  3. πŸ’¬ EFEKTA Temperature & Humidity mini sensor
temperatureatmega328batteryhumidityatmega 328p-mu
42 Posts 10 Posters 11.0k Views 9 Watching
  • YveauxY Yveaux
    @berkseo what's the function of the 2 buttons?
    berkseoB
    berkseoB
    berkseo
    #23
    @yveaux
    One button is reset, the second button is multifunctional. Depends on how many seconds you hold this button. In my program, I use this button to connect via air to other devices and to transfer the device to receive settings (data transmission intervals, led operation and so on). This button is not used in my test sketch
    An example of direct connection between devices (without the use of controllers, without changing the SOFTWARE) is my development, which is in the testing stage is the controller of Underfloor heating. This device controls the five contours of the Underfloor heating. Up to 10 such temperature sensors can be connected to this device simply by pressing the connect button. Maximum of two temperature sensors per one relay channel.
    https://youtu.be/8mvJFieInsM
    https://youtu.be/kXsxtYVbNAw
    https://youtu.be/NyNFx7sd9ZE
    Examples of direct connections (micro-networks) based on MySensors can be found here:
    https://youtu.be/jFDBeInBZcI
    https://youtu.be/x1oNCO0TXG8
    https://youtu.be/h8Ly_JRFwLg
    • berkseoB
      berkseoB
      berkseo
      https://youtu.be/puOXej1odeU
      • jeremushkaJ
        jeremushkaJ
        jeremushka
        Is it possible for you to share the sketch as it has been removed from the project presentation because of the rules of the website?
        berkseoB 1 Reply Last reply
        • jeremushkaJ jeremushka
          berkseoB
          berkseoB
          berkseo
          @jeremushka said in πŸ’¬ EFEKTA Temperature & Humidity mini sensor:
          https://www.openhardware.io/view/589#tabs-source
          jeremushkaJ 1 Reply Last reply
          • berkseoB
            berkseoB
            berkseo
            Finished the enclosure for the sensor on the battery 2477 (1000mA) :)
            https://youtu.be/XWu5sogiiQg
            • berkseoB
              berkseoB
              berkseo
              To install the sensor on the wall, I recommend 3M adhesive strips (with easy removal)
              0_1548509884908_art-5-05119-command-17024-poloska-malenkaya-kleykaya-dlya-plakatov-belyy-450-gr-12-sht-v-up-1.jpg
              • berkseoB
                berkseoB
                berkseo
                Some more photos... :)
                • berkseoB berkseo
                  jeremushkaJ
                  jeremushkaJ
                  jeremushka
                  @berkseo said in πŸ’¬ EFEKTA Temperature & Humidity mini sensor:
                  Thank you very much. Great casing, it is very discret. professional design. congratulations :)
                    berkseoB
                    berkseoB
                    berkseo
                    @jeremushka
                    Thanks. This is actually my first experience in designing sensor housings. I've never done 3D modeling before. A month and a half ago I started watching a video on YouTube on modeling in SolidWorks. With printing on a 3D printer is also my first experience.
                    • JoeridemanJ
                      JoeridemanJ
                      Joerideman
                      How did you produce such a nice result? The text and buttons are very detailed.
                      Is it SLA printing?
                      • JoeridemanJ Joerideman
                        Is it SLA printing?
                        berkseoB
                        berkseoB
                        berkseo
                        @joerideman said in πŸ’¬ EFEKTA Temperature & Humidity mini sensor:
                        Is it SLA printing?
                        Yes it is an SLA. One day, watching again another video on YouTube about how people make models of characters on such printers(with high detail), at some point I realized that this technology is very well suited for prototyping cases for miniature devices. It is possible to obtain an almost industrial quality of the final product. ...Then I bought it :) ...And I did.
                        These are attempts to repeat the model on the FDM printer(two different people, on two different printers):
                        1_1548692930506_photo_2019-01-27_19-49-24.jpg 0_1548692930506_photo_2019-01-27_19-19-28.jpg
                        • berkseoB
                          berkseoB
                          berkseo
                          SLA printer:
                          1_1548693091849_photo_2019-01-25_21-27-54.jpg 0_1548693091849_photo_2019-01-25_21-27-54 (2).jpg
                          • berkseoB
                            berkseoB
                            berkseo
                            It turns out a very interesting surface, like a soft-touch
                            • JoeridemanJ
                              JoeridemanJ
                              Joerideman
                              Nice to see the difference.
                              • jeremushkaJ
                                jeremushkaJ
                                jeremushka
                                Do you solder the components on the PCB by yourself and you launch the whole process in factory? Because soldering such kind of chip ATMEGA328_QFN32 is not that easy or need a microscope i think.
                                  berkseoB
                                  berkseoB
                                  berkseo
                                  #38
                                  I myself solder pcb. These small 328s are easier and faster to solder than the large 328s. Because you don’t need to solder each contact. Positioning, fixing, heating with a soldering dryer, elimination of excess solder with the help of a soldering iron.
                                  • berkseoB
                                    berkseoB
                                    berkseo
                                    https://youtu.be/k2tJ3sJiTnc
                                    • jeremushkaJ
                                      jeremushkaJ
                                      jeremushka
                                      Hello Berk,
                                      Do you still have PCB board available for sales for this project or for the upgraded one with NRF5 ?
                                        Hello Berk,
                                        berkseoB
                                        berkseoB
                                        berkseo
                                        #41
                                        Hello Berk,
                                        In about a week, I will post an updated version of this device. The changes will affect the attachment to the case. And it will be available for purchase.
                                        • berkseoB berkseo
                                          Hello Berk,
                                          jeremushkaJ
                                          jeremushkaJ
                                          jeremushka
                                          @berkseo Thank you for your answer :) Good continuation on your nice project.
                                          With your input, this post could be even better πŸ’—
