  3. Failed to make encryption work on a barebone ATMEGA328P
atmega328prfm69wsecurity
42 Posts 5 Posters 7.4k Views 5 Watching
  • EncryptE
    EncryptE
    Encrypt
    Maybe I've missed something but any #define set will make the code write to the EEPROM.
    I ran the SecurityPersonalizer again, it reset the EEPROM to FF's.
    I enabled the PERSONALIZE_SOFT_RANDOM_SERIAL flag ran it again and finally re-uploaded my pilot wire code.
    I still have that "tempered" message in the logs, I really don't know what I can do...
    I may just end up disabling encryption I guess...
    Come have fun with me on IRC: #mysensors on Libera.chat :)
    AnticimexA 1 Reply Last reply
    • EncryptE Encrypt
      AnticimexA
      AnticimexA
      Anticimex
      @encrypt that sounds very strange to me. The sketch is written to do nothing when left unchanged from git. Just output the current status.
      • EncryptE
        EncryptE
        Encrypt
        Here is what I get with the SecurityPersonalizer sketch directly from GitHub:
        |                           MySensors security personalizer                          |
        | You are running without any configuration flags set.                               |
        | No changes will be made to ATSHA204A or EEPROM except for the EEPROM checksum      |
        | which will be updated.                                                             |
        | If you want to personalize your device, you have two options.                      |
        | 1. a. Enable either GENERATE_KEYS_ATSHA204A or GENERATE_KEYS_SOFT                  |
        |       This will generate keys for ATSHA204A or software signing.                   |
        |    b. Execute the sketch. You will be guided through the steps below under         |
        |       WHAT TO DO NEXT?                                                             |
        |    c. Copy the generated keys and replace the topmost definitions in this file.    |
        |    d. Save the sketch and then disable the flag you just enabled.                  |
        |    e. Enable PERSONALIZE_ATSHA204A to personalize the ATSHA204A device.            |
        |       or        |
        |       Enable PERSONALIZE_SOFT to personalize the EEPROM for software signing.      |
        |       If you want to use whitelisting you need to pick a unique serial number      |
        |       for each device you run the sketch on and fill in MY_SOFT_SERIAL.            |
        |       or        |
        |       Enable PERSONALIZE_SOFT_RANDOM_SERIAL to personalzie the EEPROM and          |
        |       include a new random serial number every time the sketch is executed.        |
        |       Take note of each saved serial number if you plan to use whitelisting.       |
        |    f. Execute the sketch on each device you want to personalize that is supposed   |
        |       to communicate securely.                                                     |
        | 2. Enable any configuration flag as you see fit.                                   |
        |    It is assumed that you know what you are doing.                                 |
        |                           Hardware security peripherals                            |
        | Device       | Status       | Revision     | Serial number                | Locked |
        | AVR          | DETECTED     | N/A          | N/A (generation required)    | N/A    |
        | ATSHA204A    | NOT DETECTED | N/A          | N/A                          | N/A    |
        |                                  Execution result                                  |
        | FAILURE (last ATSHA204A return code: 0xE7)                                         |
        • EncryptE Encrypt
          |       WHAT TO DO NEXT?                                                             |
          |       or        |
          |       or        |
          |                                  Execution result                                  |
          AnticimexA
          AnticimexA
          Anticimex
          @encrypt hm ok. Try to enable the MY_SIGNING_SOFT flag. I am on cell phone so I have a hard time reading the logic flow of the code.
          • EncryptE
            EncryptE
            Encrypt
            Hmmm... I'm starting to believe that the bootloader i used could be the problem.
            Someone using an "alternative" bootloader got problems with signing a few years ago: https://forum.mysensors.org/topic/4991/mysbootloader-1-3pre2-testing/2
            • EncryptE
              EncryptE
              Encrypt
              According to that post, it seems there is a high correlation between the fuses value and the fact that security may or may not work.
              Here is the boards.txt file I got from the official "Arduino on a breadboard with internal 8MHz clock" bootloader:
              atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
              atmega328bb.upload.protocol=arduino
              atmega328bb.upload.maximum_size=30720
              atmega328bb.upload.speed=57600
              atmega328bb.bootloader.low_fuses=0xE2
              atmega328bb.bootloader.high_fuses=0xDA
              atmega328bb.bootloader.extended_fuses=0x05
              atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
              atmega328bb.bootloader.unlock_bits=0x3F
              atmega328bb.bootloader.lock_bits=0x0F
              atmega328bb.build.board=AVR_ATMEGA328BB
              atmega328bb.build.mcu=atmega328p
              atmega328bb.build.f_cpu=8000000L
              atmega328bb.build.core=arduino:arduino
              atmega328bb.build.variant=arduino:standard
              atmega328bb.bootloader.tool=arduino:avrdude
              atmega328bb.upload.tool=arduino:avrdude
              Do you have any clue @Anticimex / @mfalkvidd?
              • EncryptE Encrypt
                AnticimexA
                AnticimexA
                Anticimex
                #29
                @encrypt sorry no. There is no direct dependency between the security functionality and avr fuses. Atsha communications and some timeouts do expect the clocks to be working at expected rates though so the concept of time is valid. If the core clock is not matching what the preprocessor flags specify (F_CPU) then there could be problems.
                Perhaps your device is not really running @8Mhz?
                Perhaps you could test running a simple sketch that prints something at a specific pace and match that with a "real" clock. For example printing something every 10s specified by some delay or wait function and measure that that is reasonably accurate.
                I would expect that if the MCU is not executing at the speed F_CPU specifies, a thing like delay(10s) would not really delay for 10s.
                • EncryptE Encrypt
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @encrypt but I still do not get how the bootloader could cause you to get tampered eeprom data.
