  3. Minimal design thoughts
299 Posts 34 Posters 276.4k Views 17 Watching
  • tbowmoT tbowmo
    @ServiceXp said:
    @tbowmo
    That's 2 questions... :-)
    I edited it a couple of times while talking with @hek last evening, so it slipped. Hope you can forgive me ;)
    1. Yes, It's worth it to me (Hopefully there will be MySensors software support down the road)
    2. I would probably start off with 3 to 5.
    Will there be a "kit" price for those who want to populate and reflow themselves?
    No kit version, the pcb will be released under oshw so you could order it yourself, and source the components. However my unit price for the initial units will hit 11-12$, so it's only 1 or 2$ extra to get it smt assembled in China.
    The more units we can order the cheaper it will become.
    bjornhallbergB
    bjornhallbergB
    bjornhallberg
    wrote on last edited by bjornhallberg
    #143
    @tbowmo I might be interested in a few, seeing as this PCB has some pretty unique features, but I'm still in the market for a board with an on-board regulator that will give me a bit more flexibility.
    The problem (for me) is that while waiting for any official hardware, I've bought a lot of other stuff. I had another 10x Arduino Pro Mini arrive just yesterday for instance. Plus the booster project above. I ordered a couple of hundred brand inductors and capacitors as well as ltc3525 ICs. So basically now I don't have a choice but to go it alone for the most part :sweat:
    What we could need right now is some clear direction, like whether the ATSHA204 is the way to go. Or some common form factor that would allow future shields or whatnot.
    Also, for something really small like this, to be put into production, I would have liked to have tried with the "smd / mini nrf24" version that is also available on Ebay, just to keep the size down even further. I just got three of those yesterday and they are indeed very tiny (pin header spacing is 1.27mm). Whether they work ok or not I do not know. I do know that some people on the forum have posted project pictures with these mini nrf24. I guess what I'm saying is that lowpowerlabs already invented the wheel here: http://lowpowerlab.com/moteino/
    Would be great to hang a mini nrf24 flat off of the back if at all possible. But given what we know of the nrf24 it would probably blow up in our faces compared to the RFM12B/RFM69 that the moteino uses. Of course, they also use a wire antenna while we still trust the pcb antenna ...
    tbowmoT 1 Reply Last reply
      tbowmoT
      tbowmoT
      tbowmo
      #144
      I forgot about the mini nrf24 modules. But I don't think that we could have squeezed it that much more in size, we could probably save 2-3mm in stack height, but that's about it.
      Also, this board was designed from the beginning to be a battery operated node. That is why there is no regulator on board (besides the fact that there is no room for it). I selected the components for their ability to work on low voltages all, except the atsha204, is able to work on a VCC as low as 1.8V)
      I have seen lot's of questions asking about battery operation of 3.3V arduino mini pro, with DHT22 sensors attached. People cut LED's and regulators on the arduino, in order to get the power consumption as low as possible. This is where this particular board fits in. It's ready for battery operation, and has the temperature / humidity sensor build in.
      It started out because I wanted an "easy" clean option for sensor nodes for my own application, without any wire nests between arduino and nrf24 modules. I hope that it will be useful for others as well, and might be able to get others going with the mysensor project.
      For my own part, I could use up to 20 of these, for measuring temperature / humidity in every room in the house (and out side as well)
      Btw. all those arduinos you've bought, could be turned into something else :)
      • bjornhallbergB
        bjornhallbergB
        bjornhallberg
        I snapped some pictures just so everyone can see the difference between the nrf24 modules.
        Of course, like I said, I don't even know if the "mini" works in a satisfactory manner. I'm gonna get some smaller pitch headers so I can make a prototype. But the PCB antenna actually seems to be the exact same size so I have high hopes for that aspect at least.
        • tbowmoT
          tbowmoT
          tbowmo
          @bjornhallberg
          The antenna still needs to hang over "free air" (or an unrouted PCB area), this is the area where the logo is located on the current design. It could be moved to the opposite end of the pcb (where the nrf24 pinheader is located).
          If we switch to the mini module, then the pinheader for the radio is removed, but then you need a "larger" area where there is no components at all, in order to mount the nrf module flat to the sensor pcb. So in theory it will not be that much smaller, only the pinheader distance between the two pcbs can be removed.. lenght /width will be almost the same, maybe a bit longer as there is not that much room to give, with the current number of components (Si7021, eeprom, atsha204 etc).
