  3. Trouble setting up repeater node
10 Posts 2 Posters 1.1k Views 2 Watching
  • R Offline
    R Offline
    rjad
    I'm having a lot of trouble getting a repeater node to work. I've tried to do some background on this, and have checked a few other posts that also seem to have trouble, but I'm not really any closer.
    Here is my scenario:
    I have a gateway connected to a raspberry pi.
    I have a battery powered node (set node ID to 47). I'd like to be able to place this a fair distance away from the gateway, and so I need a repeater. I made a repeater node (node id set to 46).
    The repeater node appears to connect to the gateway ok. The mobile temp node also connects ok if I'm close to the gateway. But doesn't seem to be able to use the repeater.
    For testing, to try to force the temp node to use the repeater, I have set:
    #define MY_NODE_ID 47                    //To set a fixed ID for your node
    #define MY_PARENT_NODE_ID 46             //To set a fixed parent for this node
    I noticed that if I didn't have MY_PARENT_NODE_IS_STATIC the node would still connect to the
    gateway. If I defined it, then it seemed to only try to connect to the repeater node, which is what I want at least for testing.
    So, I'm pretty sure the repeater node connects. Code for repeater is:
    #include <Arduino.h>
    #define MY_RADIO_RF24
    #define MY_NODE_ID 46                        //To set a fixed ID for your node
    #define CHILD_ID 0
    //#define MY_REPEATER_FEATURE
      sendSketchInfo("Repeater Node", "1.1");
      present(CHILD_ID, S_DOOR);
    And output from gateway when connecting the repeater:
    mysgw: Starting gateway...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: TSF:MSG:READ,46-46-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=46
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysgw: TSF:MSG:PINGED,ID=46,HP=1
    mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    mysgw: TSF:MSG:READ,46-46-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.1
    mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Repeater Node
    mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
    mysgw: TSF:MSG:READ,46-46-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:READ,46-46-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    mysgw: TSF:MSG:SEND,0-0-46-46,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    So seems ok. Connecting the temperature node, with debug on, serial output looks like:
     __  __       ____
            |___/                      2.3.1
    16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
    28 TSM:INIT
    28 TSF:WUR:MS=0
    34 TSM:INIT:TSP OK
    36 TSM:INIT:STATID=47
    40 TSF:SID:OK,ID=47
    43 TSM:FPAR
    43 TSM:FPAR:STATP=46
    45 TSM:ID
    47 TSM:ID:OK
    49 TSM:UPL
    51 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2060 TSM:UPL
    2062 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4071 TSM:UPL
    4073 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    6082 TSM:UPL
    6084 TSF:MSG:SEND,47-47-46-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    8093 !TSM:UPL:FAIL
    8095 TSM:FPAR
    8095 TSM:FPAR:STATP=46
    8099 TSM:ID
    8099 TSM:ID:OK
    8101 TSM:UPL
    I'm guessing that the repeater isn't forwarding the messages. I'm also having trouble parsing the log output. There are links to the message parser, but this doesn't seem to function anymore (https://www.mysensors.org/build/parser doesn't point to a project anymore).
    If anyone could help interpret the messages that would be great.
    Robert
    • R rjad
      #define CHILD_ID 0
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      mysgw: TSF:MSG:BC
       __  __       ____
              |___/                      2.3.1
      28 TSM:INIT
      28 TSF:WUR:MS=0
      34 TSM:INIT:TSP OK
      40 TSF:SID:OK,ID=47
      43 TSM:FPAR
      45 TSM:ID
      47 TSM:ID:OK
      49 TSM:UPL
      2060 TSM:UPL
      4071 TSM:UPL
      6082 TSM:UPL
      8093 !TSM:UPL:FAIL
      8095 TSM:FPAR
      8099 TSM:ID
      8099 TSM:ID:OK
      8101 TSM:UPL
      Robert
      Hi @rjad, welcome to the MySensors forum.
      The log parser works good for me. See screen shot below. Could you clarify what you mean by "doesn't point to a project anymore"? Could you check the browser console if there are any messages when you try to use the parser?
      Could you grab the debug log from the repeater node, while the temp node is starting up?
      You do have capacitors on the nrf24 radios, right?
      How far from the repeater node is the temp node?
      R 2 Replies Last reply
        R Offline
        R Offline
        rjad
        @mfalkvidd
        When I go to the link https://www.mysensors.org/build/parser I get a page with the message:
        !Doh.. This project isn't published!
