  3. GUIDE - NRF5 / NRF51 / NRF52 for beginners
102 Posts 26 Posters 50.2k Views 26 Watching
    Just paste your hex file to the JLINK drive that appears when you connect your DK. That will handle the upload for you. It's as simple as that.
    ileneken3I 1 Reply Last reply
      ileneken3I
      ileneken3I
      ileneken3
      @neverdie
      Unfortunately, nothing is that simple - at least for me. I have gone in circles with the J-LINK drivers. In order to use the Arduino IDE for programming, you must use the WinUSB driver installed by Zadig. But if you do that, the nRFgo Studio no longer recognizes any J-LINK device. So I re-install RFgo Studio, and then I can't use the Arduino IDE anymore!
      But I can work around those issues, because everything programs and works right when programming the device on the NRF DK board. The problem is I can't do anything with the two external boards I tried. With one, I was able to unlock it with a "Recover" in nRFgo Studio, but the programming doesn't seem to cause the chip to do anything (nothing logged by the gateway). With the other, I can't unlock the board - it always says: "Recover failed: Unknown error".
      Both boards are E73 - but one is marked as E73-2G4M04S and the other is E73-2G4M04S1B.
      Any ideas?
      O NeverDieN 2 Replies Last reply
      • ileneken3I ileneken3
        @neverdie
        Any ideas?
        O
        O
        Omemanti
        wrote on last edited by Omemanti
        #25
        @ileneken3
        the difference between E73-2G4M04S and E73-2G4M04S1B is that the last one seems to be from a new batch. I got both, the only difference was that the last one I needed to recover and the other one (old) I only had to "burn bootloader".
        your problem with the Arduino IDE seems to have something to do with the Sandeep installation, see the comment of @Toyman: https://forum.mysensors.org/topic/6961/nrf5-action/1749
          @neverdie
          Any ideas?
          #26
          @ileneken3 What I meant was just export your .hex file and then drop it on the virtual JLINK drive to do the chip programming, not try to burn it directly from the IDE. That way you only depend on the DK doing it's job, not on an arduino IDE, where some versions don't seem to work well. Anyhow, that's how I do it now, and, at least for me, it seems to work the most reliably.
          That said, I haven't tried the E73-2G4M04S1B, so can't really say regarding that one specifically. On the inside they should all be the same chip though, so I'm surprised to hear that it may have different requirements.
          These days I'm largely focused on the nRF52840 and driving it with Forth. Maybe later I may circle back to the 832.
            ileneken3I
            ileneken3I
            ileneken3
            @neverdie
            Yes, I understood what you meant. I will only do the "Export compiled Binary" from the IDE, and leave the drivers as J-Link commander or nrfGo Studio wants them.
            In: https://www.openhardware.io/view/376/MySensors-NRF5-Platform it says:
            "Currently, the nRF52832 and nRF51822 are supported so we recommend sticking with those for now."
            I noticed that my board: (E73-2G4M04S) is labeled "NRF52810". So is that why after programming it nothing works (nothing seen on gateway) :( ?
            If so, I messed up on that order.
            But I am also trying the E73 2G4M04S1B, which at least from the AliExpress order
            https://www.aliexpress.com/item/CDEBYTE-E73-2G4M04S-BLE-4-2-5-0-long-distance-100m-2-4GHz-SMD-ARM-Core/32820692238.html?spm=a2g0s.9042311.0.0.27424c4dSKBLn7
            says it is nRF52832. (It isn't labeled on the board though). For this module, I can't unlock it using "Recover" from nRfgoStudio. It always fails with a message "Recover failed: Unknown error".
            From the command line, if I do
            nrfjprog.exe -f NRF52 --recover --log
            and it comes back immediately with:
            Recovering device. This operation might take 30s.
            ERROR: Recover failed. Please make sure that the correct device family is given
            ERROR: and try again.
