  3. Electrodragon NRF Pro Mini Sensor Board
16 Posts 8 Posters 5.2k Views 6 Watching
  • patt896P Offline
    patt896P Offline
    patt896
    I've identified multiple Pro Mini NRF24l01 PCB Sensor Boards
    http://dutch-arduino-tinkering.blogspot.com/2014/01/arduino-pro-mini-33v-wireless-nrf24l01.html
    https://www.openhardware.io/view/480/nRF24L01-Pro-Mini-Bottom-Shield
    https://www.openhardware.io/view/561/JMP-Arduino-Pro-Mini-Multisensor-Board-v21
    https://forum.mysensors.org/uploads/files/1440959677580-board.png
    https://github.com/tonnerre33/Soil_Moisture_Sensor_MD-cr/blob/master/Soil_Moisture_Sensor_SMD-cr.csvS
    But none match Electrodragons :
    http://www.electrodragon.com/product/nrf24duino-arduino-mini-plus-nrf24l01-board/
    • patt896P Offline
      patt896P Offline
      patt896
      And Electrodragon also offers a Mini Boost Buck DC Board 1.8-5V to 3.3V, for Battery Juice R2:
      http://www.electrodragon.com/product/mini-boost-buck-dc-board-1-8-5v-3-3v/
      Use full battery juice!
      • Super mini size 11.5×9.5mm, SOT23-6 IC with only three caps
      • Input Voltag 1.8-5V, output 3.3V up to 150mA
      • Constant Frequency Operation at All Loads. Low Noise Constant Frequency (1.2MHz)
      Operation
      • Automatic Soft-Start Reduces Inrush Current
      • Shutdown Current <1 uA, No load current is 1.77mA.
      • Short-Circuit Protection
      • No Inductors
      • Standard 2.54 pin output, 3.3V-GND-VIN (face to top), can be used as a normal SMD part.
      Testing for reference:
      • 1.8V VIN -> 3.3V output
      • 1.5V VIN -> 3.1xV output, still can drive a lot MCUs.
      Updated to R2:
      RPunktR 1 Reply Last reply
      • rvendrameR Offline
        rvendrameR Offline
        rvendrame
        Just a comment for this board, the minimum current consumption in mySensors Sleep() that I could achieve is ~700uA, with 2XAA batteries.
        According to seller, this the benchmark for this board.
        I should have enquired it first, before buying 10 boards... one more lesson learned!
        ESP8266 GW + mySensors 2.3.2
        Alexa / Google Home
        • N Offline
          N Offline
          ncollins
          I had similar high power consumption issues with this NRFduino from electrodragon. It turns out it was the attached flash module that was consuming a lot of power.
          I was able to reduce the sleep current by immediately powering down the flash module.
          #include<SPIFlash.h>
          // load user settings
          #include "config.h"
          // include supporting libraries
          #ifdef MY_GATEWAY_ESP8266
            #include <ESP8266WiFi.h>
          // load MySensors library
          // load NodeManager library
          #include "NodeManager.h"
          // create a NodeManager instance
          NodeManager nodeManager;
          SPIFlash flash(8);
          // before
          void before() {
            Serial.begin(MY_BAUD_RATE);
            flash.powerDown();
          rvendrameR 1 Reply Last reply
          • N ncollins
            #include "config.h"
            SPIFlash flash(8);
            // before
            void before() {
              flash.powerDown();
            rvendrameR Offline
            rvendrameR Offline
            rvendrame
            @nikola-collins , yes, I just got the same conclusion. After installing the latest SPIFlash lib from lowpowerlab.com, and changed the constructor to "SPIFlash flash(8)" (like your code), seems that now I have ~12uA in sleep mode.
            Thanks anyway!
            Alexa / Google Home
            • X Offline
              X Offline
              xreichardx
              I am considering ordering several of these for new and future sensors. I thought I saw this board supported by myscontroller bootloader in 13pre or the github dev branch but cant seem to find it at the moment.
              Has anyone tried this FOTA?
              --Reichard
              N 1 Reply Last reply
              • X xreichardx
                --Reichard
                N Offline
                N Offline
                ncollins
                @xreichardx I have not tried the myscontroller bootloader, sorry.
                • X Offline
                  X Offline
                  xreichardx
                  I received my order of these nrf24duinos and loaded up a Nodemanger BME280 sketch. Currently running on a battery and waking up every 10 minutes.
                  I installed the spiflash.h library, added the "SPIFlash flash(8);" but flash.powerDown(); throws the an error during compilation "class SPIFlash has no member named 'powerDown".
                  I opened the spiflash.h library and no powerDown defined. I did see sleep() though.
                  • N Offline
                    N Offline
                    ncollins
                    Interesting. I might be using a different library. I would stick with the LowPowerLab version, looks like sleep is equivalent to power down.
                    #define SPIFLASH_SLEEP            0xB9        // deep power down
                    https://github.com/LowPowerLab/SPIFlash/blob/master/SPIFlash.h line 82
                    I guess I'm using this library, https://github.com/Marzogh/SPIMemory. It was renamed to SPIMemory.
                    • X Offline
                      X Offline
                      xreichardx
                      Thanks, I'll check out that library as well.
                      After four days of operating on a 18650 battery, the battery voltage hasn't dropped from full charge voltage of 4.12v. I was quite pleased with the nrf24 range of these ElectroDragon boards as well.
                      • S Offline
                        sergio ramos
                        Banned
                        wrote on last edited by sergio ramos
                        X 1 Reply Last reply
                        • S sergio ramos
                          X Offline
                          X Offline
                          xreichardx
                          @sergio-ramos Did you have an issue with one? I have purchased many of them and have not had one problem.
                          • X xreichardx
                            @xreichardx that user was fake, copying a question from earlier in this thread and later editing the post to contain spam links.
                            nagelcN 1 Reply Last reply
                              nagelcN Offline
                              nagelcN Offline
                              nagelc
                              @mfalkvidd Thanks for doing this kind of work (deleting fake users and stopping spam). I am sure it is not as much fun as answering real questions about MySensors topics. But I learn so much from people in these forums, that I would hate to see it overtaken by trolls and spam.
                              • patt896P patt896
                                Operation
                                • No Inductors
                                Updated to R2:
                                RPunktR Offline
                                RPunktR Offline
                                RPunkt
                                @patt896 I have the same setting: the "Atmega328P Arduino Plus Nrf24l01+ Board, Nrf24Duino R1.6" and the "Mini Boost Buck DC Board".
                                But I can't get this to a current lower than 3 mA while sleeping.
                                This is to much for me, because I want it to be powered with 5 volt solar module in combination with a supercap.
                                Can You give me a hint, what to do, to reduce the power consumption?
                                • RPunktR RPunkt
                                  X Offline
                                  X Offline
                                  xreichardx
                                  @rpunkt if 3ma is your current draw while sleeping, you will quickly drain any battery or supercap. The "mini boost buck dc board" itself has a no-load current of 1.77mA.
                                  Might look here for low-power libraries and design considerations:
                                  http://www.home-automation-community.com/arduino-low-power-how-to-run-atmega328p-for-a-year-on-coin-cell-battery/
                                  https://github.com/rocketscream/Low-Power
                                  11.9k
                                  113.3k