        R mfalkviddM 2 Replies Last reply
        • R rjad
          @mfalkvidd
          R Offline
          R Offline
          rjad
          @rjad ,
          Also, I have 4.7uF caps on all the radios. And even if I put the repeater a metre away from the temp node I get the same result. Its awkward getting the log from the repeater, but I'll get on it.
            R Offline
            R Offline
            rjad
            wrote on last edited by rjad
            @mfalkvidd
            This is the output from the repeater node when I turn on the temperature node:
            28 TSM:INIT
            28 TSF:WUR:MS=0
            34 TSM:INIT:TSP OK
            36 TSM:INIT:STATID=46
            40 TSF:SID:OK,ID=46
            43 TSM:FPAR
            77 TSF:MSG:SEND,46-46-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            649 TSF:MSG:READ,0-0-46,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            655 TSF:MSG:FPAR OK,ID=0,D=1
            2088 TSM:FPAR:OK
            2088 TSM:ID
            2091 TSM:ID:OK
            2093 TSM:UPL
            2097 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2109 TSF:MSG:READ,0-0-46,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2115 TSF:MSG:PONG RECV,HP=1
            2117 TSM:UPL:OK
            2119 TSM:READY:ID=46,PAR=0,DIS=1
            2123 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2136 TSF:MSG:READ,0-0-46,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2144 TSF:MSG:SEND,46-46-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
            2154 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            2854 TSF:MSG:READ,0-0-46,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            2865 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Repeater Node
            2875 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
            2885 TSF:MSG:SEND,46-46-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
            2891 MCO:REG:REQ
            2895 TSF:MSG:SEND,46-46-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            2904 TSF:MSG:READ,0-0-46,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            2910 MCO:PIM:NODE REG=1
            2912 MCO:BGN:STP
            2914 MCO:BGN:INIT OK,TSP=1
            55711 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            55717 !TSF:MSG:REL MSG,NREP
            57733 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            57741 !TSF:MSG:REL MSG,NREP
            59746 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            59752 !TSF:MSG:REL MSG,NREP
            61761 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            61767 !TSF:MSG:REL MSG,NREP
            63791 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            63797 !TSF:MSG:REL MSG,NREP
            65804 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            65810 !TSF:MSG:REL MSG,NREP
            67831 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            67837 !TSF:MSG:REL MSG,NREP
            69844 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            69851 !TSF:MSG:REL MSG,NREP
            71874 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            71880 !TSF:MSG:REL MSG,NREP
            73891 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            73897 !TSF:MSG:REL MSG,NREP
            75929 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            75935 !TSF:MSG:REL MSG,NREP
            77940 TSF:MSG:READ,47-47-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            • R rjad
              @mfalkvidd
              @rjad interesting. I wonder what is so special about your environment, since it works for almost everyone else.
              Do you have blocker plugins or a filtering proxy? Could you try from a different web browser?
              Edit: it seems you are not entirely alone https://forum.mysensors.org/topic/10292/log-parser-error
              Iam unable to reproduce the problem though - as I showed in the screen shot it works for me.
              R 1 Reply Last reply
              • R rjad
                @mfalkvidd
                28 TSM:INIT
                28 TSF:WUR:MS=0
                34 TSM:INIT:TSP OK
                40 TSF:SID:OK,ID=46
                43 TSM:FPAR
                2088 TSM:FPAR:OK
                2088 TSM:ID
                2091 TSM:ID:OK
                2093 TSM:UPL
                2117 TSM:UPL:OK
                2891 MCO:REG:REQ
                2912 MCO:BGN:STP
                @rjad the log mentions NREP which means
                "message relaying request, but not a repeater"
                I noticed in your sketch that you have commented out the line that enables the repeater. Maybe it works better if you remove the // before #define MY_REPEATER_FEATURE
                  R Offline
                  R Offline
                  rjad
                  @mfalkvidd
                  Well that's embarrassing....
                  That was part of my testing to make sure it worked as a normal node. Looks like I forgot to put it back.
                  Thanks for pointing it out.
                    R Offline
                    R Offline
                    rjad
                    @mfalkvidd
                    The log parser now works for me too. Thanks.
                    • R rjad
                      @mfalkvidd
                      Great work @rjad, thanks for reporting back.
                      11.9k
                      113.3k
