  3. [SOLVED] Raspberry Pi serial gateway NRF24 - !TSM:INIT:TSP FAIL
20 Posts 7 Posters 4.8k Views 6 Watching
  • xandaX
    xandaX
    xanda
    Hi, can somebody help me resolve !TSM:INIT:TSP FAIL? I proceeded according to https://www.mysensors.org/build/raspberry but I get error and not sure where is the problem:
    ./configure --my-transport=rf24 --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
    sudo ./bin/mysgw
    Dec 31 11:07:50 INFO  Starting gateway...
    Dec 31 11:07:50 INFO  Protocol version - 2.3.1
    Dec 31 11:07:50 DEBUG Serial port /dev/ttyMySensorsGateway (115200 baud) created
    Dec 31 11:07:50 DEBUG MCO:BGN:INIT GW,CP=RNNGL-Q-,REL=255,VER=2.3.1
    Dec 31 11:07:50 DEBUG TSF:LRT:OK
    Dec 31 11:07:50 DEBUG TSM:INIT
    Dec 31 11:07:50 DEBUG TSF:WUR:MS=0
    Dec 31 11:07:50 DEBUG !TSM:INIT:TSP FAIL
    Dec 31 11:07:50 DEBUG TSM:FAIL:CNT=1
    Dec 31 11:07:50 DEBUG TSM:FAIL:DIS
    Dec 31 11:07:50 DEBUG TSF:TDI:TSL
    Double checked wiring of NRF24L01+ with 100uf capacitor, NRF24L01+ works OK on my arduino.
    RPi 3 B, Debian 9.3 Stretch
    • xandaX xanda
      sudo ./bin/mysgw
      @xanda could you post photos of the wiring? Maybe we can spot something.
      xandaX 2 Replies Last reply
      • V
        V
        vidin
        Hello, try --my-transport=nrf24
          xandaX
          xandaX
          xanda
          wrote on last edited by xanda
          @mfalkvidd 0_1546330440084_IMG_20190101_084305.jpg 0_1546331110995_IMG_20190101_084343.jpg
            xandaX
            xandaX
            xanda
            @vidin --my-transport=nrf24 returns [ERROR] Invalid transport type.
              I am not sure if the 3.3v output from raspberry is enough to power the nrf24
                @gohan it works for me
                @xanda wiring looks good to me.
                  Did it work before on an Arduino board? If you haven't tried and you paid it very cheap it could also be a fake chinese clone that is either bad or not a really nrf24 chip
                  xandaX 1 Reply Last reply
                    xandaX
                    xandaX
                    xanda
                    @gohan Yes it worked on Arduino board and about a year ago it even worked on Raspberry. So I thought its software issue.
                    • kebibgK
                      kebibgK
                      kebibg
                      wrote on last edited by kebibg
                      Ok man, where is connection to NFR24l01????
                      From picture i see you are use SPI but never see where is configure it ?
                      1st. check are you have a spidev0.0 or another. then config need to be like this:
                      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=rf24 --my-rf24-ce-pin=XX --my-rf24-cs-pin=YY
                      need to change XX and YY with your connection to the Pi.
                      You use SPI for connection but configure gateway as a serial input.
                      With this configuration never work. If you make external plate (arduino with NRF24l02) and connect it to serial port of
                      Pi will work but serial need to be one of real TTys.
                      Regards
                      • MGHaffM
                        MGHaffM
                        MGHaff
                        wrote on last edited by MGHaff
                        This is what i use to configure my raspberry pi3 to work vi serial.
                        --my-transport=rf24 --my-rf24-pa-level=RF24_PA_LOW --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                        Built using this page. https://www.mysensors.org/build/raspberry
                        And when recieving this error "Dec 31 11:07:50 DEBUG !TSM:INIT:TSP FAIL" I had found a bad jumper that I had used. Hope This helps!
                        • B
                          B
                          badisensors
                          wrote on last edited by badisensors
                          As kebibg said you must also configure the pins for CE and CS. The configure i used was :
                          --my-transport=rf24 --my-rf24-pa-level=RF24_PA_LOW --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB020 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                          Also you must connect MISO to pin 21, Mosi to pin 19 and CLK to pin 23 on raspberry
                          MGHaffM 1 Reply Last reply
                          • B badisensors
                            MGHaffM
                            MGHaffM
                            MGHaff
                            @badisensors said in Raspberry Pi serial gateway NRF24 - !TSM:INIT:TSP FAIL:
                            The only pin's I needed to specify on my setup was IRQ and leds. The GW has been working great for 2+ years on my raspberry pie 3b with nrf24+.
