  3. Failed to make encryption work on a barebone ATMEGA328P
atmega328prfm69wsecurity
42 Posts 5 Posters 7.4k Views 5 Watching
  • K kimot
    @encrypt
    I do not see encryption kye for RFM69 in your code...
    AnticimexA
    AnticimexA
    Anticimex
    @kimot all security secrets are stored in eeprom or in an atsha204a device. Never in the sketch unless you use the simple security option.
    Exception being the personalizer sketch for obvious reasons :)
    • EncryptE
      EncryptE
      Encrypt
      @kimot: I used the SecurityPersonalizer sketch with the keys defined in it.
      Here is the beginning of the sketch:
       * Copyright (C) 2013-2018 Sensnology AB
       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
       * @ingroup MySigninggrp
       * @file SecurityPersonalizer.ino
       * @brief Security personalization sketch
       *  - See git log (git log libraries/MySensors/examples/SecurityPersonalizer/SecurityPersonalizer.ino)
       * @example SecurityPersonalizer.ino
       * This sketch will personalize either none-volatile memory or ATSHA204A for security functions
       * available in the MySensors library.<br>
       * Details on personalization procedure is given in @ref personalization.<br>
       * This sketch will when executed without modifications also print a guided workflow on the UART.
      #include "sha204_library.h"
      /** @brief Make use of the MySensors framework without invoking the entire system */
      #define MY_CORE_ONLY
      /************************************ User defined key data ***************************************/
      /** @brief The user-defined HMAC key to use unless @ref GENERATE_HMAC_KEY is set */
      #define MY_HMAC_KEY 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05
      /** @brief The user-defined AES key to store in EEPROM unless @ref GENERATE_AES_KEY is set */
      #define MY_AES_KEY 0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x01,0x02,0x03,0x04,0x05,0x06,0x07
      /** @brief The user-defined soft serial to use for soft signing unless @ref GENERATE_SOFT_SERIAL is set */
      #define MY_SOFT_SERIAL 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
      /***************************** Flags for guided personalization flow ******************************/
       * @def GENERATE_KEYS_ATSHA204A
       * @brief Default settings for generating keys using ATSHA204A
       * @note The generated keys displayed in the serial log with this setting needs to be written down
       *       and transferred to all nodes this gateway will communicate with. This is mandatory for ALL
       *       nodes for encryption (AES key). For signing (HMAC key) it is only required for nodes that
       *       use signing. Typically you set the values for @ref MY_HMAC_KEY and @ref MY_AES_KEY.
      //#define GENERATE_KEYS_ATSHA204A
       * @def GENERATE_KEYS_SOFT
       * @brief Default settings for generating keys using software
       * @b Important<br>
       * You will need to ensure @ref MY_SIGNING_SOFT_RANDOMSEED_PIN is set to an unconnected analog pin
       * in order to provide entropy to the software RNG if your hardware has no HWRNG.
      //#define GENERATE_KEYS_SOFT
       * @def PERSONALIZE_ATSHA204A
       * @brief Default settings for personalizing an ATSHA204A
       * It is assumed that you have updated @ref MY_HMAC_KEY and @ref MY_AES_KEY with the keys displayed
       * when executing this sketch with @ref GENERATE_KEYS_ATSHA204A or @ref GENERATE_KEYS_SOFT defined.
      //#define PERSONALIZE_ATSHA204A
       * @def PERSONALIZE_SOFT
       * @brief Default settings for personalizing EEPROM for software signing
      #define PERSONALIZE_SOFT
       * @def PERSONALIZE_SOFT_RANDOM_SERIAL
       * @brief This is an alternative to @ref PERSONALIZE_SOFT which will also store a randomly generated
       * serial to EEPROM in addition to the actions performed by @ref PERSONALIZE_SOFT. Take note of the
       * generated soft serial as it will be needed if you plan to use whitelisting. It should be
       * unique for each node.
       * @note This is only needed for targets that lack unique device IDs. The sketch will inform you if
       *       there is a need for generating a random serial or not. Check the "Hardware security
       *       peripherals" listing. If a target has a unique device ID and a serial in EEPROM, the serial
       *       in EEPROM will be used. If erased (replaced with FF:es) the unique device ID will be used
       *       instead.
