  2. Announcements
  3. 💬 Log Parser
💬 Log Parser
27 Posts 17 Posters 11.3k Views 16 Watching
  • Ivan ZI
    Ivan ZI
    Ivan Z
    I crash parser
    0 MCO:BGN:INIT REPEATER,CP=RNORAA-,VER=2.1.1
    4 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSF:SID:OK,ID=15
    15 TSM:FPAR
    51 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2059 !TSM:FPAR:NO REPLY
    2061 TSM:FPAR
    2097 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2610 TSF:MSG:READ,5-5-15,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    2615 TSF:MSG:FPAR OK,ID=5,D=2
    3053 TSF:MSG:READ,0-0-15,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    3057 TSF:MSG:FPAR OK,ID=0,D=1
    4105 TSM:FPAR:OK
    4106 TSM:ID
    4107 TSM:ID:OK
    4109 TSM:UPL
    4146 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    6153 TSM:UPL
    6190 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=NACK:1
    8197 TSM:UPL
    8233 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=2,st=NACK:1
    10241 TSM:UPL
    10244 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=3,st=OK:1
    10250 TSF:MSG:READ,0-0-15,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    10255 TSF:MSG:PONG RECV,HP=1
    10258 TSM:UPL:OK
    10259 TSM:READY:ID=15,PAR=0,DIS=1
    10267 TSF:MSG:SEND,15-15-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:FFFFFFFF40016FF10300
    10311 !TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
    12322 TSF:MSG:SEND,15-15-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=1,st=OK:2.1.1
    12331 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    12562 TSF:MSG:READ,0-0-15,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    12578 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:Lighting
    12597 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
    12613 TSF:MSG:SEND,15-15-0-0,s=1,c=0,t=3,pt=0,l=11,sg=0,ft=0,st=OK:Light relay
    12628 TSF:MSG:SEND,15-15-0-0,s=2,c=0,t=6,pt=0,l=15,sg=0,ft=0,st=OK:Key temperature
    12641 TSF:MSG:SEND,15-15-0-0,s=3,c=0,t=30,pt=0,l=14,sg=0,ft=0,st=OK:Source current
      Ok, fixed the problem. Thanks for reporting.
      • U
        U
        user2684
        Hi, I wonder why the following is parsed as a S_LIGHT presentation. Shouldn't be S_BINARY the type number 3? (https://www.mysensors.org/download/serial_api_20). Thanks!
        0;1;0;0;3;
          @user2684
          Yes, it should be S_BINARAY. Thanks for reporting. Updated.
          • ben999B
            ben999B
            ben999
            I have just discovered "The Log Parser" !!!
            WOW that's huge !
            Thumbs up to those involved in that !!! Thanks a lot :)
            • raptorjrR
              raptorjrR
              raptorjr
              The link "More details about the log messages." don't work. 404
              • raptorjrR raptorjr
                @raptorjr thanks for reporting. Could you describe where this link exists?
                Edit: Found it. The link is fixed now. Thanks!
                raptorjrR 1 Reply Last reply
                  raptorjrR
                  raptorjrR
                  raptorjr
                  @mfalkvidd I'm sorry. Thought it was obviuos since I posted in the comment section of the article where the link was =) But I will be more clear if I find a problem some other time.
                  Thanks for fixing the link.
                  • wesW
                    wesW
                    wes
                    wrote on last edited by wes
                    I think the log parser needs to be updated for new message types in MySensors v2.2.0 - they are currently being shown in the log parser as "Undefined":
                    I_SIGNAL_REPORT_REQUEST = 29,
                    I_SIGNAL_REPORT_REVERSE = 30,
                    I_SIGNAL_REPORT_RESPONSE = 31,
                    I_PRE_SLEEP_NOTIFICATION = 32,
                    I_POST_SLEEP_NOTIFICATION = 33
                    Is the source code for this parser somewhere on Github? If not, could we get it put on Github so it's easier to maintain?
                    Blog: https://www.wes.id.au/
                    Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                    Gateway & Controller: Raspberry Pi 3 + Home Assistant
                      @Wes,
                      Here's a gist with the code for the log parser
                      https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
                      • wesW
                        wesW
                        wes
                        @hek I believe this should fix the issue:
                        https://gist.github.com/liwenyip/de6ff2a646ee417fcf2629eae64e6974/revisions#diff-a83c26f29ff664a062308cb4387554c0
                        AFAIK you can't do a pull request on Github Gists.
                        Hope that helps.
                          Thanks, updated.
                          • Nca78N
                            Hello, it seems only the two rightmost columns are filled, I have the same problem with all the browsers.
                            Example:
                            https://www.mysensors.org/build/parser?log=TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A40 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A40 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A45 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A45 TSF%3AMSG%3AACK TSF%3AMSG%3AREAD%2C0-0-255%2Cs%3D255%2Cc%3D3%2Ct%3D20%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A TSF%3AMSG%3ABC TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D21%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A0 TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A50 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A50 TSF%3AMSG%3AACK TSF%3AMSG%3ASEND%2C1-1-0-0%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A55 TSF%3AMSG%3AREAD%2C0-0-1%2Cs%3D5%2Cc%3D1%2Ct%3D38%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A55 TSF%3AMSG%3AACK
                            • B
                              B
                              BoresExpress
                              wrote on last edited by BoresExpress
                              Seems like log parser incorrectly prints command types for signature messages (see picture):
                              • G
                                G
                                gbsmith
                                Just started MySensors 2.3 project. I have the same problem as Nca78 had 5 months again.
                                Only the two right columns are filled. Better than nothing but not perfect as intended.
                                And yes I tried running this code directly: https://gist.github.com/henrikekblad/c1d652cce16eaf2ef6340eacaefc97b0
                                Is anyone maintaining this code?
                                • G
                                  G
                                  gbsmith
                                  Clearly the debug log format has changed to something that this tool does not support.
                                  My log entries look like:
                                  228642 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  The old log entries looked like this:
                                  0;255;3;0;9;TSF:MSG:READ,12-4-0,s=18,c=1,t=16,pt=1,l=1,sg=0:1
                                    The gist has now been updated to the lastest running on mysensors.org
                                    A 1 Reply Last reply
                                    • berkseoB
                                      berkseoB
                                      berkseo
                                      think it's time to add passive node support :) ||| Unknown | ?TSF:MSG:SEND... | |
                                      • W
                                        W
                                        willemx
                                        No support for Gateway Transport messages?
                                        GWT:TPS:TOPIC=mygateway1-out/19/255/3/0/21,MSG SENT
                                          alphaHotel
                                          @hek I was able to add support for stream message types to the log parser but can't perform a pull request against the gist. Here is my diff analysis if you're interested in this small update.
                                          I also made a subsequent one line change to correct the issue that @BoresExpress noted a while back.