                            Why did I Not have to specify them in my setup? did something change? I am running version 2.3.1.
                            • B
                              B
                              badisensors
                              2 years ago were you using version 2.3.1 ?
                              • B badisensors
                                MGHaffM
                                MGHaffM
                                MGHaff
                                @badisensors 2.0.0 not really 2 years ago more like 1 1/2. Why do you ask?
                                • B
                                  B
                                  badisensors
                                  Because in 1.5-2 years many things are changing. Did you try my config?
                                  • B badisensors
                                    MGHaffM
                                    MGHaffM
                                    MGHaff
                                    @badisensors I did try your config and it works just as mine does. Just wondering if the adding this --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 to the config was necessary. But from the my test it is not. Thanks.
                                    • B
                                      B
                                      badisensors
                                      If we use pin 22 for CE and pin 24 for CS it is not necessery to declare as you said. But if we want to use other pins we need to declare. I havent try though with other pins.
                                      • xandaX
                                        xandaX
                                        xanda
                                        I changed cables, get new NRF24L01+ PA/LNA and make clean install of rasbian. Nothing helped, but then out of nothing it started to work (at least no fail). Its a mystery to me why. Thank you all for help.
                                        pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw
                                        Jan 12 10:05:42 INFO  Starting gateway...
                                        Jan 12 10:05:42 INFO  Protocol version - 2.3.1
                                        Jan 12 10:05:42 DEBUG Serial port /dev/ttyUSB020 (115200 baud) created
                                        Jan 12 10:05:42 DEBUG MCO:BGN:INIT GW,CP=RNNGL-Q-,REL=255,VER=2.3.1
                                        Jan 12 10:05:42 DEBUG TSF:LRT:OK
                                        Jan 12 10:05:42 DEBUG TSM:INIT
                                        Jan 12 10:05:42 DEBUG TSF:WUR:MS=0
                                        Jan 12 10:05:42 DEBUG !TSM:INIT:TSP FAIL
                                        Jan 12 10:05:42 DEBUG TSM:FAIL:CNT=1
                                        Jan 12 10:05:42 DEBUG TSM:FAIL:DIS
                                        Jan 12 10:05:42 DEBUG TSF:TDI:TSL
                                        Jan 12 10:05:52 DEBUG TSM:FAIL:RE-INIT
                                        Jan 12 10:05:52 DEBUG TSM:INIT
                                        Jan 12 10:05:52 DEBUG !TSM:INIT:TSP FAIL
                                        Jan 12 10:05:52 DEBUG TSM:FAIL:CNT=2
                                        Jan 12 10:05:52 DEBUG TSM:FAIL:DIS
                                        Jan 12 10:05:52 DEBUG TSF:TDI:TSL
                                        ^CJan 12 10:05:53 NOTICE Received SIGINT
                                        Jan 12 10:14:30 INFO  Starting gateway...
                                        Jan 12 10:14:30 INFO  Protocol version - 2.3.1
                                        Jan 12 10:14:30 DEBUG Serial port /dev/ttyUSB020 (115200 baud) created
                                        Jan 12 10:14:30 DEBUG MCO:BGN:INIT GW,CP=RNNGL-Q-,REL=255,VER=2.3.1
                                        Jan 12 10:14:30 DEBUG TSF:LRT:OK
                                        Jan 12 10:14:30 DEBUG TSM:INIT
                                        Jan 12 10:14:30 DEBUG TSF:WUR:MS=0
                                        Jan 12 10:14:30 DEBUG TSM:INIT:TSP OK
                                        Jan 12 10:14:30 DEBUG TSM:INIT:GW MODE
                                        Jan 12 10:14:30 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                        Jan 12 10:14:30 DEBUG MCO:REG:NOT NEEDED
                                        Jan 12 10:14:30 DEBUG MCO:BGN:STP
                                        Jan 12 10:14:30 DEBUG MCO:BGN:INIT OK,TSP=1
                                        Jan 12 10:14:30 DEBUG TSM:READY:NWD REQ
                                        Jan 12 10:14:30 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:```
                                          dodgy cable/pin maybe?
