  3. Another possible board - ATMega328, nRF socket, DHT22 socket, MOSFET, Uno pinout
board
39 Posts 17 Posters 24.2k Views 5 Watching
    @Mrlynx Didn't know the esp8266 was such a power hog. I'm still going to go for Linear LTC3525-3.3 initially though.
    The xc6210 looks promising though! What's the catch here?
    Not sure about the part designation but it seems to be pretty cheap on AliExpress. In 50 or 100 pcs though ...
    axillentA
    axillentA
    axillent
    I'm using for a long time xc206, it s one of the best to power NRF24
    xc6210 should be also good. Any good proposals on pricing?
    xc6206 i was purchased $5 per 100pcs
    for esp it can be also reasonable to use DC-DC, it will be much more efficient
    for example NCP1529 if you need 5V -> 3.3V conversion (1.7A)
    or MP2359 if you need to convert any up to 24V (1.2A)
    both requires just a few components and a very small SOT23 package
    MP2359 costs about $20 per 100pcs and can be used widely
    i use them for example to light up and dim strip leds
    sense and drive
    • AWIA AWI
      @obstler42 Got mine also upload-75883dcf-6004-4676-8600-82332f72b86b
      Beautiful boards! I "assembled" all 4 of them and will transform them into Sensors this weekend. At this moment I am powering the boards as shown. Measurement: 4 mA active, < 15uA when in MySensors "Sleep" mode.... nothing removed.. So I don't see any need for replacing/ removing the LDO..
      Looks like a very good candidate for future expansion..
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @AWI Do you have an enclosure in mind?
      RJ_Make
      AWIA 1 Reply Last reply
      • RJ_MakeR RJ_Make
        AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        @ServiceXp Not sure yet, probably a cheap ABS box. The enclosure suggested by the seller of this module looks like the perfect fit.. ! with an external antenna. upload-d4a4e674-6be1-4aa8-b637-4aacbe627440
        It can be found on on e-bay (name of the seller in the logo)
        upload-3289262f-8733-4c34-9679-a44dc314904f
        RJ_MakeR 1 Reply Last reply
        • AWIA AWI
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @AWI I guess this would count as reason #18 to purchase a 3D Printer..... Yeah Like I need a reason to buy tech gear...
          RJ_Make
          • axillentA axillent
            therik
            Just to add another option...I've been using the Fremont Micro Devices USA FT531JA. It has higher ripple rejection ratio than either of the above and is ~$20 for 100. Not as cheap as the xc6206, but much, much better ripple rejection. So, just another option that I found, it also has the same pin-out as the xc6210!! So, we can try them both with the same PCB design, cool.
            • C
              C
              ceech
              If interested in another voltage regulator, I can equip a few boards with ADP3338, low dropout and low ground current regulators. Description:
              http://www.analog.com/en/power-management/linear-regulators/adp3338/products/product.html
              Any other wish - let me know.
              hekH AWIA 2 Replies Last reply
              • C ceech
                @ceech
                Are you the creator of the board?
                C 1 Reply Last reply
                  @ceech
                  C
                  C
                  ceech
                  @hek
                  I've made it, yes.
                  • C
                    C
                    ceech
                    This is the enclosure from the pictures:
                    http://www.ebay.com/itm/Aluminum-Project-Box-Enclosure-Case-Electronic-DIY-1111-4-33-2-44-0-98-L-W-H-/300376371464?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item45efd3b108
                    It's a tight fit. Needs a few strokes with the sand paper over the PCB. No need for drilling holes, though.
                    And here is one more option for a voltage regulator:
                    http://www.microchip.com/wwwproducts/Devices.aspx?product=TC2117
                    • AWIA AWI
                      O
                      O
                      obstler42
                      How are you measuring power consumption? Are you powering from ftdi and measuring on the vcc cable? I've found that when TX/RX are connected and power consumption goes down that with some ftdi boards power is supplied through ftdi TX to the board RX, which makes exact measurements difficult. I only ever connect GND and VIN when measuring now.
                      So I'd be really interested in how you can get 15 uA sleep with the stock regulator as I spent a whole day trying everything before desoldering it ;)
                      • O obstler42
                        AWIA
                        AWIA
                        AWI
                        @obstler42 Oops... . Just tried again and found out that my uA meter was on "autorange". Only a factor 1000 off... I'm sorry for that, how can I compensate. for this stupid mistake..
                        • O
                          O
                          obstler42
                          I've made so many mistakes myself trying to optimize for lowest power consumption battery deplyment...
                          BTW: another gotcha: don't leave the NRF24 on the board when connecting to a 5V FTDI... the FTDI connector voltage pin does NOT go through the voltage regulator but straight to VCC -- which means you'll be roasting the NRF24 with 5 V...
                          • C ceech
                            AWIA
                            AWIA
                            AWI
                            @ceech Since you are the creator of this board. I am interested in how you use it. Especially how to operate this board on battery power and the power consumption..
                            C 2 Replies Last reply
                            • AWIA AWI
                              C
                              C
                              ceech
                              @AWI
                              I normally use a 12V car battery, for monitoring different values in the car. When the board is used in single cell battery applications, I go with a different type of voltage regulator. Normally I use TC2117 3.3V voltage regulator. Unfortunately those regulators are not available for purchase either form Farnell nor Microchip at the moment. They will be available on the 9th of March. So a bit of a set back. As for the enclosure, I use this:
                              And a little 5V solar cell, when appropriate:
                              there is also a matter of battery charging, which I leave to this fellow:
                              http://www.ebay.com/itm/221533778016?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                              I'm also preparing a new board, with integrated battery charger for LiPo, LiIon batteries and some other cool features.
                              • AWIA AWI
                                C
                                C
                                ceech
                                wrote on last edited by ceech
                                #30
                                @AWI Here is a graphical explanation of the socket connections:
                                SDA and SCL lines also have pull-up resistors. They are 10k.
                                • C ceech
                                  AWIA
                                  AWIA
                                  AWI
                                  @ceech Thanks!!
                                  • R
                                    R
                                    rachmat aditiya27
                                    how to upload custom bootloader?maybe you should put additional icsp port
                                    • R rachmat aditiya27
                                      C
                                      C
                                      ceech
                                      #33
                                      @rachmat-aditiya27 The board is kind of hardware oriented, so I ran out of space for the ICSP header. All the needed pins are available though. Either from remaining pins of the NRF24 socket, either from digital 11, 12 and 13 header pins.
                                      • R
                                        R
                                        rachmat aditiya27
                                        oh, okay got it :)
                                        • R
                                          R
                                          Raoul Hecky
                                          I just got 2 boards and I'em trying to test them. For now I only plugged a usb/serial adapter with an ftdi to the JP3 connector to program the board. The program is simple as Serial.begin(9600); Serial.println("test");
                                          But that's not working. The programming was done successfully, and when I open the Serial monitor in the arduino ide, all I got is garbage characters. I have setup the correct communication option in the ide of course. The power VCC comes from my USB and I tried with 3.3v or 5v, but it did not change anything.
                                          When I do the with a standard arduino mini pro, it works correctly, but not with the @ceech boards...
                                          Any idea why and whats wrong here?
                                          thanks
                                          AWIA C 2 Replies Last reply