            The key error from the log seems to be:
            2018-Dec-27 12:25:22 . . . . . nRF52_power_debug_and_system_regions
            2018-Dec-27 12:25:22 . . . . . . nRF52_write_debug_port_register
            2018-Dec-27 12:25:22 . . . . . . nRF52_write_debug_port_register: JLink: JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
            2018-Dec-27 12:25:22 . . . . . . nRF52_write_debug_port_register: JLink: returns -1
            2018-Dec-27 12:25:23 . . . . . . nRF52_write_debug_port_register: JLink: (0005ms, 0288ms total)
            2018-Dec-27 12:25:23 . . . . . . nRF52_write_debug_port_register: JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -1.
            2018-Dec-27 12:25:23 . . . . . nRF52_power_debug_and_system_regions: JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -102.
            If I do: nrfjprog.exe -f NRF51 --recover --log
            it actually makes LD5 on the DK board flash for 30 seconds, but still returns failure with the exact same message.
            Any other tricks for "recover/unlock" of those boards?
            NeverDieN O 2 Replies Last reply
              @neverdie
              #28
              @ileneken3 I suggest posting a query on the nordic devzone forum. A Nordic engineer will get assigned to it and give you an answer. I've tried this a few times, and I had good luck with it. Generally 24 hour turnaround on weekdays, and no answers on weekends. So, if you post it now, you may get an answer tomorrow. It's in Nordic's interest to help developers unlock these chips, and if there are any secrets to doing so, Nordic will certainly know them.
              It sounds as though once you get past the unlock issue, it will be easier for you.
                @neverdie
                O
                O
                Omemanti
                #29
                @ileneken3 sorry, can't help you anymore.
                I can only tell that I installed the segger drivers, and everything as described by @d00616
                Most issues I have, happen when I did some soldering wrong or when I've been messing around with drivers. A clean setup almost always solve my problems
                I used both old and new ebyte modules and they work like a charm.0_1545943568844_IMG_20181227_213333.jpg
                  Sancho119
                  I'm trying to begin with nrf52832.
                  I have follow advice, with soldering 4 wires. I use STlink v2, downloading soft before use it.
                  When i try to erase the nrf52832, with sketch "mass_erase" in exemple, i have the following error :
                  Arduino : 1.8.7 (Windows 10), Carte : "MyBoardNRF5 nRF52832, None, Crystal Oscillator, Don't enable"
                  C:\Users\Sancho\AppData\Local\Arduino15\packages\sandeepmistry\tools\openocd\0.10.0-dev.nrf5/bin/openocd.exe -d2 -f interface/stlink-v2.cfg -c transport select hla_swd; set WORKAREASIZE 0x4000; -f target/nrf52.cfg -c init; halt; nrf51 mass_erase; program {{{build.core.path}/SDK/components/softdevice/none/hex/none_nrf52_{softdeviceversion}_softdevice.hex}} verify reset; shutdown;
                  Licensed under GNU GPL v2
                  For bug reports, read
                  debug_level: 2
                  0x4000
                  adapter speed: 10000 kHz
                  Info : clock speed 4000 kHz
                  Info : STLINK v2 JTAG v29 API v2 SWIM v7 VID 0x0483 PID 0x3748
                  Info : using stlink api v2
                  Info : Target voltage: 3.280426
                  Error: init mode failed (unable to connect to the target)
                  in procedure 'init'
                  in procedure 'ocd_bouncer'
                  Erreur lors de la gravure de la séquence d'initialisation.
                  I try to upload an empty sketch (MyBoardNRF5), and have this message :
                  Le croquis utilise 10508 octets (2%) de l'espace de stockage de programmes. Le maximum est de 524288 octets.
