  2. Announcements
  3. 💬 Building a wired RS485 sensor network
164 Posts 33 Posters 79.9k Views 35 Watching
  • A
    Andreas Sieber
    I have the problem that I always get this error: !TSM:FPAR:NO REPLY
    Once it worked briefly yesterday.
    What have I tried everything?
    All hardware exchanged - without success.
    Now I have just written two small scripts that send RS485 back and forth. without problems. So wiring has to fit. I spent then in the serial montior the data which the node sends me, there comes some. Then I once tried to display the data that sends the GW, because nothing comes.
    Does anyone have an idea why my GW does not answer?
    • A Andreas Sieber
      @andreas-sieber could you post the debug output from the node and the gateway?
      • A
        Andreas Sieber
        | |/| | | | _
        \ / _ \ _ \/ __|/ _ \|
        _/ __|
        | || | / | | _ \ _ | | _
        |_
        , |/ ___|| ||/_/|| |/
        __/ 2.3.0-alpha
        17 MCO:BGN:INIT NODE,CP=RSNNA---,VER=2.3.0-alpha
        26 TSM:INIT
        27 TSF:WUR:MS=0
        29 TSM:INIT:TSP OK
        30 TSM:FPAR
        49 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2056 !TSM:FPAR:NO REPLY
        2058 TSM:FPAR
        2075 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4083 !TSM:FPAR:NO REPLY
        4085 TSM:FPAR
        4103 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6111 !TSM:FPAR:NO REPLY
        6113 TSM:FPAR
        6130 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        0;255;3;0;9;0 MCO:BG
        0;255;3;0;9;29 MCO:BGN:INIT OK,TSP=1
        0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RSNGA---,VER=2.3.0-alpha
        0;255;3;0;9;5 TSM:INIT
        0;255;3;0;9;7 TSF:WUR:MS=0
        0;255;3;0;9;9 TSM:INIT:TSP OK
        0;255;3;0;9;12 TSM:INIT:GW MODE
        0;255;3;0;9;15 TSM:READY:ID=0,PAR=0,DIS=0
        0;255;3;0;9;18 MCO:REG:NOT NEEDED
        0;255;0;0;18;2.3.0-alpha
        0;255;3;0;9;22 MCO:BGN:STP
          why don't you use the stable 2.2? Anyway the node is missing the my_node_id define and second it seems the gateway isn't receiving anything, so I guess there is something very wrong in communication
          • A
            Andreas Sieber
            in the 2.2 the same problem, i have now updagradet to alpha.
            When you have a solution on 2.2 i will downgrade. no problem!
            Guys you are good! I had set the mynodeid. But befor i include the my sensors.. that's the mistake..
            hour of hour to search... thx!
            • O
              O
              Omemanti
              Is it possible, or will it be possible to build a combination between wired and wireless nodes?
                one network, one gateway
                • P
                  P
                  Pavel Polititsky
                  I just trying to work with examples but my node always transmitting some piece of shit from hardware serial:
                   __  __       ____
                  16 MCO:BGN:INIT NODE,CP=RSNNA---,VER=2.3.0
                  25 TSM:INIT
                  26 TSF:WUR:MS=0
                  28 TSM:INIT:TSP OK
                  29 TSF:SID:OK,ID=5
                  31 TSM:FPAR
                  ⸮X⸮⸮w34 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2041 !TSM:FPAR:NO REPLY
                  2043 TSM:FPAR
                  ⸮X⸮⸮w2045 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4054 !TSM:FPAR:NO REPLY
                  4056 TSM:FPAR
                  ⸮X⸮⸮w4058 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6066 !TSM:FPAR:NO REPLY
                  6068 TSM:FPAR
                  ⸮X⸮⸮w6070 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8078 !TSM:FPAR:FAIL
                  8079 TSM:FAIL:CNT=1
                  8081 TSM:FAIL:DIS
                  8083 TSF:TDI:TSL
                  From software serial too
                  ⸮X⸮⸮w
                  ⸮X⸮⸮w
                  ⸮X⸮⸮w
                  ⸮X⸮⸮w
                  Consequently the gateway can't find any device.
                  I have tried also with RS485 with different baudrate. Finally I just connect my USB TTL directly to ouput pins, but always same result.
                  How to fix it?
                  • rejoe2R
                    rejoe2R
                    rejoe2
                    @Pavel-Polititsky
                    To me this looks like you mixed between-node communication (RS485) with debug output (and maybe also serial output of the gw).
                    The corresponding serial interface for RS485 should be dedicated to RS485 exclusively.
