  3. Own action on heatbeat request
7 Posts 4 Posters 1.9k Views 4 Watching
  • wimdW
    wimdW
    wimd
    I would like to capture the heartbeat request send by a controller (in my case Domoticz).
    However this does not work within the receive funtction.
    What did I overlook?
        if (message.type == I_HEARTBEAT_REQUEST) {
          Serial.println("heartbeat request");
    • rejoe2R
      rejoe2R
      rejoe2
      Afaik, heartbeat (and other internal messages) are designed for "internal" use, so the automatics behind that is - without further changes in the internal coding - not meant to be used by "regular" receive function.
      Why don't you just use other data types like S_CUSTOM to get the same result?
      • K
        K
        kimot
        @wimd said in Own action on heatbeat request:
        I_HEARTBEAT_REQUEST
        It looks is done automatically:
        MySensorsCore.cpp
        bool _processInternalMessages(void)
        		} else if (type == I_HEARTBEAT_REQUEST) {
        			(void)sendHeartbeat();
        		} else if (type == I_TIME) {
        			// Deliver time to callback
        			if (receiveTime) {
        				receiveTime(_msg.getULong());
        • wimdW
          wimdW
          wimd
          wrote on last edited by wimd
          All works fine.
          I can update Text sensor or send a switch command.
          But when it comes to the heartbeat request there is no response form the gateway.
          I
          rejoe2R 1 Reply Last reply
          • wimdW wimd
            All works fine.
            I
            rejoe2R
            rejoe2R
            rejoe2
            @wimd In case you are looking for an option to check if the GW is available: There somewhere is an option to check, if uplink is available. Don't have a link by hand, but search for that, there's somewhere at least one sketch in the forum offering that (light-switch afai remember).
            wimdW 1 Reply Last reply
            • rejoe2R rejoe2
              wimdW
              wimdW
              wimd
              I have now a heartbeat response form the gateway.
              For my test stetup I did not define any transport layer and this is probably the reason why the gateway did not respond to the heatbeatrequest from domoticz.
              • N
                N
                nekitoss
                wrote on last edited by nekitoss
                @wimd Could you share how you done that?
                I also want to check if gate is alive (backup-batterypowered node - if mains or gateway died, send me a message).
                I also use domoticz.