                  C:\Users\Sancho\AppData\Local\Arduino15\packages\sandeepmistry\tools\openocd\0.10.0-dev.nrf5/bin/openocd.exe -d2 -f interface/stlink-v2.cfg -c transport select hla_swd; set WORKAREASIZE 0x4000; -f target/nrf52.cfg -c program {{C:\Users\Sancho\AppData\Local\Temp\arduino_build_74329/MyBoardNRF5.ino.hex}} verify reset; shutdown;
                  debug_level: 2
                  0x4000
                  Une erreur est survenue lors du transfert du croquis
                  in procedure 'program'
                  in procedure 'init' called at file "embedded:startup.tcl", line 473
                  ** OpenOCD init failed **
                  shutdown command invoked
                  Can you help me please ?
                  monteM 1 Reply Last reply
                  • S Sancho119
                    debug_level: 2
                    0x4000
                    in procedure 'init'
                    debug_level: 2
                    0x4000
                    monteM
                    monteM
                    monte
                    wrote on last edited by monte
                    #31
                    @sancho119 what exact model of a board do you have? Did you try to switch SWDIO and SWCLK, maybe they are messed up? Or lose connection? To erase softdevice you can simply chose Tools>Softdevice>"None" and then press "Burn bootloader" button.
                      Sancho119
                      Hello
                      it's a E73 2G4M04S1B from EBYTE
                      When i switch SWDIO and SWCLK, i can see the led of STLink V2 changing from red to blue, but when i try to uplod empty sketch (MyBoardNRF5), i have this error :
                      C:\Users\Sancho\AppData\Local\Arduino15\packages\sandeepmistry\tools\openocd\0.10.0-dev.nrf5/bin/openocd.exe -d2 -f interface/stlink-v2.cfg -c transport select hla_swd; set WORKAREASIZE 0x4000; -f target/nrf52.cfg -c program {{C:\Users\Sancho\AppData\Local\Temp\arduino_build_432557/MyBoardNRF5.ino.hex}} verify reset; shutdown;
                      debug_level: 2
                      0x4000
                      Info : Target voltage: 3.283200
                      in procedure 'reset' called at file "embedded:startup.tcl", line 478
                      embedded:startup.tcl:454: Error: ** Unable to reset target **
                      in procedure 'program_error' called at file "embedded:startup.tcl", line 479
                      le port série sélectionné at file "embedded:startup.tcl", line 454
                      n'existe pas ou votre Arduino n'est pas connectée
                      N 1 Reply Last reply
                      • S Sancho119
                        Hello
                        debug_level: 2
                        0x4000
                        N
                        N
                        ncollins
                        @sancho119 No matter what I tried, I could not unlock the E73 with the STLink.
                        I had to buy a jlink clone, download a bunch of segger debugging tools, use the segger tools to override the lock flag. After that I could flash the bootloader.
                        https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
                        #To share my experience with the nRF52832.
                        #I was unable to disable the read protection / flash lock with a BMP or ST-Link V2, but i was successful with a J-Link.
                        #When nRF52832 chip is read protected / locked, the first step is to try:
                        nrfjprog –recover -f nrf52
                        #This performs the same task as:
                        Jlink -if swd -device nrf52
                        J-Link>SWDSelect
                        J-Link>SWDWriteDP 1, 0x50000000
                        J-Link>SWDWriteDP 2, 0x01000000
                        J-Link>SWDWriteAP 1, 0x00000001
                        #Wait until AP 2 is 0, and the operation is complete
                        J-Link>SWDReadAP 2
                        #If two successive reads from AP 3 produce 0, then 1 then protection is disabled
                        J-Link>SWDReadAP 3
                        J-Link>SWDReadAP 3
                        #Tested with JLink v6.20b
                        • N ncollins
                          J-Link>SWDSelect
                          J-Link>SWDReadAP 2
                          J-Link>SWDReadAP 3
                          J-Link>SWDReadAP 3
                          monteM
                          monteM
                          monte
                          @ncollins have you tried this: https://github.com/AndruPol/nrf52832-recover ?
