  3. Nrf52 gateway crashes
30 Posts 5 Posters 6.2k Views 4 Watching
  • O
    O
    Omemanti
    wrote on last edited by Omemanti
    I've been troubleshooting for the last couple of days now;
    so far:
    • switches Weemos modules => both crashed
    • switches Ebyte modules => both crashed
    • powered the Ebyte modules separately from the ESP8266 => no luck eighter
    2 things that came up "positive"
    • remove: #define MY_SECURITY_SIMPLE_PASSWD => it ran all night without any errors
    • FTDI + nrf52832 (serial gateway) + #define MY_SECURITY_SIMPLE_PASSWD => ran for the last couple of hours without any incident.
    I don't know if it makes any sense, but when I combine the weemos with a nrf52832 (using Serial Gateway) is get bumps in the road. separate they work like charm.
    • electrikE
      electrikE
      electrik
      @omemanti said in Nrf52 gateway crashes:
      So you powered the Ebyte module with an external regulator?
      Are your power supply and regulator powerful enough?
      O 1 Reply Last reply
      • electrikE electrik
        O
        O
        Omemanti
        @electrik
        It an assumption but I guess so, its an ST-Link V2 as power for the Ebyte module.
        I use it to test my nodes with. So far none broke down.
        The Weemos has its own USB power
        • electrikE
          electrikE
          electrik
          wrote on last edited by electrik
          It is worth to investigate the specs of the regulator of the St link. Did you try adding a capacitor on the power supply?
            O
            O
            Omemanti
            @electrik,
            ill take a look at it, yup, a 100nf and 100uf next to the nrf52832. One setup had a 470uf for good measure..
            • O
              O
              Omemanti
              tonight, I let a node send data to the gateway, this one hangs after a couple of hours, but this time, I also hooked up an FTDI to the node, to have some readout as well from it.
              It also broke down at the same stage like all the others did:
              45381108 TSF:MSG:SEND,215-215-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:13.3
              45381165 NRF5:SND:TO=0,LEN=32,PID=1,NOACK=0
              Why would it always hang on that this same line?
              -- while operation, the node stays at a solid 3,0 V during all operations.
              • O
                O
                Omemanti
                A month ago, I changed my sketch.
                I replaced "MY_SECURITY_SIMPLE_PASSWD" to "MY_ENCRYPTION_SIMPLE_PASSWD" because this was most important to me. Nothing bad happened, I received everything in perfect order.
                for the sake of testing, I switched back to "MY_SECURITY_SIMPLE_PASSWD" a couple of days ago, Guess what is happening since that time.
                So there are to options to consider, or the implementation of MY_SECURITY_SIMPLE_PASSWD has a bug, or the Simple Signing is messing with my gateway.
                AnticimexA 1 Reply Last reply
                • O Omemanti
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @omemanti it is not clear from your message what actually happened. Did something stop working?
                  Remember that you need to share the "simple" flag setting across all nodes in the network for it to work properly. You cannot have the password option on one node and the security option on another.
                  • AnticimexA Anticimex
                    O
                    O
                    Omemanti
                    @anticimex said in Nrf52 gateway crashes:
                    like posted a month ago; it "sometimes" stops working at the following line:
                    0;255;3;0;9;759816 TSF:MSG:READ,215-215-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                    0;255;3;0;9;759818 NRF5:SND:TO=215,LEN=32,PID=2,NOACK=0
                    All nodes in the network are sending in data every 5 to 10 minutes (depending on the node) it all runs smoothly up until the line like above comes around. So all nodes send data and are using the same password etc.
                    All went oke when I changed to only encryption, when I went back to security it starts breaking again.
                    Average time form rebooting the gateway up until crashing averages from 30 minutes up until 15 hours. (yesterday I rebooted the gateway at 8:00 and it stopped working at 23:30)
                    • O Omemanti
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @omemanti ok. I am not sure if there is anything specific in the nrf52 port but I think that the signing code is pretty much the same across all ports for software signing. Perhaps @d00616 has a clue?