      //#define PERSONALIZE_SOFT_RANDOM_SERIAL
      /*************************** The settings below are for advanced users ****************************/
       * @def USE_SOFT_SIGNING
       * @brief Uncomment this to generate keys by software and store them to EEPROM instead of ATSHA204A
      //#define USE_SOFT_SIGNING
       * @def LOCK_ATSHA204A_CONFIGURATION
       * @brief Uncomment this to enable locking the ATSHA204A configuration zone
       * It is still possible to change the key, and this also enable random key generation.
       * @warning BE AWARE THAT THIS PREVENTS ANY FUTURE CONFIGURATION CHANGE TO THE CHIP
      //#define LOCK_ATSHA204A_CONFIGURATION
       * @def SKIP_UART_CONFIRMATION
       * @brief Uncomment this for boards that lack UART
       * This will disable additional confirmation for actions that are non-reversible.
       * @b Important<br> For ATSHA204A, no confirmation will be required for locking any zones with this
       * configuration! Also, if you generate keys on a board without UART, you have no way of determining
       * what the key is unless it is stored in EEPROM.
       * @def GENERATE_HMAC_KEY
       * @brief Uncomment this to generate a random HMAC key using ATSHA204A or software depending on
       *        @ref USE_SOFT_SIGNING
       * @note If not enabled, key defined by @ref MY_HMAC_KEY will be used instead.
      //#define GENERATE_HMAC_KEY
       * @def STORE_HMAC_KEY
       * @brief Uncomment this to store HMAC key to ATSHA204A or EEPROM depending on @ref USE_SOFT_SIGNING
      //#define STORE_HMAC_KEY
       * @def GENERATE_AES_KEY
       * @brief Uncomment this to generate a random AES key using ATSHA204A or software depending on
       * @note If not enabled, key defined by @ref MY_AES_KEY will be used instead.
      //#define GENERATE_AES_KEY
       * @def STORE_AES_KEY
       * @brief Uncomment this to store AES key to EEPROM
      //#define STORE_AES_KEY
       * @def GENERATE_SOFT_SERIAL
       * @brief Uncomment this to generate a random serial number for software signing
       * @note If not enabled, serial defined by @ref MY_SOFT_SERIAL will be used instead.
      #define GENERATE_SOFT_SERIAL
       * @def STORE_SOFT_SERIAL
       * @brief Uncomment this to store the serial number to EEPROM
      //#define STORE_SOFT_SERIAL
       * @def PRINT_DETAILED_ATSHA204A_CONFIG
       * @brief Uncomment to print the detailed ATSHA204A configuration
      //#define PRINT_DETAILED_ATSHA204A_CONFIG
       * @def RESET_EEPROM_PERSONALIZATION
       * @brief Uncomment to reset the personalization data in EEPROM to 0xFF:es
      //#define RESET_EEPROM_PERSONALIZATION
      /********************* Guided mode flag configurations (don't change these) ***********************/
      #ifdef GENERATE_KEYS_ATSHA204A
      #define LOCK_ATSHA204A_CONFIGURATION // We have to lock configuration to enable random number generation
      #define GENERATE_HMAC_KEY // Generate random HMAC key
      #define GENERATE_AES_KEY // Generate random AES key
      #define SKIP_UART_CONFIRMATION // This is an automated mode
      #ifdef GENERATE_KEYS_SOFT
      #define USE_SOFT_SIGNING // Use software backend
      #ifdef PERSONALIZE_ATSHA204A
      #define STORE_HMAC_KEY // Store the HMAC key
      #define STORE_AES_KEY // Store the AES key
      #ifdef PERSONALIZE_SOFT_RANDOM_SERIAL
      #define GENERATE_SOFT_SERIAL // Generate a soft serial number
      #define PERSONALIZE_SOFT // Do the rest as PERSONALIZE_SOFT
      #define STORE_SOFT_SERIAL // Store the soft serial number
      #if defined(GENERATE_HMAC_KEY) || defined(GENERATE_AES_KEY) || defined(GENERATE_SOFT_SERIAL)
      #define GENERATE_SOMETHING
      #if defined(MY_LOCK_MCU)
      #undefine MY_LOCK_MCU  // The Sketch after SecurityPersonaliter should lock the MCU
      /********************************** Preprocessor sanitychecks *************************************/
      Note that the values of MY_HMAC_KEY and MY_AES_KEY in the text above are not the ones I'm currently using.
