  3. Minimal design thoughts
299 Posts 34 Posters 276.4k Views 17 Watching
  • tbowmoT tbowmo
    @bjornhallberg
    The antenna still needs to hang over "free air" (or an unrouted PCB area), this is the area where the logo is located on the current design. It could be moved to the opposite end of the pcb (where the nrf24 pinheader is located).
    If we switch to the mini module, then the pinheader for the radio is removed, but then you need a "larger" area where there is no components at all, in order to mount the nrf module flat to the sensor pcb. So in theory it will not be that much smaller, only the pinheader distance between the two pcbs can be removed.. lenght /width will be almost the same, maybe a bit longer as there is not that much room to give, with the current number of components (Si7021, eeprom, atsha204 etc).
    bjornhallbergB
    bjornhallbergB
    bjornhallberg
    @tbowmo Yeah, you're probably right. It would take some re-design and you might not save all that much space, given all the other components as you say.
    Still, it'd be great to achieve something ... flatter ... like:
    http://harizanov.com/2014/07/diy-internet-of-things-fire-alarm/
    Runs an attiny84 though, but still.
    • tbowmoT
      tbowmoT
      tbowmo
      @bjornhallberg
      Could you measure the mini pcb? the width of the module, and lenght of the area with gnd, and the length of the antenna area (and total length of the module, should be the two lengths added together)
      • tbowmoT tbowmo
        @bjornhallberg
        bjornhallbergB
        bjornhallbergB
        bjornhallberg
        @tbowmo I found an old post I made here:
        http://forum.mysensors.org/topic/413/is-there-a-schematic-of-the-nrf24-board/2
        I checked the measurements and they seem right. In addition, the antenna-area is about 8mm long.
        • tbowmoT
          tbowmoT
          tbowmo
          @bjornhallberg
          made a mockup of the nrf24 mini module, and tried to place it on the sensor board.. If I should use it, I have to remove the ISP pinheader from the board, as there is no room for it.
          Also, it is filling up almost half the populated pcb area on the sensor board, which means that there is not enough space for the components, and we have to make a bigger pcb, in order to have room for everything.
          • tbowmoT tbowmo
            @bjornhallberg
            bjornhallbergB
            bjornhallbergB
            bjornhallberg
            @tbowmo Yeah, better to save it for a future project. I mean, there will never be a one size fits all and that is what is so great about MySensors. All the PCBs designed so far have a purpose and a market. And ideally, we'd want a few of each in the sensor network to complement each other.
            The reason I brought up the "mini", aside from wanting a flatter sensor node, is that the module seems to be getting more common on Ebay as well as cheaper. I've seen some sellers that sell them for the same price as the regular NRF24 now (in 10pcs). Four months ago, they were rare and many times more expensive. So if they work as advertised they could soon replace the NRF24 module we've all come to use.
            In this context, and knowing very little of antennas, it is too bad they don't have a version without the PCB antenna altogether. We could add our own antennas and more easily fit the module on miniscule sensor nodes such as yours.
            • T
              tlund
              I would be interested in 5 units. I lean towards including ATSHA204 and smt assembled, but I would buy without and unassembled.
              • tbowmoT
                tbowmoT
                tbowmo
                @tlund
                So you would just buy the PCB, and source all components yourself?
                • T
                  tlund
                  @tbowmo
                  Sorry I was a bit unclear. I would like to buy all components as a package from you/mysensors. Preferably assembled, but I would also accept if you sell it unassembled (pcb+components). I would rather not have to source the components myself :)
                  Btw, have you measured the actual power consumption? Sleep vs temp/hum measurement?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @tlund
                    I haven't measured supply current, as I don't have the equipment to do that. I am looking at getting the uCurrent gold from eevblog, but it's expensive to import it to Denmark.
                    It will probably not be offered as a kit. Too much work from my/our part :-)
                      @tbowmo said:
                      uCurrent gold
                      I can probably test it using mine. Any plans going to Skåne soon ;)
                      • A
                        Alphalove
                        Hello, I'd be in for at least 5 assembled boards.
                          A Former User
                          Soo .. this like a breadmix ? :) All we have to add is the sensors ?
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #159
                            @hek
                            You already got an ucurrent? I had planned to import an extra one from Australia for you :) (thought that we might be able to save some $ if we ordered 4-5 units).
                            But as so many other things i got away from it again :(
                            Unfortunately I only come to Copenhagen these days, visiting a client.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @JimmyH
                              There is a temperature / humidity sensor on it already. But more can be added :)
                                wrote on last edited by hek
                                #161
                                Ok, pushed a product page to the main site just now. Hope the page is selling enough. ;)
                                http://www.mysensors.org/hardware/micro
                                • RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  "ATSHA204A sot23 footprint on board"
                                  So does that mean this run will not have the ATSHA204A populated?
                                  RJ_Make
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @ServiceXp
                                    We haven't started production yet, I'm still waiting for the latest prototype pcb to arrive from China, before I can make the (hopefully) last prototype before "mass production". Which also means I have to find the atsha204 somewhere, so I can test it.
                                    And yes I know mouser has it, but I don't need that much more from them, so will have to pay a big handling/shipping fee to them
                                      @Anticimex , did you have any spare atsha204 left?
                                      • tbowmoT tbowmo
                                        @ServiceXp
                                        bjornhallbergB
                                        bjornhallbergB
                                        bjornhallberg
                                        @tbowmo Have you looked on AliExpress. A quick search seems to suggest that could be a viable alternative. Try some different search combinations though ... their search engine sucks. "ATSHA204" wont find "ATSHA204A" for instance when I try.
                                        Wont be quick though, and the Chinese New Year is coming up ...
                                        • AnticimexA
                                          AnticimexA
                                          Anticimex
                                          I can part with a SOT23 ATSHA204A if necessary. They can also be sampled from Atmel in small quantities for free (that's what I did).
                                          hekH 1 Reply Last reply