                        O
                        O
                        Omemanti
                        I posted a Log of the gateway from boot (around 2 hours ago) to last crash.
                        https://github.com/Omemanti/Paste/blob/master/Gateway_log_01-01-2019_security.txt
                        everything seems normal (to me) except de crash in the end.
                        • O
                          O
                          Omemanti
                          FYI:
                          Yesterday I tried to use the MY_ENCRYPTION_SIMPLE_PASSWD and SIGNING (so not MY_SECURITY, everything separate), the gateway also crashes after a couple of hours.
                          So reverted all my sketches and now only have MY_ENCRYPTION_SIMPLE_PASSWD on all my nodes. Since that time I've been receiving everything and had no crashes.
                          • alowhumA
                            alowhumA
                            alowhum
                            I'm in the same situation, but with an Arduino Nano.
                            Did you ever get MY_SECURITY_SIMPLE_PASSWD to work ok in the end?
                            When I tried MY_ENCRYPTION_SIMPLE_PASSWD instead it worked straight away, so now I'm moving my network to that first. But I'd like to have optimal security if possible.
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              Please remember that the simple security flags use software implementation for signing (encryption as well unless the radio has native support), so they claim more resources. This is noticible on resource limited devices such as the atmega328p.
                              Nowadays, running both software encryption and softare signing on atmega328p at the same time is almost doomed to fail due to the heap and stack colliding.
                              alowhumA 1 Reply Last reply
                                alowhumA
                                alowhumA
                                alowhum
                                @anticimex I've become quite good at saving memory precisely because I anticipated that I wanted to enable full security. Are you saying that's a fools errand?
                                I was hoping that future versions of the security functionality might save some memory too?
                                • alowhumA alowhum
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @alowhum security v3 will most likely not be less resource intensive. The aim there is to make it more secure and less complicated to use.
                                  However, I am currently in a stage in life where I simply do not have the time to actively work on that so someone else have to look into it, details for the plans are on github, or it has to wait for now.
                                  There is still the option to use hw accelerated signing so atmega328p users at least in theory can still use it. And if you do manage to squeeze out enough ram to avoid the arduino environment to warn about it you should be fine.
                                  If the environment do give warnings on memory usage, it might still work, but that is less guaranteed and light very well lead to crashes.
                                  • alowhumA
                                    alowhumA
                                    alowhum
                                    Interesting, I didn't know there was hardware acceleration in the Arduino for encryption type things.
                                    I've built all my nodes to leave about 20% memory for security, as you said. I believe 20% should be quite doable for most uses, as some of my most outrageous nodes still have enough available. I've come to love progmem, use byte instead of int, etc. For me the Arduino Nano is still the most beginner friendly device out there, bar perhaps the Micro:bit (NRf51), and I believe there's still some life left in her.
                                    Talking about which: glad to hear usability is a focus for the next version, and I'm sorry to hear you won't have much time to work on it. I totally get it though. Life always has priority :-)
                                    • alowhumA alowhum
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @alowhum I never said there was hw acceleration in atmega328p for encryption. There is hw acceleration for signing with atsha204a. And some radios have hw acceleration for encryption such as rfm69.
                                      I don't recall that I have stated 20% ram for security either. I do not have a % for security at all. But I do recommend you follow the build environments warnings on memory usage where it states stability problems might occur.
                                        alowhumA
                                        alowhumA
                                        alowhum
                                        @anticimex The Arduino IDE always gives a warning at 80%? Or is that actually variable?
                                        I was wondering why I had never heard of hardware acceleration on the nano ;-)
                                        • alowhumA alowhum
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #27
                                          @alowhum the arduino IDE is not very clever and I believe the 20% left when it starts to warn is the % of ram available for the stack. So depending on your sketch, and the libraries you use, the functions you call and the order they are called has an impact in how much stack is claimed and if the stack needs more than what is left of the ram, bad and strange things start to happen.
                                          The 20% is just a PUMA (PUlled out of My Ass) number the arduino folks came up with for what the think is a reasonable stack usage for an average user. And so, if they see that you use more ram after linking your sketch, they think you should be warned that you might get into trouble.
