  3. [SOLVED] ds18b20 vs si7021 loss of granularity in measurement
9 Posts 3 Posters 2.0k Views 3 Watching
  • W
    W
    waspie
    I've got two nodes sitting right next to each other taking measurements every 3-4 minutes and I'm finding the si7021 doesn't present a very fine-grained measurement like the dallas:
    The green line is the dallas sensor and the red line is the si7021. How do I get the si7021 to behave more like the dallas?
    as you can see I'm getting temperatures in steps greater than .5 degrees fahrenheit.
    The si7021 is using @NeverDie round board with this code:
    // SUMMARY: This demo sketch runs on MultiSensor Version 7 board with an I2C Si7021 module to transmit temperature, humidity, and battery voltage to a MySensors gateway using MySensors protocols.
    // Note: because this is a passive node, node ID must be set manually to a unique sensor node ID:
    #define MY_NODE_ID 128  // Passive mode requires static node ID
     * Copyright (C) 2013-2017 Sensnology AB
     * Version 1.0 - tekka
     * Passive node example: This is a passive & independent reporting node
    // This demo sketch uses the LowPowerLab SI7021 library and also some of its sample code:  https://github.com/LowPowerLab/SI7021
    // This demo sketch also draws from the MySensor's example MockMySensors sketch.
    // This demo sketch also draws from some of the code posted by smilvert here: https://forum.mysensors.org/topic/7961/why-do-passive-nodes-need-to-set-their-node-id-manually/14
    #define SHORT_WAIT 50
    #include <SI7021.h>  //from LowPowerLab:  https://github.com/LowPowerLab/SI7021
    SI7021 sensor;
    // Enable debug prints
    // Enable passive mode
    #define MY_PASSIVE_NODE
    //#define MY_RADIO_NRF24
    #define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define CHILD_ID_TEMP 0  //definitions contributed by smilvert (see above credit)
    #define CHILD_ID_HUM 1
    // Initialize general message
    #define ID_S_MULTIMETER        28
    float batteryVoltage=0;
    float temperature=0;
    int humidity=0;
    void blinkityBlink(uint8_t repetitions) {
        wait(20);
        wait(100);
        wait(20);
        if (x<(repetitions-1)) {  //skip waiting at the end of the final repetition
          wait(500);
      blinkityBlink(5);  //signify power-up and start of operations
      sensor.begin();
    	sendSketchInfo("Passive node", "1.0");
      wait(SHORT_WAIT);
      present(CHILD_ID_HUM, S_HUM);
      wait(SHORT_WAIT);
      present(ID_S_MULTIMETER,S_MULTIMETER,"Electric Station");
      wait(SHORT_WAIT);
        // get humidity and temperature in one shot, saves power because sensor takes temperature when doing humidity anyway
        si7021_env data = sensor.getHumidityAndTemperature();
        temperature = data.celsiusHundredths/100;
        // humidity is an integer representing percent
        humidity = data.humidityBasisPoints/100;
        sleep(60000);  //sleep for one minute to recover voltage after temperature and humidity measurements.
        send(msgTemp.set(temperature,2));
        sleep(60000);  //sleep for 60 seconds
        send(msgHum.set(humidity,0));
        batteryVoltage=((float)hwCPUVoltage())/1000.0;  //take voltage measurement after transmission to hopefully measure lowest voltage that occurs.
        send(msg_S_MULTIMETER_V_VOLTAGE.set(batteryVoltage,3));  //send battery voltage with 3 decimal places
    B 1 Reply Last reply
    • W waspie
      SI7021 sensor;
      int humidity=0;
          wait(20);
          wait(100);
          wait(20);
            wait(500);
        sensor.begin();
        wait(SHORT_WAIT);
        wait(SHORT_WAIT);
        wait(SHORT_WAIT);
      B
      B
      boozz
      @waspie said in ds18b20 vs si7021 loss of granularity in measurement:
      In my opinion does the above line not cohere with the statement that the steps are greater than .5 degrees fahrenheit.
      Have you tried using:
      temperature = data.getFahrenheitHundredths/100;
      and what was the result.
      Could it be you've been playing with the examples as provided with the library from LowPowerLab and you accidentally forgot to "turn the heater off"? I'm guessing at the moment, but you could end up with the device being heated up in the range of 70ºC (which is 158 degrees fahrenheit...:grimacing: )
      BR,
      Boozz
      W 1 Reply Last reply
      • B boozz
        BR,
        Boozz
        W
        W
        waspie
        @boozz
        That isn't 100% the exact code. I convert the celcius manually so that temp graphed is farhenheit.
        The first 2-3 nodes i put together I didn't know about the ismetric thing going on and I didn't want to go back and reflash those modules so I just make sure to calculate before sending to the GW. Definitely not a heater issue.
        • W waspie
          @boozz
          @waspie Seems like you're rounding to full degrees in the line
          In the si7021 library the si7021_env type is defined as:
          typedef struct si7021_env {
              int celsiusHundredths;
              int fahrenheitHundredths;
              unsigned int humidityBasisPoints;
          } si7021_env;
          so temperature is an integer in 1/100th increments.
          Try converting this integer to float before dividing, like:
          temperature = float(data.celsiusHundredths)/100.0;
          • YveauxY Yveaux
            } si7021_env;
            W
            W
            waspie
            @yveaux
            thank you, this sounds very promising! I will try it this evening
            • W
              W
              waspie
              @Yveaux this has resolved it, thank you
              • W waspie
                B
                B
                boozz
                @Yveaux
                Good to see it solved for @waspie
                Conversion from int (or byte) to float and vise versa is something that often brings me a headache.
                I literaly spend many hours searching for a good guide in via google, but never really found one.
                Are you maybe aware of a good guide how to properly do the conversions between different types (byte from floats etc. without getting involved in memory hungry libraries).
                BR,
                Boozz
                • B boozz
                  @Yveaux
                  BR,
                  Boozz
                  @boozz this is standard c / c++.
                  Any good book on the topic should explain how it works.
                  Basically it comes down to when you cast from float to integer that the value will be rounded down and that you will loose any decimals.
                  From integer to float will introduce decimals, set to 0.
                  • YveauxY Yveaux
                    B
                    B
                    boozz
                    wrote on last edited by boozz
                    @yveaux
                    Thanks for the hint and explanation. I appreciate that!
                    I always used the search term: "conversion" (English is not my native language). I tried "casting" in combination with "c#" and I was almost immediately directed to my favorit c++ internet source (cplusplus.com)
                    http://www.cplusplus.com/doc/tutorial/typecasting/
                    Many thanks! :+1:
                    Boozz
