  3. Failed to make encryption work on a barebone ATMEGA328P
atmega328prfm69wsecurity
42 Posts 5 Posters 7.4k Views 5 Watching
  • K kimot
    @encrypt
    I am not sure, if we speak about the same AES key.
    I mean encryption key for RFM69 chip, because you select using encryption by this radio in your network.
    But I am on my mobile only, so it is dificult study source codes Now.
    AnticimexA
    AnticimexA
    Anticimex
    @kimot AES key is stored in eeprom for all radios. It is fetched and loaded to the radio in runtime. Not compiletime.
    • EncryptE Encrypt
      I've enabled MY_DEBUG_VERBOSE_SIGNING and MY_DEBUG_VERBOSE_RFM69, here is what I get:
       __  __       ____
              |___/                      2.3.1
      16 MCO:BGN:INIT NODE,CP=RPNNAS-X,REL=255,VER=2.3.1
      40 !SGN:PER:TAMPERED
      77 SGN:INI:BND OK
      79 TSM:INIT
      81 TSF:WUR:MS=0
      83 RFM69:INIT
      83 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
      90 RFM69:PTX:LEVEL=5 dBm
      92 TSM:INIT:TSP OK
      94 TSM:FPAR
      96 SGN:SGN:NREQ=255
      98 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
      102 RFM69:CSMA:RSSI=-108
      108 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2117 !TSM:FPAR:NO REPLY
      2119 TSM:FPAR
      2121 SGN:SGN:NREQ=255
      2123 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
      2127 RFM69:CSMA:RSSI=-108
      2136 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4145 !TSM:FPAR:NO REPLY
      4147 TSM:FPAR
      4149 SGN:SGN:NREQ=255
      4151 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
      4155 RFM69:CSMA:RSSI=-107
      4163 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      6172 !TSM:FPAR:NO REPLY
      6174 TSM:FPAR
      6176 SGN:SGN:NREQ=255
      6178 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
      6182 RFM69:CSMA:RSSI=-108
      6191 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      8200 !TSM:FPAR:FAIL
      8202 TSM:FAIL:CNT=1
      8204 TSM:FAIL:DIS
      8206 TSF:TDI:TSL
      8206 RFM69:RSL
      I'm wondering: maybe I should try to dump the EEPROM memory to be sure the keys were properly set?
      Also, regarding my question in the first post, do you know where messages are dropped if the AES key isn't correct? Is it at the radio or software level?
      AnticimexA
      AnticimexA
      Anticimex
      @encrypt
      The key here is "!SGN:PER:Tampered".
      The security backend checks a checksum of the eeprom data used for security. If it is not valid, it considers data tampered and will not use it. So your eeprom has been corrupted one way or another. Or you use either a really old personalizer or a really old library version.
      Edit: not old library. And old library would not care about checksum.
      • EncryptE
        EncryptE
        Encrypt
        Hello again,
        I don't know why I'm getting that "!SGN:PER:Tampered" message...
        I've run the SecurityPersonalizer sketch again and it reported that everything went as expected:
        |                           MySensors security personalizer                          |
        |                               Configuration settings                               |
        | * Guided personalization/storage of keys in EEPROM                                 |
        | * Software based personalization (no ATSHA204A usage whatsoever)                   |
        | * Will not require any UART confirmations                                          |
        | * Will store HMAC key to EEPROM                                                    |
        | * Will store AES key to EEPROM                                                     |
        | * Will generate soft serial using software                                         |
        | * Will store soft serial to EEPROM                                                 |
        |                           Hardware security peripherals                            |
        | Device       | Status       | Revision     | Serial number                | Locked |
        | AVR          | DETECTED     | N/A          | N/A (generation required)    | N/A    |
        |                                   Key generation                                   |
        | Key ID | Status | Key                                                              |
        | SERIAL | OK     | 2DFECBDAE05BB8414C                                               |
        |                                  Key copy section                                  |
        #define MY_SOFT_SERIAL 0x2D,0xFE,0xCB,0xDA,0xE0,0x5B,0xB8,0x41,0x4C
        |                                    Key storage                                     |
        | HMAC   | OK     | XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX |
        | AES    | OK     | XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX                                 |
        |                                       EEPROM                                       |
        |                      This nodes whitelist entry on other nodes                     |
        {.nodeId = <ID of this node>,.serial = {0x2D,0xFE,0xCB,0xDA,0xE0,0x5B,0xB8,0x41,0x4C}}
        |                                  WHAT TO DO NEXT?                                  |
        | This device has now been personalized. Run this sketch with its current settings   |
        | on all the devices in your network that have security enabled.                     |
        |                                  Execution result                                  |
        | SUCCESS        |
        Also, note I'm running the latest version of the SecurityPersonalizer sketch, which can be found here: https://github.com/mysensors/MySensors/blob/development/examples/SecurityPersonalizer/SecurityPersonalizer.ino
        I really don't know what can be wrong here...