      I re-checked that the AES and HMAC keys are indeed the same on the gateway and that's correct.
      I don't use the MY_SOFT_SERIAL key yet, so I let the sketch generate a random one.
      @Anticimex: I could indeed see in the file ~/Arduino/hardware/breadboard/avr/boards.txt that atmega328bb.build.f_cpu=8000000L is defined.
      Come have fun with me on IRC: #mysensors on Libera.chat :)
      AnticimexA K 2 Replies Last reply
      • EncryptE Encrypt
         * @b Important<br>
         *       instead.
        AnticimexA
        AnticimexA
        Anticimex
        @encrypt then I am fresh out of alternatives. Have you tried the verbose flag for signing just to see if it is signing/encryption that is causing the problems? Or try using signing / encryption one at a time.
        Signing can be set up on a per device/gw basis but encryption has to be configured for all devices (that need to communicate).
        • EncryptE
          EncryptE
          Encrypt
          I've enabled MY_DEBUG_VERBOSE_SIGNING and MY_DEBUG_VERBOSE_RFM69, here is what I get:
           __  __       ____
                  |___/                      2.3.1
          16 MCO:BGN:INIT NODE,CP=RPNNAS-X,REL=255,VER=2.3.1
          40 !SGN:PER:TAMPERED
          77 SGN:INI:BND OK
          79 TSM:INIT
          81 TSF:WUR:MS=0
          83 RFM69:INIT
          83 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
          90 RFM69:PTX:LEVEL=5 dBm
          92 TSM:INIT:TSP OK
          94 TSM:FPAR
          96 SGN:SGN:NREQ=255
          98 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
          102 RFM69:CSMA:RSSI=-108
          108 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          2117 !TSM:FPAR:NO REPLY
          2119 TSM:FPAR
          2121 SGN:SGN:NREQ=255
          2123 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
          2127 RFM69:CSMA:RSSI=-108
          2136 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          4145 !TSM:FPAR:NO REPLY
          4147 TSM:FPAR
          4149 SGN:SGN:NREQ=255
          4151 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
          4155 RFM69:CSMA:RSSI=-107
          4163 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          6172 !TSM:FPAR:NO REPLY
          6174 TSM:FPAR
          6176 SGN:SGN:NREQ=255
          6178 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
          6182 RFM69:CSMA:RSSI=-108
          6191 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          8200 !TSM:FPAR:FAIL
          8202 TSM:FAIL:CNT=1
          8204 TSM:FAIL:DIS
          8206 TSF:TDI:TSL
          8206 RFM69:RSL
          I'm wondering: maybe I should try to dump the EEPROM memory to be sure the keys were properly set?
          Also, regarding my question in the first post, do you know where messages are dropped if the AES key isn't correct? Is it at the radio or software level?
          AnticimexA 1 Reply Last reply
          • EncryptE Encrypt
             * @b Important<br>
             *       instead.
            K
            K
            kimot
            wrote on last edited by kimot
            @encrypt
            I am not sure, if we speak about the same AES key.
            I mean encryption key for RFM69 chip, because you select using encryption by this radio in your network.
            But I am on my mobile only, so it is dificult study source codes Now.
            • K kimot
              @encrypt
              AnticimexA
              AnticimexA
              Anticimex
              @kimot AES key is stored in eeprom for all radios. It is fetched and loaded to the radio in runtime. Not compiletime.