          • tbowmoT tbowmo
            @bjornhallberg
            bjornhallbergB
            bjornhallbergB
            bjornhallberg
            @tbowmo Yeah, you're probably right. It would take some re-design and you might not save all that much space, given all the other components as you say.
            Still, it'd be great to achieve something ... flatter ... like:
            http://harizanov.com/2014/07/diy-internet-of-things-fire-alarm/
            Runs an attiny84 though, but still.
            • tbowmoT
              tbowmoT
              tbowmo
              @bjornhallberg
              Could you measure the mini pcb? the width of the module, and lenght of the area with gnd, and the length of the antenna area (and total length of the module, should be the two lengths added together)
              • tbowmoT tbowmo
                @bjornhallberg
                bjornhallbergB
                bjornhallbergB
                bjornhallberg
                @tbowmo I found an old post I made here:
                http://forum.mysensors.org/topic/413/is-there-a-schematic-of-the-nrf24-board/2
                I checked the measurements and they seem right. In addition, the antenna-area is about 8mm long.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @bjornhallberg
                  made a mockup of the nrf24 mini module, and tried to place it on the sensor board.. If I should use it, I have to remove the ISP pinheader from the board, as there is no room for it.
                  Also, it is filling up almost half the populated pcb area on the sensor board, which means that there is not enough space for the components, and we have to make a bigger pcb, in order to have room for everything.
                  • tbowmoT tbowmo
                    @bjornhallberg
                    bjornhallbergB
                    bjornhallbergB
                    bjornhallberg
                    @tbowmo Yeah, better to save it for a future project. I mean, there will never be a one size fits all and that is what is so great about MySensors. All the PCBs designed so far have a purpose and a market. And ideally, we'd want a few of each in the sensor network to complement each other.
                    The reason I brought up the "mini", aside from wanting a flatter sensor node, is that the module seems to be getting more common on Ebay as well as cheaper. I've seen some sellers that sell them for the same price as the regular NRF24 now (in 10pcs). Four months ago, they were rare and many times more expensive. So if they work as advertised they could soon replace the NRF24 module we've all come to use.
                    In this context, and knowing very little of antennas, it is too bad they don't have a version without the PCB antenna altogether. We could add our own antennas and more easily fit the module on miniscule sensor nodes such as yours.
                    • T
                      tlund
                      I would be interested in 5 units. I lean towards including ATSHA204 and smt assembled, but I would buy without and unassembled.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @tlund
                        So you would just buy the PCB, and source all components yourself?
                        • T
                          tlund
                          @tbowmo
                          Sorry I was a bit unclear. I would like to buy all components as a package from you/mysensors. Preferably assembled, but I would also accept if you sell it unassembled (pcb+components). I would rather not have to source the components myself :)
                          Btw, have you measured the actual power consumption? Sleep vs temp/hum measurement?
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @tlund
                            I haven't measured supply current, as I don't have the equipment to do that. I am looking at getting the uCurrent gold from eevblog, but it's expensive to import it to Denmark.
                            It will probably not be offered as a kit. Too much work from my/our part :-)
                              @tbowmo said:
                              uCurrent gold
                              I can probably test it using mine. Any plans going to Skåne soon ;)
                              • A
                                Alphalove
                                Hello, I'd be in for at least 5 assembled boards.
                                  A Former User
                                  Soo .. this like a breadmix ? :) All we have to add is the sensors ?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    #159
                                    @hek
                                    You already got an ucurrent? I had planned to import an extra one from Australia for you :) (thought that we might be able to save some $ if we ordered 4-5 units).
                                    But as so many other things i got away from it again :(
                                    Unfortunately I only come to Copenhagen these days, visiting a client.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @JimmyH
                                      There is a temperature / humidity sensor on it already. But more can be added :)
                                        wrote on last edited by hek
                                        #161
                                        Ok, pushed a product page to the main site just now. Hope the page is selling enough. ;)
                                        http://www.mysensors.org/hardware/micro
                                        • RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          "ATSHA204A sot23 footprint on board"
                                          So does that mean this run will not have the ATSHA204A populated?
                                          RJ_Make