        Could the 8MHz internal clock be the faulty part? Maybe it fails to correctly read the EEPROM data due to a misconfigured clock?
        Here is what avrdude shows in the debug view of the Arduino IDE ; using the Arduino Uno as a programmer:
        /opt/arduino-1.8.7/hardware/tools/avr/bin/avrdude -C/opt/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyACM0 -b19200 -Uflash:w:/tmp/arduino_build_879921/fil_pilote.ino.hex:i
        avrdude: Version 6.3-20171130
                 System wide configuration file is "/opt/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf"
                 User configuration file is "/home/encrypt/.avrduderc"
                 Using Port                    : /dev/ttyACM0
                 Programmer Type : Arduino
                 Description     : Arduino
                 Hardware Version: 2
                 Firmware Version: 1.18
                 Topcard         : Unknown
                 Vtarget         : 0.0 V
                 Varef           : 0.0 V
                 Oscillator      : Off
                 SCK period      : 0.1 us
        avrdude: erasing chip
        avrdude: reading input file "/tmp/arduino_build_879921/fil_pilote.ino.hex"
        avrdude: writing flash (21394 bytes):
        Writing | ################################################## | 100% 23.60s
        avrdude: 21394 bytes of flash written
        avrdude: verifying flash memory against /tmp/arduino_build_879921/fil_pilote.ino.hex:
        avrdude: load data flash data from input file /tmp/arduino_build_879921/fil_pilote.ino.hex:
        avrdude: input file /tmp/arduino_build_879921/fil_pilote.ino.hex contains 21394 bytes
        Reading | ################################################## | 100% 13.37s
        avrdude: verifying ...
        avrdude: 21394 bytes of flash verified
        avrdude done.  Thank you.
        Come have fun with me on IRC: #mysensors on Libera.chat :)
        AnticimexA 1 Reply Last reply
        • EncryptE Encrypt
          Hello again,
          |                                   Key generation                                   |
          |                                  Key copy section                                  |
          |                                    Key storage                                     |
          |                                       EEPROM                                       |
          |                                  WHAT TO DO NEXT?                                  |
          |                                  Execution result                                  |
          | SUCCESS        |
                   Hardware Version: 2
                   Topcard         : Unknown
                   Vtarget         : 0.0 V
                   Varef           : 0.0 V
                   Oscillator      : Off
                   SCK period      : 0.1 us
          AnticimexA
          AnticimexA
          Anticimex
          @encrypt normally when this happens, it is the main sketch that writes something to eeprom without taking into consideration what parts of the eeprom the MySensors library reserves for internal use.
          Could you try to run the personalizer to write the eeprom, then your main sketch, and after that the personalizer again, but this time, configured to not write any data, just print out what is already there?
          Sara should be identical but I strongly suspect it will not be (as the main sketch consider data "tampered").