              • EncryptE Encrypt
                 __  __       ____
                        |___/                      2.3.1
                77 SGN:INI:BND OK
                79 TSM:INIT
                81 TSF:WUR:MS=0
                83 RFM69:INIT
                92 TSM:INIT:TSP OK
                94 TSM:FPAR
                96 SGN:SGN:NREQ=255
                2119 TSM:FPAR
                4147 TSM:FPAR
                6174 TSM:FPAR
                8200 !TSM:FPAR:FAIL
                8202 TSM:FAIL:CNT=1
                8204 TSM:FAIL:DIS
                8206 TSF:TDI:TSL
                8206 RFM69:RSL
                AnticimexA
                AnticimexA
                Anticimex
                @encrypt
                The key here is "!SGN:PER:Tampered".
                The security backend checks a checksum of the eeprom data used for security. If it is not valid, it considers data tampered and will not use it. So your eeprom has been corrupted one way or another. Or you use either a really old personalizer or a really old library version.
                Edit: not old library. And old library would not care about checksum.
                • EncryptE
                  EncryptE
                  Encrypt
                  Hello again,
                  I don't know why I'm getting that "!SGN:PER:Tampered" message...
                  I've run the SecurityPersonalizer sketch again and it reported that everything went as expected:
                  |                           MySensors security personalizer                          |
                  |                               Configuration settings                               |
                  | * Guided personalization/storage of keys in EEPROM                                 |
                  | * Software based personalization (no ATSHA204A usage whatsoever)                   |
                  | * Will not require any UART confirmations                                          |
                  | * Will store HMAC key to EEPROM                                                    |
                  | * Will store AES key to EEPROM                                                     |
                  | * Will generate soft serial using software                                         |
                  | * Will store soft serial to EEPROM                                                 |
                  |                           Hardware security peripherals                            |
                  | Device       | Status       | Revision     | Serial number                | Locked |
                  | AVR          | DETECTED     | N/A          | N/A (generation required)    | N/A    |
                  |                                   Key generation                                   |
                  | Key ID | Status | Key                                                              |
                  | SERIAL | OK     | 2DFECBDAE05BB8414C                                               |
                  |                                  Key copy section                                  |
                  #define MY_SOFT_SERIAL 0x2D,0xFE,0xCB,0xDA,0xE0,0x5B,0xB8,0x41,0x4C
                  |                                    Key storage                                     |
                  | HMAC   | OK     | XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX |
                  | AES    | OK     | XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX                                 |
                  |                                       EEPROM                                       |
                  |                      This nodes whitelist entry on other nodes                     |
                  {.nodeId = <ID of this node>,.serial = {0x2D,0xFE,0xCB,0xDA,0xE0,0x5B,0xB8,0x41,0x4C}}
                  |                                  WHAT TO DO NEXT?                                  |
                  | This device has now been personalized. Run this sketch with its current settings   |
                  | on all the devices in your network that have security enabled.                     |
                  |                                  Execution result                                  |
                  | SUCCESS        |
                  Also, note I'm running the latest version of the SecurityPersonalizer sketch, which can be found here: https://github.com/mysensors/MySensors/blob/development/examples/SecurityPersonalizer/SecurityPersonalizer.ino
                  I really don't know what can be wrong here...
                  Could the 8MHz internal clock be the faulty part? Maybe it fails to correctly read the EEPROM data due to a misconfigured clock?
                  Here is what avrdude shows in the debug view of the Arduino IDE ; using the Arduino Uno as a programmer:
                  /opt/arduino-1.8.7/hardware/tools/avr/bin/avrdude -C/opt/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyACM0 -b19200 -Uflash:w:/tmp/arduino_build_879921/fil_pilote.ino.hex:i
                  avrdude: Version 6.3-20171130
                           System wide configuration file is "/opt/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf"
                           User configuration file is "/home/encrypt/.avrduderc"
                           Using Port                    : /dev/ttyACM0
                           Programmer Type : Arduino
                           Description     : Arduino
                           Hardware Version: 2
                           Firmware Version: 1.18
                           Topcard         : Unknown
                           Vtarget         : 0.0 V
                           Varef           : 0.0 V
                           Oscillator      : Off
                           SCK period      : 0.1 us
                  avrdude: erasing chip
                  avrdude: reading input file "/tmp/arduino_build_879921/fil_pilote.ino.hex"
                  avrdude: writing flash (21394 bytes):
                  Writing | ################################################## | 100% 23.60s
                  avrdude: 21394 bytes of flash written
                  avrdude: verifying flash memory against /tmp/arduino_build_879921/fil_pilote.ino.hex:
                  avrdude: load data flash data from input file /tmp/arduino_build_879921/fil_pilote.ino.hex:
                  avrdude: input file /tmp/arduino_build_879921/fil_pilote.ino.hex contains 21394 bytes
                  Reading | ################################################## | 100% 13.37s
                  avrdude: verifying ...
                  avrdude: 21394 bytes of flash verified
                  avrdude done.  Thank you.
