  3. Nrf52 gateway crashes
30 Posts 5 Posters 5.9k Views 4 Watching
  • O Offline
    O Offline
    Omemanti
    wrote on last edited by Omemanti
    Hey There,
    Something annoying is happening;
    My setup:
    a nrf52832+ ESP8266 as a gateway.
    Several nodes, all have a nrf52832. most run the same sketch, everything is fine with those.
    However, there is one node that is throwing a curveball once in a while. I need to cut the power off the gateway to reset. (the nrf needs to get powered down I assume)
    I've been working on it for a couple of days now but haven't found the answer yet, maybe some of you will.
    The last2 lines of the 4 instances the gateway crashes;
    0;255;3;0;22;2665656
    0;255;3;0;9;2674632 TSF:MSG:READ,114-114-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
    216;0;1;0;1;67.6
    0;255;3;0;9;10584601 TSF:MSG:READ,114-114-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
    216;0;1;0;1;67.0
    0;255;3;0;9;2311492 TSF:MSG:READ,114-114-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
    216;0;1;0;1;59.4
    0;255;3;0;9;11077691 TSF:MSG:READ,114-114-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
    Its node 114 that always does this, but sometimes all goes well. I have some good readings from it, so it seems that not every entry makes my gateway crash.
    the sketch for this node is similar to: https://www.mysensors.org/build/temp and im using: MY_SECURITY_SIMPLE_PASSWD since a couple of weeks.
    Can anyone tell me why this is happing?
    • electrikE Offline
      electrikE Offline
      electrik
      Perhaps it is related to the ESP. Do you have the possibility to exchange and test it with another module?
      O 1 Reply Last reply
      • electrikE electrik
        O Offline
        O Offline
        Omemanti
        @electrik yup, switche the esp. I use esplink, and when the gateway crashes I can still reach the web-interface. So my guess is that the nrf is the problem, it somehow crashes or refuses to send/read data through the RX/TX.
        It just crashed again: same node..
        • O Omemanti
          @omemanti adding
          #define 	MY_DEBUG_VERBOSE_RF24
          to the gateway might give some insight inte what is happening.
            @omemanti adding
            O Offline
            O Offline
            Omemanti
            @mfalkvidd
            Does this give me more information compared to the normal #MY_DEBUG? Skip that, had to change things in MyConig.. lets see what happens
            to be complete; I used: #define MY_DEBUG_VERBOSE_NRF5_ESB
            • O Offline
              O Offline
              Omemanti
              i got 3 crashes, every one of them happened within the 20 minutes:
              all ended like:
              0;255;3;0;9;759816 TSF:MSG:READ,215-215-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
              0;255;3;0;9;759818 NRF5:SND:TO=215,LEN=32,PID=2,NOACK=0
              the strange part, its now node 215 instead of 114, both are located in a room somewhat distance from the gateway
              average communication looks like:
              0;255;3;0;9;750507 NRF5:RX:LEN=32,NOACK=0,PID=0,RSSI=-34,RX=0
              0;255;3;0;9;750508 TSF:MSG:READ,216-216-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
              0;255;3;0;9;750510 NRF5:SND:TO=216,LEN=32,PID=1,NOACK=0
              0;255;3;0;9;750514 NRF5:SND:END=1,ACK=1,RTRY=1,RSSI=-35,WAKE=5
              0;255;3;0;9;750515 TSF:MSG:SEND,0-0-216-216,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
              0;255;3;0;9;750535 NRF5:RX:LEN=32,NOACK=0,PID=1,RSSI=-34,RX=0
              0;255;3;0;9;750537 TSF:MSG:READ,216-216-0,s=0,c=1,t=1,pt=7,l=5,sg=1:60.9
              • O Offline
                O Offline
                Omemanti
                every time it crashes, it at this line:
                0;255;3;0;9;1268917 NRF5:SND:TO=216,LEN=32,PID=0,NOACK=0
                The "good" part, it happens to all nodes.
                Could it have something to do with power? because the next line should be also an "SND"
                Or can it be an encryption thing, that it happens before the SND part?
                • O Offline
                  O Offline
                  Omemanti
                  I've been troubleshooting for the last couple of days now;
                  so far:
                  • switches Weemos modules => both crashed
                  • switches Ebyte modules => both crashed
                  • powered the Ebyte modules separately from the ESP8266 => no luck eighter
                  2 things that came up "positive"
                  • remove: #define MY_SECURITY_SIMPLE_PASSWD => it ran all night without any errors
                  • FTDI + nrf52832 (serial gateway) + #define MY_SECURITY_SIMPLE_PASSWD => ran for the last couple of hours without any incident.