          • EncryptE
            EncryptE
            Encrypt
            I've run the Arduino IDE in "debug" mode to be sure the F_CPU variable was taken into account and it seems it is indeed:
            /opt/arduino-1.8.7/arduino-builder -dump-prefs -logger=machine -hardware /opt/arduino-1.8.7/hardware -hardware /home/encrypt/Arduino/hardware -tools /opt/arduino-1.8.7/tools-builder -tools /opt/arduino-1.8.7/hardware/tools/avr -built-in-libraries /opt/arduino-1.8.7/libraries -libraries /home/encrypt/Arduino/libraries -fqbn=breadboard:avr:atmega328bb -vid-pid=0X2341_0X0043 -ide-version=10807 -build-path /tmp/arduino_build_879921 -warnings=none -build-cache /tmp/arduino_cache_286732 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/opt/arduino-1.8.7/hardware/tools/avr -verbose /home/encrypt/Documents/Projets/Domotique/Fil_pilote/fil_pilote/fil_pilote.ino
            /opt/arduino-1.8.7/arduino-builder -compile -logger=machine -hardware /opt/arduino-1.8.7/hardware -hardware /home/encrypt/Arduino/hardware -tools /opt/arduino-1.8.7/tools-builder -tools /opt/arduino-1.8.7/hardware/tools/avr -built-in-libraries /opt/arduino-1.8.7/libraries -libraries /home/encrypt/Arduino/libraries -fqbn=breadboard:avr:atmega328bb -vid-pid=0X2341_0X0043 -ide-version=10807 -build-path /tmp/arduino_build_879921 -warnings=none -build-cache /tmp/arduino_cache_286732 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/opt/arduino-1.8.7/hardware/tools/avr -verbose /home/encrypt/Documents/Projets/Domotique/Fil_pilote/fil_pilote/fil_pilote.ino
            Using board 'atmega328bb' from platform in folder: /home/encrypt/Arduino/hardware/breadboard/avr
            Using core 'arduino' from platform in folder: /opt/arduino-1.8.7/hardware/arduino/avr
            Detecting libraries used...
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /dev/null
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /dev/null
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors -I/opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /dev/null
            Using cached library dependencies for file: /home/encrypt/Arduino/libraries/MySensors/MyASM.S
            Using cached library dependencies for file: /opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src/SPI.cpp
            Generating function prototypes...
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors -I/opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /tmp/arduino_build_879921/preproc/ctags_target_for_gcc_minus_e.cpp
            /opt/arduino-1.8.7/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_879921/preproc/ctags_target_for_gcc_minus_e.cpp
            Compilation du croquis...
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors -I/opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp.o
            Compiling libraries...
            Compiling library "MySensors"
            Utilisation du fichier déjà compilé : /tmp/arduino_build_879921/libraries/MySensors/MyASM.S.o
            Compiling library "SPI"
            Utilisation du fichier déjà compilé : /tmp/arduino_build_879921/libraries/SPI/SPI.cpp.o
            Compiling core...
            Using precompiled core: /tmp/arduino_cache_286732/core/core_breadboard_avr_atmega328bb_8bcbb10bb0e7a5b614c24d1e9ac07d80.a
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_879921/fil_pilote.ino.elf /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp.o /tmp/arduino_build_879921/libraries/MySensors/MyASM.S.o /tmp/arduino_build_879921/libraries/SPI/SPI.cpp.o /tmp/arduino_build_879921/../arduino_cache_286732/core/core_breadboard_avr_atmega328bb_8bcbb10bb0e7a5b614c24d1e9ac07d80.a -L/tmp/arduino_build_879921 -lm
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_879921/fil_pilote.ino.elf /tmp/arduino_build_879921/fil_pilote.ino.eep
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_879921/fil_pilote.ino.elf /tmp/arduino_build_879921/fil_pilote.ino.hex
            Utilisation de la bibliothèque MySensors version 2.3.1 dans le dossier: /home/encrypt/Arduino/libraries/MySensors
            Utilisation de la bibliothèque SPI version 1.0 dans le dossier: /opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI
            /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_879921/fil_pilote.ino.elf
            Le croquis utilise 21394 octets (69%) de l'espace de stockage de programmes. Le maximum est de 30720 octets.
            Les variables globales utilisent 1022 octets de mémoire dynamique.
            Now, to answer your question @Anticimex, how do you run the SecurityPersonalizer sketch to only print the content of the EEPROM and not do any write? I've commented out all options but now it reports that no #define has been set :sweat_smile:
            • EncryptE Encrypt
              Compiling core...
              AnticimexA
              AnticimexA
              Anticimex
              @encrypt you should be able to run it without any local modifications to get it to print the data.
              • EncryptE
                EncryptE
                Encrypt
                Maybe I've missed something but any #define set will make the code write to the EEPROM.
                I ran the SecurityPersonalizer again, it reset the EEPROM to FF's.
                I enabled the PERSONALIZE_SOFT_RANDOM_SERIAL flag ran it again and finally re-uploaded my pilot wire code.
                I still have that "tempered" message in the logs, I really don't know what I can do...
                I may just end up disabling encryption I guess...
                • EncryptE Encrypt
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @encrypt that sounds very strange to me. The sketch is written to do nothing when left unchanged from git. Just output the current status.