                  • EncryptE Encrypt
                    Hello again,
                    |                                   Key generation                                   |
                    |                                  Key copy section                                  |
                    |                                    Key storage                                     |
                    |                                       EEPROM                                       |
                    |                                  WHAT TO DO NEXT?                                  |
                    |                                  Execution result                                  |
                    | SUCCESS        |
                             Hardware Version: 2
                             Topcard         : Unknown
                             Vtarget         : 0.0 V
                             Varef           : 0.0 V
                             Oscillator      : Off
                             SCK period      : 0.1 us
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @encrypt normally when this happens, it is the main sketch that writes something to eeprom without taking into consideration what parts of the eeprom the MySensors library reserves for internal use.
                    Could you try to run the personalizer to write the eeprom, then your main sketch, and after that the personalizer again, but this time, configured to not write any data, just print out what is already there?
                    Sara should be identical but I strongly suspect it will not be (as the main sketch consider data "tampered").
                    • EncryptE
                      EncryptE
                      Encrypt
                      I've run the Arduino IDE in "debug" mode to be sure the F_CPU variable was taken into account and it seems it is indeed:
                      /opt/arduino-1.8.7/arduino-builder -dump-prefs -logger=machine -hardware /opt/arduino-1.8.7/hardware -hardware /home/encrypt/Arduino/hardware -tools /opt/arduino-1.8.7/tools-builder -tools /opt/arduino-1.8.7/hardware/tools/avr -built-in-libraries /opt/arduino-1.8.7/libraries -libraries /home/encrypt/Arduino/libraries -fqbn=breadboard:avr:atmega328bb -vid-pid=0X2341_0X0043 -ide-version=10807 -build-path /tmp/arduino_build_879921 -warnings=none -build-cache /tmp/arduino_cache_286732 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/opt/arduino-1.8.7/hardware/tools/avr -verbose /home/encrypt/Documents/Projets/Domotique/Fil_pilote/fil_pilote/fil_pilote.ino
                      /opt/arduino-1.8.7/arduino-builder -compile -logger=machine -hardware /opt/arduino-1.8.7/hardware -hardware /home/encrypt/Arduino/hardware -tools /opt/arduino-1.8.7/tools-builder -tools /opt/arduino-1.8.7/hardware/tools/avr -built-in-libraries /opt/arduino-1.8.7/libraries -libraries /home/encrypt/Arduino/libraries -fqbn=breadboard:avr:atmega328bb -vid-pid=0X2341_0X0043 -ide-version=10807 -build-path /tmp/arduino_build_879921 -warnings=none -build-cache /tmp/arduino_cache_286732 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/opt/arduino-1.8.7/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/opt/arduino-1.8.7/hardware/tools/avr -verbose /home/encrypt/Documents/Projets/Domotique/Fil_pilote/fil_pilote/fil_pilote.ino
                      Using board 'atmega328bb' from platform in folder: /home/encrypt/Arduino/hardware/breadboard/avr
                      Using core 'arduino' from platform in folder: /opt/arduino-1.8.7/hardware/arduino/avr
                      Detecting libraries used...
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /dev/null
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /dev/null
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors -I/opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /dev/null
                      Using cached library dependencies for file: /home/encrypt/Arduino/libraries/MySensors/MyASM.S
                      Using cached library dependencies for file: /opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src/SPI.cpp
                      Generating function prototypes...
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors -I/opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /tmp/arduino_build_879921/preproc/ctags_target_for_gcc_minus_e.cpp
                      /opt/arduino-1.8.7/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_879921/preproc/ctags_target_for_gcc_minus_e.cpp
                      Compilation du croquis...
