  3. DHT and DOOR sensor
DHT and DOOR sensor
20 Posts 6 Posters 4.3k Views 6 Watching
  • T
    Terence Faul
    Hi
    Please assist, I am trying to combine the default straight from the examples, but the DHT give an error on compile
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RS485
    #define DHT_DATA_PIN 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID 3
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    Bounce debouncer = Bounce();
    int oldValue=-1;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID, S_DOOR);
    	// Setup the button
    pinMode(BUTTON_PIN,INPUT);
    // Activate internal pull-up
    debouncer.attach(BUTTON_PIN);
    debouncer.interval(5);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
    		debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
      sleep(UPDATE_INTERVAL);
    The error is below
    /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino: In function 'void loop()':
    /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino:129:22: error: no matching function for call to
    'DHT::readSensor(bool)'
    dht.readSensor(true);```
    HomerH S 2 Replies Last reply
    • T Terence Faul
      Hi
      //#define MY_RS485
      #define CHILD_ID 3
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      int oldValue=-1;
      	// Setup the button
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
      		debouncer.update();
           oldValue = value;
      The error is below
      HomerH
      HomerH
      Homer
      @terence-faul I'm probably wrong, but it looks to me like the sensor and the button are on the same pin.
      I'm only learning, so it's probably wise to wait for someone else to chime in.
      mfalkviddM 2 Replies Last reply
      • HomerH Homer
        @homer you'll need to install the modified DHT library as described on https://www.mysensors.org/build/humidity#example
        HomerH 1 Reply Last reply
          HomerH
          HomerH
          Homer
          @mfalkvidd said in DHT and DOOR sensor:
          Thanks, but did I spot the issue with the pins correctly?
          • HomerH Homer
            @homer yes, they are using the same pin. Move one of them (doesn't matter which) to pin 2. On atmega328, only pins 2 and 3 have full interrupt functionality.
            • T
              Terence Faul
              Hi
              I have sorted the pins and library problems, but now I get failed to read errors
              Updated Sketch
              #define MY_RX_MESSAGE_BUFFER_FEATURE
              #define MY_RF24_IRQ_PIN 2
              //#define MY_RS485
              #define DHT_DATA_PIN 4
              #define CHILD_ID 3
              float lastTemp;
              float lastHum;
              bool metric = true;
              DHT dht;
              int oldValue=-1;
                sendSketchInfo("Door/DHT", "1.1");
              	// Setup the button
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesHum++;
              		debouncer.update();
                   oldValue = value;
              and error snippet
              3534 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
              3545 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
              3553 TSF:TDI:TSL
              3555 MCO:SLP:WUP=1
              3557 TSF:TRI:TSB
              3584 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
              3592 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
              3602 TSF:TDI:TSL
              3604 MCO:SLP:WUP=1
              3606 TSF:TRI:TSB
              • T Terence Faul
                Hi
                Updated Sketch
                //#define MY_RS485
                #define CHILD_ID 3
                float lastTemp;
                float lastHum;
                bool metric = true;
                DHT dht;
                int oldValue=-1;
                	// Setup the button
                    if (!metric) {
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesTemp++;
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                    nNoUpdatesHum++;
                		debouncer.update();
                     oldValue = value;
                and error snippet
                3553 TSF:TDI:TSL
                3555 MCO:SLP:WUP=1
                3557 TSF:TRI:TSB
                3602 TSF:TDI:TSL
                3604 MCO:SLP:WUP=1
                3606 TSF:TRI:TSB
                @terence-faul said in DHT and DOOR sensor:
                This means the DHT library is unable to read from the DHT sensor. Double-check that the DHT gets sufficient power and that it is wired correctly. If you have another DHT sensor, switch sensors and see if that helps.
                • T
                  Terence Faul
                  Will give that a go. But if I load the DHT only sketch on the same node it reads fine.
                  Could you check my sketch I’m a bit of a noob with code
                  • T Terence Faul
                    @terence-faul the sketch looks good to me. Could you post your "dht only" sketch?
                    • HomerH
                      HomerH
                      Homer
                      I can't believe I spotted am error in the code! I guess I'm starting to get a bit better at this! 😁😁
                      • T
                        Terence Faul
                        //#define MY_RS485
                        float lastTemp;
                        float lastHum;
                        bool metric = true;
                        DHT dht;
                            if (!metric) {
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesTemp++;
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesHum++;
                        • T Terence Faul
                          //#define MY_RS485
                          float lastTemp;
                          float lastHum;
                          bool metric = true;
                          DHT dht;
                              if (!metric) {
                              nNoUpdatesTemp = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesTemp++;
                              lastHum = humidity;
                              nNoUpdatesHum = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesHum++;
                          Thanks @terence-faul
                          I can't see any problem with the sketches.
                          • skywatchS
                            skywatchS
                            skywatch
                            @Terence-Faul The only thing I can say is that it is generally good practice to put all #include statements at the start of the code, then all the #define statements and finally all other items. At the moment you #define things before you #include the library and maybe that is an issue for the compiler?
                            • skywatchS skywatch
                              @skywatch while your recommendation is good in general, all MySensors defines (MY_*) must be defined before including MySensors.h. Otherwise the defines won't be available to the library, so the library will need to fall back on the default settings.
                              skywatchS 1 Reply Last reply
                              • T
                                Terence Faul
                                Thanks so much for the help, what is the next step then? create two sensors?
                                K 1 Reply Last reply
                                • T Terence Faul
                                  K
                                  K
                                  kimot
                                  wrote on last edited by kimot
                                  @terence-faul
                                  comment step by step blocks of code for DOOR switch and try when it start to work.
                                    skywatchS
                                    skywatchS
                                    skywatch
                                    @mfalkvidd Ah yes, I forgot that bit!
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      • T Terence Faul
                                        Hi
                                        //#define MY_RS485
                                        #define CHILD_ID 3
                                        float lastTemp;
                                        float lastHum;
                                        bool metric = true;
                                        DHT dht;
                                        int oldValue=-1;
                                        	// Setup the button
                                            if (!metric) {
                                            nNoUpdatesTemp = 0;
                                            #ifdef MY_DEBUG
                                            nNoUpdatesTemp++;
                                            lastHum = humidity;
                                            nNoUpdatesHum = 0;
                                            #ifdef MY_DEBUG
                                            nNoUpdatesHum++;
                                        		debouncer.update();
                                             oldValue = value;
                                        The error is below
                                        sharpy
                                        Hi @terence-faul did you fix this?
                                        i'm also trying too merge a door & dht sketch but have not got a clue where too start
                                        if you have solved this can you post the working sketch
                                        • HomerH
                                          HomerH
                                          Homer
                                          How much power are you feeding the sensor? I've had issues when I've fed too little power and it's resolved once I use more power.