                  • EncryptE
                    EncryptE
                    Encrypt
                    Here is what I get with the SecurityPersonalizer sketch directly from GitHub:
                    | You are running without any configuration flags set.                               |
                    | No changes will be made to ATSHA204A or EEPROM except for the EEPROM checksum      |
                    | which will be updated.                                                             |
                    | If you want to personalize your device, you have two options.                      |
                    | 1. a. Enable either GENERATE_KEYS_ATSHA204A or GENERATE_KEYS_SOFT                  |
                    |       This will generate keys for ATSHA204A or software signing.                   |
                    |    b. Execute the sketch. You will be guided through the steps below under         |
                    |       WHAT TO DO NEXT?                                                             |
                    |    c. Copy the generated keys and replace the topmost definitions in this file.    |
                    |    d. Save the sketch and then disable the flag you just enabled.                  |
                    |    e. Enable PERSONALIZE_ATSHA204A to personalize the ATSHA204A device.            |
                    |       or        |
                    |       Enable PERSONALIZE_SOFT to personalize the EEPROM for software signing.      |
                    |       If you want to use whitelisting you need to pick a unique serial number      |
                    |       for each device you run the sketch on and fill in MY_SOFT_SERIAL.            |
                    |       or        |
                    |       Enable PERSONALIZE_SOFT_RANDOM_SERIAL to personalzie the EEPROM and          |
                    |       include a new random serial number every time the sketch is executed.        |
                    |       Take note of each saved serial number if you plan to use whitelisting.       |
                    |    f. Execute the sketch on each device you want to personalize that is supposed   |
                    |       to communicate securely.                                                     |
                    | 2. Enable any configuration flag as you see fit.                                   |
                    |    It is assumed that you know what you are doing.                                 |
                    | ATSHA204A    | NOT DETECTED | N/A          | N/A                          | N/A    |
                    |                                  Execution result                                  |
                    | FAILURE (last ATSHA204A return code: 0xE7)                                         |
                    • EncryptE Encrypt
                      |       WHAT TO DO NEXT?                                                             |
                      |       or        |
                      |       or        |
                      |                                  Execution result                                  |
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @encrypt hm ok. Try to enable the MY_SIGNING_SOFT flag. I am on cell phone so I have a hard time reading the logic flow of the code.
                      • EncryptE
                        EncryptE
                        Encrypt
                        Hmmm... I'm starting to believe that the bootloader i used could be the problem.
                        Someone using an "alternative" bootloader got problems with signing a few years ago: https://forum.mysensors.org/topic/4991/mysbootloader-1-3pre2-testing/2
                        • EncryptE
                          EncryptE
                          Encrypt
                          According to that post, it seems there is a high correlation between the fuses value and the fact that security may or may not work.
                          Here is the boards.txt file I got from the official "Arduino on a breadboard with internal 8MHz clock" bootloader:
                          atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
                          atmega328bb.upload.protocol=arduino
                          atmega328bb.upload.maximum_size=30720
                          atmega328bb.upload.speed=57600
                          atmega328bb.bootloader.low_fuses=0xE2
                          atmega328bb.bootloader.high_fuses=0xDA
                          atmega328bb.bootloader.extended_fuses=0x05
                          atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                          atmega328bb.bootloader.unlock_bits=0x3F
                          atmega328bb.bootloader.lock_bits=0x0F
                          atmega328bb.build.board=AVR_ATMEGA328BB
                          atmega328bb.build.mcu=atmega328p
                          atmega328bb.build.f_cpu=8000000L
                          atmega328bb.build.core=arduino:arduino
                          atmega328bb.build.variant=arduino:standard
                          atmega328bb.bootloader.tool=arduino:avrdude
                          atmega328bb.upload.tool=arduino:avrdude
                          Do you have any clue @Anticimex / @mfalkvidd?
                          • EncryptE Encrypt
                            AnticimexA
                            AnticimexA
                            Anticimex
                            #29
                            @encrypt sorry no. There is no direct dependency between the security functionality and avr fuses. Atsha communications and some timeouts do expect the clocks to be working at expected rates though so the concept of time is valid. If the core clock is not matching what the preprocessor flags specify (F_CPU) then there could be problems.
                            Perhaps your device is not really running @8Mhz?
                            Perhaps you could test running a simple sketch that prints something at a specific pace and match that with a "real" clock. For example printing something every 10s specified by some delay or wait function and measure that that is reasonably accurate.