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10807 -DARDUINO_AVR_ATMEGA328BB -DARDUINO_ARCH_AVR -I/opt/arduino-1.8.7/hardware/arduino/avr/cores/arduino -I/opt/arduino-1.8.7/hardware/arduino/avr/variants/standard -I/home/encrypt/Arduino/libraries/MySensors -I/opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp -o /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp.o
                      Compiling libraries...
                      Compiling library "MySensors"
                      Utilisation du fichier déjà compilé : /tmp/arduino_build_879921/libraries/MySensors/MyASM.S.o
                      Compiling library "SPI"
                      Utilisation du fichier déjà compilé : /tmp/arduino_build_879921/libraries/SPI/SPI.cpp.o
                      Compiling core...
                      Using precompiled core: /tmp/arduino_cache_286732/core/core_breadboard_avr_atmega328bb_8bcbb10bb0e7a5b614c24d1e9ac07d80.a
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_879921/fil_pilote.ino.elf /tmp/arduino_build_879921/sketch/fil_pilote.ino.cpp.o /tmp/arduino_build_879921/libraries/MySensors/MyASM.S.o /tmp/arduino_build_879921/libraries/SPI/SPI.cpp.o /tmp/arduino_build_879921/../arduino_cache_286732/core/core_breadboard_avr_atmega328bb_8bcbb10bb0e7a5b614c24d1e9ac07d80.a -L/tmp/arduino_build_879921 -lm
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_879921/fil_pilote.ino.elf /tmp/arduino_build_879921/fil_pilote.ino.eep
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_879921/fil_pilote.ino.elf /tmp/arduino_build_879921/fil_pilote.ino.hex
                      Utilisation de la bibliothèque MySensors version 2.3.1 dans le dossier: /home/encrypt/Arduino/libraries/MySensors
                      Utilisation de la bibliothèque SPI version 1.0 dans le dossier: /opt/arduino-1.8.7/hardware/arduino/avr/libraries/SPI
                      /opt/arduino-1.8.7/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_879921/fil_pilote.ino.elf
                      Le croquis utilise 21394 octets (69%) de l'espace de stockage de programmes. Le maximum est de 30720 octets.
                      Les variables globales utilisent 1022 octets de mémoire dynamique.
                      Now, to answer your question @Anticimex, how do you run the SecurityPersonalizer sketch to only print the content of the EEPROM and not do any write? I've commented out all options but now it reports that no #define has been set :sweat_smile:
                      • EncryptE Encrypt
                        Compiling core...
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @encrypt you should be able to run it without any local modifications to get it to print the data.
                        • EncryptE
                          EncryptE
                          Encrypt
                          Maybe I've missed something but any #define set will make the code write to the EEPROM.
                          I ran the SecurityPersonalizer again, it reset the EEPROM to FF's.
                          I enabled the PERSONALIZE_SOFT_RANDOM_SERIAL flag ran it again and finally re-uploaded my pilot wire code.
                          I still have that "tempered" message in the logs, I really don't know what I can do...
                          I may just end up disabling encryption I guess...
                          • EncryptE Encrypt
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @encrypt that sounds very strange to me. The sketch is written to do nothing when left unchanged from git. Just output the current status.
