  3. DHT and DOOR sensor
DHT and DOOR sensor
20 Posts 6 Posters 4.3k Views 6 Watching
  • HomerH Homer
    @terence-faul I'm probably wrong, but it looks to me like the sensor and the button are on the same pin.
    I'm only learning, so it's probably wise to wait for someone else to chime in.
    @homer yes, they are using the same pin. Move one of them (doesn't matter which) to pin 2. On atmega328, only pins 2 and 3 have full interrupt functionality.
    • T
      Terence Faul
      Hi
      I have sorted the pins and library problems, but now I get failed to read errors
      Updated Sketch
       * Version 1.0: Henrik EKblad
       * sensor using a DHT11/DHT-22.
      // Enable debug prints
      #define MY_RX_MESSAGE_BUFFER_FEATURE
      #define MY_RF24_IRQ_PIN 2
      #define MY_RADIO_RF24
      //#define MY_RS485
      #define DHT_DATA_PIN 4
      #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
      // Set this offset if the sensor has a permanent small offset to the real temperatures.
      // In Celsius degrees (as measured by the device)
      #define SENSOR_TEMP_OFFSET 0
      static const uint64_t UPDATE_INTERVAL = 60000;
      #define CHILD_ID 3
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      float lastTemp;
      float lastHum;
      uint8_t nNoUpdatesTemp;
      uint8_t nNoUpdatesHum;
      bool metric = true;
      DHT dht;
      Bounce debouncer = Bounce();
      int oldValue=-1;
        sendSketchInfo("Door/DHT", "1.1");
        present(CHILD_ID_HUM, S_HUM);
        present(CHILD_ID, S_DOOR);
      	// Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
        dht.readSensor(true);
        if (isnan(temperature)) {
          lastTemp = temperature;
          // apply the offset before converting to something different than Celsius degrees
          if (!metric) {
          // Reset no updates counter
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          Serial.print("T: ");
          nNoUpdatesTemp++;
        if (isnan(humidity)) {
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          Serial.print("H: ");
          Serial.println(humidity);
          nNoUpdatesHum++;
      		debouncer.update();
        // Get the update value
        int value = debouncer.read();
        if (value != oldValue) {
           // Send in the new value
           send(msg.set(value==HIGH ? 1 : 0));
           oldValue = value;
        sleep(UPDATE_INTERVAL);
      and error snippet
      3534 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
      3545 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
      3553 TSF:TDI:TSL
      3555 MCO:SLP:WUP=1
      3557 TSF:TRI:TSB
      3584 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
      3592 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
      3602 TSF:TDI:TSL
      3604 MCO:SLP:WUP=1
      3606 TSF:TRI:TSB
      • T Terence Faul
        Hi
        Updated Sketch
        //#define MY_RS485
        #define CHILD_ID 3
        float lastTemp;
        float lastHum;
        bool metric = true;
        DHT dht;
        int oldValue=-1;
        	// Setup the button
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            nNoUpdatesHum++;
        		debouncer.update();
             oldValue = value;
        and error snippet
        3553 TSF:TDI:TSL
        3555 MCO:SLP:WUP=1
        3557 TSF:TRI:TSB
        3602 TSF:TDI:TSL
        3604 MCO:SLP:WUP=1
        3606 TSF:TRI:TSB
        @terence-faul said in DHT and DOOR sensor:
        This means the DHT library is unable to read from the DHT sensor. Double-check that the DHT gets sufficient power and that it is wired correctly. If you have another DHT sensor, switch sensors and see if that helps.
        • T
          Terence Faul
          Will give that a go. But if I load the DHT only sketch on the same node it reads fine.
          Could you check my sketch I’m a bit of a noob with code
          • T Terence Faul
            @terence-faul the sketch looks good to me. Could you post your "dht only" sketch?
            • HomerH
              HomerH
              Homer
              I can't believe I spotted am error in the code! I guess I'm starting to get a bit better at this! 😁😁
              • T
                Terence Faul
                //#define MY_RS485
                float lastTemp;
                float lastHum;
                bool metric = true;
                DHT dht;
                  sendSketchInfo("TemperatureAndHumidity", "1.1");
                    if (!metric) {
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesTemp++;
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesHum++;
                • T Terence Faul
                  //#define MY_RS485
                  float lastTemp;
                  float lastHum;
                  bool metric = true;
                  DHT dht;
                      if (!metric) {
                      nNoUpdatesTemp = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesTemp++;
                      lastHum = humidity;
                      nNoUpdatesHum = 0;
                      #ifdef MY_DEBUG
                      nNoUpdatesHum++;
                  Thanks @terence-faul
                  I can't see any problem with the sketches.
                  • skywatchS
                    skywatchS
                    skywatch
                    @Terence-Faul The only thing I can say is that it is generally good practice to put all #include statements at the start of the code, then all the #define statements and finally all other items. At the moment you #define things before you #include the library and maybe that is an issue for the compiler?
                    • skywatchS skywatch
                      @skywatch while your recommendation is good in general, all MySensors defines (MY_*) must be defined before including MySensors.h. Otherwise the defines won't be available to the library, so the library will need to fall back on the default settings.
                      skywatchS 1 Reply Last reply
                      • T
                        Terence Faul
                        Thanks so much for the help, what is the next step then? create two sensors?
                        K 1 Reply Last reply
                        • T Terence Faul
                          K
                          K
                          kimot
                          wrote on last edited by kimot
                          @terence-faul
                          comment step by step blocks of code for DOOR switch and try when it start to work.
                            skywatchS
                            skywatchS
                            skywatch
                            @mfalkvidd Ah yes, I forgot that bit!
                            • skywatchS
                              skywatchS
                              skywatch
                              • T Terence Faul
                                Hi
                                Please assist, I am trying to combine the default straight from the examples, but the DHT give an error on compile
                                //#define MY_RS485
                                #define DHT_DATA_PIN 3
                                #define CHILD_ID 3
                                float lastTemp;
                                float lastHum;
                                bool metric = true;
                                DHT dht;
                                int oldValue=-1;
                                	// Setup the button
                                    if (!metric) {
                                    nNoUpdatesTemp = 0;
                                    #ifdef MY_DEBUG
                                    nNoUpdatesTemp++;
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    #ifdef MY_DEBUG
                                    nNoUpdatesHum++;
                                		debouncer.update();
                                     oldValue = value;
                                The error is below
                                /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino: In function 'void loop()':
                                /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino:129:22: error: no matching function for call to
                                'DHT::readSensor(bool)'
                                dht.readSensor(true);```
                                sharpy
                                Hi @terence-faul did you fix this?
                                i'm also trying too merge a door & dht sketch but have not got a clue where too start
                                if you have solved this can you post the working sketch
                                • HomerH
                                  HomerH
                                  Homer
                                  How much power are you feeding the sensor? I've had issues when I've fed too little power and it's resolved once I use more power.