                  I don't know if it makes any sense, but when I combine the weemos with a nrf52832 (using Serial Gateway) is get bumps in the road. separate they work like charm.
                  • electrikE Offline
                    electrikE Offline
                    electrik
                    @omemanti said in Nrf52 gateway crashes:
                    So you powered the Ebyte module with an external regulator?
                    Are your power supply and regulator powerful enough?
                      O Offline
                      O Offline
                      Omemanti
                      @electrik
                      It an assumption but I guess so, its an ST-Link V2 as power for the Ebyte module.
                      I use it to test my nodes with. So far none broke down.
                      The Weemos has its own USB power
                      • electrikE Offline
                        electrikE Offline
                        electrik
                        wrote on last edited by electrik
                        It is worth to investigate the specs of the regulator of the St link. Did you try adding a capacitor on the power supply?
                          O Offline
                          O Offline
                          Omemanti
                          @electrik,
                          ill take a look at it, yup, a 100nf and 100uf next to the nrf52832. One setup had a 470uf for good measure..
                          • O Offline
                            O Offline
                            Omemanti
                            tonight, I let a node send data to the gateway, this one hangs after a couple of hours, but this time, I also hooked up an FTDI to the node, to have some readout as well from it.
                            It also broke down at the same stage like all the others did:
                            45381108 TSF:MSG:SEND,215-215-0-0,s=1,c=1,t=0,pt=7,l=5,sg=1,ft=0,st=OK:13.3
                            45381165 NRF5:SND:TO=0,LEN=32,PID=1,NOACK=0
                            Why would it always hang on that this same line?
                            -- while operation, the node stays at a solid 3,0 V during all operations.
                            • O Offline
                              O Offline
                              Omemanti
                              A month ago, I changed my sketch.
                              I replaced "MY_SECURITY_SIMPLE_PASSWD" to "MY_ENCRYPTION_SIMPLE_PASSWD" because this was most important to me. Nothing bad happened, I received everything in perfect order.
                              for the sake of testing, I switched back to "MY_SECURITY_SIMPLE_PASSWD" a couple of days ago, Guess what is happening since that time.
                              So there are to options to consider, or the implementation of MY_SECURITY_SIMPLE_PASSWD has a bug, or the Simple Signing is messing with my gateway.
                              A 1 Reply Last reply
                              • O Omemanti
                                A Offline
                                A Offline
                                Anticimex
                                @omemanti it is not clear from your message what actually happened. Did something stop working?
                                Remember that you need to share the "simple" flag setting across all nodes in the network for it to work properly. You cannot have the password option on one node and the security option on another.
                                • A Anticimex
                                  O Offline
                                  O Offline
                                  Omemanti
                                  @anticimex said in Nrf52 gateway crashes:
                                  like posted a month ago; it "sometimes" stops working at the following line:
                                  All nodes in the network are sending in data every 5 to 10 minutes (depending on the node) it all runs smoothly up until the line like above comes around. So all nodes send data and are using the same password etc.
                                  All went oke when I changed to only encryption, when I went back to security it starts breaking again.
                                  Average time form rebooting the gateway up until crashing averages from 30 minutes up until 15 hours. (yesterday I rebooted the gateway at 8:00 and it stopped working at 23:30)
                                  • O Omemanti
                                    A Offline
                                    A Offline
                                    Anticimex
                                    @omemanti ok. I am not sure if there is anything specific in the nrf52 port but I think that the signing code is pretty much the same across all ports for software signing. Perhaps @d00616 has a clue?
                                    • A Anticimex
                                      O Offline
                                      O Offline
                                      Omemanti
                                      I posted a Log of the gateway from boot (around 2 hours ago) to last crash.
                                      https://github.com/Omemanti/Paste/blob/master/Gateway_log_01-01-2019_security.txt
                                      everything seems normal (to me) except de crash in the end.
                                      • O Offline
                                        O Offline
                                        Omemanti
                                        FYI:
                                        Yesterday I tried to use the MY_ENCRYPTION_SIMPLE_PASSWD and SIGNING (so not MY_SECURITY, everything separate), the gateway also crashes after a couple of hours.
                                        So reverted all my sketches and now only have MY_ENCRYPTION_SIMPLE_PASSWD on all my nodes. Since that time I've been receiving everything and had no crashes.
                                        • alowhumA Offline
                                          alowhumA Offline
                                          alowhum
                                          I'm in the same situation, but with an Arduino Nano.
                                          Did you ever get MY_SECURITY_SIMPLE_PASSWD to work ok in the end?
                                          When I tried MY_ENCRYPTION_SIMPLE_PASSWD instead it worked straight away, so now I'm moving my network to that first. But I'd like to have optimal security if possible.