                            • EncryptE
                              EncryptE
                              Encrypt
                              Here is what I get with the SecurityPersonalizer sketch directly from GitHub:
                              | You are running without any configuration flags set.                               |
                              | No changes will be made to ATSHA204A or EEPROM except for the EEPROM checksum      |
                              | which will be updated.                                                             |
                              | If you want to personalize your device, you have two options.                      |
                              | 1. a. Enable either GENERATE_KEYS_ATSHA204A or GENERATE_KEYS_SOFT                  |
                              |       This will generate keys for ATSHA204A or software signing.                   |
                              |    b. Execute the sketch. You will be guided through the steps below under         |
                              |       WHAT TO DO NEXT?                                                             |
                              |    c. Copy the generated keys and replace the topmost definitions in this file.    |
                              |    d. Save the sketch and then disable the flag you just enabled.                  |
                              |    e. Enable PERSONALIZE_ATSHA204A to personalize the ATSHA204A device.            |
                              |       or        |
                              |       Enable PERSONALIZE_SOFT to personalize the EEPROM for software signing.      |
                              |       If you want to use whitelisting you need to pick a unique serial number      |
                              |       for each device you run the sketch on and fill in MY_SOFT_SERIAL.            |
                              |       or        |
                              |       Enable PERSONALIZE_SOFT_RANDOM_SERIAL to personalzie the EEPROM and          |
                              |       include a new random serial number every time the sketch is executed.        |
                              |       Take note of each saved serial number if you plan to use whitelisting.       |
                              |    f. Execute the sketch on each device you want to personalize that is supposed   |
                              |       to communicate securely.                                                     |
                              | 2. Enable any configuration flag as you see fit.                                   |
                              |    It is assumed that you know what you are doing.                                 |
                              | ATSHA204A    | NOT DETECTED | N/A          | N/A                          | N/A    |
                              |                                  Execution result                                  |
                              | FAILURE (last ATSHA204A return code: 0xE7)                                         |
                              • EncryptE Encrypt
                                |       WHAT TO DO NEXT?                                                             |
                                |       or        |
                                |       or        |
                                |                                  Execution result                                  |
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @encrypt hm ok. Try to enable the MY_SIGNING_SOFT flag. I am on cell phone so I have a hard time reading the logic flow of the code.
                                • EncryptE
                                  EncryptE
                                  Encrypt
                                  Hmmm... I'm starting to believe that the bootloader i used could be the problem.
                                  Someone using an "alternative" bootloader got problems with signing a few years ago: https://forum.mysensors.org/topic/4991/mysbootloader-1-3pre2-testing/2
                                  • EncryptE
                                    EncryptE
                                    Encrypt
                                    According to that post, it seems there is a high correlation between the fuses value and the fact that security may or may not work.
                                    Here is the boards.txt file I got from the official "Arduino on a breadboard with internal 8MHz clock" bootloader:
                                    atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
                                    atmega328bb.upload.protocol=arduino
                                    atmega328bb.upload.maximum_size=30720
                                    atmega328bb.upload.speed=57600
                                    atmega328bb.bootloader.low_fuses=0xE2
                                    atmega328bb.bootloader.high_fuses=0xDA
                                    atmega328bb.bootloader.extended_fuses=0x05
                                    atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                                    atmega328bb.bootloader.unlock_bits=0x3F
                                    atmega328bb.bootloader.lock_bits=0x0F
                                    atmega328bb.build.board=AVR_ATMEGA328BB
                                    atmega328bb.build.mcu=atmega328p
                                    atmega328bb.build.core=arduino:arduino
                                    atmega328bb.build.variant=arduino:standard
                                    atmega328bb.bootloader.tool=arduino:avrdude
                                    atmega328bb.upload.tool=arduino:avrdude
                                    Do you have any clue @Anticimex / @mfalkvidd?
                                    • EncryptE Encrypt
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      #29
                                      @encrypt sorry no. There is no direct dependency between the security functionality and avr fuses. Atsha communications and some timeouts do expect the clocks to be working at expected rates though so the concept of time is valid. If the core clock is not matching what the preprocessor flags specify (F_CPU) then there could be problems.
                                      Perhaps your device is not really running @8Mhz?
                                      Perhaps you could test running a simple sketch that prints something at a specific pace and match that with a "real" clock. For example printing something every 10s specified by some delay or wait function and measure that that is reasonably accurate.
                                      I would expect that if the MCU is not executing at the speed F_CPU specifies, a thing like delay(10s) would not really delay for 10s.
                                      • EncryptE Encrypt
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @encrypt but I still do not get how the bootloader could cause you to get tampered eeprom data.
                                        Unless the fuses also affect eeprom writes of course.
                                        • EncryptE
                                          EncryptE
                                          Encrypt
                                          @Anticimex: I have just found that there is an EESAVE fuse on the ATMEGA328P which prevents the EEPROM from being erased whenever a new sketch is pushed to the microcontroller.
                                          It seems to be the root cause of the issue since I've found references in other posts of the MySensors forum to that problem.
                                          I'll test that now and let you know.
