet library with a smaller footprint -> could improve stability, too"
                    Currently I use these libraries:
                    #include <RFM69.h>
                    I hope this points to the right direction.
                    I currently use the Computourist RFM69 MQTT gateway sketch (get it here: https://github.com/computourist/RFM69-MQTT-client). But it is on my agenda to change all my code to MySensors. I just did not have time to do it. Anyway, long story short, if you send me a PM with an email address I could send you my sketch if you are interested. The code is not well structured currently, however, therefore I do not what to share it publicly.
                    Sincerely
                    Karl-Heinz
                    KH: quick and dirty documentation (end of 2017):
                    /*  Connect Arduino Mega:
                     *  EthernetShield Labels = Mega Labels
                     *  5V              = 5V
                     *  GND             = GND
                     *  IRQ = D2        = 2
                     *  RST =           = 4
                     *  SCL = D13       = 52
                     *  CS              = 8
                     *  Miso = D12      = 50
                     *  Mosi = D11      = 51
                    /*This sketch only works under the following conditions:*/
                    /*1) An Arduino Mega must be used due to memory problems of Uno/Nano (SRAM)
                       and it has to be an EthernetShield with W5100 chip, but it should be the newer
                      version of the EthernetShield, because older versions have the SPI
                       interface permanently blocked by the EthernetShield. Only after a
                       hardware modification at the SENS pin of the W5100 chip the blocking is no longer the case.
                     2) the RFM69 Library of LowPowerLabs does not yet (end of 2017) contain all
                        necessary adaptations, so that SPI conflicts between the Ethernet card
                        and the RFM69 module can be solved.
                        There is a patched version for this purpose:
                           https://github.com/rrobinet/RFM69_Libary
                      3) The original Ethernet Library of the Arduino IDE does not consider the Arduino IDE's
                         own current SPI library and must also be patched.
                         Copy from the Internet:
                    	"[Changes to the Ethernet Library](http://harizanov.com/2012/04/rfm12b-and-arduino-ethernet-with-wiznet5100-chip/)
                    	 I edited the Arduino Ethernet library file W5100.h so that it doesn’t
                    	allow RFM12b to interrupt while the SPI bus is busy handling Wiznet5100.
                    	I added a cli(); and sei(); as follows in the W5100 library."
                    	für Arduino Mega...
                    	[Reference](https://lowpowerlab.com/forum/moteino/moteino-w5100-ethernet-spi-support-spi_has_transaction/60/):
                    	In my case using an ATMEGA2560 changing the W5100.h library from:
                    	    #if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                    	      inline static void initSS()    { DDRB  |=  _BV(4); };
                    	      inline static void setSS()     { PORTB &= ~_BV(4); };
                    	      inline static void resetSS()   { PORTB |=  _BV(4); };
                    	To
                    	      inline static void setSS()     { cli ();PORTB &= ~_BV(4); };
                    	      inline static void resetSS()   { PORTB |=  _BV(4); sei();};"*/```
                    12.5k