                    • P
                      P
                      PepoV6
                      first of I have to thank you for your effort on this project! It helped me a lot.
                      In my house I would like to build 2 networks, one with serial gateway with RF24 for ground floor and outside. Second will be in cellar and I was thinking about Ethernet gateway (W5500) but sensors will be connected via RS485. Do you have code for that? On the video it looks like that in the box on right side it is something like this.
                      • G
                        G
                        GieBek
                        I have exactly the same problem. Has anyone managed to run it.
                        • G
                          G
                          GieBek
                          | |/| | | | _
                          _/ __|
                          | || | / | | _ \ _ | | _
                          |_
                          __/ 2.3.1
                          16 MCO:BGN:INIT NODE,CP=RSNNA---,REL=255,VER=2.3.1
                          26 TSM:INIT
                          27 TSF:WUR:MS=0
                          28 TSM:INIT:TSP OK
                          30 TSM:FPAR
                          56 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2063 !TSM:FPAR:NO REPLY
                          2065 TSM:FPAR
                          2082 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4090 !TSM:FPAR:NO REPLY
                          4092 TSM:FPAR
                          4110 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6118 !TSM:FPAR:NO REPLY
                          6120 TSM:FPAR
                          6137 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          8146 !TSM:FPAR:FAIL
                          8147 TSM:FAIL:CNT=1
                          8150 TSM:FAIL:DIS
                          8152 TSF:TDI:TSL
                          18154 TSM:FAIL:RE-INIT
                          18156 TSM:INIT
                          18157 TSM:INIT:TSP OK
                          18159 TSM:FPAR
                          18178 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          20186 !TSM:FPAR:NO REPLY
                          20188 TSM:FPAR
                          20206 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          22213 !TSM:FPAR:NO REPLY
                          22215 TSM:FPAR
                          22234 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          24241 !TSM:FPAR:NO REPLY
                          24243 TSM:FPAR
                          24261 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          26268 !TSM:FPAR:FAIL
                          26269 TSM:FAIL:CNT=2
                          26271 TSM:FAIL:DIS
                          26273 TSF:TDI:TSL
                          • G GieBek
                            #138
                            @giebek could you describe the problem, what your setup looks like, and what you have tried so far to troubleshoot it? There are 137 posts in this thread so it is a bit hard to figure out which problem you are referring to.
                            rejoe2R 1 Reply Last reply
                              rejoe2R
                              rejoe2R
                              rejoe2
                              wrote on last edited by rejoe2
                              #139
                              @GieBek
                              Imo this indicates your node doesn't have a NodeID yet. When using RS485 you have to assign the ID's manually in the sketch, auto doesn't work... (e.g. #define MY_NODE_ID 123)
                              • G
                                G
                                GieBek
                                Thanks for the answers.
                                And even more thanks to the rejoe2
                                it helped 100% the transmission went, domoticz sees children.
                                • dzjrD
                                  dzjrD
                                  dzjr
                                  hello MySensors friends,
                                  I am currently making a node based on an arduino Mega 2560 with transport via RS-485, the build page says that we should use the MEGA pin 46 & 48, I was wondering if I would like a reference for this. in the sketch.
                                  Second question; can I use pin 47 for the DE pin with:
                                  #define MY_RS485_DE_PIN 47
                                  I haven't tested anything yet, so actually I just ask a lazy question ;)
                                  dzjrD 1 Reply Last reply
                                  • A
                                    APL2017
                                    Hello, I would like to better understand the concept here. It sounds like we still need a gateway connected to a controller (serial, Ethernet, WiFi, etc.) but the interface between gateway and multiple nodes is over wired RS485 serial interface. Please confirm. Thank you for your great efforts!
                                    • A APL2017
                                      rejoe2R
                                      rejoe2R
                                      rejoe2
                                      @apl2017 Yes, also for RS485 variant you'll need a gateway. Only the communication between the gateway and the other nodes is handled over RS485, connected to a second (typically software) serial interface (for remote nodes, you may just use the hardware serial interface to connect the RS485 transceiver, if you do not need debug output; but imo this option is not recommended for beginners).
                                      • dzjrD dzjr
                                        dzjrD
                                        dzjrD
                                        dzjr
                                        @dzjr said in 💬 Building a wired RS485 sensor network:
                                        I have it working, so you don't have to adjust anything for a Mega, and pin 47 for DE also works!
                                        • zrom69Z
                                          zrom69Z
                                          zrom69
                                          in a node how many children can put rs-485
                                          thanks good work
