  3. [SOLVED] Raspberry Pi serial gateway NRF24 - !TSM:INIT:TSP FAIL
20 Posts 7 Posters 4.9k Views 6 Watching
  • MGHaffM
    MGHaffM
    MGHaff
    wrote on last edited by MGHaff
    This is what i use to configure my raspberry pi3 to work vi serial.
    --my-transport=rf24 --my-rf24-pa-level=RF24_PA_LOW --my-rf24-irq-pin=15 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
    Built using this page. https://www.mysensors.org/build/raspberry
    And when recieving this error "Dec 31 11:07:50 DEBUG !TSM:INIT:TSP FAIL" I had found a bad jumper that I had used. Hope This helps!
    • B
      B
      badisensors
      wrote on last edited by badisensors
      As kebibg said you must also configure the pins for CE and CS. The configure i used was :
      --my-transport=rf24 --my-rf24-pa-level=RF24_PA_LOW --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB020 --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 --my-rf24-irq-pin=15 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
      Also you must connect MISO to pin 21, Mosi to pin 19 and CLK to pin 23 on raspberry
      MGHaffM 1 Reply Last reply
      • B badisensors
        MGHaffM
        MGHaffM
        MGHaff
        @badisensors said in Raspberry Pi serial gateway NRF24 - !TSM:INIT:TSP FAIL:
        The only pin's I needed to specify on my setup was IRQ and leds. The GW has been working great for 2+ years on my raspberry pie 3b with nrf24+.
        Why did I Not have to specify them in my setup? did something change? I am running version 2.3.1.
        • B
          B
          badisensors
          2 years ago were you using version 2.3.1 ?
          • B badisensors
            MGHaffM
            MGHaffM
            MGHaff
            @badisensors 2.0.0 not really 2 years ago more like 1 1/2. Why do you ask?
            • B
              B
              badisensors
              Because in 1.5-2 years many things are changing. Did you try my config?
              • B badisensors
                MGHaffM
                MGHaffM
                MGHaff
                @badisensors I did try your config and it works just as mine does. Just wondering if the adding this --my-rf24-ce-pin=22 --my-rf24-cs-pin=24 to the config was necessary. But from the my test it is not. Thanks.
                • B
                  B
                  badisensors
                  If we use pin 22 for CE and pin 24 for CS it is not necessery to declare as you said. But if we want to use other pins we need to declare. I havent try though with other pins.
                  • xandaX
                    xandaX
                    xanda
                    I changed cables, get new NRF24L01+ PA/LNA and make clean install of rasbian. Nothing helped, but then out of nothing it started to work (at least no fail). Its a mystery to me why. Thank you all for help.
                    pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw
                    Jan 12 10:05:42 INFO  Starting gateway...
                    Jan 12 10:05:42 INFO  Protocol version - 2.3.1
                    Jan 12 10:05:42 DEBUG Serial port /dev/ttyUSB020 (115200 baud) created
                    Jan 12 10:05:42 DEBUG MCO:BGN:INIT GW,CP=RNNGL-Q-,REL=255,VER=2.3.1
                    Jan 12 10:05:42 DEBUG TSF:LRT:OK
                    Jan 12 10:05:42 DEBUG TSM:INIT
                    Jan 12 10:05:42 DEBUG TSF:WUR:MS=0
                    Jan 12 10:05:42 DEBUG !TSM:INIT:TSP FAIL
                    Jan 12 10:05:42 DEBUG TSM:FAIL:CNT=1
                    Jan 12 10:05:42 DEBUG TSM:FAIL:DIS
                    Jan 12 10:05:42 DEBUG TSF:TDI:TSL
                    Jan 12 10:05:52 DEBUG TSM:FAIL:RE-INIT
                    Jan 12 10:05:52 DEBUG TSM:INIT
                    Jan 12 10:05:52 DEBUG !TSM:INIT:TSP FAIL
                    Jan 12 10:05:52 DEBUG TSM:FAIL:CNT=2
                    Jan 12 10:05:52 DEBUG TSM:FAIL:DIS
                    Jan 12 10:05:52 DEBUG TSF:TDI:TSL
                    ^CJan 12 10:05:53 NOTICE Received SIGINT
                    Jan 12 10:14:30 INFO  Starting gateway...
                    Jan 12 10:14:30 INFO  Protocol version - 2.3.1
                    Jan 12 10:14:30 DEBUG Serial port /dev/ttyUSB020 (115200 baud) created
                    Jan 12 10:14:30 DEBUG MCO:BGN:INIT GW,CP=RNNGL-Q-,REL=255,VER=2.3.1
                    Jan 12 10:14:30 DEBUG TSF:LRT:OK
                    Jan 12 10:14:30 DEBUG TSM:INIT
                    Jan 12 10:14:30 DEBUG TSF:WUR:MS=0
                    Jan 12 10:14:30 DEBUG TSM:INIT:TSP OK
                    Jan 12 10:14:30 DEBUG TSM:INIT:GW MODE
                    Jan 12 10:14:30 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                    Jan 12 10:14:30 DEBUG MCO:REG:NOT NEEDED
                    Jan 12 10:14:30 DEBUG MCO:BGN:STP
                    Jan 12 10:14:30 DEBUG MCO:BGN:INIT OK,TSP=1
                    Jan 12 10:14:30 DEBUG TSM:READY:NWD REQ
                    Jan 12 10:14:30 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:```
                      dodgy cable/pin maybe?