                  Unless the fuses also affect eeprom writes of course.
                  • EncryptE
                    EncryptE
                    Encrypt
                    @Anticimex: I have just found that there is an EESAVE fuse on the ATMEGA328P which prevents the EEPROM from being erased whenever a new sketch is pushed to the microcontroller.
                    It seems to be the root cause of the issue since I've found references in other posts of the MySensors forum to that problem.
                    I'll test that now and let you know.
                    • EncryptE Encrypt
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @encrypt ah, that would indeed explain a lot and especially the tampered indication.
                      If true, I'll see if I can add that to the troubleshooting section to the documentation.
                      I was not aware of this fuse.
                      • EncryptE
                        EncryptE
                        Encrypt
                        wrote on last edited by Encrypt
                        #33
                        IT WORKS @Anticimex !!! :the_horns:
                        The issue was indeed the EESAVE fuse not set, which caused the EEPROM to be erased after each sketch upload.
                        Here is my modified boards.txt file:
                        atmega328bb.bootloader.high_fuses=0xD2
                        So, basically, for people coming here in the future:
                        Follow the tutorial https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard to flash the bootloader of your ATMEGA328P but replace the given boards.txt file (in the breadboard-1-6-x.zip archive) by the one above.
                        A useful link to calculate the fuses values: http://www.engbedded.com/fusecalc/
                        Thanks for your help @Anticimex, @mfalkvidd and @kimot :)
                        • EncryptE Encrypt
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @encrypt great news! Thanks for joining the community and for your troubleshooting. This information will be compiled into the docs for future reference. Happy signing :spock-hand:
                          tekkaT 1 Reply Last reply
                          • AnticimexA Anticimex
                            tekkaT
                            tekkaT
                            tekka
                            wrote on last edited by tekka
                            #35
                            @anticimex @Encrypt That's a bit odd and certainly specific to the bootloader you're using (ATmegaBoot): AVRdude does (at least with optiboot) a page erase (vs. chip erase where EESAVE has an effect). I do not have the EESAVE fuse bit set and no issues with erased eeprom when loading a new sketch, also see below:
                            Arduino Uno with optiboot:
                            uno.bootloader.tool=avrdude
                            uno.bootloader.low_fuses=0xFF
                            uno.bootloader.high_fuses=0xDE
                            uno.bootloader.extended_fuses=0xFD
                            uno.bootloader.unlock_bits=0x3F
                            uno.bootloader.lock_bits=0x0F
                            uno.bootloader.file=optiboot/optiboot_atmega328.hex
                            High fuse (0xDE) does not enable EESAVE.
                            • EncryptE
                              EncryptE
                              Encrypt
                              #36
                              Hello @tekka and thank you for your remarks!
                              Your input makes questions come to my mind:
                              1. What is the difference between Optiboot and the bootloader given in the Arduino tutorial? I am quite new to the world of microcontrollers and I don't know much for the moment, I simply use what is working, eh eh :P
                              2. The configuration you gave here doesn't use the internal 8MHz clock, therefore it doesn't fit my needs here, eh eh. Could I just use the "regular" Arduino Uno bootloader and set the proper fuses values in the boards.txt file to use the internal 8MHz clock?
                              3. You are saying that it's actually optiboot which does the page erase and not avrdude? I believed there the "chip erase" instruction is the only instruction possible to erase the flash, handled by avrdude. And according to the ATMEGA328P datasheet (page 297), I have understood that any "chip erase" instruction will also erase the EEPROM if the EESAVE fuse isn't set. That operation seems to be mandatory too as they say: « A Chip Erase must be performed before the Flash and/or EEPROM are reprogrammed ». So, how does Optiboot / avrdude handle that in such a configuration?
                              Finally, it seems there is no tutorial in the MySensors documentation explaining how to build a project using a standalone ATMEGA328P and which bootloader to choose (there are a few discussions though). It could be worth creating a tutorial / post about that and I could contribute to it of course :)
                              • EncryptE Encrypt
                                tekkaT
                                tekkaT
                                tekka
                                #37
                                @encrypt I may have an idea what's going on here: Are you programming a new sketch to your barebone AT328p via ArduinoISP or any other means of serial (=SPI) programming? Programming via bootloader (ATmegaboot or optiboot) requires a FTDI adapter and will only do page erases while leaving the eeprom untouched.
                                • EncryptE
                                  EncryptE
                                  Encrypt
                                  #38
                                  Hi @tekka!
                                  I'm indeed programming the ATMEGA328P using an Arduino Uno transformed as ISP with the ArduinoISP sketch.
                                  I've wired the circuit exactly as shown on the first picture of the tutorial here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard. I used the same circuit to burn the bootloader and to upload my sketches.
                                  Your remark makes me wonder: do I really need a bootloader at the end?
                                  • EncryptE Encrypt
                                    Hi @tekka!
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @encrypt Ok, this explains your issue: programming via ISP will do a chip erase and hence the EESAVE fuse setting is critical for e2p persistance. The most common use case is programming via serial bootloader (e.g. optiboot, atmegaboot, etc.) which only does page erases and leaves the rest untouched. To answer your question: If you're using an ISP programmer you do not need a bootloader.
                                    • mfalkviddM
                                      #40
                                      I thought the bootloader is overwritten when using ISP? So "you don't need a bootlader" is slightly incorrect, you can not have a bootloader when using isp?
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #41
                                        @mfalkvidd The Arduino builder generates two .hex files, one of which contains the bootloader as specified in boards.txt. Depending on the flashing settings you may burn the sketch only or the sketch + bootloader, however, the bootloader is not needed for ISP programming.
                                        • tekkaT tekka
                                          @tekka I see. Thanks for explaining.
