  2. Feature Requests
  3. ImperiHome Standard System API
Scheduled Pinned Locked Moved Feature Requests
11 Posts 5 Posters 7.8k Views 1 Watching
  • korttomaK
    korttomaK
    korttoma
    It would be nice if more than one "controller" (Vera, OpenHAB, ImperiHome, whatever) could connect to the same Ethernet GW. Maybe limited to 3-4 controllers max.
    • Tomas
    • epierreE
      epierreE
      epierre
      I have made the imperihome interface for domoticz, so I know how to do it.
      So far I've had no time to finish my domoticz to mysensor interface, all the more that domoticz now is making its native mysensors interface. I just had to plus both together, making the missing bits specific, it would have been a standalone Imperihome to mysensor controller ;-)
      You can use imperihome with the vera which is natively fine and faster than the ISS.
      If the gateway should have the ISS interface that would mean:
      • an ethernet gateway only
      • a controller capacity (not juste a gateway) for it assigns ne node id, it handles state and values (not just keep it for the controller), and it sends out orders on its own. This means something to store it in memory or on a file, something far more advanced that an arduino alone could make. Also, imperihome expectd quite a complex hardware listing if you have many nodes, this would use a lot of CPU... a raspi would be fit, but not an arduino.
      z-wave - Vera -> Domoticz
      AnticimexA 1 Reply Last reply
      • epierreE epierre
        AnticimexA
        AnticimexA
        Anticimex
        @epierre
        I see. I already have ImperiHome interfacing with my Vera. However, in the long run, I am not going to allow Vera in my home. It sets up a local server with an outbound connection directly to Mios which therefore bypass my firewall. I am not going to allow that company to monitor my home. Currently I only use Vera since it is a known good reference for the MySensor framework.
        I also have Domoticz running but have not yet tried to hook it up to the MySensors GW. Also, I have the desire to use some good Android frontend to the whole setup, and so far ImeriHome seem the best. But there are others and the Domoticz web UI might also be good enough.
        • RJ_MakeR
          RJ_MakeR
          RJ_Make
          I too hope to find a path away from Vera LTD., but as of now that seems to be a long way off..
          RJ_Make
          • tbowmoT
            tbowmoT
            tbowmo
            @Anticimex
            Why don't you put the vera in a firewalled DMZ? Then it can do less harm to the network.
            • tbowmoT tbowmo
              @Anticimex
              AnticimexA
              AnticimexA
              Anticimex
              @tbowmo
              The issue is not it doing harm on my network. The issue is that I do not have control over the access management to it. I do not trust MiIOS to handle my account securely enough for me to entrust them with access to monitor and control my stuff.
              I will eventually hack into it and disable the outbound connectivity I think (if it does not end up in the trash before that). I think there are some guides available for this on the web and forums.
              • epierreE
                epierreE
                epierre
                there are ways to log as root and deactivate the remote access... anytime...
                • epierreE epierre
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @epierre
                  Yep. And for good measure it is advisable to clean out a few backdoors as well. They always leave a root password that they "know", which it also is a good idea to change. After all, that is how you login yourself in the shell :)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Anticimex
                    Ok, got it. Thought that you where concerned that they would log in to snoop around in the traffic on your local network.
                    But yes, I can see that it's a problem when they can take control over it, which means that they are able to change the programming you have done yourself.
                    • tbowmoT tbowmo
                      @Anticimex
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @tbowmo
                      Thats right.
                      But more imprtantly, the whole purpose of my signing development is to allow sensor nodes to trust the "sender". But this of course chains all the way to the controller, and with the MiOS tunnel, that chains outside the walls and then signing does not matter at all. Anybode with access to my MiOS account (which is hackable) can then access potentially my doorlock. And that would be...bad...
                      I know that MiOS intention is sort of honorable; easily provide remote access to your HA system. However, they should provide better support to opt-out of that option. If I wanted to access stuff remotely, I open a SSH tunnel with my two-factor authentication and then I have total access to my LAN.
                      But we are gliding off topic here :) @epierre basically answered my question and killed the overall topic since my query was if the current HW design could support this. If a much more gateway HW is required, then there are better alternatives to pursue.