                          • N
                            N
                            ncollins
                            At the time, I did not have a BMP or any STM32 capable of being flashed as a programmer.
                            I figured the jlink clone might be useful in the future, but I definitely think the BMP / diy programmer is the way I would have gone if I had one sitting around.
                              Sancho119
                              @ncollins
                              @monte
                              thx for these advices.
                              I think i will try with BMP clone (STM32F103C8T6), cheaper than J-link (i must only wait 1 month to have it, buying it in china...)
                              is it possible to erase E73 with BMP in win10 ?
                              • berkseoB
                                berkseoB
                                berkseo
                                #37
                                https://translate.google.ru/translate?sl=auto&tl=en&u=http%3A%2F%2Fmysensors.ru%2Fforum%2Fviewtopic.php%3Ff%3D5%26t%3D456
                                https://www.nordicsemi.com/Software-and-Tools/Development-Tools/nRFgo-Studio/Download#infotabs
                                  Sancho119
                                  Some news !
                                  i buy a Jlink, and success in erase my nrf52832 with nrf prog, using method of berkseo.
                                  Next i try to upload a basic sketch (blink) :
                                  #define MY_RADIO_NRF5_ESB
                                  #include <nrf.h>
                                  Serial.begin(9600);
                                  hwPinMode(LED_BUILTIN,OUTPUT_H0H1);
                                  digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
                                  delay(1000); // wait for a second
                                  digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
                                  I have this :
                                  debug_level: 2
                                  Info : No device selected, using first device.
                                  Info : J-Link ARM-OB STM32 compiled Aug 22 2012 19:52:04
                                  Info : Hardware version: 7.00
                                  Info : VTarget = 3.300 V
                                  Info : clock speed 10000 kHz
                                  Info : SWD IDCODE 0x2ba01477
                                  Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
                                  xPSR: 0x01000000 pc: 0x0000051c msp: 0x20010000
                                  ** Programming Started **
                                  auto erase enabled
                                  Warn : Unknown device (HWID 0x00000139)
                                  Warn : not enough working area available(requested 32)
                                  Warn : no working area available, falling back to slow memory writes
                                  wrote 12288 bytes from file C:\Users\Sancho\AppData\Local\Temp\arduino_build_76789/NRF5_blink_led8.ino.hex in 4.155332s (2.888 KiB/s)
                                  ** Programming Finished **
                                  ** Verify Started **
                                  Warn : not enough working area available(requested 52)
                                  verified 10812 bytes in 0.165932s (63.632 KiB/s)
                                  ** Verified OK **
                                  ** Resetting Target **
                                  I think its good, but when i put a led with a resistance on P0.08, nothing :(
                                  could you help me more ?
                                  • S Sancho119
                                    Some news !
                                    #include <nrf.h>
                                    Serial.begin(9600);
                                    I have this :
                                    debug_level: 2
                                    auto erase enabled
                                    ** Verified OK **
                                    Toyman
                                    @sancho119 said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                                    Some news !
                                    #include <nrf.h>
                                    Serial.begin(9600);
                                    I have this :
                                    debug_level: 2
                                    auto erase enabled
                                    ** Verified OK **
                                    LED_BUILTIN corresponds to po17
                                    • P
                                      P
                                      p359
                                      Hi. Are the steps in first post still valid please?
                                      I'm trying without luck to get first nrf52 programmed. I get a weird error"Error resolving FQBN: missing" in Arduino IDE when I try to verify any basic sketch, even blink. Thanks for any thoughts
                                      • P p359
                                        N
                                        N
                                        ncollins
                                        @p359 Which version of Arduino IDE are you using? I was seeing that with 1.8.10, but I ended up downgrading to 1.8.6 to test and it worked.
                                        P 1 Reply Last reply
                                        • N ncollins
                                          P
                                          P
                                          p359
                                          @ncollins 1.8.10 also. I'll try then 1.8.6 tonight. Cheers for the idea!