                            I would expect that if the MCU is not executing at the speed F_CPU specifies, a thing like delay(10s) would not really delay for 10s.
                            • EncryptE Encrypt
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @encrypt but I still do not get how the bootloader could cause you to get tampered eeprom data.
                              Unless the fuses also affect eeprom writes of course.
                              • EncryptE
                                EncryptE
                                Encrypt
                                @Anticimex: I have just found that there is an EESAVE fuse on the ATMEGA328P which prevents the EEPROM from being erased whenever a new sketch is pushed to the microcontroller.
                                It seems to be the root cause of the issue since I've found references in other posts of the MySensors forum to that problem.
                                I'll test that now and let you know.
                                • EncryptE Encrypt
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @encrypt ah, that would indeed explain a lot and especially the tampered indication.
                                  If true, I'll see if I can add that to the troubleshooting section to the documentation.
                                  I was not aware of this fuse.
                                  • EncryptE
                                    EncryptE
                                    Encrypt
                                    wrote on last edited by Encrypt
                                    #33
                                    IT WORKS @Anticimex !!! :the_horns:
                                    The issue was indeed the EESAVE fuse not set, which caused the EEPROM to be erased after each sketch upload.
                                    Here is my modified boards.txt file:
                                    atmega328bb.bootloader.high_fuses=0xD2
                                    So, basically, for people coming here in the future:
                                    Follow the tutorial https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard to flash the bootloader of your ATMEGA328P but replace the given boards.txt file (in the breadboard-1-6-x.zip archive) by the one above.
                                    A useful link to calculate the fuses values: http://www.engbedded.com/fusecalc/
                                    Thanks for your help @Anticimex, @mfalkvidd and @kimot :)
                                    • EncryptE Encrypt
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @encrypt great news! Thanks for joining the community and for your troubleshooting. This information will be compiled into the docs for future reference. Happy signing :spock-hand:
                                      tekkaT 1 Reply Last reply
                                      • AnticimexA Anticimex
                                        tekkaT
                                        tekkaT
                                        tekka
                                        wrote on last edited by tekka
                                        #35
                                        @anticimex @Encrypt That's a bit odd and certainly specific to the bootloader you're using (ATmegaBoot): AVRdude does (at least with optiboot) a page erase (vs. chip erase where EESAVE has an effect). I do not have the EESAVE fuse bit set and no issues with erased eeprom when loading a new sketch, also see below:
                                        Arduino Uno with optiboot:
                                        uno.bootloader.tool=avrdude
                                        uno.bootloader.low_fuses=0xFF
                                        uno.bootloader.high_fuses=0xDE
                                        uno.bootloader.extended_fuses=0xFD
                                        uno.bootloader.unlock_bits=0x3F
                                        uno.bootloader.lock_bits=0x0F
                                        uno.bootloader.file=optiboot/optiboot_atmega328.hex
                                        High fuse (0xDE) does not enable EESAVE.
                                        • EncryptE
                                          EncryptE
                                          Encrypt
                                          #36
                                          Hello @tekka and thank you for your remarks!
                                          Your input makes questions come to my mind:
                                          1. What is the difference between Optiboot and the bootloader given in the Arduino tutorial? I am quite new to the world of microcontrollers and I don't know much for the moment, I simply use what is working, eh eh :P
                                          2. The configuration you gave here doesn't use the internal 8MHz clock, therefore it doesn't fit my needs here, eh eh. Could I just use the "regular" Arduino Uno bootloader and set the proper fuses values in the boards.txt file to use the internal 8MHz clock?
                                          3. You are saying that it's actually optiboot which does the page erase and not avrdude? I believed there the "chip erase" instruction is the only instruction possible to erase the flash, handled by avrdude. And according to the ATMEGA328P datasheet (page 297), I have understood that any "chip erase" instruction will also erase the EEPROM if the EESAVE fuse isn't set. That operation seems to be mandatory too as they say: « A Chip Erase must be performed before the Flash and/or EEPROM are reprogrammed ». So, how does Optiboot / avrdude handle that in such a configuration?
                                          Finally, it seems there is no tutorial in the MySensors documentation explaining how to build a project using a standalone ATMEGA328P and which bootloader to choose (there are a few discussions though). It could be worth creating a tutorial / post about that and I could contribute to it of course :)
